@9b035a0a
06/07/17 05:11:23 |
Sebastian Huber |
network: Update <arpa/inet.h>
Update #2833.
5
@3bc19384
06/06/17 13:30:40 |
Sebastian Huber |
network: Move header files
Prevent accidental use of legacy network …
5
@d4ab0aef
06/06/17 09:14:21 |
Sebastian Huber |
network: Move RTEMS specifics
Move RTEMS specifics to …
5
@d7613f7a
05/22/17 10:36:55 |
Sebastian Huber |
network: Include <sys/uio.h> explicitly
Do not rely on indirect …
5
@643b820
06/06/17 09:11:49 |
Sebastian Huber |
Include missing <sys/param.h>
Some kernel-space header expect that …
5
@1e0cc86
06/06/17 09:09:19 |
Sebastian Huber |
rpc: Remove superfluous includes
Update #2833.
5
@787f51f
06/06/17 09:08:16 |
Sebastian Huber |
Do not include <sys/ioctl.h> in kernel-space
Update #2833.
5
@93531e9b
06/06/17 06:03:45 |
Sebastian Huber |
Move RTEMS-specific Termios API content
Remove obsolete support for …
5
@64ecfc1
06/06/17 06:03:07 |
Sebastian Huber |
Do not use deprecated <sys/termios.h>
Update #2833.
5
@81ea001
06/06/17 05:19:12 |
Sebastian Huber |
Test for POSIX headers from Newlib 20170522
Update #2833.
5
@d60bc7c8
05/22/17 10:34:27 |
Sebastian Huber |
Provide kernel space headers used by Newlib
Update #2833.
5
@eddb134
05/22/17 10:38:32 |
Sebastian Huber |
network: Do not use MSIZE
Do not use the MSIZE for the legacy network …
5
@cf54965
06/07/17 05:22:38 |
Sebastian Huber |
network: Include missing <inttypes.h>
Update #2833.
5
@7ec982bf
05/26/17 00:35:17 |
Chris Johns |
build-system: Fix the targets support for the parallel build.
5
@a748603
05/14/17 01:52:52 |
Chris Johns |
build-system: Parallel build all subdirs.
5
@8aa62776
05/23/17 23:21:04 |
Chris Johns |
cpukit/libxz: Fix the include path to remove the make warnings.
5
@d5c8756
05/23/17 08:03:56 |
Sebastian Huber |
arm: Fix profiling support of Thumb-1 targets
Update #2751.
5
@a330c5d
05/16/17 15:37:27 |
Gedare Bloom |
posix: clarify expression with parentheses
Close #3010.
5
@6bc63df1
05/12/17 07:53:35 |
Sebastian Huber |
confdefs.h: Add SMP enabled field to configuration
Do not use the …
5
@0b8084c2
05/16/17 07:47:08 |
Sebastian Huber |
confdefs.h: Fix compile error in non-SMP cfg
Bug introduced by …
5
@f778b7f3
05/12/17 06:35:36 |
Sebastian Huber |
confdefs.h: Use SMP scheduler only if necessary
Update #3001.
5
@13097181
05/11/17 09:03:00 |
Sebastian Huber |
confdefs.h: CONFIGURE_DISABLE_SMP_CONFIGURATION
Enable the SMP …
5
@87de70a2
03/15/17 18:31:00 |
Gedare Bloom |
posix/mman: add mmap support for shm objects
Update #2859.
5
@8290f95c
03/13/17 16:00:35 |
Chris Johns |
posix: Add mmap/unmap support for mapping files.
This version of mmap …
5
@bd9d5eb
03/31/17 19:23:47 |
Gedare Bloom |
posix/shm: replace threadq with mutex (allocator lock)
Closes #2957.
5
@889eb76
03/15/17 18:29:19 |
Gedare Bloom |
posix/mman: update atime on shared memory read call
Update #2859.
