@ea4488ae
08/02/17 23:26:51 |
joel |
posix shm: Add oflag to Shm_Control
5
@bdc468a
09/22/17 06:22:11 |
Sebastian Huber |
posix: Allow PTHREAD_PROCESS_SHARED for rwlocks
Close #3153.
5
@c030edd
09/15/17 11:48:44 |
Sebastian Huber |
posix: Allow PTHREAD_PROCESS_SHARED for condvar
Close #3137.
5
@8230a329
09/15/17 11:24:51 |
Sebastian Huber |
posix: Allow PTHREAD_PROCESS_SHARED for barriers
Close #3126.
5
@3b47ce73
09/15/17 11:14:57 |
Sebastian Huber |
posix: Allow PTHREAD_PROCESS_SHARED for mutexes
Close #3125.
5
@baef823c
09/13/17 07:22:19 |
Sebastian Huber |
libio: Add hold/drop iop reference
Check iop reference count in …
5
@ca90c6c
09/13/17 12:00:50 |
Sebastian Huber |
libio: Add rtems_libio_iop_flags_initialize()
Update #3132.
5
@856ede4f
09/13/17 08:11:46 |
Sebastian Huber |
libio: Add iop set/clear flags
Update #3132.
5
@694e946d
09/06/17 05:31:48 |
Sebastian Huber |
libio: Remove special-case reference count
The top-level IO library …
5
@18b32d76
09/08/17 13:25:47 |
Sebastian Huber |
posix: Ignore pshared for semaphores
Since we have only one process, …
5
@62c912e
09/08/17 11:10:24 |
Sebastian Huber |
posix: Use mutex object itself for condvar
We should only use the …
5
@1f22b26
08/25/17 08:59:52 |
Sebastian Huber |
Include missing <limits.h>
Update #2132.
5
@b2ed712
08/25/17 08:58:58 |
Sebastian Huber |
Include missing <string.h>
Update #2133.
5
@c6d897e5
07/24/17 19:09:52 |
Gedare Bloom |
posix: fix warnings with mmap from heap/wkspace
Avoid void pointer …
5
@b264998
07/24/17 18:46:49 |
Gedare Bloom |
posix: replace mmap mappings lock with libio lock
Use the libio mutex …
5
@b965f461
07/20/17 05:25:55 |
Sebastian Huber |
posix: Use unprotected chain operations
Operarations are already …
5
@bb01a36
07/19/17 14:59:16 |
kevin-kirspel |
Fixed issue with searching mapped addresses
The loop that checks if …
5
@c6bb1c33
06/29/17 14:36:43 |
kevin-kirspel |
posix/mmap: Add support for file handler and MAP_ANON
Added a mmap …
5
@836f454
06/07/17 06:14:30 |
Sebastian Huber |
Fix CPU_COPY() usage
The original CPU_COPY() support of Newlib …
5
@a330c5d
05/16/17 15:37:27 |
Gedare Bloom |
posix: clarify expression with parentheses
Close #3010.
5
@87de70a2
03/15/17 18:31:00 |
Gedare Bloom |
posix/mman: add mmap support for shm objects
Update #2859.
5
@8290f95c
03/13/17 16:00:35 |
Chris Johns |
posix: Add mmap/unmap support for mapping files.
This version of mmap …
5
@bd9d5eb
03/31/17 19:23:47 |
Gedare Bloom |
posix/shm: replace threadq with mutex (allocator lock)
Closes #2957.
5
@889eb76
03/15/17 18:29:19 |
Gedare Bloom |
posix/mman: update atime on shared memory read call
Update #2859.
5
@12f9c5b7
04/27/17 23:52:01 |
joel |
posix/src/mutexinit.c: Reorder to make priority a scoped variable
5
@c16d45a5
04/26/17 20:42:09 |
joel |
5
@6601684f
04/25/17 18:57:03 |
joel |
posix/src/mutexinit.c: Fix used before initialized warning
5
@82c0836
03/28/17 05:51:16 |
Sebastian Huber |
posix: Fix pthread_detach() internal lock acquire
5
@e366f77
01/31/17 07:08:24 |
Sebastian Huber |
score: Add _Thread_queue_Object_name
Add the special thread queue …
5
@090bdc7e
01/25/17 10:45:49 |
Sebastian Huber |
posix: Fix use of uninitialized variable
Update #2859.
