@79a998d
11/16/17 13:08:20 |
Sebastian Huber |
rtems: rtems_semaphore_flush() with prio inherit
The …
5
@888da71
11/16/17 06:17:05 |
Sebastian Huber |
score: Check thread resource count in timer server
The watchdog …
5
@d4b99ae3
11/15/17 12:21:01 |
Sebastian Huber |
libio: Add assert to rtems_libio_iop_drop()
This assert helps to …
5
@62119d2
11/15/17 06:55:43 |
Sebastian Huber |
dl01, dl02, dl05: Fix unresolved printf symbol
The link time wrap of …
5
@2727bc7f
06/20/17 15:39:21 |
javier.jalle |
leon, grspw_router: Clear only error bits defined by clear mask
5
@56cf340
10/10/17 15:24:42 |
javier.jalle |
leon, grspw_router: Allow thread safe per-bit managing of pctrl regs
5
@cc40f0b
10/10/17 15:22:40 |
javier.jalle |
leon, grspw_router: Move register bit defs to header
5
@59af2cc
03/07/17 12:59:09 |
javier.jalle |
leon, grspw_router: Changed driver C API
SMP safe by spin-lock …
5
@631f711
11/14/17 00:57:55 |
Chris Johns |
build: Fix the dependence for the generating the key file.
Update #3217.
5
@cb40687
11/10/17 07:39:23 |
Sebastian Huber |
Change RTEMS_API from 5.0 to 5
This fixes the legacy Makefile based …
5
@f5b3c024
11/12/17 14:39:53 |
martinerikwerner |
Fix bashism in vc-key.sh
Change "==" to "=", since "==" for …
5
@e6df806
11/08/17 02:27:25 |
Chris Johns |
tests: Use ld to map (wrap) printf, puts and putchar to tester …
5
@bcd0c06c
11/07/17 21:25:36 |
Chris Johns |
tests: Use rtems_test_begin and rtems_test_end.
Add a tests enum and …
5
@a6bf052
11/10/17 20:24:34 |
joel |
mvme162: Fix errors tripped by transition to using polled IO for tests
5
@cba8970e
11/10/17 20:23:05 |
joel |
mcf5206elite/include/bsp.h: Rename delay() to rtems_bsp_delay() to …
5
@52841b58
11/10/17 20:22:40 |
joel |
csb360/include/bsp.h: Rename delay() to rtems_bsp_delay() to avoid …
5
@6f3fb8a
11/07/17 05:43:11 |
Chris Johns |
cpukit: Add a Version API.
Provide functions to get the version …
5
@748a126
11/09/17 21:06:19 |
joel |
pppd/Makefile.am: Add support/include
5
@b225aa1
11/09/17 12:39:03 |
Sebastian Huber |
Reject incompatible tool chains
Update #3185.
5
@5f02a57
10/24/17 09:17:54 |
Sebastian Huber |
score: Change _Timecounter_Time_uptime to int32_t
Move basic …
5
@4a147518
10/17/17 11:44:22 |
Sebastian Huber |
Upgrade to 5.0.0
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
5
@64ba1a96
11/08/17 14:29:14 |
Sebastian Huber |
posix: Change created_with_explicit_scheduler
Remove …
5
@7147dc4
11/08/17 13:37:35 |
Sebastian Huber |
posix: Remove POSIX_API_Control::schedpolicy
Use the thread CPU …
5
@8d0a0aa
11/03/17 20:16:09 |
Sebastian Huber |
sptests/spconsole01: New test
5
@7078a00b
11/08/17 12:13:32 |
Sebastian Huber |
bsp/t32mppc: Use fixed exception handlers
5
@fdf0e55
11/08/17 07:42:33 |
Sebastian Huber |
bsp/imx: Add UART baud change
Update #3090.
5
@336fe3b
11/08/17 07:19:15 |
Sebastian Huber |
bsp/imx: Better utilize UART transmit FIFO
Update #3090.
5
@791469bd
11/06/17 13:49:32 |
Sebastian Huber |
termios: Fix canonical mode
In canonical mode, input is made …
5
@1055ff20
11/07/17 06:07:35 |
Sebastian Huber |
tests: Use normal console for user input tests
5
@32ceb385
11/07/17 07:30:59 |
Sebastian Huber |
tests: Use <tmacros.h>
Update #3170.
Update #3199.
5
@fb272963
11/02/17 20:01:06 |
Sebastian Huber |
score: Use Processor_mask instead of cpu_set_t
5
@0c286e3
10/25/17 14:00:17 |
Sebastian Huber |
score: _Chain_Insert_ordered_unprotected()
Change the chain order …
5
@bceb9db6
11/02/17 16:01:57 |
Sebastian Huber |
score: Remove superfluous include
Update #3059.
5
@7b00c2fa
11/06/17 06:56:17 |
Sebastian Huber |
tests: Use <tmacros.h> in all tests
Update #3170.
Update #3199.
