@c63e8bb
04/19/19 09:02:02 |
Sebastian Huber |
score: Modify _Per_CPU_Perform_jobs()
Process only the jobs initially …
5
@85d6e845
04/19/19 09:01:31 |
Sebastian Huber |
score: Add _Per_CPU_Add_job()
5
@8fa14da0
04/18/19 06:38:00 |
Sebastian Huber |
score: Move per-processor job data structures
This enables re-use for …
5
@3b2481f
04/18/19 05:08:32 |
Sebastian Huber |
score: Simplify _SMP_Multicast_action()
Move resposibility to disable …
5
@7fdf48a
04/28/19 12:29:21 |
Sebastian Huber |
score: Add _SMP_Othercast_action()
5
@65870044
04/18/19 04:47:01 |
Sebastian Huber |
score: Add _SMP_Broadcast_action()
5
@4f06863
04/18/19 04:31:33 |
Sebastian Huber |
score: Use dedicated lock for per-CPU jobs
5
@327ae9ac
04/18/19 04:29:57 |
Sebastian Huber |
score: Fix per-CPU job done handling
5
@ef9d20f6
04/12/19 09:13:32 |
Sebastian Huber |
score: More robust _SMP_Multicast_action()
If the caller already …
5
@ad40d05e
04/12/19 05:55:31 |
Sebastian Huber |
score: Remove _SMP_Before_multitasking_action()
Use …
5
@f410b31b
04/11/19 13:39:36 |
Sebastian Huber |
score: Improve _SMP_Multicast_action()
Let it work during system …
5
@e90486a
04/11/19 13:16:40 |
Sebastian Huber |
score: Rework SMP multicast action
Use a FIFO list of jobs per …
5
@df8d7bd7
04/09/19 08:58:35 |
Sebastian Huber |
score: Use processor mask in _SMP_Multicast_action
Processor_mask is …
5
@e97b7c9a
04/11/19 11:47:50 |
Sebastian Huber |
score: Use an ISR lock for Per_CPU_Control::Lock
The use of a hand …
5
@18d45d9
04/11/19 10:10:53 |
Sebastian Huber |
score: Add _ISR_lock_Set_name()
Add _ISR_lock_Set_name() to optimize …
5
@ad87de4
04/11/19 06:54:29 |
Sebastian Huber |
score: Rename _SMP_Get_processor_count()
Rename …
5
@cfcd6dc9
04/11/19 06:52:36 |
Sebastian Huber |
score: Rename _SMP_Processor_count
Rename _SMP_Processor_count in …
5
@e0dcf294
04/05/19 07:58:07 |
Sebastian Huber |
Remove superfluous run-time check
The _Objects_Information_table[ …
5
@4c20da4b
04/04/19 07:18:11 |
Sebastian Huber |
doxygen: Rename Score* groups in RTEMSScore*
Update #3706
5
@5526527e
03/25/19 09:45:25 |
Sebastian Huber |
score: Rename ScoreCPU Doxygen group
Update #3706.
5
@3fe2155
02/01/19 09:00:36 |
Sebastian Huber |
Remove superfluous <rtems/system.h> includes
5
@c10e8b6
03/08/19 22:38:46 |
joel |
coremsgseize.c: Fix spelling error
5
@03b2163
03/01/19 09:10:19 |
Sebastian Huber |
score: Fix _Scheduler_EDF_Cancel_job()
Remove the priority node only …
5
@feea03b6
02/27/19 09:53:30 |
Sebastian Huber |
Remove explicit file names from @file
This makes the @file …
5
@e4ad14cc
02/12/19 11:19:38 |
Sebastian Huber |
score: Avoid some deadlocks in _Once()
Recursive usage of the same …
5
@fbd08066
02/07/19 06:46:38 |
Sebastian Huber |
score: Fix plain priority thread queues (SMP)
We must add/remove the …
5
@b5bdecf
01/18/19 11:54:05 |
Sebastian Huber |
score: Avoid internal API and use ISR lock
5
@3bd39999
01/08/19 08:53:26 |
Sebastian Huber |
Adjust interrupt mode tests for some CPU ports
In case the robust …
5
@38cb59e
01/08/19 07:36:31 |
Sebastian Huber |
Separate task mode checks
Update #3000.
