@b54558ac
03/26/18 11:20:43 |
Sebastian Huber |
bsps/mcf5225x: Move libcpu content to bsps
This patch is a part of …
5
@4d22b554
03/26/18 11:11:51 |
Sebastian Huber |
bsps/m68k: Fix warning
5
@945095d
03/26/18 11:08:07 |
Sebastian Huber |
bsps/genmcf548x: Move libcpu content to bsps
5
@ddf3ea2
03/26/18 10:23:22 |
Sebastian Huber |
bsps/csb360: Move libcpu content to bsps
This patch is a part of the …
5
@2190bc6
03/26/18 10:20:45 |
Sebastian Huber |
bsps/mcf5206elite: Move libcpu content to bsps
This patch is a part …
5
@3cf2bf63
03/26/18 10:17:06 |
Sebastian Huber |
bsps/m68k: Move fpsp support to bsps
This patch is a part of the BSP …
5
@fc2ec62
03/26/18 10:10:15 |
Sebastian Huber |
bsps/m68k: Move libcpu content to bsps
5
@1e23c47
03/26/18 10:01:18 |
Sebastian Huber |
bsps/m68k: Remove unused define
5
@f8e4755f
03/26/18 09:59:23 |
Sebastian Huber |
bsps/m68k: Use namespace header
5
@1048a165
03/26/18 08:36:52 |
Sebastian Huber |
bsp/tqm8xx: Use shared linker command file
Update #3339.
5
@11a8296
03/26/18 05:57:53 |
Sebastian Huber |
bsp/mvme3100: Simplify Makefile.am
5
@5f59e2a
03/26/18 05:52:57 |
Sebastian Huber |
bsps/powerpc: Move dec timer driver
5
@6882be7
03/26/18 05:47:02 |
Sebastian Huber |
bsps/powerpc: Remove libcpu/powerpc
5
@2d33672a
03/26/18 05:43:09 |
Sebastian Huber |
bsps/powerpc: Move ppc403 clock driver to bsps
5
@d7c232f
03/26/18 05:18:20 |
Sebastian Huber |
bsps/powerpc: Remove unused files
5
@4fd1ff0f
03/26/18 04:57:10 |
Sebastian Huber |
bsps/powerpc: Move AltiVec? support to bsps
5
@d813d9aa
03/26/18 04:24:55 |
Sebastian Huber |
bsps/powerpc: Move dec clock driver to bsps
5
@11fe8c59
03/26/18 04:18:51 |
Sebastian Huber |
bsps/powerpc: Move MMU support to bsps
5
@b8c468b
03/23/18 15:11:55 |
Sebastian Huber |
bsp/tqm8xx: Move libcpu content to bsps
5
@a12dcff8
03/23/18 15:04:18 |
Sebastian Huber |
bsp/mpc8260: Move libcpu content to bsps
5
@0cab067
03/23/18 14:54:12 |
Sebastian Huber |
bsps/powerpc: Move libcpu content to bsps
5
@e2bd1f6
03/21/18 15:38:43 |
Sebastian Huber |
bsp/bfin: Move libcpu content to bsps
5
@96400050
03/26/18 07:04:43 |
Sebastian Huber |
bsp/pc386: Remove unused RTEMS_CPU_MODEL
5
@b1b7390
03/26/18 06:58:42 |
Sebastian Huber |
bsp/pc386: Fix build
This patch is a part of the BSP source …
5
@f17df94
03/26/18 07:14:16 |
Sebastian Huber |
build: configure.ac is a file
5
@d7fd3bc
03/23/18 16:33:45 |
Gedare Bloom |
sparc64: remove header file with duplicated macros
The boot/stack.h …
5
@b1d3b0f
03/23/18 02:46:49 |
Chris Johns |
libcpu: Only build if there is a valid configure.ac
5
@df8a31d
03/22/18 13:50:02 |
thomas.doerfler |
bsp/tqm8xx: Fix network interface driver
5
@7353422f
03/22/18 08:05:26 |
Sebastian Huber |
mpci: Fix _MPCI_Enqueue_callout()
Update #3117.
Update #3182.
