@79a998d
11/16/17 13:08:20 |
Sebastian Huber |
rtems: rtems_semaphore_flush() with prio inherit
The …
5
@888da71
11/16/17 06:17:05 |
Sebastian Huber |
score: Check thread resource count in timer server
The watchdog …
5
@d4b99ae3
11/15/17 12:21:01 |
Sebastian Huber |
libio: Add assert to rtems_libio_iop_drop()
This assert helps to …
5
@631f711
11/14/17 00:57:55 |
Chris Johns |
build: Fix the dependence for the generating the key file.
Update #3217.
5
@cb40687
11/10/17 07:39:23 |
Sebastian Huber |
Change RTEMS_API from 5.0 to 5
This fixes the legacy Makefile based …
5
@f5b3c024
11/12/17 14:39:53 |
martinerikwerner |
Fix bashism in vc-key.sh
Change "==" to "=", since "==" for …
5
@e6df806
11/08/17 02:27:25 |
Chris Johns |
tests: Use ld to map (wrap) printf, puts and putchar to tester …
5
@bcd0c06c
11/07/17 21:25:36 |
Chris Johns |
tests: Use rtems_test_begin and rtems_test_end.
Add a tests enum and …
5
@6f3fb8a
11/07/17 05:43:11 |
Chris Johns |
cpukit: Add a Version API.
Provide functions to get the version …
5
@b225aa1
11/09/17 12:39:03 |
Sebastian Huber |
Reject incompatible tool chains
Update #3185.
5
@5f02a57
10/24/17 09:17:54 |
Sebastian Huber |
score: Change _Timecounter_Time_uptime to int32_t
Move basic …
5
@4a147518
10/17/17 11:44:22 |
Sebastian Huber |
Upgrade to 5.0.0
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
5
@64ba1a96
11/08/17 14:29:14 |
Sebastian Huber |
posix: Change created_with_explicit_scheduler
Remove …
5
@7147dc4
11/08/17 13:37:35 |
Sebastian Huber |
posix: Remove POSIX_API_Control::schedpolicy
Use the thread CPU …
5
@791469bd
11/06/17 13:49:32 |
Sebastian Huber |
termios: Fix canonical mode
In canonical mode, input is made …
5
@fb272963
11/02/17 20:01:06 |
Sebastian Huber |
score: Use Processor_mask instead of cpu_set_t
5
@0c286e3
10/25/17 14:00:17 |
Sebastian Huber |
score: _Chain_Insert_ordered_unprotected()
Change the chain order …
5
@bceb9db6
11/02/17 16:01:57 |
Sebastian Huber |
score: Remove superfluous include
Update #3059.
5
@ac28f15
11/03/17 07:33:16 |
Sebastian Huber |
Add simple console driver
Update #3170.
Update #3199.
5
@1082798
10/23/17 11:30:44 |
Sebastian Huber |
score: Add _IO_Printf() and _IO_Vprintf()
The previous vprintk() …
5
@3e81d52
10/29/17 19:29:05 |
Sebastian Huber |
posix: Use far future for very long timeouts
Close #3205.
5
@11ff3a9
10/27/17 04:18:40 |
Hesham Almatary |
cpukit: RISC-V - make riscv32 code work for riscv64 - v2
* Use …
5
@9db3cc21
10/29/17 06:38:37 |
Sebastian Huber |
score: Fix non-SMP build
5
@7bec7f27
10/26/17 11:59:06 |
Sebastian Huber |
rtems: Add rtems_print_printer_fprintf_putc()
Update #3170.
Update #3199.
5
@f703e7f
10/26/17 11:59:05 |
Sebastian Huber |
tests: Move rtems_test_printer definition
Statically initialize it to …
5
@cf614ec
10/28/17 11:33:17 |
Sebastian Huber |
riscv32: Add missing preinstall.am
Update #3109.
5
@8744498
10/27/17 07:04:53 |
Sebastian Huber |
score: Fix _Scheduler_Set_affinity()
5
@1d572eba
10/27/17 07:03:55 |
Sebastian Huber |
posix: Fix pthread_create() with user stack
In case the user provides …
5
@4edcede7
10/27/17 07:03:31 |
Sebastian Huber |
score: Simplify SMP get lowest scheduled
There is no need to pass in …
5
@660db8c8
10/26/17 23:12:41 |
Hesham Almatary |
cpukit: Add basic riscv32 architecture port v3
Limitations:
* NO FPU …
5
@f47dc8d
10/20/17 06:05:17 |
Hesham Almatary |
cpukit: librpc - add riscv* to xdr_float.c v3
5
@a5273ab
10/20/17 06:04:08 |
Hesham Almatary |
Add riscv32 to autotools files v3
5
@8388ceea
10/24/17 04:31:03 |
Sebastian Huber |
score: Delete _Scheduler_Thread_set_priority()
5
@0ddffb76
10/24/17 08:31:05 |
Sebastian Huber |
confdefs: CONFIGURE_MICROSECONDS_PER_TICK
Reject non-positive …
5
@34799c3b
10/24/17 07:35:06 |
Sebastian Huber |
rtems: rtems_clock_get_ticks_per_second()
Add macro implementation …
5
@c3105894
10/19/17 11:47:57 |
Sebastian Huber |
score: Move thread queue timeout handling
Update #3117.