5
@956d76cc
01/07/19 08:30:43 |
Sebastian Huber |
score: Remove superfluous include from chainimpl.h
5
@7c19e50
12/18/18 07:45:06 |
Sebastian Huber |
score: Fix per-CPU data allocation
Allocate the per-CPU data for …
5
@21275b58
11/22/18 18:14:51 |
Sebastian Huber |
score: Static Objects_Information initialization
Statically allocate …
5
@8b0e752f
12/10/18 12:44:53 |
Sebastian Huber |
score: Remove Objects_Information::auto_extend
Use …
5
@f70079c
11/25/18 19:26:02 |
Sebastian Huber |
score: Remove Objects_Information::the_api
Remove …
5
@1c2d178
11/25/18 19:15:26 |
Sebastian Huber |
score: Remove Objects_Information::maximum
This information is …
5
@3899bc1a
11/24/18 10:51:28 |
Sebastian Huber |
score: Optimize object lookup
Use the maximum ID for the ID to object …
5
@359a3a3
11/22/18 05:38:42 |
Sebastian Huber |
score: Rename Objects_Information::allocation_size
Rename …
5
@0da9d80
11/22/18 05:16:52 |
Sebastian Huber |
score: Rename Objects_Information::size
Rename …
5
@9c9c6a9
11/21/18 16:30:52 |
Sebastian Huber |
score: Remove Objects_Information::is_string
Use …
5
@d6e3473
11/23/18 19:37:57 |
Sebastian Huber |
score: Remove dead code
Update #3621.
5
@5fc727f
11/26/18 07:25:36 |
Sebastian Huber |
score: <rtems/score/smplockstats.h>
Remove <rtems/score/chainimpl.h> …
5
@52c7cb1
11/21/18 16:30:22 |
Sebastian Huber |
score: Simplify _Workspace_String_duplicate()
5
@28bf4ca
11/14/18 06:00:59 |
Sebastian Huber |
or1k: Support GCC 9
Close #3602.
5
@ccc6695
11/08/18 10:50:24 |
Sebastian Huber |
score: Introduce <rtems/score/watchdogticks.h>
Separate the …
5
@ff081aee
11/06/18 15:58:02 |
Sebastian Huber |
score: Rename interrupt stack symbols
Rename
5
@878487b0
11/05/18 08:53:04 |
Sebastian Huber |
score: Optimize Objects_Information
Reduce structure internal …
5
@54f35888
10/25/18 08:54:12 |
Sebastian Huber |
posix: Provide threads by default
Update #2514.
5
@e97806a
10/14/18 17:20:05 |
Sebastian Huber |
posix: Split posix_api_configuration_table
Use separate configuration …
5
@7038271
10/25/18 10:05:53 |
Sebastian Huber |
Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES
Enable support for …
5
@5090a71b
10/25/18 09:32:01 |
Sebastian Huber |
score: Remove bogus thread object name support
Update #2514.
5
@56e61e24
09/20/18 05:57:08 |
Sebastian Huber |
Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
The configured …
5
@776464a
09/19/18 09:52:47 |
Sebastian Huber |
score: Allocate per-CPU data only if necessary
The …
5
@7097962
08/29/18 07:43:44 |
Sebastian Huber |
score: Add thread pin/unpin support
Add support to temporarily pin a …
5
@cfc4231d
08/27/18 08:36:35 |
Sebastian Huber |
score: Add flexible per-CPU data
Update #3507.
5
@e0a9336b
09/03/18 06:12:35 |
Sebastian Huber |
score: Fix EDF SMP scheduler
Fix a special case: block a one-to-one …
5
@3aad9d9b
09/03/18 07:31:19 |
Sebastian Huber |
score: Generalize SMP scheduler block support
Add extract from …
5
@6695d02
08/23/18 12:39:33 |
Sebastian Huber |
Update FreeBSD kernel timespec support
This change is based on the …
5
@ba0e9631
08/10/18 05:34:03 |
Sebastian Huber |
score: Do not inline _Thread_Dispatch_enable()
This function is …
5
@a1f7d7d
07/24/18 07:00:18 |
Sebastian Huber |
score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE()
Add …
5
@406dd62
07/24/18 09:18:27 |
Sebastian Huber |
_SMP_Start_multitasking_on_secondary_processor()
Pass current …
5
@bda8f80
07/18/18 06:54:57 |
Sebastian Huber |
score: Add a FALLTHROUGH comment to kvprintf()
This change was added …
5
@ffd4617
07/17/18 13:33:49 |
Sebastian Huber |
score: Fix _Scheduler_EDF_SMP_Set_affinity()
Commit …
5
@6539bea
06/29/18 18:00:28 |
Sebastian Huber |
score: Add postorder tree iteration support
Update #3465.
5
@995e91e8
06/28/18 06:21:44 |
Sebastian Huber |
riscv: Fix global construction
Update #3433.
5
@511dc4b
06/19/18 07:09:51 |
Sebastian Huber |
Rework initialization and interrupt stack support
Statically …
5
@b8774933
05/25/18 12:12:22 |
Sebastian Huber |
score: Simplify _Objects_Name_to_string()
Do not use isprint() from …
5
@7353422f
03/22/18 08:05:26 |
Sebastian Huber |
mpci: Fix _MPCI_Enqueue_callout()
Update #3117.
Update #3182.