5
@e0627c69
05/02/17 08:19:34 |
Sebastian Huber |
cpukit: Fix RTEMS_REVISION define
5
@6234abe
03/08/17 11:59:07 |
javier.jalle |
leon, l4stat: Initial driver commit
5
@c241236
03/15/17 13:38:21 |
javier.jalle |
leon, memscrub: add GR740 memory scrubber driver
5
@d79429f
03/15/17 14:04:33 |
javier.jalle |
leon, griommu: add GR740 IOMMU driver
The driver is limited to the …
5
@dfa86338
02/21/17 08:14:46 |
javier.jalle |
leon, l2cache: add GR740 L2-Cache driver
5
@7075fb11
04/07/17 06:30:46 |
Daniel Hellstrom |
drvmgr: ability to configure IRQ affinity
5
@61788e76
01/31/17 09:13:41 |
javier.jalle |
leon, GR-CPCI-GR740: Added peripheral PCI driver
5
@6b42018e
05/02/17 06:06:12 |
Sebastian Huber |
shell: Fix format specifiers
5
@20775247
04/28/17 16:11:14 |
joel |
rtems/inttypes.h: Add PRIdrtems_vector_number. Missed in previous commit
5
@12f9c5b7
04/27/17 23:52:01 |
joel |
posix/src/mutexinit.c: Reorder to make priority a scoped variable
5
@c16d45a5
04/26/17 20:42:09 |
joel |
5
@9e6ef36
04/26/17 01:14:28 |
joel |
rtems/inttypes.h, block08: Add and use PRIdrtems_blkdev_bnum
5
@03e4be12
04/26/17 01:02:09 |
joel |
score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning
5
@65807379
04/26/17 01:01:41 |
joel |
score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning
5
@c723ee4
04/25/17 18:57:21 |
joel |
libdl/rtl-obj-cache.c: Fix printf() format warning
5
@6601684f
04/25/17 18:57:03 |
joel |
posix/src/mutexinit.c: Fix used before initialized warning
5
@f6bd41e
04/25/17 18:56:31 |
joel |
moxie/rtems/score/cpu.h: Fix printf() format warning
5
@fdfbb0a8
04/25/17 18:39:50 |
joel |
epiphany/rtems/score/cpu.h: Fix printf() format warning
5
@7db09923
04/25/17 16:42:18 |
joel |
rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number …
5
@28e5749e
04/25/17 16:41:35 |
joel |
epiphany/cpu.c: Fix typo to eliminate warning
5
@b261dec
04/24/17 17:00:43 |
joel |
xz/xz_config.h: Address unable to inline warning
5
@3144292b
04/24/17 16:18:47 |
joel |
libdl/rtl-obj-cache.c: Use PRIdoff_t to avoid printf() format warnings …
5
@a300ca1b
04/24/17 01:35:41 |
joel |
ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and 64 …
5
@0c334a5
04/23/17 17:57:27 |
joel |
epiphany/cpu.c: Fix not a prototype warning
5
@473a3cd
04/23/17 17:53:44 |
joel |
rtems/inttypes.h: Add PRIdioctl_command_t
5
@438ca2f
04/22/17 19:15:22 |
joel |
rtems/inttypes.h: Add blksize_t and blkcnt_t
5
@7f95cc0
04/19/17 04:33:29 |
Chris Johns |
libdebugger: Fix the mode on task create. Clean up warnings.
Closes #2976.
5
@4fd25c4
04/18/17 02:44:44 |
Chris Johns |
libmisc/monitor: Correctly print unlimited configuration table …
5
@d420b67
04/14/17 20:18:56 |
joel |
Merge tmacros.h PRIxxx constants from testsuites/ into …
5
@54bdf0c
04/14/17 18:55:48 |
joel |
rtems/inttypes.h: New file. Uses contents from cpukit
Provide …
5
@b53ad46
04/14/17 07:12:44 |
Chris Johns |
libdebugger: Work around assert when using _Thread_Executing.
Using …
5
@62c238e
04/08/17 10:30:50 |
cpodonnell8 |
cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning.
5
@d2390ce4
04/10/17 13:41:02 |
kevin-kirspel |
Updating default termios initialization for dedicated input/output …
5
@2c23639
04/07/17 20:40:11 |
cpodonnell8 |
libdl/rtl-obj-cache.c: Using inttypes macros fixes 4 format warnings
5
@c475924d
04/06/17 23:24:58 |
joel |
xz_config.h: Define XZ_USE_CRC64
close #2909.
5
@46f05b92
04/05/17 09:28:46 |
Sebastian Huber |
SMP: Simplify SMP multicast actions
5
@b3bfc242
04/04/17 08:39:45 |
Sebastian Huber |
sys/event.h: Update to FreeBSD head 2017-02-13
5
@1301468
04/03/17 10:51:51 |
Sebastian Huber |
bsps: Fix baud settings
Update #2897.
5
@36f0ac2
03/30/17 11:59:16 |
Sebastian Huber |
configure: Remove defunct configure stuff
5
@bba48d9
03/30/17 00:06:24 |
Chris Johns |
libdl: Support link ordered loading of ELF sections.