5
@d71542c
11/06/17 08:05:30 |
Sebastian Huber |
fsjffs2gc01: Fix sporadic test failures
5
@c4b8b147
11/03/17 07:35:38 |
Sebastian Huber |
tests: Use simple console driver
Update #3170.
Update #3199.
5
@ac28f15
11/03/17 07:33:16 |
Sebastian Huber |
Add simple console driver
Update #3170.
Update #3199.
5
@1082798
10/23/17 11:30:44 |
Sebastian Huber |
score: Add _IO_Printf() and _IO_Vprintf()
The previous vprintk() …
5
@a54d10d
11/03/17 11:53:51 |
Sebastian Huber |
smpscheduler02: Avoid sporadic test failures
5
@3e81d52
10/29/17 19:29:05 |
Sebastian Huber |
posix: Use far future for very long timeouts
Close #3205.
5
@8c1f4064
11/02/17 12:56:12 |
Sebastian Huber |
tests: Use printf() instead of fprintf()
Update #3170.
Update #3199.
5
@0d796d6
11/02/17 13:08:02 |
Sebastian Huber |
tests: Delete obsolete TESTS_USE_PRINTF
Update #3170.
Update #3199.
5
@4438c4d8
11/02/17 12:27:33 |
Sebastian Huber |
bsp/imx: More robust and faster bsp_reset()
Update #3090.
5
@4b055e23
11/02/17 10:21:51 |
Sebastian Huber |
bsp/imx: Drain console before reset
Update #3090.
5
@c52a968
11/02/17 10:20:56 |
Sebastian Huber |
bsp/imx: Implement bsp_reset()
Update #3090.
5
@81fd79d
10/27/17 06:52:41 |
Sebastian Huber |
smppsxaffinity02: Fix thread attribute usage
The pthread_getattr_np() …
5
@8fa827c
10/26/17 22:51:09 |
Hesham Almatary |
bsp: Make riscv_generic work for both riscv32 and riscv64 - v2
Update …
5
@11ff3a9
10/27/17 04:18:40 |
Hesham Almatary |
cpukit: RISC-V - make riscv32 code work for riscv64 - v2
* Use …
5
@2126438a
10/30/17 05:30:11 |
Chris Johns |
testsuite: Add bspIo for a local printk.
Update #3170.
Update #3199.
5
@9db3cc21
10/29/17 06:38:37 |
Sebastian Huber |
score: Fix non-SMP build
5
@af43554
10/26/17 11:59:11 |
Sebastian Huber |
tests: Remove TEST_INIT
The TEST_EXTERN is a used only by the …
5
@acc9d064
10/26/17 11:59:10 |
Sebastian Huber |
tests: Remove obsolete TESTS_USE_PRINTK
Update #3170.
Update #3199.
5
@7e102915
10/26/17 11:59:09 |
Sebastian Huber |
tests: Use rtems_test_printer in general
Update #3170.
Update #3199.
5
@46ddc3c5
10/26/17 11:59:08 |
Sebastian Huber |
tests: Use rtems_print_printer_fprintf_putc()
Use …
5
@73d892d8
10/26/17 11:59:07 |
Sebastian Huber |
Update #3170.
Update #3199.
5
@7bec7f27
10/26/17 11:59:06 |
Sebastian Huber |
rtems: Add rtems_print_printer_fprintf_putc()
Update #3170.
Update #3199.
5
@f703e7f
10/26/17 11:59:05 |
Sebastian Huber |
tests: Move rtems_test_printer definition
Statically initialize it to …
5
@cf614ec
10/28/17 11:33:17 |
Sebastian Huber |
riscv32: Add missing preinstall.am
Update #3109.
5
@0719fc6
10/27/17 07:04:54 |
Sebastian Huber |
sptests/spscheduler01: Test POSIX set/get affinity
5
@8744498
10/27/17 07:04:53 |
Sebastian Huber |
score: Fix _Scheduler_Set_affinity()
5
@1d572eba
10/27/17 07:03:55 |
Sebastian Huber |
posix: Fix pthread_create() with user stack
In case the user provides …
5
@4edcede7
10/27/17 07:03:31 |
Sebastian Huber |
score: Simplify SMP get lowest scheduled
There is no need to pass in …
5
@6d85e05
10/21/17 07:06:44 |
Hesham Almatary |
bsp: Add new riscv_generic bsp v3
* Only runs/tested on …
5
@660db8c8
10/26/17 23:12:41 |
Hesham Almatary |
cpukit: Add basic riscv32 architecture port v3
Limitations:
* NO FPU …
5
@f47dc8d
10/20/17 06:05:17 |
Hesham Almatary |
cpukit: librpc - add riscv* to xdr_float.c v3
5
@a5273ab
10/20/17 06:04:08 |
Hesham Almatary |
Add riscv32 to autotools files v3
5
@0f1fa19
10/26/17 11:19:57 |
Sebastian Huber |
smptests: Fix format warnings
5
@1510ce4
10/26/17 11:17:21 |
Sebastian Huber |
psxtests/psxstat: Fix format warnings
5
@b31ccb5
10/26/17 11:08:27 |
Sebastian Huber |
psxtests/psxclockrealtime01: Fix warnings
Update #3182.
