@b2b7b58e
04/02/19 11:02:47 |
andreas.dachsberger |
doxygen: Added Management to Example CPU Architecture
Update #3706.
5
@493c1e8
04/01/19 07:14:14 |
doxygen: score: Put ARM Co-Processor 15 group in ARM
Update #3706.
5
@95c76030
03/27/19 10:17:16 |
doxygen: score: Add x86-64 CPU architecture group
Update #3706.
5
@9f8af67
03/27/19 10:11:54 |
doxygen: score: Add V850 CPU architecture group
Update #3706.
5
@2a50f87
03/27/19 09:59:35 |
doxygen: score: Add SPARC64 CPU architecture group
Update #3706.
5
@25afa79
03/27/19 09:50:44 |
doxygen: score: Add SPARC CPU architecture group
Update #3706.
5
@2b37eca5
03/27/19 09:46:08 |
doxygen: score: Add SuperH CPU architecture group
Update #3706.
5
@71f9098
03/27/19 09:38:56 |
doxygen: score: Add RISC-V CPU architecture group
Update #3706.
5
@6ddbcbc
03/26/19 10:48:20 |
doxygen: score: Add powerpc CPU architecture group
Update #3706.
5
@39594416
03/26/19 10:40:41 |
doxygen: score: Add or1k CPU architecture group
Update #3706.
5
@92c2db64
03/26/19 10:33:40 |
doxygen: score: Add nios2 CPU architecture group
Update #3706.
5
@f2e282d
03/26/19 10:25:44 |
doxygen: score: Add Moxie CPU architecture group
Update #3706.
5
@0be1e54
03/26/19 09:44:58 |
doxygen: score: Add m68k CPU architecture group
Update #3706.
5
@ee38c54
03/26/19 09:22:26 |
doxygen: score: Change no_cpu architecture group
Groups CPUContext …
5
@9fa3561b
03/26/19 08:50:42 |
doxygen: score: Add lm32 CPU architecture group
Update #3706.
5
@d670ef9
03/26/19 08:02:04 |
doxygen: score: Add i386 CPU architecture group
Update #3706.
5
@40b90a08
03/26/19 07:15:29 |
doxygen: score: Add Epiphany CPU architecture group
Update #3706.
5
@eca13a8f
03/25/19 14:19:41 |
doxygen: score: Add Blackfin CPU architecture group
Update #3706.
5
@abec398
03/25/19 09:42:52 |
Sebastian Huber |
score: Add ARM CPU architecture group
Update #3706.
5
@5a19915
03/25/19 09:33:05 |
Sebastian Huber |
score: Add example CPU architecture group
Update #3706.
5
@5526527e
03/25/19 09:45:25 |
Sebastian Huber |
score: Rename ScoreCPU Doxygen group
Update #3706.
5
@3fe2155
02/01/19 09:00:36 |
Sebastian Huber |
Remove superfluous <rtems/system.h> includes
5
@12075ac3
03/14/19 10:09:09 |
Sebastian Huber |
sparc64: Do not include <rtems/asm.h> in C source
5
@c10e8b6
03/08/19 22:38:46 |
joel |
coremsgseize.c: Fix spelling error
5
@b1ac3a5
03/01/19 18:21:52 |
Jonathan Brandmeyer |
cpukit/arm: Correct register definition
The register definition for …
5
@03b2163
03/01/19 09:10:19 |
Sebastian Huber |
score: Fix _Scheduler_EDF_Cancel_job()
Remove the priority node only …
5
@feea03b6
02/27/19 09:53:30 |
Sebastian Huber |
Remove explicit file names from @file
This makes the @file …
5
@7abc497
02/21/19 22:13:58 |
nyphbl8d |
bsps/arm: Fix system register for virtual timer
The system register …
5
@e4ad14cc
02/12/19 11:19:38 |
Sebastian Huber |
score: Avoid some deadlocks in _Once()
Recursive usage of the same …
5
@4408603
01/09/19 11:14:11 |
Chris Johns |
libdl: Fix the support for constructors and desctructors.
- Fix the …
5
@fbd08066
02/07/19 06:46:38 |
Sebastian Huber |
score: Fix plain priority thread queues (SMP)
We must add/remove the …
5
@9399473c
02/02/19 10:03:13 |
Sebastian Huber |
riscv: Fix misaligned access in context validate
5
@f0ae613b
01/17/19 06:33:08 |
Sebastian Huber |
m68k: Avoid _Addresses_Add_offset()
This prevents a cyclic dependency …
5
@d3d4e77
01/18/19 11:37:55 |
Jiri Gaisler |
riscv: add griscv bsp
Update #3678.