5
@28a6bb8
03/22/18 05:36:11 |
Sebastian Huber |
mpci: Avoid use of RTEMS_RELLDFLAGS
5
@2c65588
03/22/18 06:48:05 |
Sebastian Huber |
config: Fix re-definition warning
5
@3da2f471
03/22/18 06:47:46 |
Sebastian Huber |
mpci: Update due to thread queue API changes
Update #3117.
Update #3182.
5
@dc1ea01
03/22/18 05:27:31 |
Sebastian Huber |
bsps/mpc55xx: Move libcpu content to bsps
5
@3f3f246a
03/22/18 05:19:16 |
Sebastian Huber |
bsps/mpc55xx: Remove unused files
5
@bb22a3f3
03/21/18 05:27:24 |
Sebastian Huber |
bsp/powerpc: Move libcpu timer to bsps
Use only one timer driver …
5
@f3a51d62
03/21/18 07:11:33 |
Sebastian Huber |
bsps/powerpc: Remove bsp_timer_internal_clock
The only consumer of …
5
@a7fa9e91
03/20/18 15:16:53 |
Sebastian Huber |
bsp/pc386: Move libcpu content to bsps
5
@4c36a525
03/19/18 07:58:39 |
christian.mauderer |
bsp/atsam: Fix GMAC Rx Descriptor fields.
5
@7341dbd6
03/21/18 07:20:00 |
Sebastian Huber |
bsps/powerpc: Remove obsolete BSP_Configuration
5
@26623e3
03/21/18 06:15:22 |
Sebastian Huber |
bsp/lpc176x: Remove blunt OPERATION_COUNT define
BSP-specific test …
5
@e40c589
03/20/18 12:43:07 |
Sebastian Huber |
MAINAINERS: Add rule for BSP-specific patches
5
@5cf0656
03/20/18 13:14:39 |
Eric Tremblay |
bsps/powerpc: Support more than 256MiB of RAM
Close #3322.
5
@5d44981c
03/20/18 06:34:22 |
Sebastian Huber |
bsp/qoriq: Fix bsp_restart()
Update #3085.
5
@09dd82a5
03/13/18 15:43:25 |
Sebastian Huber |
bsp/ss555: Move libcpu content to bsps
5
@bd150801
03/13/18 15:24:16 |
Sebastian Huber |
bsps/powerpc: Move exceptions support to bsps
5
@ff3b9aa
03/13/18 05:23:40 |
Sebastian Huber |
5
@7dbc43d
03/13/18 05:18:38 |
Sebastian Huber |
bsps/powerpc: Move basic support to bsps
5
@ac04bb85
03/12/18 15:42:16 |
Sebastian Huber |
bsps/powerpc: Move legacy IRQ support
5
@efa0039e
03/13/18 16:14:15 |
amaan.cheval |
i386/smp: Export _CPU_SMP_Prepare_start_multitasking as a function
5
@51614c01
03/13/18 16:14:14 |
amaan.cheval |
i386/smp: Have ld use incremental build for appstart.o
With HAS_SMP …
5
@e9fb3133
03/13/18 16:14:13 |
amaan.cheval |
i386/smp: Define CPU_Interrupt_frame as non-void struct
This change, …
5
@2e5cf7f
03/16/18 14:09:36 |
Sebastian Huber |
bsps/powerpc: Use shared linker command file
Close #3339.
5
@9860cc7
03/16/18 10:01:03 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
Update #3339.
5
@be3d7d75
03/15/18 22:20:23 |
joel |
pc386/include/edid.h: Fix macro name to use _ not -
Closes #3349.
5
@8307723d
03/15/18 22:18:14 |
joel |
beatnik/include/bsp.h: Add spaces around "."
Closes #3348.
5
@b3360235
03/15/18 15:01:37 |
joel |
mvme5500/include/bsp/VMEConfig.h: Remove spaces after \ and remove tabs
5
@3200c300
03/15/18 14:58:13 |
joel |
bsp/arm-a8core-start.h: Add void return type to fix warning
5
@74fe9ce
03/15/18 14:49:11 |
joel |
rtems/bfin/bf533.h: Eliminate redefinition warning and add sanity …
5
@dce920ae
03/15/18 14:48:21 |
joel |
mvme3100/include/bsp.h: Add spaces around "."
Closes #3345.
5
@0c70535
03/15/18 14:44:45 |
joel |
mcf5272.h: Fix duplicate defintions for INT3
Closes #3344.
