@3b68442
03/07/19 09:42:32 |
Sebastian Huber |
bsps/powerpc: Move mpc55xx header files
They are only used by this BSP.
5
@ec1dd51a
03/06/19 10:15:56 |
Chris Johns |
libdl: Add small data support to the remaining PowerPC BSPs.
Updates #3687
5
@96e4b22
03/06/19 09:39:29 |
Chris Johns |
testsuite: Make the OPERATION_COUNT a test configuration parameter.
5
@a06356b
03/06/19 09:31:10 |
Chris Johns |
testsuite: Add rexclude, rinclude and cflags to test config files.
5
@85d5f6c
03/06/19 12:26:29 |
Sebastian Huber |
bsp/atsam: Accept only 8/16 bits per word
For proper 16 bits per word …
5
@b82a4b4
03/06/19 12:06:27 |
Sebastian Huber |
bsp/atsam: Optimize XDMAD_Handler()
Load the channel interrupt mask …
5
@847638af
03/06/19 11:48:31 |
Sebastian Huber |
bsp/atsam: Fix SPI CS change support
The previous approach contained …
5
@923a033f
03/06/19 10:48:00 |
Sebastian Huber |
bsp/atsam: Change CS delay after transfer
5
@b934898
03/06/19 08:48:41 |
Sebastian Huber |
bsp/atsam: Make SPI CS delays configurable
5
@02926290
03/06/19 08:38:12 |
Sebastian Huber |
bsp/atsam: Simplify SPI configuration
Do not use SPID_Configure() …
5
@7604a130
03/05/19 08:03:58 |
Sebastian Huber |
bsps: Move VME header files
They are only used by PowerPC BSPs.
5
@dbe6e0ad
03/04/19 08:22:32 |
Sebastian Huber |
bsps/powerpc: Move .rtemstack section
Move the .rtemsstack section …
5
@e1fc23f0
03/04/19 08:20:43 |
Sebastian Huber |
bsps/powerpc: Fix PAGE_ALIGN() macros
Previous warning fixes which …
5
@9d41fca
02/27/19 10:39:29 |
Sebastian Huber |
bsp/altera-cyclone-v: Adjust Doxygen file groups
Update #3707.
5
@631ccd7
02/27/19 08:24:22 |
Sebastian Huber |
bsp/altera-cyclone-v: Adjust Doxygen groups
Update #3706
5
@212663be
02/26/19 14:44:50 |
Sebastian Huber |
bsps: Adjust architecture Doxygen groups
- Use CamelCase as it is …
5
@a6e39d4a
02/27/19 06:22:54 |
Sebastian Huber |
Update Doxyfile to Doxygen 1.8.15
Generate Doxygen output in doc and …
5
@6016894e
02/25/19 14:33:31 |
Sebastian Huber |
bsp/lpc1768_mbed*: Disable unsupported tests
5
@5ff61810
02/25/19 13:37:45 |
Sebastian Huber |
bsp/mpc5643l_*: Disable unsupported tests
5
@77971b6
02/25/19 12:47:42 |
Sebastian Huber |
bsp/lm4f120: Disable unsupported tests
5
@e6dd36ca
03/01/19 10:00:35 |
Sebastian Huber |
bsp/gen5200: Remove offending @mainpage
Update #3705.
5
@03b2163
03/01/19 09:10:19 |
Sebastian Huber |
score: Fix _Scheduler_EDF_Cancel_job()
Remove the priority node only …
5
@a3db5001
02/28/19 10:21:40 |
Sebastian Huber |
bsp/altera-cyclone-v: Enable FIQ for group 0 irqs
5
@76918e1
02/28/19 09:40:10 |
Sebastian Huber |
bsps/arm: Add BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
The following …
5
@8e8e269
02/28/19 10:35:53 |
Sebastian Huber |
bsps/arm: Fix typo
5
@e33be09
02/27/19 14:10:53 |
Sebastian Huber |
bsps/arm: Support GIC group 0/1
5
@feea03b6
02/27/19 09:53:30 |
Sebastian Huber |
Remove explicit file names from @file
This makes the @file …
5
@262cb534
02/27/19 10:43:49 |
Sebastian Huber |
bsp/altera-cyclone-v: Move header file
This gets rid of a special …
5
@e99847bf
02/21/19 06:01:22 |
christian.mauderer |
dev/sc16is752: Fix parity generation.
5
@68a5f751
02/25/19 22:30:11 |
garnie_a |
arm/beagle: Fix sdcard.sh tool
5
@ecf62845
02/25/19 22:30:09 |
garnie_a |
arm/beagle: SPI driver
5
@7abc497
02/21/19 22:13:58 |
nyphbl8d |
bsps/arm: Fix system register for virtual timer
The system register …
5
@c5615ddc
02/18/19 02:28:10 |
Chris Johns |
libdl/unresolved: Fix return value for rtems_rtl_unresolved_remove
5
@7aa0530
02/18/19 01:37:05 |
Chris Johns |
libdl/archive: Check for an overflow of the symbol table.