5
@9b2b389
01/18/19 17:00:47 |
Jiri Gaisler |
grlib: use cpu-independent routines for uncached access
Update #3678.
5
@b5bdecf
01/18/19 11:54:05 |
Sebastian Huber |
score: Avoid internal API and use ISR lock
5
@4596127
01/10/19 19:14:03 |
joel |
m68k/include/rtems/score/cpu.h: Add include of address.h
5
@b9ffc41c
01/08/19 08:50:50 |
Sebastian Huber |
riscv: Enable robust thread dispatch
It must be enabled, since the …
5
@3bd39999
01/08/19 08:53:26 |
Sebastian Huber |
Adjust interrupt mode tests for some CPU ports
In case the robust …
5
@38cb59e
01/08/19 07:36:31 |
Sebastian Huber |
Separate task mode checks
Update #3000.
5
@956d76cc
01/07/19 08:30:43 |
Sebastian Huber |
score: Remove superfluous include from chainimpl.h
5
@7c19e50
12/18/18 07:45:06 |
Sebastian Huber |
score: Fix per-CPU data allocation
Allocate the per-CPU data for …
5
@21275b58
11/22/18 18:14:51 |
Sebastian Huber |
score: Static Objects_Information initialization
Statically allocate …
5
@8b0e752f
12/10/18 12:44:53 |
Sebastian Huber |
score: Remove Objects_Information::auto_extend
Use …
5
@f70079c
11/25/18 19:26:02 |
Sebastian Huber |
score: Remove Objects_Information::the_api
Remove …
5
@1c2d178
11/25/18 19:15:26 |
Sebastian Huber |
score: Remove Objects_Information::maximum
This information is …
5
@3899bc1a
11/24/18 10:51:28 |
Sebastian Huber |
score: Optimize object lookup
Use the maximum ID for the ID to object …
5
@359a3a3
11/22/18 05:38:42 |
Sebastian Huber |
score: Rename Objects_Information::allocation_size
Rename …
5
@0da9d80
11/22/18 05:16:52 |
Sebastian Huber |
score: Rename Objects_Information::size
Rename …
5
@9c9c6a9
11/21/18 16:30:52 |
Sebastian Huber |
score: Remove Objects_Information::is_string
Use …
5
@d6e3473
11/23/18 19:37:57 |
Sebastian Huber |
score: Remove dead code
Update #3621.
5
@0a1f5df9
05/03/18 11:03:27 |
Sebastian Huber |
Simplify _CPU_Counter_difference()
In order to simplify the use of …
5
@0446f680
12/03/18 20:37:32 |
mcomajoancara |
Spelling and grammar fixes in source code comments (GCI 2018)
5
@5fc727f
11/26/18 07:25:36 |
Sebastian Huber |
score: <rtems/score/smplockstats.h>
Remove <rtems/score/chainimpl.h> …
5
@52c7cb1
11/21/18 16:30:22 |
Sebastian Huber |
score: Simplify _Workspace_String_duplicate()
5
@28bf4ca
11/14/18 06:00:59 |
Sebastian Huber |
or1k: Support GCC 9
Close #3602.
5
@4539e307
11/08/18 15:06:44 |
Sebastian Huber |
x86_64: Remove use of proc_ptr
Update #3585.
5
@70928bc9
11/09/18 07:12:49 |
Sebastian Huber |
sparc64: Remove use of proc_ptr
Update #3585.
5
@ce37237f
11/08/18 05:41:15 |
Sebastian Huber |
sparc: Remove use of proc_ptr
Update #3585.
5
@510fbfc3
11/08/18 14:31:03 |
Sebastian Huber |
sh: Remove use of proc_ptr
Update #3585.
5
@ed9da8e
11/09/18 06:56:48 |
Sebastian Huber |
powerpc: Remove use of proc_ptr
Update #3585.
5
@54c5ffc
11/08/18 14:05:22 |
Sebastian Huber |
or1k: Remove use of proc_ptr
Update #3585.
5
@12dfa5e2
11/08/18 15:03:10 |
Sebastian Huber |
nios2: Remove use of proc_ptr
Update #3585.
5
@264e128
11/09/18 07:04:23 |
Sebastian Huber |
moxie: Remove use of proc_ptr
Update #3585.
5
@b6be8f33
11/08/18 14:34:59 |
Sebastian Huber |
mips: Remove use of proc_ptr
Update #3585.
5
@5c6edee
11/08/18 14:44:56 |
Sebastian Huber |
m68k: Remove use of proc_ptr
Update #3585.
