Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/score/src
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @6c2b8a4b   11/29/17 05:23:27 Sebastian Huber score: Use self-contained API mutex Use a self-contained recursive … 5
(edit) @a7dcef97   11/17/17 05:36:54 Sebastian Huber score: Simplify global construction Update #3243. 5
(edit) @c597fb1   11/09/17 15:21:37 Sebastian Huber score: Optimize scheduler priority updates Thread priority changes … 5
(edit) @91a2d5e   11/10/17 15:21:18 Sebastian Huber score: Adjust _Scheduler_EDF_SMP_Insert_ready() Use only one … 5
(edit) @ec771f2   11/16/17 14:04:21 Sebastian Huber score: Fix priority ceiling updates We must not clear the priority … 5
(edit) @9c30c31e   11/16/17 13:38:07 Sebastian Huber score: Fix _Thread_queue_Flush_critical() The thread queue extract … 5
(edit) @5f02a57   10/24/17 09:17:54 Sebastian Huber score: Change _Timecounter_Time_uptime to int32_t Move basic … 5
(edit) @fb272963   11/02/17 20:01:06 Sebastian Huber score: Use Processor_mask instead of cpu_set_t 5
(edit) @0c286e3   10/25/17 14:00:17 Sebastian Huber score: _Chain_Insert_ordered_unprotected() Change the chain order … 5
(edit) @1082798   10/23/17 11:30:44 Sebastian Huber score: Add _IO_Printf() and _IO_Vprintf() The previous vprintk() … 5
(edit) @9db3cc21   10/29/17 06:38:37 Sebastian Huber score: Fix non-SMP build 5
(edit) @8744498   10/27/17 07:04:53 Sebastian Huber score: Fix _Scheduler_Set_affinity() 5
(edit) @4edcede7   10/27/17 07:03:31 Sebastian Huber score: Simplify SMP get lowest scheduled There is no need to pass in … 5
(edit) @c3105894   10/19/17 11:47:57 Sebastian Huber score: Move thread queue timeout handling Update #3117. Update #3182. 5
(edit) @1666ffe5   10/19/17 12:17:31 Sebastian Huber score: Rename function threadq support function Rename … 5
(edit) @6de1f92   10/19/17 11:41:25 Sebastian Huber score: Add _Thread_Continue() Update #3117. Update #3182. 5
(edit) @ecef3698   10/17/17 14:19:03 Sebastian Huber score: Rename _Watchdog_Ticks_from_*() Rename … 5
(edit) @02878626   10/17/17 14:15:31 Sebastian Huber score: Add _Thread_Add_timeout_ticks() Replace … 5
(edit) @6d6f6a20   10/21/17 07:42:30 Sebastian Huber score: Fix warning 5
(edit) @bf2a53d2   10/14/17 13:14:53 Sebastian Huber score: Rename watchdog variants Rename PER_CPU_WATCHDOG_RELATIVE in … 5
(edit) @d8b6f1c   10/11/17 14:19:28 Sebastian Huber timecounter: Update FreeBSD identifiers Update #3175. 5
(edit) @bcbbe76   10/11/17 11:03:11 kib timecounter: Merge FreeBSD change r324528 The th_bintime, … 5
(edit) @5167d0e   03/14/17 22:02:02 vangyzen timecounter: Merge FreeBSD change r315287 Add missing pieces of … 5
(edit) @952b42b6   03/14/17 19:06:44 vangyzen timecounter: Merge FreeBSD change r315280 When the RTC is adjusted, … 5
(edit) @a9219e7   12/14/16 12:56:58 ed timecounter: Merge FreeBSD change r310053 Add labels to sysctls … 5
(edit) @74887157   08/17/16 09:52:09 kib timecounter: Merge FreeBSD change r304285 Implement userspace … 5
(edit) @c382cc83   07/30/16 09:25:57 kib timecounter: Merge FreeBSD change r303548 Cache getbintime(9) answer … 5
(edit) @b48aeaf   07/27/16 11:49:41 kib timecounter: Merge FreeBSD change r303387 Prevent parallel … 5
(edit) @464fd5d   07/27/16 11:33:33 kib timecounter: Merge FreeBSD change r303384 Style. Sponsored by: The … 5
(edit) @6d3c125   07/27/16 11:27:52 kib timecounter: Merge FreeBSD change r303383 Reduce number of timehands … 5
(edit) @d310aa7   07/27/16 11:08:59 kib timecounter: Merge FreeBSD change r303382 Hide the boottime and … 5
(edit) @65f2cd7a   04/29/16 22:15:33 pfg timecounter: Merge FreeBSD change r298819 sys/kern: spelling fixes in … 5
(edit) @4cd742e   11/02/15 03:14:37 ngie timecounter: Merge FreeBSD change r290257 Define fhard in … 5
