@fcd9618a
12/11/20 12:57:31 |
Sebastian Huber |
config: Fix invalid static assertions in C
Expressions in static …
@d188e6e8
12/08/20 15:11:34 |
kinsey.moore |
cpukit/aarch64: Add explanation of exception flow
@f046af5
12/07/20 20:51:10 |
kinsey.moore |
cpukit/aarch64: Use hex consistently for offsets
@9955487d
12/07/20 13:15:10 |
Sebastian Huber |
arm: Support Armv8 in <rtems/score/arm.h>
Update #4202.
@7930fbdd
12/03/20 14:32:14 |
Sebastian Huber |
score: Fix discard 'const' qualifier warning
@768327d0
06/22/20 11:36:21 |
Sebastian Huber |
rtems: Generate <rtems/rtems/timer.h>
Change license to BSD-2-Clause …
@e2f888d1
11/24/20 12:36:32 |
Sebastian Huber |
score: Free old name in _Objects_Set_name()
This is the behaviour …
@766009b4
11/23/20 16:24:39 |
Sebastian Huber |
rtems: Fix rtems_object_set_name()
Return RTEMS_NO_MEMORY if there is …
@13bab34
11/23/20 16:22:10 |
Sebastian Huber |
score: Return a status in _Objects_Set_name()
@65969c1
06/24/20 06:59:35 |
Sebastian Huber |
rtems: Generate <rtems/rtems/object.h>
@ef0fe8e
12/02/20 12:18:42 |
Sebastian Huber |
dosfs: Fix Doxygen group placement
Update #3706.
@3393ff1d
12/02/20 12:10:49 |
Sebastian Huber |
libfs: Fix Doxygen group placement
Update #3706.
@295b05f9
12/02/20 12:02:58 |
Sebastian Huber |
nfsclient: Rework Doxygen groups
Update #3706.
@7f1ba9c7
12/02/20 10:41:09 |
Sebastian Huber |
build: Add <rtems/rtems/clockimpl.h>
@1fa3821
12/02/20 10:34:33 |
Sebastian Huber |
score: Fix Doxygen group membership
Update #3706.
@1c60622
12/02/20 10:34:03 |
Sebastian Huber |
score: Fix Doxygen group name
Update #3706.
@c296d150
12/01/20 13:09:23 |
Sebastian Huber |
rtems: Fix Doxygen return description
@1af4493
12/02/20 07:32:44 |
Sebastian Huber |
rtems: Clarify invalid identifier descriptions
Update #3993.
@5a285e3
12/01/20 15:51:40 |
Sebastian Huber |
rtems: Clarify rtems_partition_delete()
Move the PTCB sentence to the …
@8756d5c
12/01/20 15:35:05 |
Sebastian Huber |
rtems: Clarify rtems_partition_create()
The rtems_partition_create() …
@5555c0c
12/02/20 07:15:32 |
Sebastian Huber |
rtems: Fix Doxygen group name
Update #3706.
@226b90b4
12/02/20 07:13:26 |
Sebastian Huber |
rtems: Fix Doxygen group memberships
Update #3706.
@70dbafb
11/30/20 13:00:08 |
Sebastian Huber |
config: Canonicalize @defgroup and @file comments
Adjust group …
@3db9c820
11/28/20 10:16:28 |
Sebastian Huber |
sapi: Canonicalize @defgroup and @file comments
Adjust group …
@9278f3d
11/27/20 16:21:23 |
Sebastian Huber |
score: Canonicalize Doxygen @file comments
Use common phrases for the …
@6b5f22dc
11/26/20 10:45:47 |
Sebastian Huber |
rtems: Canonicalize Doxygen @file comments
@23494c2
11/30/20 18:32:22 |
Sebastian Huber |
score: Always define RTEMSScoreMRSP group
This fixes a Doxygen warning.
@c81ac0e
11/26/20 09:42:03 |
Sebastian Huber |
score: Canonicalize Doxygen groups
Adjust group identifier and names …
@e07088d9
11/25/20 15:42:08 |
Sebastian Huber |
rtems: Canonicalize implementation Doxygen groups
Rename Classic API …
@9c20b987
11/26/20 18:53:25 |
Sebastian Huber |
rtems: Add <rtems/rtems/clockimpl.h>
@501bd46f
11/28/20 08:44:08 |
Sebastian Huber |
shell: Rename "IO" typedef for better Doxygen
An automatic link from …
@b1a8be4
11/30/20 11:53:06 |
Sebastian Huber |
rtems: Simplify includes in version.c
@3732c93
11/30/20 10:43:09 |
Sebastian Huber |
posix: Delete unused _POSIX_Fatal_error()
@b48b1808
11/27/20 18:51:59 |
Sebastian Huber |
score: Delete empty pheapinit.c
@7995329
12/01/20 13:39:43 |
Sebastian Huber |
rtems: Fix documentation in <rtems/rtems/part.h>
Update #3993.
