@eca13a8f
03/25/19 14:19:41 |
andreas.dachsberger |
doxygen: score: Add Blackfin CPU architecture group
Update #3706.
5
@294c6f4
03/29/19 22:58:31 |
Chris Johns |
Set the small data section size to max. for mvme5500 and mvme2100 BSPs …
5
@cbfc3415
03/14/19 07:20:54 |
Sebastian Huber |
ttest01: New test
This is an example test using the RTEMS Test …
5
@cfcc2cbf
01/31/19 13:45:31 |
Sebastian Huber |
Add RTEMS Test Framework
Update #3199.
5
@6fe01e4b
01/14/19 08:08:18 |
Sebastian Huber |
build: Move test support to librtemstest.a
One reason to move the …
5
@abec398
03/25/19 09:42:52 |
Sebastian Huber |
score: Add ARM CPU architecture group
Update #3706.
5
@5a19915
03/25/19 09:33:05 |
Sebastian Huber |
score: Add example CPU architecture group
Update #3706.
5
@5526527e
03/25/19 09:45:25 |
Sebastian Huber |
score: Rename ScoreCPU Doxygen group
Update #3706.
5
@40d15f5
03/25/19 09:31:51 |
Sebastian Huber |
score: Add implementation top-level group
Update #3706.
5
@127ee3a5
03/18/19 13:47:58 |
joel |
psxhdrs/stdio/v*.c: Fix warnings in varargs tests
5
@b0f524f
03/18/19 13:46:56 |
joel |
libfs/src/pipe/fifo.c: Fix warning.
5
@6163ab2
03/18/19 13:46:32 |
joel |
erc32/start/setvec.c: Fix warning
5
@db23c3c
03/15/19 17:16:48 |
joel |
pthreadcreate.c: Silence unused variable warning (CID 1399716)
5
@7a1934d
03/25/19 07:09:09 |
Sebastian Huber |
build: Always build libmghttpd.a
5
@311270c
03/20/19 10:03:12 |
Sebastian Huber |
score: Update Objects_Information documentation
5
@dad6fd43
03/09/19 18:04:42 |
Chris Johns |
libdl: Add an archive command
- The archive command lists archives, …
5
@a5f84c6a
03/19/19 09:04:33 |
Sebastian Huber |
bsp/atsam: Fix SPI driver DMA support
5
@5f813694
03/19/19 09:45:06 |
Sebastian Huber |
bsp/atsam: Simplify XDMAD_Handler()
Remove the channel status …
5
@007d4e12
02/25/19 06:07:19 |
Sebastian Huber |
bsp/lpc24xx: Convert I2C driver to Linux API
Change license to …
5
@9e48958
03/15/19 06:32:28 |
Sebastian Huber |
bsps/powerpc: Initialize stack earlier
The eabi() call may use the …
5
@31e8f1b
03/14/19 19:25:18 |
joel |
shmopen.c: Fix logically unreachable code (Coverity ID: 1399706, …
5
@c319945
03/13/19 15:07:23 |
joel |
main_edit.c: Use strncpy() to eliminate potential buffer overflow.
5
@11eb818
03/13/19 15:06:45 |
joel |
fifo.c: Eliminate logically dead code (Coverity 1437635)
5
@90232bc
03/12/19 19:33:20 |
joel |
z85c30.c: Do not process 0 baud and return an error (CID 1399713)
5
@3fe2155
02/01/19 09:00:36 |
Sebastian Huber |
Remove superfluous <rtems/system.h> includes
5
@12075ac3
03/14/19 10:09:09 |
Sebastian Huber |
sparc64: Do not include <rtems/asm.h> in C source
5
@20d472d
01/31/19 13:45:17 |
Sebastian Huber |
Add rtems_board_support_package()
5
@da4ca4d
02/01/19 09:01:05 |
Sebastian Huber |
posix: is_initialized is of type int not bool
5
@286e935
03/13/19 07:14:40 |
Sebastian Huber |
Regenerate cpukit/headers.am
Updates #3686.