(edit) @f013c14   09/25/15 13:03:57 kib timecounter: Merge FreeBSD change r288216 Use per-cpu values for base … 5
(edit) @f1463c8   08/12/15 20:50:20 ian timecounter: Merge FreeBSD change r286701 If a specific timecounter … 5
(edit) @7494681   08/07/15 23:31:31 ian timecounter: Merge FreeBSD change r286429 Only process the PPS event … 5
(edit) @ec349b58   08/07/15 21:14:19 ian timecounter: Merge FreeBSD change r286423 RFC 2783 requires a status … 5
(edit) @0163063   07/08/15 18:42:08 kib timecounter: Merge FreeBSD change r285286 Reimplement the ordering … 5
(edit) @4d0ade9   06/11/15 04:41:54 kib timecounter: Merge FreeBSD change r284256 Tweaks for r284178: Do not … 5
(edit) @51304dde   05/04/15 17:59:39 ian timecounter: Merge FreeBSD change r282424 Implement a mechanism for … 5
(edit) @0aef6fb   03/14/15 23:16:12 ian timecounter: Merge FreeBSD change r280012 Use sbuf_printf() for … 5
(edit) @ea0b339   03/07/15 18:23:32 hselasky timecounter: Merge FreeBSD change r279728 Add mutex support to the … 5
(edit) @b2dbb634   10/10/17 09:36:23 Sebastian Huber score: Remove CPU_set_Control Use Processor_mask instead. Update #2514. 5
(edit) @a3ad4af   10/10/17 09:22:21 Sebastian Huber posix: Validate affinity sets by the scheduler Update #2514. 5
(edit) @db3a3de   10/10/17 08:03:48 Sebastian Huber score: Add _Thread_queue_Dispatch_disable() 5
(edit) @65012bf   10/06/17 13:41:46 Sebastian Huber score: Change Timestamp_Control to sbintime_t The timestamp are based … 5
(edit) @2256946   10/06/17 13:30:47 Sebastian Huber score: Use struct timespec for TOD Use the timestamps only for uptime … 5
(edit) @de59c065   09/27/17 13:08:33 Sebastian Huber posix: Implement self-contained POSIX mutex POSIX mutexes are now … 5
(edit) @89fc9345   09/21/17 13:42:45 Sebastian Huber posix: Implement self-contained POSIX rwlocks POSIX rwlocks are now … 5
(edit) @c090db7   09/12/17 06:09:16 Sebastian Huber posix: Implement self-contained POSIX semaphores For semaphore object … 5
(edit) @47b1e31   09/19/17 12:10:33 Sebastian Huber posix: Optimize pthread_once_t Reduce size of pthread_once_t and make … 5
(edit) @e2fe881a   09/27/17 12:37:07 Sebastian Huber score: Simplify red-black tree debug support Make the RBTree_Node … 5
(edit) @9a50e32   09/19/17 08:56:25 Sebastian Huber score: Include missing <limits.h> Update #2132. Close #3140. 5
(edit) @1f22b26   08/25/17 08:59:52 Sebastian Huber Include missing <limits.h> Update #2132. 5
(edit) @b2ed712   08/25/17 08:58:58 Sebastian Huber Include missing <string.h> Update #2133. 5
(edit) @279c540   08/10/17 12:21:37 Sebastian Huber score: Fix format specifier Update #3082. 5
(edit) @b2e1bded   07/18/17 12:53:16 Sebastian Huber score: Add optional _CPU_Context_Destroy() Update #3077. 5
(edit) @852d7059   07/17/17 07:15:04 Sebastian Huber score: Fix warning Update #3059. 5
(edit) @34487537   07/04/17 07:57:30 Sebastian Huber score: Add simple affinity support to EDF SMP Update #3059. 5
(edit) @197a614   07/05/17 13:14:26 Sebastian Huber score: Add scheduler node to set affinity op Update #3059. 5
(edit) @76d1198   07/07/17 05:45:57 Sebastian Huber score: Introduce _SMP_Get_online_processors() Update #3059. 5
(edit) @0232b28   07/04/17 06:59:37 Sebastian Huber score: Use processor mask for set affinity Update #3059. 5
(edit) @6b1d8c7   07/04/17 05:28:44 Sebastian Huber score: Add processor set to scheduler context Replace the simple … 5
(edit) @7851555   07/03/17 12:05:26 Sebastian Huber score: Move processor affinity to Thread_Control Update #3059. 5
(edit) @7a5e4d94   07/03/17 11:14:35 Sebastian Huber score: Add processor mask to/from cpu_set_t Update #3059. 5
(edit) @3dfe55ee   07/03/17 09:46:12 Sebastian Huber score: Use <sys/bitset.h> for Processor_mask Implement the … 5