Coverty …
5
@62b01ab
02/18/19 01:18:50 |
Chris Johns |
libdl/archive: Fix the config file string index while removing tailing …
5
@be62def9
02/18/19 01:12:53 |
Chris Johns |
libdl/archive: Return false on read failure.
Coverity issue 1442641
5
@22afb034
02/18/19 00:46:22 |
Chris Johns |
libdl/alloc: Add a locking interface to the allocator.
- Allow an …
5
@bdec62c4
02/18/19 08:01:27 |
Sebastian Huber |
bsps/arm: Move device tree copy
Move device tree copy operation after …
5
@af80b0a
02/18/19 07:24:37 |
Sebastian Huber |
bsp/altera-cyclone-v: Use FDT for clock frequency
5
@43fbb50f
02/15/19 11:07:23 |
Sebastian Huber |
bsp/altera-cyclone-v: Make FDT support optional
5
@3d65f45
02/18/19 07:32:42 |
Sebastian Huber |
psxtests/psxonce01: Fix typo
Update #3334.
5
@e4ad14cc
02/12/19 11:19:38 |
Sebastian Huber |
score: Avoid some deadlocks in _Once()
Recursive usage of the same …
5
@3ecb207
02/14/19 23:38:41 |
Chris Johns |
libdl/rap: Add the section alloc call after section load was split
5
@e309f77
02/14/19 03:00:05 |
Chris Johns |
libdl: Allocator does not unlock and lock memory on loading.
Close #3692
5
@e214ff4b
02/12/19 12:18:56 |
Sebastian Huber |
posix: Remove unused _POSIX_Get_object_body()
5
@7fdcd023
02/12/19 09:26:34 |
Sebastian Huber |
psxtests: Remove bogus file
This file is unused and makes trouble on …
5
@eec706e2
02/11/19 06:34:14 |
Sebastian Huber |
bsps/powerpc: Fix small data area section
Fix small data area in case …
5
@6c9f017
02/02/19 04:09:53 |
Chris Johns |
libdl: Add powerpc large memory and small data support.
- Add support …
5
@194eb403
01/21/19 21:48:19 |
Chris Johns |
libdl: Add support for large memory programs
- Add trampolines to …
5
@d8c70ba6
01/15/19 06:47:41 |
Chris Johns |
libdl: Add support for trampolines
- Trampolines or fixups for …
5
@4408603
01/09/19 11:14:11 |
Chris Johns |
libdl: Fix the support for constructors and desctructors.
- Fix the …
5
@a7c6176
12/17/18 06:48:30 |
Chris Johns |
libtest/dl08: Add a test for archives.
- Create 2 archives.
- Load 1 …
5
@bac53634
12/17/18 06:40:46 |
Chris Johns |
libtests/dl02: Update the rtl-shell path. More verbose test.
Updates #3686
5
@85b59974
12/17/18 06:40:25 |
Chris Johns |
Updates #3686
5
@89c59be
12/17/18 05:36:48 |
Chris Johns |
libdl: Add symbol searching and loading from archives.
- Load archive …
5
@b08278e
02/02/19 04:32:38 |
Chris Johns |
powerpc/psim: Increase the psim memory to 256M
This allows test dl09 …
5
@e2f13430
02/02/19 04:19:59 |
Chris Johns |
libdl: Fix dlerror non-conformance
Closes #3298
5
@2d8a9c79
02/02/19 04:22:04 |
Chris Johns |
libmisc: Fix rtems_print_buffer
Closes #3684
5
@568490a
02/08/19 11:40:45 |
Jiri Gaisler |
griscv: add additional cpu configurations
* Also switch default …
5
@26333f2a
02/08/19 09:16:07 |
Sebastian Huber |
score: Fix _User_extensions_Thread_switch() (SMP)
We have to read the …
5
@4e686261
02/07/19 10:13:01 |
Sebastian Huber |
bsps/irq: Fix interrupt server init (SMP)
5
@fbd08066
02/07/19 06:46:38 |
Sebastian Huber |
score: Fix plain priority thread queues (SMP)
We must add/remove the …
5
@0fb52ce
02/07/19 06:45:58 |
Sebastian Huber |
bsps/arm: Fix generic timer frequency
Update #3456.
5
@03fcbb1
11/27/18 11:45:53 |
Sebastian Huber |
fs: Add struct dirent::d_type support
5
@9399473c
02/02/19 10:03:13 |
Sebastian Huber |
riscv: Fix misaligned access in context validate
5
@b015c01
01/28/19 11:26:25 |
Sebastian Huber |
build: Do not install test programs
5
@03cdd5ea
01/30/19 08:41:49 |
Sebastian Huber |
record: Add enum value for each event
Update #3665.