5
@ba776282
08/12/16 19:25:10 |
Gedare Bloom |
posix: shared memory support
Add POSIX shared memory manager (Shm). …
5
@2b442a8e
08/12/16 16:21:00 |
Gedare Bloom |
posix: fix typo in mmap arguments
5
@1ca8ee13
08/12/16 15:17:40 |
Gedare Bloom |
posix: add stub implementations for mman functions
5
@e7eeb38d
07/29/16 19:28:49 |
Gedare Bloom |
posix: move sys/mman.h to newlib and test it in psxhdrs
5
@4a03e752
01/13/17 08:45:59 |
Sebastian Huber |
configure: Remove SIZEOF_PTHREAD_SPINLOCK_T
5
@544b59bf
01/13/17 08:35:01 |
Sebastian Huber |
configure: Remove HAVE_SEMAPHORE_H support
5
@7c499279
01/12/17 08:26:08 |
Sebastian Huber |
posix: Add pthread_getname_np(), ...
Add pthread_getname_np() and …
5
@d063e7b3
01/11/17 07:42:04 |
Sebastian Huber |
score: Replace STATES_DELAYING
Replace STATES_DELAYING with …
5
@7a4b2645
01/11/17 15:43:06 |
joel |
Remove obsolete RTEMS_HAVE_SYS_CPUSET_H
5
@ef362818
12/06/16 03:06:40 |
joel |
Add support for posix_devctl()
5
@5aa0fa1
01/11/17 12:47:22 |
Sebastian Huber |
posix: Fix alarm() in SMP configurations
Avoid to change the CPU of …
5
@9a448aab
12/23/16 15:02:07 |
Sebastian Huber |
score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER
Add thread state bit …
5
@3a659b04
12/09/16 06:19:22 |
Sebastian Huber |
score: Introduce _Internal_error()
5
@0a81a58
12/09/16 05:51:44 |
Sebastian Huber |
Add INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@5b6c290
12/01/16 19:42:48 |
Sebastian Huber |
score: Initialize thread queue context early
Initialize thread queue …
5
@6cc83b32
12/02/16 11:40:32 |
Sebastian Huber |
posix: Fix typo
5
@aadd318
12/02/16 08:56:40 |
Sebastian Huber |
posix: Fix fall back spinlock implementation
Update #2674.
5
@c09db57
11/28/16 12:28:32 |
Sebastian Huber |
score: Fix thread queue context initialization
Initialize the thread …
5
@620b23e
11/24/16 05:13:11 |
Sebastian Huber |
score: Optimize _Thread_queue_Enqueue()
Move thread state for …
5
@d42cf33
11/23/16 14:12:28 |
Sebastian Huber |
posix: Fix typo
Update #2674.
5
@c42be504
11/16/16 13:50:09 |
Sebastian Huber |
posix: Add self-contained pthread spinlock
Turn pthread_spinlock_t …
5
@a4217c6
11/22/16 09:53:03 |
Sebastian Huber |
score: Rename _Thread_queue_Enqueue_critical()
Delete unused …
5
@125f248
11/16/16 15:39:43 |
Sebastian Huber |
score: Add thread queue enqueue callout
Replace the expected thread …
5
@d78d529
11/14/16 08:11:07 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_direct()
This function is useful …
5
@0e658d45
11/09/16 15:29:17 |
Sebastian Huber |
posix: Simplify cleanup push/pop
The POSIX cleanup list must be …
5
@8b18b8eb
11/04/16 09:53:16 |
Sebastian Huber |
posix: Fix _POSIX_RWLock_Manager_initialization()
Use right object class.
5
@2dd098a
10/31/16 07:33:11 |
Sebastian Huber |
score: Introduce Thread_Scheduler_control::home
Replace …
5
@bb9f09f
10/31/16 12:07:34 |
Sebastian Huber |
posix: Fix timer interval
Do not overwrite timer interval with …
5
@3e9f4c92
10/31/16 12:05:55 |
Sebastian Huber |
posix: Fix timeout handling in sigtimedwait()
Update #2798.
5
@8797c76
09/27/16 13:23:00 |
Sebastian Huber |
score: Unify CORE mutex seize/surrender
Use the …
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@15b5678d
08/01/16 09:03:16 |
Sebastian Huber |
score: Move thread wait node to scheduler node
Update #2556.