5
@0e16fa45
11/08/18 14:47:42 |
Sebastian Huber |
lm32: Remove use of proc_ptr
Update #3585.
5
@3c6a6e8
11/08/18 14:14:32 |
Sebastian Huber |
i386: Remove use of proc_ptr
Update #3585.
5
@a043ff8
11/08/18 14:33:47 |
Sebastian Huber |
epiphany: Remove use of proc_ptr
Update #3585.
5
@8203db45
11/09/18 06:59:57 |
Sebastian Huber |
bfin: Remove use of proc_ptr
Update #3585.
5
@685aa28
11/09/18 07:01:53 |
Sebastian Huber |
arm: Remove use of proc_ptr
Update #3585.
5
@d997aa1
11/09/18 06:54:31 |
Sebastian Huber |
no_cpu: Remove use of proc_ptr
Update #3585.
5
@ccc6695
11/08/18 10:50:24 |
Sebastian Huber |
score: Introduce <rtems/score/watchdogticks.h>
Separate the …
5
@0a9378af
11/12/18 12:09:36 |
Sebastian Huber |
x86_64: Remove duplicate _CPU_Thread_Idle_body()
5
@bfcf1473
11/08/18 15:21:48 |
Sebastian Huber |
m32c: Remove this target
Update #3599.
5
@947b679
11/08/18 15:46:17 |
Sebastian Huber |
h8300: Remove left over files
Update #2452.
5
@4fea054c
11/06/18 18:34:15 |
Sebastian Huber |
score: Remove _ISR_Dispatch()
This function was only used on some …
5
@ff081aee
11/06/18 15:58:02 |
Sebastian Huber |
score: Rename interrupt stack symbols
Rename
5
@878487b0
11/05/18 08:53:04 |
Sebastian Huber |
score: Optimize Objects_Information
Reduce structure internal …
5
@54f35888
10/25/18 08:54:12 |
Sebastian Huber |
posix: Provide threads by default
Update #2514.
5
@e97806a
10/14/18 17:20:05 |
Sebastian Huber |
posix: Split posix_api_configuration_table
Use separate configuration …
5
@7038271
10/25/18 10:05:53 |
Sebastian Huber |
Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES
Enable support for …
5
@5090a71b
10/25/18 09:32:01 |
Sebastian Huber |
score: Remove bogus thread object name support
Update #2514.
5
@2548d14
09/10/18 15:38:14 |
Sebastian Huber |
build: Include header.am in cpukit/Makefile.am
Include all …
5
@477bca2
10/06/18 08:59:10 |
Sebastian Huber |
build: Remove local.am
5
@637546a
10/05/18 18:12:40 |
Sebastian Huber |
build: Merge score/cpu/*/Makefile.am
5
@1d93843
09/14/18 18:02:02 |
Sebastian Huber |
build: Merge score/Makefile.am
5
@68e1ccc4
09/11/18 04:30:20 |
Sebastian Huber |
build: Remove specialized CPPFLAGS
5
@8776bb9
09/26/18 04:34:54 |
Sebastian Huber |
score: Remove CPU_PROVIDES_IDLE_THREAD_BODY
Remove the …
5
@242887bc
09/13/18 04:19:05 |
Sebastian Huber |
Rename files to make them unique within cpukit
This allows to build …
5
@f004b2b8
10/02/18 08:22:15 |
Sebastian Huber |
Use rtems_task_exit()
Update #3530.
Update #3533.
5
@56e61e24
09/20/18 05:57:08 |
Sebastian Huber |
Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
The configured …
5
@227b145
08/31/18 06:56:08 |
Daniel Hellstrom |
sparc: clang AS does no accept UNIMP without argument
5
@1c34a9b
12/19/17 12:36:33 |
cederman |
sparc: Remove sequence that could trigger B2BST errata
5
@e20da8b
12/12/17 10:19:46 |
cederman |
sparc: Return to previous section type when done with .data._SPARC_Counter
5
@776464a
09/19/18 09:52:47 |
Sebastian Huber |
score: Allocate per-CPU data only if necessary
The …
5
@fe283f6c
09/14/18 11:20:05 |
Sebastian Huber |
powerpc: Fix _CPU_Counter_read() for MPC860
The mpc860 is a …
5
@7097962
08/29/18 07:43:44 |
Sebastian Huber |
score: Add thread pin/unpin support
Add support to temporarily pin a …
5
@cfc4231d
08/27/18 08:36:35 |
Sebastian Huber |
score: Add flexible per-CPU data
Update #3507.
5
@e0a9336b
09/03/18 06:12:35 |
Sebastian Huber |
score: Fix EDF SMP scheduler
Fix a special case: block a one-to-one …
5