5
@8ce93dc9
03/15/18 14:42:10 |
joel |
lm32_evr/include/bsp.h: Remove definition of BSP_DIRTY_MEMORY to …
5
@a4eb7836
03/14/18 21:14:41 |
joel |
bsps/arm/gdbarmsim/include/bsp.h: Fix warning
5
@820c667
03/14/18 21:14:07 |
joel |
5
@52cdb134
03/14/18 21:11:51 |
joel |
bsps/sh/gensh1/include/bsp.h: Fix redefined warning
5
@ca866cc
03/14/18 20:24:37 |
joel |
mcf5206elite/include/ds1307.h: Fix extra tokens at end of #endif warning
5
@9b61342
03/16/18 13:23:45 |
Sebastian Huber |
bsp/gen83xx: Fix define redefinitions
Close #3340.
5
@478dc89
03/16/18 06:01:48 |
Sebastian Huber |
imfs: Use most efficient way to get the time
As a side-effect, this …
5
@0a7a30d
03/12/18 19:53:09 |
joel |
Add PowerPC paravirtualization support
Cannot read or write MSR when …
5
@c0443b4c
03/12/18 19:42:47 |
joel |
Add ARM Paravirtualization support
Closes #3305.
5
@7c39cab
03/12/18 19:46:29 |
joel |
Rework i386 Paravirtualization to have paravirt.h
5
@71c5552f
03/12/18 15:43:28 |
bsp/atsam: Allow setting the drive strength.
This adds a simple …
5
@7633f5b
03/12/18 05:59:15 |
Sebastian Huber |
sparc64: Move libcpu content to cpukit
5
@8b5778e
03/12/18 05:37:36 |
Sebastian Huber |
sparc: Move libcpu content to cpukit
5
@c4905d8d
03/10/18 09:17:35 |
Sebastian Huber |
bsps/arm: Move libcpu content to bsps
5
@b6755af
03/09/18 15:45:56 |
Sebastian Huber |
bsps/mips: Move libcpu content to bsps
5
@961e2ef
03/12/18 05:23:08 |
Sebastian Huber |
bsps/mips: Remove Mongoose-V README
5
@4c83f292
03/12/18 07:16:17 |
Sebastian Huber |
bsps: Remove unused RTEMS_CPU_MODEL
5
@a4570829
03/09/18 15:22:25 |
Sebastian Huber |
bsps: Remove unused memcpy() implementations
5
@c2282d6d
03/08/18 23:28:31 |
joel |
sparc/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@55e76c2
03/08/18 23:27:37 |
joel |
sparc64/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@d978d1b
03/08/18 23:25:54 |
joel |
powerpc/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@8d96b46
03/08/18 23:24:47 |
joel |
m68k/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@5b88ec5
03/08/18 23:23:21 |
joel |
riscv/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@eb142fee
03/08/18 23:16:59 |
joel |
arm/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@43bd6b15
03/08/18 23:11:03 |
joel |
v850/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@e88abc0
03/08/18 23:10:38 |
joel |
no_cpu/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@7dde32f0
03/08/18 23:09:52 |
joel |
or1k/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@924cecd9
03/08/18 22:56:14 |
joel |
m32c/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@a518ff4b
03/08/18 22:16:42 |
joel |
moxie/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@fce900b5
03/08/18 20:15:47 |
joel |
sh/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@0706581
03/07/18 20:31:31 |
joel |
misc sh: Remove includes of rtems/score/types.h
5
@00acca28
03/08/18 19:29:17 |
joel |
nios2/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@c83d169
03/08/18 19:23:06 |
joel |
epiphany/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@c98d4748
03/08/18 19:18:43 |
joel |
lm32/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@a1df2fdc
03/08/18 19:09:17 |
joel |
i386/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@859251a
03/08/18 18:29:23 |
joel |
mips/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@cbbe68b
03/08/18 18:28:54 |
joel |
bfin/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@2cec5ac
03/12/18 09:29:21 |
Sebastian Huber |
shell: Fix rtems_shell_init_env()
Do not discard a user provided task …
5
@0fb724a
03/12/18 09:04:11 |
Sebastian Huber |
libblock: C++ compatibility
5
@6fadb7af
03/08/18 05:33:24 |
Sebastian Huber |
config: Use new scheduler configuration defines
Update #3325.
5
