Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @2e77151   09/10/18 04:31:53 Sebastian Huber mghttpd: Add configuration to source file Update #3375. 5
(edit) @06060da   09/10/18 04:29:11 Sebastian Huber pppd: Simplify Makefile.am Update #3375. 5
(edit) @e069f7fe   09/10/18 04:27:10 Sebastian Huber rpc: Use configuration header file Update #3375. 5
(edit) @f004b2b8   10/02/18 08:22:15 Sebastian Huber Use rtems_task_exit() Update #3530. Update #3533. 5
(edit) @e50e3f70   10/01/18 07:25:06 Sebastian Huber rtems: Add rtems_task_exit() Update #3533. 5
(edit) @57a7ecde   10/01/18 06:20:11 Sebastian Huber telnetd: Remove CEXP convenience routines Close #3535. 5
(edit) @a346ebba   09/26/18 07:04:43 Sebastian Huber telnetd: Remove CONFIGURE_MAXIMUM_PTYS Add a … 5
(edit) @2da93bcb   09/26/18 07:18:12 Sebastian Huber telnetd: Regroup includes 5
(edit) @8e075540   09/26/18 07:17:55 Sebastian Huber telnetd: Remove dead code 5
(edit) @0413b14   09/26/18 07:06:43 Sebastian Huber telnetd: Remove superfluous global variable Update #3528. 5
(edit) @b980f363   09/25/18 13:07:35 Sebastian Huber telnetd: Convert pty driver to new Termios API Update #3526. 5
(edit) @ac9f8087   09/25/18 13:19:08 Sebastian Huber pppd: Remove unused get_pty() function Update #3526. 5
(edit) @c56721c   09/27/18 05:21:27 Sebastian Huber printer: Fix Doxygen comments 5
(edit) @7d1acc03   09/24/18 07:15:10 Sebastian Huber stackchk: Fix interrupt stack preparation We have to prepare the … 5
(edit) @4221d93   09/20/18 06:47:44 Sebastian Huber stackchk: Improve support for interrupt stacks Prepare the interrupt … 5
(edit) @a75a7d3   09/21/18 05:30:44 Sebastian Huber stackchk: Remove heap hack It is now guranteed that threads do not … 5
(edit) @56e61e24   09/20/18 05:57:08 Sebastian Huber Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL The configured … 5
(edit) @227b145   08/31/18 06:56:08 Daniel Hellstrom sparc: clang AS does no accept UNIMP without argument 5
(edit) @1c34a9b   12/19/17 12:36:33 cederman sparc: Remove sequence that could trigger B2BST errata 5
(edit) @e20da8b   12/12/17 10:19:46 cederman sparc: Return to previous section type when done with .data._SPARC_Counter 5
(edit) @776464a   09/19/18 09:52:47 Sebastian Huber score: Allocate per-CPU data only if necessary The … 5
(edit) @68f339b6   09/17/18 09:53:10 Sebastian Huber Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE The RTEMS configuration … 5
(edit) @5fa0a1f6   09/17/18 08:35:45 Sebastian Huber config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE RTEMS had the … 5
(edit) @bd5cec41   09/17/18 08:31:29 Sebastian Huber config: Remove CONFIGURE_HAS_OWN_FILESYSTEM_TABLE This configuration … 5
(edit) @fe283f6c   09/14/18 11:20:05 Sebastian Huber powerpc: Fix _CPU_Counter_read() for MPC860 The mpc860 is a … 5
(edit) @aaa6653   09/13/18 09:33:11 Sebastian Huber score: Fix PER_CPU_DATA_ITEM_DECLARE() Fix … 5
(edit) @1fe1b820   09/10/18 09:47:24 Sebastian Huber score: Fix PER_CPU_DATA_GET_BY_OFFSET() Add uniprocessor version for … 5
(edit) @e58f1cd3   09/05/18 05:27:24 Sebastian Huber Add more dummy values to <sys/priority.h> Update #3472. 5
(edit) @7097962   08/29/18 07:43:44 Sebastian Huber score: Add thread pin/unpin support Add support to temporarily pin a … 5
(edit) @d8bc0730   09/07/18 09:27:45 Sebastian Huber score: Modify _Scheduler_Unblock() In SMP configurations, obtain the … 5
(edit) @cfc4231d   08/27/18 08:36:35 Sebastian Huber score: Add flexible per-CPU data Update #3507. 5
(edit) @77d374f5   09/07/18 05:12:06 Sebastian Huber cpukit/Makefile.am: Cleanup 5
(edit) @cb68253   09/07/18 04:19:02 Sebastian Huber network: Use kernel/user space header files Add and use … 5