5
@8388ceea
10/24/17 04:31:03 |
Sebastian Huber |
score: Delete _Scheduler_Thread_set_priority()
5
@cfc3604
09/12/17 09:24:48 |
Daniel Hellstrom |
leon,gr740: start ASR22:23 up-counter on boot by writing ASR22
5
@e3ef14b
10/25/17 05:57:58 |
Sebastian Huber |
smptests: Remove duplicate Makefile targets
Close #3187.
5
@0ddffb76
10/24/17 08:31:05 |
Sebastian Huber |
confdefs: CONFIGURE_MICROSECONDS_PER_TICK
Reject non-positive …
5
@34799c3b
10/24/17 07:35:06 |
Sebastian Huber |
rtems: rtems_clock_get_ticks_per_second()
Add macro implementation …
5
@4c70110
10/24/17 21:32:53 |
Chris Johns |
testsuite: Fix build
Updates #3170.
5
@c3105894
10/19/17 11:47:57 |
Sebastian Huber |
score: Move thread queue timeout handling
Update #3117.
Update #3182.
5
@1666ffe5
10/19/17 12:17:31 |
Sebastian Huber |
score: Rename function threadq support function
Rename …
5
@6de1f92
10/19/17 11:41:25 |
Sebastian Huber |
score: Add _Thread_Continue()
Update #3117.
Update #3182.
5
@5747962
10/20/17 05:29:22 |
Sebastian Huber |
score: _Watchdog_Per_CPU_lazy_insert_monotonic()
Update #3117.
Update …
5
@b13ec80
10/20/17 13:23:49 |
Sebastian Huber |
score: Add _Watchdog_Monotonic_from_timespec()
Update #3117.
Update #3182.
5
@cea5ff7
10/20/17 13:35:14 |
Sebastian Huber |
score: Add _Watchdog_Nanoseconds_per_tick
Move it from the …
5
@7ed377b
10/20/17 06:43:15 |
Sebastian Huber |
score: _Watchdog_Is_far_future_monotonic_timespec
Update #3117. …
5
@d16d07f
10/20/17 06:42:55 |
Sebastian Huber |
score: Add _Watchdog_Is_valid_interval_timespec()
Update #3117. …
5
@adaf5c23
10/19/17 11:38:48 |
Sebastian Huber |
score: _Watchdog_Is_far_future_realtime_timespec()
Update #3117. …
5
@ecef3698
10/17/17 14:19:03 |
Sebastian Huber |
score: Rename _Watchdog_Ticks_from_*()
Rename …
5
@381ef5c
10/20/17 06:33:03 |
Sebastian Huber |
confdefs: Warn about problematic ticks per second
A non-integer clock …
5
@e0dc6efc
10/20/17 13:41:29 |
Sebastian Huber |
rtems: Simplify RTEMS_MILLISECONDS_TO_MICROSECONDS
Remove the cast so …
5
@27cfe7c
10/20/17 06:31:36 |
Sebastian Huber |
score: Add _Watchdog_Ticks_per_second
This value is frequently used. …
5
@02878626
10/17/17 14:15:31 |
Sebastian Huber |
score: Add _Thread_Add_timeout_ticks()
Replace …
5
@d85c94c0
10/13/17 06:00:46 |
Sebastian Huber |
psxclockrealtime01: New test
Update #3182.
5
@a0d09107
10/20/17 14:53:04 |
Sebastian Huber |
posix: Do not touch msg priority in case of error
5
@0e1ad7fa
10/24/17 07:27:06 |
Sebastian Huber |
tmtests/tmfine01: Reduce test context size
Reduce test context size …
5
@88e84c22
10/23/17 11:48:56 |
Sebastian Huber |
Updates #3170.
5
@36d974ba
10/22/17 22:57:52 |
Chris Johns |
testsuite: Remove warnings.
5
@98c6d50
10/19/17 05:39:16 |
Chris Johns |
testsuite: Use printk for all test output where possible.
- Remove …
5
@eeb8d83
10/23/17 05:12:57 |
Sebastian Huber |
posix: Fix POSIX disabled build
Update #2514.
5
@a05861d
10/21/17 10:16:21 |
Sebastian Huber |
libtests/tar01: Fix build dependencies
5
@6d6f6a20
10/21/17 07:42:30 |
Sebastian Huber |
score: Fix warning
5
@dbb30e26
10/18/17 07:17:32 |
Sebastian Huber |
Update #2514.
5
@248f867
10/17/17 09:46:15 |
Christian.Mauderer |
bsps/arm: Remove DWT based clock.
It seems that the DWT CYCCNT does …
5
