Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @1ef9caa2   03/29/16 12:59:59 Daniel Hellstrom leon, grspw_pkt: support for reading tx/rx DMA queue * Add support … 5
(edit) @eb5a42f6   03/23/16 09:45:26 Daniel Hellstrom leon, grspw_pkt: fixed device/dma closing The user is now responsible … 5
(edit) @36c3fbbd   03/23/16 08:57:10 Daniel Hellstrom leon, grspw_pkt: coding style fixups 5
(edit) @9cb7e5d   03/22/16 15:41:51 Daniel Hellstrom leon, grspw_pkt: fixed and improved RX/TX wait 5
(edit) @57e1f4c3   03/22/16 15:07:51 Daniel Hellstrom leon, grspw_pkt: fixed error return path in dma_open 5
(edit) @ac7da5bc   03/22/16 14:51:13 Daniel Hellstrom leon, grspw_pkt: Manual handling of link status events Added … 5
(edit) @49cf776e   03/22/16 14:37:36 Daniel Hellstrom leon, grspw_pkt: added link_ctrl options Improved the link error … 5
(edit) @fad4324d   03/22/16 12:59:56 Daniel Hellstrom leon, grspw_pkt: added grspw_link_status_clr() to API 5
(edit) @c442647f   03/22/16 10:42:10 Daniel Hellstrom leon, grspw_pkt: code style clean-ups 5
(edit) @61cc024a   03/21/16 14:02:58 Daniel Hellstrom leon, gptimer: start/reset must take RS and IP into account 5
(edit) @b109add   03/21/16 12:50:27 Daniel Hellstrom leon: Fix ambapp_bus OCCAN device registeration order NOTE that this … 5
(edit) @6ecad1d   10/27/15 11:41:50 maberg leon, grspw_pkt: Preserve DMA address enable at start. The EN bit … 5
(edit) @a48bfc0f   10/20/15 09:25:06 maberg leon, grspw_pkt: Fixed txpkt flag for link error There was a mixup … 5
(edit) @3395ca99   06/30/15 13:00:51 maberg leon, grspw_pkt: Fixed parameter check in grspw_dma_open() 5
(edit) @4431f7d   04/13/15 07:01:54 Daniel Hellstrom leon, gr1553b: RT status words register declarations fix The fix does … 5
(edit) @d745297   01/02/15 12:18:33 Daniel Hellstrom leon, gr1553b: comment cleanup 5
(edit) @be66bbc1   01/02/15 12:16:10 Daniel Hellstrom leon, grspw: rxPktSize must set DMA RX max length 5
(edit) @c0dafd7b   03/02/17 15:53:45 Sebastian Huber bsp/qoriq: Use at most 2GiB of RAM 5
(edit) @d3f60af   03/02/17 14:25:34 Sebastian Huber bsp/qoriq: Adjust workspace according to FDT 5
(edit) @35136d3   03/02/17 14:20:52 Sebastian Huber bsp/qoriq: Use -O2 5
(edit) @62f16ad   03/02/17 14:20:19 Sebastian Huber bsp/qoriq: Enable linker garbage collection 5
(edit) @891b834f   03/02/17 14:17:35 Sebastian Huber bsp/qoriq: Do not overwrite configured baud 5
(edit) @805d7213   03/02/17 10:57:28 Sebastian Huber powerpc: Fix warnings 5
(edit) @09dab28d   03/02/17 10:54:58 Sebastian Huber powerpc: Fix interrupt thread dispatch Update #2751. 5
(edit) @08d85992   03/01/17 10:31:57 Sebastian Huber bsps/powerpc: Fix warnings 5
(edit) @3398602   02/21/17 14:25:03 Sebastian Huber Add rtems_interrupt_server_request_submit() This function may be used … 5
(edit) @11f0d52   02/22/17 08:01:40 Sebastian Huber bsp/xilinx-zynq: Add interrupt support to UART 5
(edit) @6b2fcc4   02/21/17 09:30:30 Sebastian Huber bsp/xilinx-zynq: Use new Termios device driver 5
(edit) @7318e7db   02/15/17 12:41:02 Sebastian Huber bsp/lpc24xx: Remove debug output 5
(edit) @6afeeda   02/15/17 12:39:02 Sebastian Huber bsps/powerpc: Fix warnings 5
(edit) @f6f764c1   02/15/17 12:28:02 Sebastian Huber bsps/powerpc: Fix warnings 5
(edit) @32292d5d   02/15/17 12:14:40 Sebastian Huber bsps/powerpc: Fix warning 5
(edit) @bc744618   02/15/17 11:57:56 Sebastian Huber bsps/sparc: Fix warnings 5