Update #3182.
5
@1666ffe5
10/19/17 12:17:31 |
Sebastian Huber |
score: Rename function threadq support function
Rename …
5
@6de1f92
10/19/17 11:41:25 |
Sebastian Huber |
score: Add _Thread_Continue()
Update #3117.
Update #3182.
5
@5747962
10/20/17 05:29:22 |
Sebastian Huber |
score: _Watchdog_Per_CPU_lazy_insert_monotonic()
Update #3117.
Update …
5
@b13ec80
10/20/17 13:23:49 |
Sebastian Huber |
score: Add _Watchdog_Monotonic_from_timespec()
Update #3117.
Update #3182.
5
@cea5ff7
10/20/17 13:35:14 |
Sebastian Huber |
score: Add _Watchdog_Nanoseconds_per_tick
Move it from the …
5
@7ed377b
10/20/17 06:43:15 |
Sebastian Huber |
score: _Watchdog_Is_far_future_monotonic_timespec
Update #3117. …
5
@d16d07f
10/20/17 06:42:55 |
Sebastian Huber |
score: Add _Watchdog_Is_valid_interval_timespec()
Update #3117. …
5
@adaf5c23
10/19/17 11:38:48 |
Sebastian Huber |
score: _Watchdog_Is_far_future_realtime_timespec()
Update #3117. …
5
@ecef3698
10/17/17 14:19:03 |
Sebastian Huber |
score: Rename _Watchdog_Ticks_from_*()
Rename …
5
@381ef5c
10/20/17 06:33:03 |
Sebastian Huber |
confdefs: Warn about problematic ticks per second
A non-integer clock …
5
@e0dc6efc
10/20/17 13:41:29 |
Sebastian Huber |
rtems: Simplify RTEMS_MILLISECONDS_TO_MICROSECONDS
Remove the cast so …
5
@27cfe7c
10/20/17 06:31:36 |
Sebastian Huber |
score: Add _Watchdog_Ticks_per_second
This value is frequently used. …
5
@02878626
10/17/17 14:15:31 |
Sebastian Huber |
score: Add _Thread_Add_timeout_ticks()
Replace …
5
@a0d09107
10/20/17 14:53:04 |
Sebastian Huber |
posix: Do not touch msg priority in case of error
5
@eeb8d83
10/23/17 05:12:57 |
Sebastian Huber |
posix: Fix POSIX disabled build
Update #2514.
5
@6d6f6a20
10/21/17 07:42:30 |
Sebastian Huber |
score: Fix warning
5
@dbb30e26
10/18/17 07:17:32 |
Sebastian Huber |
Update #2514.
5
@37eb717
10/17/17 09:46:54 |
Sebastian Huber |
posix: Simplify _POSIX_Threads_Create_extension()
Move unblocked …
5
@3f3f4248
10/17/17 07:20:20 |
Sebastian Huber |
posix: Remove POSIX_API_Control::schedparam
Move sporadic server …
5
@2be22d4
10/17/17 06:38:47 |
Sebastian Huber |
posix: Move POSIX_API_Control::thread
This member is only used by the …
5
@2fcea4c
10/17/17 08:06:08 |
Sebastian Huber |
posix: Fix _POSIX_Threads_Create_extension()
The thread POSIX API …
5
@91ce012c
10/16/17 07:32:37 |
Sebastian Huber |
score: Rename _Watchdog_Per_CPU_insert_monotonic()
Rename …
5
@bf2a53d2
10/14/17 13:14:53 |
Sebastian Huber |
score: Rename watchdog variants
Rename PER_CPU_WATCHDOG_RELATIVE in …
5
@addeb53a
10/11/17 23:36:42 |
Chris Johns |
doxygen: Set the Latex generation default to NO.
Closes #3130.
5
@6c99abd
10/12/17 09:42:45 |
Sebastian Huber |
score: Remove unused function declaration
5
@16db540a
10/12/17 05:23:51 |
Sebastian Huber |
Use right time format in _times()
Update #2740.
Close #3179.
5
@58500540
10/12/17 05:18:28 |
Sebastian Huber |
posix: Fix const qualifier warning
Update #2514.
Update #3179.
5
@9c0cefb
10/11/17 05:46:41 |
Sebastian Huber |
confdefs: Add warnings for obsolete options
Update #2674.
Close …
5
@d8b6f1c
10/11/17 14:19:28 |
Sebastian Huber |
timecounter: Update FreeBSD identifiers
Update #3175.