@6c8c774
11/27/20 15:14:22 |
Sebastian Huber |
rtems: Remove empty and unused rtclock.c
@6e566bad
11/27/20 08:52:07 |
Sebastian Huber |
config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Fix the …
@3a5c33a7
11/26/20 10:29:20 |
Sebastian Huber |
sapi: Remove obsolete README file
@2406fe8
11/20/20 17:46:04 |
Sebastian Huber |
rtems: Delete rtems_object_id_api_maximum_class()
This directive has …
@6c1afc19
11/24/20 07:05:43 |
Sebastian Huber |
config: Check CONFIGURE_INIT_TASK_STACK_SIZE
@657e30c1
11/19/20 15:07:04 |
Sebastian Huber |
In order to better …
@bc175a1
11/19/20 14:30:17 |
Sebastian Huber |
Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
Replace a runtime …
@ef8c4ebc
11/25/20 06:59:30 |
Sebastian Huber |
config: Clarify the use of pragmas
@b2a677b
11/26/20 10:08:54 |
Sebastian Huber |
rtems: Move "Set Errno" group to the API
@41725e95
11/26/20 09:01:18 |
Sebastian Huber |
score: Change _Per_CPU_Information declaration
Change the …
@139306c
11/26/20 07:57:23 |
Sebastian Huber |
rtems: Remove unused barriermp.h
@0f5f4261
11/18/20 22:36:38 |
kinsey.moore |
score/aarch64: Resolve warning in exception dump
This resolves a …
@3c093d6
10/14/20 08:32:18 |
Sebastian Huber |
rtems: Move _Partition_Allocate()
It is only used by …
@accbe3c4
10/14/20 08:31:45 |
Sebastian Huber |
rtems: Move _Partition_Initialize()
@1784799
10/14/20 08:30:45 |
Sebastian Huber |
rtems: Move _Partition_Is_buffer_area_aligned()
@1eafefbf
10/14/20 08:29:19 |
Sebastian Huber |
rtems: Move _Partition_Is_buffer_size_aligned()
@a61e221d
10/14/20 08:26:53 |
Sebastian Huber |
rtems: Move _Partition_Is_buffer_on_boundary()
It is used only by …
@2572a3f
10/14/20 08:25:59 |
Sebastian Huber |
rtems: Move _Partition_Is_buffer_valid()
It is used only in one …
@aa1c6dd
11/21/20 20:15:39 |
Sebastian Huber |
libtest: Fix undefined setjmp() behaviour
Bug was introduced by …
@cbfacee4
10/14/20 08:22:52 |
Sebastian Huber |
rtems: Remove _Partition_Destroy()
It was a trivial function call …
@3c029026
10/14/20 08:22:18 |
Sebastian Huber |
rtems: Remove _Partition_Free()
@76263d8
10/14/20 08:14:10 |
Sebastian Huber |
rtems: Move _Partition_Free_buffer()
@6d413ef1
10/14/20 08:12:56 |
Sebastian Huber |
rtems: Move _Partition_Allocate_buffer()
@ede8f51
10/14/20 07:43:48 |
Sebastian Huber |
rtems: Update partition documentation
@4c1e793
10/14/20 06:51:39 |
Sebastian Huber |
rtems: Canonicalize partition file documentation
@134fc76d
10/14/20 09:30:19 |
Sebastian Huber |
rtems: Update event documentation
@83c37fc
10/14/20 09:04:12 |
Sebastian Huber |
rtems: Remove unused _Event_Timeout()
@acf1a987
10/14/20 09:02:25 |
Sebastian Huber |
rtems: Remove EVENT_SETS_NONE_PENDING
This define was only used in …
@422b003
10/14/20 09:01:32 |
Sebastian Huber |
rtems: Remove unused EVENT_CURRENT
@72811c7
10/14/20 08:57:35 |
Sebastian Huber |
rtems: Canonicalize task event file documentation
@bdfc58fb
10/13/20 13:52:56 |
Sebastian Huber |
libio: Move to RTEMS implementation group
@6c07890
10/13/20 13:48:14 |
Sebastian Huber |
doxygen: Use common syntax for groups
@f1d932d5
10/13/20 12:35:18 |
Sebastian Huber |
doxygen: Rename Internal to Implementation
Use a top-level …
@b169095c
11/17/20 08:38:50 |
christian.mauderer |
cpu/armv7m: Add table based init for ARMV7M_MPU
Modify the MPU …
@c13fd2d
11/20/20 07:10:06 |
Sebastian Huber |
score: Restore RTEMS_COMPILER_UNUSED_ATTRIBUTE
Commit …
@298b5ef1
11/19/20 07:40:25 |
Sebastian Huber |
config: Initialize task stack allocator on demand
Register a custom …
@c5af8aa0
11/19/20 07:40:13 |
Sebastian Huber |
config: Simplify task stack allocator init
Replace runtime checks …
@c542345
11/12/20 10:05:19 |
Sebastian Huber |
libtest: Simplify "Load" environment reporting
Report all runtime …
@78baeb7
11/11/20 16:09:58 |
Sebastian Huber |
libtest: Allow assert checks during test begin
Allow assert checks in …
@d2bc5945
11/11/20 10:27:50 |
Sebastian Huber |
libtest: Rename ValidCache? in FullCache?