(edit) @444cb5c   02/15/17 10:12:40 Sebastian Huber bsps/arm: Fix prototype 5
(edit) @73f8d93   02/15/17 10:09:50 Sebastian Huber bsps/powerpc: Fix warnings 5
(edit) @180107e9   01/30/17 10:33:31 Christian.Mauderer bsps/arm: Fix Cortex-M DWT CPU counter. It is necessary to enable the … 5
(edit) @b43c2e8   01/24/17 14:40:31 kevin-kirspel Adding ARM VFP V2 support 5
(edit) @2711914f   01/23/17 07:06:41 Sebastian Huber Use <sys/endian.h> Update #2803. 5
(edit) @2f8f951b   01/23/17 13:51:27 kevin-kirspel bsp/lpc32xx: Fix interrupt controller suppport Enable/Disable? vector … 5
(edit) @7fbd72c   01/20/17 14:29:00 Sebastian Huber libchip: Really fix high capacity detection Update #2239. 5
(edit) @e8606d5b   01/20/17 13:21:29 Sebastian Huber bsp/beatnik: Remove superfluous check Close #2874. 5
(edit) @21267897   01/19/17 20:37:13 Gedare Bloom raspberrypi: fix math inside of sizeof Move the subtraction of 1 for … 5
(edit) @70e8abf   01/19/17 20:34:18 Gedare Bloom raspberrypi: use signed int for return variable Closes #2873. 5
(edit) @3f09d635   01/19/17 17:58:44 Gedare Bloom smdk2410: delete unused variables Closes #2868. 5
(edit) @e397122c   01/17/17 23:57:43 joel m68k/mcf5225x/*/mc525x5-testsuite.tcfg: Add cdtest 5
(edit) @900f9857   01/17/17 23:56:53 joel m68k/mcf52235/*/mc52235-testsuite.tcfg: Add cdtest 5
(edit) @96ba863   01/17/17 23:56:19 joel arm/lpc32xx/*/lpc32xx_mzx_stage_1-testsuite.tcfg: Add dl05 5
(edit) @79ec730   01/17/17 18:39:26 joel powerpc/mpc55xxevb/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @09f6666   01/17/17 14:06:12 joel m68k/mcf5225x/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @dd14b45   01/17/17 14:05:49 joel m68k/mrm332/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @ba61311e   01/17/17 14:05:39 joel m68k/mcf52235/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @ddb28127   01/17/17 14:04:54 joel arm/stm32f4/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @9c834d1   01/17/17 14:04:33 joel arm/lpc24xx/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @ed1dcd2   01/17/17 14:04:13 joel arm/lpc32xx/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @2414497f   01/17/17 14:03:56 joel arm/lpc176x/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @6c42040   01/17/17 14:03:31 joel arm/lm3s69xx/*.tcfg: Add fsjffs2gc01 to excluded tests 5
(edit) @1fcdd639   01/12/17 22:12:51 joel powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset 5
(edit) @2a583a00   01/16/17 12:13:36 Sebastian Huber atsam: Fix SC16IS752 documentation 5
(edit) @a1e4e3bf   01/12/17 15:36:26 Christian Spindeldreier GRETH: Interrupt Handler Uses Wrong Events closes #2796. 5
(edit) @48a7fa3   11/15/16 16:37:59 joel Remove texinfo format documentation. Replaced by Sphinx formatted … 5
(edit) @81af80e5   12/20/16 09:30:05 Sebastian Huber Rename *.s to *.S Consistently use *.S for assembler files. Close #2701. 5
(edit) @71f29c12   12/20/16 07:49:32 Sebastian Huber bsp/atsam: Use standard XDMA throughout 5
(edit) @4aba8d79   12/16/16 12:05:34 Sebastian Huber bsp/atsam: Use standard XDMA for QSPI support 5
(edit) @08f1d2f7   12/15/16 14:37:00 Sebastian Huber bsp/atsam: Add SC16IS752 support 5
(edit) @a5c56af   12/15/16 14:03:56 Sebastian Huber bsp/atsam: Move interrupt setup to PIO_Configure() 5
(edit) @a4936b5   12/15/16 13:55:45 Sebastian Huber bsp/atsam: System initialization for PIO IRQs 5
(edit) @8eb5fbb6   12/15/16 12:27:17 Sebastian Huber bsp/atsamv: Move XDMAD instance out of SPI driver Use system … 5