5
@51d11dd
03/13/19 07:12:54 |
Sebastian Huber |
bsp/lm3s69xx: Fix typo in test configuration
5
@d7e2e8bb
03/12/19 15:59:56 |
joel |
mpc5643l_evb-testsuite.tcfg: : Update to account for static allocation …
5
@f22a59de
03/12/19 15:59:28 |
joel |
mpc5643l_dpu-testsuite.tcfg: Update to account for static allocation …
5
@870b527
03/08/19 22:41:46 |
joel |
mcf5225x-testsuite.tcfg: Update to account for static allocation and …
5
@539caca
03/08/19 22:41:46 |
joel |
mcf52235-testsuite.tcfg: Update to account for static allocation and …
5
@d929c483
03/08/19 22:41:46 |
joel |
tms570ls3137_hdk_with_loader-testsuite.tcfg: Update to account for …
5
@0186e39
03/08/19 22:41:45 |
joel |
tms570ls3137_hdk_intram-testsuite.tcfg: Update to account for static …
5
@8ff85c6
03/08/19 22:41:45 |
joel |
tms570ls3137_hdk-testsuite.tcfg: Update to account for static …
5
@c5dca3b7
03/08/19 22:41:45 |
joel |
stm32f4-testsuite.tcfg: Update to account for static allocation and …
5
@4f67dbda
03/08/19 22:41:45 |
joel |
stm32f105rc-testsuite.tcfg: Update to account for static allocation …
5
@0abfdc3
03/08/19 22:41:45 |
joel |
lpc32xx_mzx_stage_1-testsuite.tcfg: Update to account for static …
5
@5f07bdac
03/08/19 22:41:45 |
joel |
lpc23xx_tli800-testsuite.tcfg: Update to account for static allocation …
5
@dc632e0
03/08/19 22:41:45 |
joel |
lpc2362-testsuite.tcfg: Update to account for static allocation and …
5
@aafae0d
03/08/19 22:41:45 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Update to account for static …
5
@774ea37a
03/08/19 22:41:45 |
joel |
lpc1768_mbed_ahb_ram-testsuite.tcfg: Update to account for static …
5
@17046c9b
03/08/19 22:41:45 |
joel |
lpc1768_mbed-testsuite.tcfg: Update to account for static allocation …
5
@1526b7b
03/08/19 22:41:45 |
joel |
lm4f120-testsuite.tcfg: Update to account for static allocation and …
5
@bb1f3b4
03/08/19 22:41:44 |
joel |
lm3s6965-testsuite.tcfg: Update to account for static allocation and …
5
@c8e71bf
03/08/19 22:41:44 |
joel |
lm3s3749-testsuite.tcfg: Update to account for static allocation and …
5
@c10e8b6
03/08/19 22:38:46 |
joel |
coremsgseize.c: Fix spelling error
5
@1400210
03/08/19 10:12:31 |
Sebastian Huber |
bsp/lpc24xx: Convert SSP driver to Linux API
Use interrupts instead …
5
@b2eaa6c6
03/12/19 14:50:37 |
Sebastian Huber |
bsp/lpc24xx: Add alternative SSP2 pins
5
@01a5ced5
03/12/19 08:00:51 |
Sebastian Huber |
record: Add more system events
Update #3665.
5
@ebb8c28e
03/12/19 07:27:52 |
Sebastian Huber |
record: Add system call entry/exit events
This corresponds to the …
5
@d91951fb
03/12/19 07:15:19 |
Sebastian Huber |
record: Rename internal per-CPU events
Update #3665.
5
@0a154d5
03/02/19 17:09:39 |
shashvatjain2002 |
Correct psxtmtests_plan.csv
5
@ba34ed9c
03/11/19 06:12:38 |
Sebastian Huber |
bsp/atsam: Fix use after free
5
@529b5868
03/08/19 06:57:24 |
Sebastian Huber |
bsps: Adjust umon Doxygen groups
Update #3706.
5
@cbf773d3
03/07/19 12:29:58 |
Sebastian Huber |
bsp/atsam: Add Doxygen groups
Add Doxygen groups for contributed code …
5
@f3db3835
03/07/19 11:09:53 |
Sebastian Huber |
bsp/altera-cyclone-v: Add Doxygen groups
Add Doxygen groups for …
5
@15359bb
03/07/19 10:56:31 |
Sebastian Huber |
bsps/arm: Adjust CMSIS Doxygen groups
Update #3706.
5
@828276b
03/05/19 06:58:18 |
Sebastian Huber |
bsps: Adjust shared Doxygen groups
Update #3706.
5
@c991eeec
03/04/19 14:32:15 |
Sebastian Huber |
bsps: Adjust bsp.h Doxygen groups
Update #3706.
5
@2e8a66d
03/01/19 18:21:34 |
Jonathan Brandmeyer |
shell: Correct argument order of mfill
Close #3720.
5
@b1ac3a5
03/01/19 18:21:52 |
cpukit/arm: Correct register definition
The register definition for …
5
@3b68442
03/07/19 09:42:32 |
Sebastian Huber |
bsps/powerpc: Move mpc55xx header files
They are only used by this BSP.
5
@ec1dd51a
03/06/19 10:15:56 |
Chris Johns |
libdl: Add small data support to the remaining PowerPC BSPs.
Updates #3687
5
@96e4b22
03/06/19 09:39:29 |
Chris Johns |
testsuite: Make the OPERATION_COUNT a test configuration parameter.
5
@a06356b
03/06/19 09:31:10 |
Chris Johns |
testsuite: Add rexclude, rinclude and cflags to test config files.