This name better reflects the …
@8882635
11/10/20 11:02:34 |
Sebastian Huber |
libtest: Add primitive test case memory allocator
This primitive test …
@33cd037b
11/10/20 09:40:51 |
Sebastian Huber |
libtest: Simplify runtime measurement support
Use the test case …
@eae22cc0
11/10/20 09:23:10 |
Sebastian Huber |
libtest: Make test case allocator configurable
@eb3d7fb
10/22/20 17:58:44 |
kinsey.moore |
score/aarch64: Size saved SP register for ABI
This ensures that the …
@21af871
05/11/20 12:49:08 |
Sebastian Huber |
rtems: Generate <rtems/score/basedefs.h>
Change license to …
@ecc6b2f
06/24/20 04:35:57 |
Sebastian Huber |
rtems: Generate <rtems/rtems/part.h>
@007ee13
06/22/20 08:27:29 |
Sebastian Huber |
rtems: Generate <rtems/rtems/event.h>
@f75e240
06/05/20 12:40:10 |
Sebastian Huber |
rtems: Generate <rtems/rtems/attr.h>
@9b4458e7
06/04/20 18:41:12 |
Sebastian Huber |
rtems: Generate <rtems/rtems/types.h>
@8de874b
06/04/20 17:50:25 |
Sebastian Huber |
rtems: Generate <rtems/rtems/options.h>
Change license to …
@e05b100
06/04/20 14:54:15 |
Sebastian Huber |
rtems: Generate <rtems/rtems/modes.h>
@c0327d8
05/28/20 11:48:28 |
Sebastian Huber |
rtems: Generate <rtems/rtems/status.h>
@da44df3
05/28/20 11:48:17 |
Sebastian Huber |
rtems: Generate <rtems/rtems/config.h>
@1af94608
05/28/20 11:47:15 |
Sebastian Huber |
rtems: Generate <rtems/config.h>
@96559b3
06/04/20 14:54:36 |
Sebastian Huber |
rtems: Include missing header file
@ced13022
11/11/20 07:15:02 |
Sebastian Huber |
Improve automatically generated warning
@7f0379c
11/09/20 07:09:27 |
Sebastian Huber |
libtrace: Move _Record_Stream_header_initialize()
This fixes the …
@350bba7a
11/05/20 08:56:16 |
Sebastian Huber |
sparc: Add SPARC_INTERRUPT_SOURCE_TO_TRAP()
Update #4171.
@82811477
11/05/20 08:50:36 |
Sebastian Huber |
sparc: Add SPARC_INTERRUPT_TRAP_TO_SOURCE()
Update #4171.
@b7271f8
11/05/20 08:32:09 |
Sebastian Huber |
sparc: Add SPARC_IS_INTERRUPT_TRAP()
Update #4171.
@2c467ec
11/05/20 08:23:52 |
Sebastian Huber |
sparc: Move SPARC-specific macros to sparc.h
Clarify Doxygen …
@da9cc0b
10/29/20 13:11:32 |
jan.sommer |
confdefs: Add extern C guards to libpci.h
@6823943
10/28/20 12:25:45 |
Sebastian Huber |
score: Fix unused parameter 'lock' warning
@daeb0a1
10/19/20 12:54:39 |
frank.kuehndel |
rtems-fdt / shell - Fix string truncation warning
The compiler …
@2b9fb314
10/19/20 14:31:51 |
Sebastian Huber |
posix: Fix pthread_spin_unlock()
Prevent a call to …