5
@bcbbe76
10/11/17 11:03:11 |
kib |
timecounter: Merge FreeBSD change r324528
The th_bintime, …
5
@5167d0e
03/14/17 22:02:02 |
vangyzen |
timecounter: Merge FreeBSD change r315287
Add missing pieces of …
5
@952b42b6
03/14/17 19:06:44 |
vangyzen |
timecounter: Merge FreeBSD change r315280
When the RTC is adjusted, …
5
@a9219e7
12/14/16 12:56:58 |
ed |
timecounter: Merge FreeBSD change r310053
Add labels to sysctls …
5
@74887157
08/17/16 09:52:09 |
kib |
timecounter: Merge FreeBSD change r304285
Implement userspace …
5
@c382cc83
07/30/16 09:25:57 |
kib |
timecounter: Merge FreeBSD change r303548
Cache getbintime(9) answer …
5
@b48aeaf
07/27/16 11:49:41 |
kib |
timecounter: Merge FreeBSD change r303387
Prevent parallel …
5
@464fd5d
07/27/16 11:33:33 |
kib |
timecounter: Merge FreeBSD change r303384
Style.
Sponsored by: The …
5
@6d3c125
07/27/16 11:27:52 |
kib |
timecounter: Merge FreeBSD change r303383
Reduce number of timehands …
5
@d310aa7
07/27/16 11:08:59 |
kib |
timecounter: Merge FreeBSD change r303382
Hide the boottime and …
5
@f6c94601
05/03/16 15:14:17 |
pfg |
timecounter: Merge FreeBSD change r298981
sys/sys: minor spelling …
5
@65f2cd7a
04/29/16 22:15:33 |
pfg |
timecounter: Merge FreeBSD change r298819
sys/kern: spelling fixes in …
5
@4cd742e
11/02/15 03:14:37 |
ngie |
timecounter: Merge FreeBSD change r290257
Define fhard in …
5
@f013c14
09/25/15 13:03:57 |
kib |
timecounter: Merge FreeBSD change r288216
Use per-cpu values for base …
5
@2b6d00f
08/13/15 14:43:25 |
ian |
Constify the pointers to …
5
@f1463c8
08/12/15 20:50:20 |
ian |
timecounter: Merge FreeBSD change r286701
If a specific timecounter …
5
@7494681
08/07/15 23:31:31 |
ian |
timecounter: Merge FreeBSD change r286429
Only process the PPS event …
5
@ec349b58
08/07/15 21:14:19 |
ian |
timecounter: Merge FreeBSD change r286423
RFC 2783 requires a status …
5
@0163063
07/08/15 18:42:08 |
kib |
timecounter: Merge FreeBSD change r285286
Reimplement the ordering …
5
@4d0ade9
06/11/15 04:41:54 |
kib |
timecounter: Merge FreeBSD change r284256
Tweaks for r284178:
Do not …
5
@51304dde
05/04/15 17:59:39 |
ian |
timecounter: Merge FreeBSD change r282424
Implement a mechanism for …
5
@0aef6fb
03/14/15 23:16:12 |
ian |
timecounter: Merge FreeBSD change r280012
Use sbuf_printf() for …
5
@ea0b339
03/07/15 18:23:32 |
hselasky |
timecounter: Merge FreeBSD change r279728
Add mutex support to the …
5
@ed9a6fd
10/11/17 19:33:44 |
Sebastian Huber |
posix: Use right time format in adjtime()
Update #2740.
5
@dfa9a2e7
10/12/17 02:37:10 |
joel |
xz/README: Correct URL
Closes #2829.
5
@157c767
10/11/17 05:53:38 |
Sebastian Huber |
posix: Include missing <limits.h>
5
@b2dbb634
10/10/17 09:36:23 |
Sebastian Huber |
score: Remove CPU_set_Control
Use Processor_mask instead.
Update #2514.
5
@a3ad4af
10/10/17 09:22:21 |
Sebastian Huber |
posix: Validate affinity sets by the scheduler
Update #2514.
5
@db3a3de
10/10/17 08:03:48 |
Sebastian Huber |
score: Add _Thread_queue_Dispatch_disable()
5
@bd5be58f
10/10/17 05:18:09 |
Sebastian Huber |
posix: Unconditional thread attribute support
Update #2514.
5
@4f9ed26
10/10/17 05:13:37 |
Sebastian Huber |
posix: Constify default thread processor affinity
Set default thread …
5
@8c5267a
10/10/17 05:11:29 |
Sebastian Huber |
posix: Simplify pthread_attr_setstack()
Simplify
5
@da9f5f1
10/09/17 13:34:26 |
Sebastian Huber |
posix: Remove rtems_pthread_attribute_compare()
Update #2514.
Close #3174.
5
@af9115f3
10/06/17 08:07:38 |
Sebastian Huber |
posix: Simplify POSIX_API_Control
Return stack area via …
5
@65012bf
10/06/17 13:41:46 |
Sebastian Huber |
score: Change Timestamp_Control to sbintime_t
The timestamp are based …
5