(edit) @43fb904e   09/07/18 05:06:05 Sebastian Huber network: Remove man page installation The man page installation is … 5
(edit) @eae4d147   09/07/18 04:24:00 Sebastian Huber network: Remove unused files 5
(edit) @d9296d24   09/07/18 04:39:50 Sebastian Huber Move <poll.h> to set of default header files The <poll.h> is a POSIX … 5
(edit) @ea0a680   09/10/18 08:36:41 Sebastian Huber score: Debug aid for _Chain_Extract_unprotected() Ensure that a chain … 5
(edit) @2d1c3dff   09/07/18 05:33:47 Sebastian Huber nfsclient: Fix unused variable warning 5
(edit) @e0a9336b   09/03/18 06:12:35 Sebastian Huber score: Fix EDF SMP scheduler Fix a special case: block a one-to-one … 5
(edit) @3aad9d9b   09/03/18 07:31:19 Sebastian Huber score: Generalize SMP scheduler block support Add extract from … 5
(edit) @9b5b864   08/29/18 17:42:10 joel rtems/score/epiphany-utility.h: Fix not a prototype warning 5
(edit) @bc696482   08/29/18 17:41:35 joel score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype 5
(edit) @14a218f   08/21/18 15:32:48 joel cpukit/telnetd/pty.c: Fix format overflow warning on sprintf() … 5
(edit) @9e8bba5   08/29/18 05:53:02 Sebastian Huber score: Remove redundant #ifdef RTEMS_SMP 5
(edit) @6d70a11   08/27/18 05:33:29 Sebastian Huber Include <stdbool.h> in <machine/_kernel_types.h> The FreeBSD kernel … 5
(edit) @27c89d7   08/08/18 09:52:09 Sebastian Huber Add FreeBSD kernel space header files Move the kernel space content … 5
(edit) @0d51b6d8   06/28/18 12:39:37 Daniel Hellstrom capture: prevent unaligned access when reading time LLVM warns about … 5
(edit) @59a0541c   07/12/18 07:15:55 cederman sparc: Restore npc when returning from the syscall_lazy_fp_switch trap … 5
(edit) @6695d02   08/23/18 12:39:33 Sebastian Huber Update FreeBSD kernel timespec support This change is based on the … 5
(edit) @ba0e9631   08/10/18 05:34:03 Sebastian Huber score: Do not inline _Thread_Dispatch_enable() This function is … 5
(edit) @a36aa86   08/23/18 12:32:07 Sebastian Huber Add dummy PI_SOFT to <sys/priority.h> Update #3472. 5
(edit) @d14f934   08/10/18 05:22:43 Sebastian Huber score: Fix ISR enable in _Thread_Dispatch_enable() This bug had … 5
(edit) @dcaea71   08/15/18 10:26:13 christian.mauderer dev/sc16is752: Add name space for field names. The field names for … 5
(edit) @bc731313   08/13/18 10:55:34 amaan.cheval bsps/x86_64: Add APIC timer based clock driver The APIC timer is … 5
(edit) @6869321   08/13/18 10:50:38 amaan.cheval bsps/x86_64: Add support for RTEMS interrupts Updates #2898. 5
(edit) @4544749e   08/13/18 10:33:12 amaan.cheval bsps/x86_64: Add paging support with 1GiB super pages Updates #2898. 5
(edit) @ab971bf5   08/13/18 10:21:47 amaan.cheval bsps/x86_64: Reorganize header files and compile-options Updates #2898. 5
(edit) @b2de426   08/06/18 09:53:42 Sebastian Huber score: Fix _Addresses_Subtract() Use architecture-specific integer … 5
(edit) @66cb142   08/06/18 08:51:00 Sebastian Huber rtems: Parameter types in rtems_partition_create() Use uintptr_t to … 5
(edit) @b8eae140   08/10/18 05:11:56 Sebastian Huber Add dummy PRI_MIN_KERN to <sys/priority.h> Update #3472. 5
(edit) @aac36d15   08/08/18 09:17:36 Sebastian Huber posix: Add configure check for mprotect() Update #3491. 5
(edit) @71948f76   08/08/18 05:52:18 Sebastian Huber sys/event.h: Update version FreeBSD tag Update #3472. 5
(edit) @ac824ff   07/18/18 13:04:03 dab Make the definition of struct kevent in event.h match what the man … 5
(edit) @96b32773   07/11/18 02:09:11 dab Address some (although not all) style(9) issues in event.h after … 5
(edit) @1d00acb1   06/28/18 20:37:17 dab Fix compilation error in r335765 under gcc 4.2.1. The anonymous … 5
(edit) @b37ef68   06/28/18 17:01:04 dab Remove potential identifier conflict in the EV_SET macro. PR43905 … 5