5
@3da2f471
03/22/18 06:47:46 |
Sebastian Huber |
mpci: Update due to thread queue API changes
Update #3117.
Update #3182.
5
@ed24ed4e
02/08/18 09:47:16 |
Sebastian Huber |
Use _Thread_Dispatch_direct()
Use _Thread_Dispatch_direct() for …
5
@f14a04c6
11/24/17 05:38:07 |
Sebastian Huber |
Add RTEMS thread API
Update #2843.
5
@9480815a
12/21/17 13:36:52 |
Sebastian Huber |
score: Introduce new monotonic clock
Rename …
5
@3a4e044
12/22/17 09:35:47 |
Sebastian Huber |
score: Rename _Watchdog_Realtime_from_*()
Rename …
5
@89c0313
12/21/17 13:31:55 |
Sebastian Huber |
score: Optimize watchdog tickle
Avoid unnecessary lock …
5
@6c2b8a4b
11/29/17 05:23:27 |
Sebastian Huber |
score: Use self-contained API mutex
Use a self-contained recursive …
5
@a7dcef97
11/17/17 05:36:54 |
Sebastian Huber |
score: Simplify global construction
Update #3243.
5
@c597fb1
11/09/17 15:21:37 |
Sebastian Huber |
score: Optimize scheduler priority updates
Thread priority changes …
5
@91a2d5e
11/10/17 15:21:18 |
Sebastian Huber |
score: Adjust _Scheduler_EDF_SMP_Insert_ready()
Use only one …
5
@ec771f2
11/16/17 14:04:21 |
Sebastian Huber |
score: Fix priority ceiling updates
We must not clear the priority …
5
@9c30c31e
11/16/17 13:38:07 |
Sebastian Huber |
score: Fix _Thread_queue_Flush_critical()
The thread queue extract …
5
@5f02a57
10/24/17 09:17:54 |
Sebastian Huber |
score: Change _Timecounter_Time_uptime to int32_t
Move basic …
5
@fb272963
11/02/17 20:01:06 |
Sebastian Huber |
score: Use Processor_mask instead of cpu_set_t
5
@0c286e3
10/25/17 14:00:17 |
Sebastian Huber |
score: _Chain_Insert_ordered_unprotected()
Change the chain order …
5
@1082798
10/23/17 11:30:44 |
Sebastian Huber |
score: Add _IO_Printf() and _IO_Vprintf()
The previous vprintk() …
5
@9db3cc21
10/29/17 06:38:37 |
Sebastian Huber |
score: Fix non-SMP build
5
@8744498
10/27/17 07:04:53 |
Sebastian Huber |
score: Fix _Scheduler_Set_affinity()
5
@4edcede7
10/27/17 07:03:31 |
Sebastian Huber |
score: Simplify SMP get lowest scheduled
There is no need to pass in …
5
@c3105894
10/19/17 11:47:57 |
Sebastian Huber |
score: Move thread queue timeout handling
Update #3117.
Update #3182.
5
@1666ffe5
10/19/17 12:17:31 |
Sebastian Huber |
score: Rename function threadq support function
Rename …
5
@6de1f92
10/19/17 11:41:25 |
Sebastian Huber |
score: Add _Thread_Continue()
Update #3117.
Update #3182.
5
@ecef3698
10/17/17 14:19:03 |
Sebastian Huber |
score: Rename _Watchdog_Ticks_from_*()
Rename …
5
@02878626
10/17/17 14:15:31 |
Sebastian Huber |
score: Add _Thread_Add_timeout_ticks()
Replace …
5
@6d6f6a20
10/21/17 07:42:30 |
Sebastian Huber |
score: Fix warning
5
@bf2a53d2
10/14/17 13:14:53 |
Sebastian Huber |
score: Rename watchdog variants
Rename PER_CPU_WATCHDOG_RELATIVE in …
5
@d8b6f1c
10/11/17 14:19:28 |
Sebastian Huber |
timecounter: Update FreeBSD identifiers
Update #3175.
5
@bcbbe76
10/11/17 11:03:11 |
kib |
timecounter: Merge FreeBSD change r324528
The th_bintime, …
5
@5167d0e
03/14/17 22:02:02 |
vangyzen |
timecounter: Merge FreeBSD change r315287
Add missing pieces of …
5
@952b42b6
03/14/17 19:06:44 |
vangyzen |
timecounter: Merge FreeBSD change r315280
When the RTC is adjusted, …
5
@a9219e7
12/14/16 12:56:58 |
ed |
timecounter: Merge FreeBSD change r310053
Add labels to sysctls …
5
@74887157
08/17/16 09:52:09 |
kib |
timecounter: Merge FreeBSD change r304285
Implement userspace …
5
@c382cc83
07/30/16 09:25:57 |
kib |
timecounter: Merge FreeBSD change r303548
Cache getbintime(9) answer …
5