5
@85d5f6c
03/06/19 12:26:29 |
Sebastian Huber |
bsp/atsam: Accept only 8/16 bits per word
For proper 16 bits per word …
5
@b82a4b4
03/06/19 12:06:27 |
Sebastian Huber |
bsp/atsam: Optimize XDMAD_Handler()
Load the channel interrupt mask …
5
@847638af
03/06/19 11:48:31 |
Sebastian Huber |
bsp/atsam: Fix SPI CS change support
The previous approach contained …
5
@923a033f
03/06/19 10:48:00 |
Sebastian Huber |
bsp/atsam: Change CS delay after transfer
5
@b934898
03/06/19 08:48:41 |
Sebastian Huber |
bsp/atsam: Make SPI CS delays configurable
5
@02926290
03/06/19 08:38:12 |
Sebastian Huber |
bsp/atsam: Simplify SPI configuration
Do not use SPID_Configure() …
5
@7604a130
03/05/19 08:03:58 |
Sebastian Huber |
bsps: Move VME header files
They are only used by PowerPC BSPs.
5
@dbe6e0ad
03/04/19 08:22:32 |
Sebastian Huber |
bsps/powerpc: Move .rtemstack section
Move the .rtemsstack section …
5
@e1fc23f0
03/04/19 08:20:43 |
Sebastian Huber |
bsps/powerpc: Fix PAGE_ALIGN() macros
Previous warning fixes which …
5
@9d41fca
02/27/19 10:39:29 |
Sebastian Huber |
bsp/altera-cyclone-v: Adjust Doxygen file groups
Update #3707.
5
@631ccd7
02/27/19 08:24:22 |
Sebastian Huber |
bsp/altera-cyclone-v: Adjust Doxygen groups
Update #3706
5
@212663be
02/26/19 14:44:50 |
Sebastian Huber |
bsps: Adjust architecture Doxygen groups
- Use CamelCase as it is …
5
@a6e39d4a
02/27/19 06:22:54 |
Sebastian Huber |
Update Doxyfile to Doxygen 1.8.15
Generate Doxygen output in doc and …
5
@6016894e
02/25/19 14:33:31 |
Sebastian Huber |
bsp/lpc1768_mbed*: Disable unsupported tests
5
@5ff61810
02/25/19 13:37:45 |
Sebastian Huber |
bsp/mpc5643l_*: Disable unsupported tests
5
@77971b6
02/25/19 12:47:42 |
Sebastian Huber |
bsp/lm4f120: Disable unsupported tests
5
@e6dd36ca
03/01/19 10:00:35 |
Sebastian Huber |
bsp/gen5200: Remove offending @mainpage
Update #3705.
5
@03b2163
03/01/19 09:10:19 |
Sebastian Huber |
score: Fix _Scheduler_EDF_Cancel_job()
Remove the priority node only …
5
@a3db5001
02/28/19 10:21:40 |
Sebastian Huber |
bsp/altera-cyclone-v: Enable FIQ for group 0 irqs
5
@76918e1
02/28/19 09:40:10 |
Sebastian Huber |
bsps/arm: Add BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
The following …
5
@8e8e269
02/28/19 10:35:53 |
Sebastian Huber |
bsps/arm: Fix typo
5
@e33be09
02/27/19 14:10:53 |
Sebastian Huber |
bsps/arm: Support GIC group 0/1
5
@feea03b6
02/27/19 09:53:30 |
Sebastian Huber |
Remove explicit file names from @file
This makes the @file …
5
@262cb534
02/27/19 10:43:49 |
Sebastian Huber |
bsp/altera-cyclone-v: Move header file
This gets rid of a special …
5
@e99847bf
02/21/19 06:01:22 |
christian.mauderer |
dev/sc16is752: Fix parity generation.
5
@68a5f751
02/25/19 22:30:11 |
garnie_a |
arm/beagle: Fix sdcard.sh tool
5
@ecf62845
02/25/19 22:30:09 |
garnie_a |
arm/beagle: SPI driver
5
@7abc497
02/21/19 22:13:58 |
nyphbl8d |
bsps/arm: Fix system register for virtual timer
The system register …
5
@c5615ddc
02/18/19 02:28:10 |
Chris Johns |
libdl/unresolved: Fix return value for rtems_rtl_unresolved_remove
5
@7aa0530
02/18/19 01:37:05 |
Chris Johns |
libdl/archive: Check for an overflow of the symbol table.
Coverty …
5
@62b01ab
02/18/19 01:18:50 |
Chris Johns |
libdl/archive: Fix the config file string index while removing tailing …
5
@be62def9
02/18/19 01:12:53 |
Chris Johns |
libdl/archive: Return false on read failure.
Coverity issue 1442641
5