(edit) @bf026dd4   11/27/17 15:01:59 pfg sys/sys: further adoption of SPDX licensing ID tags. Mainly focus on … 5
(edit) @57c03363   11/25/17 04:49:12 jhb Decode kevent structures logged via ktrace(2) in kdump. - Add a new … 5
(edit) @e9b708a   06/17/17 00:57:26 kib Add abstime kqueue(2) timers and expand struct kevent members. This … 5
(edit) @f51aec8   04/08/17 04:34:18 pkelsey Fix typo. hist -> hint MFC after: 3 days 5
(edit) @fd27bae   08/07/18 04:25:47 Sebastian Huber CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE Make … 5
(edit) @0b038bd4   08/04/18 08:38:48 Sebastian Huber libblock: Add RTEMS_DEPRECATED Close #3358. 5
(edit) @ab96aec   08/04/18 08:56:46 Sebastian Huber dosfs: Avoid deprecated routine Update #3358. 5
(edit) @698093d   08/03/18 20:39:42 Sebastian Huber libblock: Use rtems_blkdev_create_partition() Update #3358. 5
(edit) @0fe7133   07/31/18 14:01:17 Sebastian Huber flashdisk: Use rtems_blkdev_create() Update #3358. 5
(edit) @16f3f10   07/31/18 13:54:29 Sebastian Huber nvdisk: Use rtems_blkdev_create() Update #3358. 5
(edit) @24b94c4   07/30/18 04:39:09 Sebastian Huber ramdisk: Use rtems_blkdev_create() Update #3358. 5
(edit) @d56e68b   08/04/18 12:27:38 Sebastian Huber rfs: Remove erroneous call of rtems_disk_release() The function … 5
(edit) @42f9963d   08/03/18 05:58:07 Sebastian Huber score: Remove superfluous semicolon This avoids warnings like this: … 5
(edit) @83ca9f0a   08/02/18 12:52:12 Sebastian Huber rtems: Relax partition buffer area alignment The partition buffer … 5
(edit) @27bbc05   08/02/18 12:49:01 Sebastian Huber score: Remove CPU_PARTITION_ALIGNMENT Use the CPU_SIZEOF_POINTER … 5
(edit) @28b8cf9b   08/02/18 07:41:08 Sebastian Huber riscv: Fix CPU_ALIGNMENT Update #3433. 5
(edit) @334e1d2   07/30/18 05:35:26 Sebastian Huber confdefs: Fix uniprocessor configuration Introduce a new internal … 5
(edit) @cfc9573   07/27/18 12:47:17 Sebastian Huber riscv: Rework CPU counter support Update #3433. 5
(edit) @6b9ef09   07/20/18 08:57:59 Sebastian Huber riscv: Add CLINT and PLIC support The CLINT and PLIC need some … 5
(edit) @c2670de   07/20/18 07:07:40 Sebastian Huber riscv: Use wfi instruction for idle task Update #3433. 5
(edit) @8db3f0e   07/19/18 10:11:19 Sebastian Huber riscv: Rework exception handling Remove … 5
(edit) @5694b0c   07/19/18 08:15:53 Sebastian Huber riscv: New CPU_Exception_frame Use the CPU_Interrupt_frame for the … 5
(edit) @d779a1e2   07/19/18 07:35:54 Sebastian Huber riscv: Add exception codes Update #3433. 5
(edit) @5677883   07/24/18 07:09:06 Sebastian Huber score: _SMP_Inter_processor_interrupt_handler() Optimize … 5
(edit) @a1f7d7d   07/24/18 07:00:18 Sebastian Huber score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE() Add … 5
(edit) @406dd62   07/24/18 09:18:27 Sebastian Huber _SMP_Start_multitasking_on_secondary_processor() Pass current … 5
(edit) @0d362ff3   07/23/18 12:54:51 Sebastian Huber score: _SMP_Inter_processor_interrupt_handler() Pass current … 5
(edit) @f8d00a3   07/25/18 06:00:22 Sebastian Huber tm27: Fix prototype warnings 5
(edit) @05259de1   07/25/18 07:54:56 Sebastian Huber powerpc: Fix _CPU_Instruction_illegal() Apparently the .word … 5
(edit) @3a646426   07/19/18 10:53:34 Sebastian Huber score: Add _CPU_Instruction_illegal() On some … 5
(edit) @b74353e   07/20/18 06:06:46 Sebastian Huber score: Add _CPU_Instruction_no_operation() This helps to reduce the … 5
(edit) @42f2fdfd   07/20/18 05:56:43 Sebastian Huber score: Move context validation declarations The context validation … 5
(edit) @248ca7a   07/20/18 07:10:29 Sebastian Huber score: Remove obsolete CPU port defines 5
(edit) @1554a8c5   07/20/18 06:47:25 Sebastian Huber dtc: Update VERSION 5