5
@dca6184
04/28/18 09:36:11 |
Sebastian Huber |
Add low level event recording support
Add low level event recording …
5
@f0ae613b
01/17/19 06:33:08 |
Sebastian Huber |
m68k: Avoid _Addresses_Add_offset()
This prevents a cyclic dependency …
5
@e74a3fd
01/29/19 12:26:12 |
Sebastian Huber |
samples/pppd: Use less memory hungry configuration
This avoids …
5
@4f3a253
01/28/19 13:16:39 |
Sebastian Huber |
psxtmtests: Fix format warnings
Update #3384.
5
@b1381ae
01/25/19 14:50:14 |
Sebastian Huber |
bsps/powerpc: Fix warnings
5
@81aec18
01/24/19 13:29:03 |
Sebastian Huber |
bsps/powerpc: Fix 64-bit issues in assembler files
We have to be …
5
@afd50b3
01/23/19 12:17:44 |
maksim.e.kozlov |
libmisc: Fix swapped parameters and enable floating point usage.
5
@d3d4e77
01/18/19 11:37:55 |
Jiri Gaisler |
riscv: add griscv bsp
Update #3678.
5
@c1dcd6af
01/21/19 10:27:07 |
Jiri Gaisler |
grlib: make memory coherency cpu-independent
Update #3678.
5
@9b2b389
01/18/19 17:00:47 |
Jiri Gaisler |
grlib: use cpu-independent routines for uncached access
Update #3678.
5
@5981c8ca
01/18/19 10:29:08 |
Jiri Gaisler |
grlib: use rtems_interrupt_handler_install()
Update #3678.
5
@411c297
01/18/19 10:24:18 |
Jiri Gaisler |
grlib: make apbuart driver independent of bsp
Update #3678.
5
@7eb606d3
12/22/18 17:31:04 |
Sebastian Huber |
grlib: Move source files
Update #3678.
5
@31720925
12/22/18 06:13:44 |
Sebastian Huber |
grlib: Move header files
Update #3678.
5
@95c1921
01/21/19 08:17:05 |
Sebastian Huber |
bsps/arm: Remove unused bsp_stack_irq_size
Update #3459.
5
@926ed2b0
01/18/19 12:32:51 |
Sebastian Huber |
score: Remove unused _ISR_lock_Flash()
5
@41310c02
01/18/19 12:16:29 |
Sebastian Huber |
score: Improve debug support for ISR locks
Ensure that interrupts are …
5
@b5bdecf
01/18/19 11:54:05 |
Sebastian Huber |
score: Avoid internal API and use ISR lock
5
@93e3b341
01/14/19 06:50:26 |
Sebastian Huber |
score: Simplify _Addresses_Is_aligned()
The CPU_ALIGNMENT must not be …
5
@12dfe5dc
01/16/19 21:42:18 |
joel |
bsps/i386/shared/cache/cache.c: Make compile
5
@4596127
01/10/19 19:14:03 |
joel |
m68k/include/rtems/score/cpu.h: Add include of address.h
5
@47d5aee
01/14/19 08:38:02 |
Sebastian Huber |
build: Add missing $(LDADD) for dependencies
5
@d1fff86
01/14/19 08:07:16 |
Sebastian Huber |
build: Remove bogus spqreslib_LDADD
5
@dc0285f
01/14/19 08:06:30 |
Sebastian Huber |
5
@8eaf136d
01/10/19 10:35:12 |
Sebastian Huber |
memalign: Add missing attributes to fix warning
Update #3666.
5
@7bde91b
01/10/19 08:05:49 |
Sebastian Huber |
Fix format warnings due to ino_t changes
5
@3a5c71de
01/10/19 07:10:17 |
Sebastian Huber |
psxconfig01: Fix pre-processor conditions
Do not rely on compiler …
5
@e7d623e7
01/10/19 06:57:36 |
Sebastian Huber |
bsps/arm: Conditional ARMv7-AR data cache disable
Update #3667.
Close …
5
@0abe47f
01/10/19 06:29:54 |
thomas.doerfler |
bsps/arm: Fix typo in disable cache for ARMv7-AR
Update #3667.
5
@b9ffc41c
01/08/19 08:50:50 |
Sebastian Huber |
riscv: Enable robust thread dispatch
It must be enabled, since the …
5
@3bd39999
01/08/19 08:53:26 |
Sebastian Huber |
Adjust interrupt mode tests for some CPU ports
In case the robust …
5
@1f285186
01/08/19 07:39:42 |
Sebastian Huber |
rtems: Allow to set ISR level 0 in SMP config
Update #3000.
5
@38cb59e
01/08/19 07:36:31 |
Sebastian Huber |
Separate task mode checks
Update #3000.
5