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@114e408
08/22/16 11:17:05 |
Sebastian Huber |
score: Simplify thread queue acquire/release
5
@db563698
09/08/16 06:08:53 |
Sebastian Huber |
score: Fix warning
5
@709594f0
08/01/16 20:54:18 |
Gedare Bloom |
posix: nanosleep: adjust elapsed time calculation
Use clock_gettime …
5
@aaaf9610
08/08/16 06:44:51 |
Sebastian Huber |
score: Add debug support to red-black trees
This helps to detect …
5
@2cb9b86e
08/08/16 06:30:17 |
Sebastian Huber |
posix: Fix for RTEMS_DEBUG
5
@3b3552bf
08/03/16 11:40:26 |
Sebastian Huber |
5
@842005e4
07/29/16 17:13:41 |
Gedare Bloom |
posix: nanosleep: optimize away a time conversion
updates #2732
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@dfa2cdb
07/27/16 07:09:01 |
Sebastian Huber |
posix: Fix error status
5
@39d97ab
07/26/16 18:13:36 |
Gedare Bloom |
cpukit: refactor nanosleep and use 64-bit timeout for threadq
* Fixes …
5
@e0f17fc
07/15/16 16:52:05 |
Gedare Bloom |
posix: fix clock_nanosleep and nanosleep clock use
Sleeping with …
5
@b5bfaaf9
06/23/16 20:55:38 |
Gedare Bloom |
posix: cond_timedwait remember and use clock from condattr
updates #2745
5
@127c20eb
06/23/16 20:10:39 |
Gedare Bloom |
posix: refactor cond wait support to defer abstime conversion
updates …
5
@6e98ea91
06/09/16 15:40:35 |
Gedare Bloom |
posix: add clock_nanosleep and tests
updates #2732
5
@f23d470
06/09/16 15:33:15 |
Gedare Bloom |
cpukit: Add and use Watchdog_Discipline.
Clock disciplines may be …
5
@059529e
07/21/16 08:15:02 |
Sebastian Huber |
score: Add debug support to chains
* double …
5
@3cdda03
07/21/16 10:02:17 |
Sebastian Huber |
posix: Fix double chain extract
5
@254dc82
06/24/16 09:22:03 |
Sebastian Huber |
score: Change Priority_Control to 64-bit
A 32-bit Priority_Control …
5
@51e008dd
06/23/16 09:49:22 |
Sebastian Huber |
posix: Fix pthread_create()
Do not access data of the executing …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@1a4eac50
06/15/16 14:31:33 |
Sebastian Huber |
posix: Generalize _POSIX_Priority_To_core()
Move POSIX API priority …
5
@5a32c48
06/14/16 13:57:54 |
Sebastian Huber |
posix: Make POSIX API aware of scheduler instances
5
@eec08ef
06/15/16 04:59:57 |
Sebastian Huber |
posix: Rework sporadic server scheduling policy
Instead of lowering …
5
@6bab009
06/14/16 15:23:03 |
Sebastian Huber |
posix: Delete POSIX_API_Control::schedparam
This field was redundant.
5
@4dc5450
06/14/16 15:21:53 |
Sebastian Huber |
posix: Delete POSIX_API_Control::schedpolicy
5
@4da078a8
06/14/16 15:01:52 |
Sebastian Huber |
posix: Delete POSIX_API_Control::ss_high_priority
This field was unused.
5
@2df7fcf
06/14/16 09:45:22 |
Sebastian Huber |
posix: _POSIX_Mutex_Default_attributes
Make …
5
@ce6e9ec2
06/14/16 04:50:38 |
Sebastian Huber |
posix: pthread_mutexattr_setprioceiling()
Accept all priority values …
5
@6131b84
03/09/16 21:15:37 |
joel |
Add pthread_condattr_getclock() and pthread_condattr_setclock()
5
@917884c
06/15/16 08:39:09 |
Sebastian Huber |
posix: Fix poradic server initial CPU budget
Update #2738.
5
@5d65d0dd
06/15/16 06:50:29 |
Sebastian Huber |
posix: Use _POSIX_Threads_Sporadic_timer_insert()
5
@d07f582
06/15/16 05:59:33 |
Sebastian Huber |
posix: Remove superfluous code
Remove double declarations, useless …
5
@6a631da
06/14/16 09:13:22 |
Sebastian Huber |
posix: sched_get_priority_max()
Enable for all configurations since …
5
@ea02782a
06/14/16 09:12:19 |
Sebastian Huber |
posix: sched_get_priority_min()
5
@0c34dbf3
06/13/16 13:22:47 |
Sebastian Huber |
posix: Add pthread_setschedprio()
Close #2734.
5