(edit) @fab446f   07/05/17 06:10:11 Sebastian Huber score: Fix format 5
(edit) @4cd52cc4   07/05/17 06:08:24 Sebastian Huber score: Avoid clash with <strings.h> provided fls() 5
(edit) @550616e5   07/03/17 05:28:15 Sebastian Huber score: Add assert to _Thread_Dispatch() Update #3060. 5
(edit) @f3d9f228   06/26/17 08:35:45 Sebastian Huber score: Add SMP EDF scheduler Update #3056. 5
(edit) @15dbc710   06/29/17 07:44:16 Sebastian Huber score: Add red-black tree node to Scheduler_Node In SMP … 5
(edit) @3dd67dd1   06/14/17 05:29:14 Sebastian Huber score: Remove rtems_ada_self This task variable is superfluous since … 5
(edit) @836f454   06/07/17 06:14:30 Sebastian Huber Fix CPU_COPY() usage The original CPU_COPY() support of Newlib … 5
(edit) @46f05b92   04/05/17 09:28:46 Sebastian Huber SMP: Simplify SMP multicast actions 5
(edit) @088acbb0   03/07/17 12:07:02 Sebastian Huber score: Fix scheduler yield in SMP configurations Check that no ask … 5
(edit) @7a462cc   02/15/17 10:09:32 Sebastian Huber score: Fix warning 5
(edit) @6dbbafc6   02/14/17 07:42:48 Sebastian Huber score: Fix warning in _Thread_Set_name() 5
(edit) @bbfbfc8   02/03/17 07:57:18 Sebastian Huber score: Move _Thread_Scheduler_ask_for_help() Move … 5
(edit) @ca1e546e   02/02/17 15:24:05 Sebastian Huber score: Improve scheduler helping protocol Only register ask for help … 5
(edit) @e366f77   01/31/17 07:08:24 Sebastian Huber score: Add _Thread_queue_Object_name Add the special thread queue … 5
(edit) @70488f56   01/31/17 08:37:54 Sebastian Huber score: Fix _Thread_Initialize() 5
(edit) @6f6da82c   01/26/17 10:06:50 Sebastian Huber score: Fix user extensions order Use forward and reverse order for … 5
(edit) @27bfcd8   01/25/17 13:32:02 Sebastian Huber score: Delete _CPU_Context_Fp_start() Since the FP area pointer is … 5
(edit) @9fad437   01/13/17 10:33:28 Sebastian Huber configure: Remove HAVE_STRUCTTHREAD_QUEUE_QUEUE 5
(edit) @da6ad56   01/12/17 12:46:55 Sebastian Huber score: Add _Thread_Set_name() Add configuration option … 5
(edit) @7ced9d9b   01/12/17 08:25:56 Sebastian Huber score: Add and use _Thread_Get_name() Update #2858. 5
(edit) @2b72162   01/12/17 09:15:56 Sebastian Huber score: Add Thread_queue_Queue::name Update #2858. 5
(edit) @b8bcebe   01/12/17 07:28:57 Sebastian Huber score: Add and use _Objects_Name_to_string() Update #2858. 5
(edit) @7a4b2645   01/11/17 15:43:06 joel Remove obsolete RTEMS_HAVE_SYS_CPUSET_H 5
(edit) @3d35bc0   01/11/17 12:41:55 Sebastian Huber score: Improve SMP lock debug support The CPU index starts with zero. … 5
(edit) @9a448aab   12/23/16 15:02:07 Sebastian Huber score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER Add thread state bit … 5
(edit) @a7cfb4b   12/23/16 12:54:11 Sebastian Huber score: Relax <sys/lock.h> static assertions Only require that the … 5
(edit) @3a659b04   12/09/16 06:19:22 Sebastian Huber score: Introduce _Internal_error() 5
(edit) @b6606e8   12/08/16 15:41:30 Sebastian Huber score: Remove fatal is internal indicator The fatal is internal … 5
(edit) @5b6c290   12/01/16 19:42:48 Sebastian Huber score: Initialize thread queue context early Initialize thread queue … 5
(edit) @b3cb2c1   12/01/16 21:24:02 Sebastian Huber score: Fix debug thread queue context init On ARM Thumb we may have … 5
(edit) @c09db57   11/28/16 12:28:32 Sebastian Huber score: Fix thread queue context initialization Initialize the thread … 5
(edit) @620b23e   11/24/16 05:13:11 Sebastian Huber score: Optimize _Thread_queue_Enqueue() Move thread state for … 5
(edit) @4b5ff47   11/23/16 15:15:13 Sebastian Huber score: Fix interrupt profiling Callers of _Thread_Do_dispatch() must … 5
(edit) @c42be504   11/16/16 13:50:09 Sebastian Huber posix: Add self-contained pthread spinlock Turn pthread_spinlock_t … 5