The ARM C++ …
5
@cd3d747
03/27/17 06:01:38 |
Sebastian Huber |
arm: Optimize context switch
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to …
5
@82c0836
03/28/17 05:51:16 |
Sebastian Huber |
posix: Fix pthread_detach() internal lock acquire
5
@70ddaa0e
03/28/17 06:18:06 |
Sebastian Huber |
rtems: Fix error return path
5
@5f382713
03/27/17 12:23:52 |
Sebastian Huber |
cpukit: Fix Makefile.am and update preinstall.am
Update #2897.
5
@94a4865
03/27/17 08:30:23 |
Sebastian Huber |
termios: Avoid invalid memory access
Update #2897.
5
@1c6926c1
03/21/17 19:39:48 |
kevin-kirspel |
termios: Synchronize with latest FreeBSD headers
Adding modified …
5
@d50ab079
03/16/17 14:12:20 |
Sebastian Huber |
dosfs: Fix file name search
Do not use our long file name entry count …
5
@dfd879fa
03/16/17 10:59:23 |
Sebastian Huber |
dosfs: Fix race condition msdos_dir_read()
Obtain file system …
5
@6c988987
03/16/17 07:03:42 |
Sebastian Huber |
dosfs: Rename fat_entries to lfn_entries
The name "fat_entries" for …
5
@5f8ed0d
03/16/17 06:44:38 |
Sebastian Huber |
dosfs: Fix long file name padding
Update #2934.
5
@e625a57
03/16/17 06:37:20 |
Sebastian Huber |
dosfs: msdos_filename_utf8_to_short_name_for_save
Simplify.
5
@b1daf0f
03/14/17 10:41:18 |
Sebastian Huber |
dosfs: Fix msdos_add_file()
Make sure that long file names work …
5
@1a9483e2
03/14/17 09:28:19 |
Sebastian Huber |
dosfs: Simplify msdos_add_file()
Update #2929.
5
@3efe749
03/14/17 08:36:07 |
Sebastian Huber |
dosfs: Add and use msdos_lfn_checksum()
Update #2929.
5
@063eb574
03/14/17 07:26:40 |
Sebastian Huber |
dosfs: Simplify fat_file_open()
Update #2929.
5
@ccd4a7f
03/14/17 07:13:07 |
Sebastian Huber |
dosfs: Simplify msdos_creat_node()
Update #2929.
5
@e69ee36
03/13/17 14:20:20 |
Sebastian Huber |
dosfs: Fix fat_file_write()
Remove forced overwrite which leads to …
5
@1becaa9
03/14/17 12:59:09 |
Sebastian Huber |
dosfs: Fix msdos_utf8_normalize_and_fold()
It is all right in case …
5
@66fac03
03/16/17 10:54:29 |
Sebastian Huber |
libio: Fix deadlock in location management
Perform a …
5
@b437a360
03/09/17 13:32:04 |
Sebastian Huber |
arm: Fix CPU context validation for Cortex-R4
Do not touch the …
5
@2433a8ab
03/07/17 13:32:42 |
Sebastian Huber |
arm: Remove legacy execption support
5
@36338fb
03/07/17 12:41:37 |
Sebastian Huber |
monitor: Do not zero sema id and name
5
@088acbb0
03/07/17 12:07:02 |
Sebastian Huber |
score: Fix scheduler yield in SMP configurations
Check that no ask …
5
@f61195b2
03/06/17 10:16:25 |
Sebastian Huber |
powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE
5
@84557ef
02/06/17 14:11:55 |
cederman |
libdrvmgr: remove braces
5
@418149c8
02/01/17 09:48:38 |
Daniel Hellstrom |
libdrvmgr: added default BSP init level hook
5
@91df5a69
01/02/15 12:17:18 |
Daniel Hellstrom |
libpci: code cleanup
5
@1f618ab0
03/02/17 06:54:52 |
Sebastian Huber |
posix_devctl: Fix for pre C99
Use restrict just like in <devctl.h> …
5
@a60db69
02/27/17 10:50:30 |
Sebastian Huber |
dosfs: Fix FAT32 formatter
The second FAT entry contains a bit to …
5
@267de79a
02/27/17 09:40:49 |
Sebastian Huber |
dosfs: Directories should have a file size of 0
Close #2755.
5
@f71ccc34
02/28/17 08:12:13 |
Sebastian Huber |
termios: Simplify some calculations
Use the modular arithmetic …
5
@36635433
02/24/17 13:44:04 |
Sebastian Huber |
termios: Implement non-blocking write
5
@a165a96
02/23/17 14:43:41 |
Sebastian Huber |
termios: Make write POSIX compatible
Currently only blocking …
5
@c41b47e3
02/23/17 14:19:47 |
Sebastian Huber |
termios: Introduce doTransmit()
5