(edit) @d1c771c   12/15/16 08:56:12 Sebastian Huber bsp/atsam: Move XDMA IRQ handler to XDMA module The XDMA is shared by … 5
(edit) @cb59276   12/15/16 05:15:13 Sebastian Huber bsp/atsam: Use _Assert() instead of assert() 5
(edit) @fd12159   12/15/16 05:12:46 Sebastian Huber bsp/atsam: Use inline functions for XDMA access 5
(edit) @8dd83d3   12/14/16 10:52:01 Sebastian Huber bsp/atsam: Optimize SPI interrupt 5
(edit) @9686c614   12/14/16 10:42:28 Sebastian Huber bsp/atsam: Simplify SPI transfer status 5
(edit) @de7c171   12/14/16 08:41:30 Sebastian Huber bsp/atsam: Reduce context switches for SPI transf 5
(edit) @b52513b   12/14/16 07:32:02 Sebastian Huber bsp/atsam: Optimize SPI DMA transfer setup 5
(edit) @f104bd3   12/14/16 07:06:14 Sebastian Huber bsp/atsam: Simplify SPI DMA transfer setup 5
(edit) @49b6931   12/14/16 07:00:56 Sebastian Huber bsp/atsam: Simplify SPI DMA initialization 5
(edit) @d0452eb   12/14/16 06:46:18 Sebastian Huber bsp/atsam: Simplify SPI interrupt handler 5
(edit) @c78928f   12/14/16 06:44:34 Sebastian Huber bsp/atsam: Remove superfluous irq field 5
(edit) @9035630f   12/14/16 06:43:25 Sebastian Huber bsp/atsam: Remove duplicate SPI register field 5
(edit) @62e1e0ff   12/14/16 06:37:49 Sebastian Huber bsp/atsam: Simplify SPI initialization 5
(edit) @3afa95b   12/14/16 06:25:49 Sebastian Huber bsp/atsam: Hide details of SPI driver 5
(edit) @1505eca5   12/14/16 06:18:11 Sebastian Huber bsp/atsam: Align SPI API with PIO_Configure() 5
(edit) @5dd02e9   12/13/16 14:49:09 Sebastian Huber bsp/atsam: Avoid to power on/off the SPI module 5
(edit) @f74e2959   12/13/16 14:18:00 Sebastian Huber bsp/atsam: Speed up SPI DMA transfer start 5
(edit) @0396f60   12/13/16 13:28:57 Sebastian Huber bsp/atsam: Optimize transfer setup checks 5
(edit) @3417070d   12/13/16 13:28:32 Sebastian Huber bsp/atsam: No timeout for SPI DMA transfers 5
(edit) @c6eead1   12/07/16 06:20:38 Chris Johns libdl: Add C++ exception support to loaded modules. This has been … 5
(edit) @6a9282d   12/09/16 09:49:49 Sebastian Huber Rename is_internal to always_set_to_false Update #2825. 5
(edit) @b6606e8   12/08/16 15:41:30 Sebastian Huber score: Remove fatal is internal indicator The fatal is internal … 5
(edit) @28fda62   12/05/16 03:53:54 Chris Johns testsuite: Add test states to the testsuit configuration files. … 5
(edit) @f65dcc71   12/02/16 12:10:31 Sebastian Huber score: Fix ARM and PowerPC context initialization Update #2751. 5
(edit) @e629076   11/29/16 22:19:05 Chris Johns libdebugger: Build for ARM's without a CP15. 5
(edit) @de7b174e   11/15/16 18:19:39 joel Remove sparc/sis BSP. closes #2810. 5
(edit) @8fd465e   11/24/16 22:45:35 Chris Johns arm/zynq: Wait for the UART TX FIFO to empty on reset. 5
(edit) @6a1b9e4   11/22/16 09:13:27 Sebastian Huber sparc: Optimize _ISR_Handler() Use _Thread_Do_dispatch() instead of … 5
(edit) @9bf9068   11/25/16 18:21:44 martinerikwerner.aac or1k: Avoid multiple iterations over cache Previously, if the cache … 5
(edit) @a59dd5c   11/25/16 18:21:43 martinerikwerner.aac or1k: Remove secondary functions in cache manager Move the code of … 5
(edit) @3b4ddaf   11/25/16 18:21:42 martinerikwerner.aac or1k: Avoid excessive ISR toggle in cache manager Previously … 5
(edit) @4dcaa48   11/25/16 18:21:41 martinerikwerner.aac or1k: Indent & comment fix in cache.c * Fix indentation of variable … 5
(edit) @e639c026   11/25/16 18:21:40 martinerikwerner.aac or1k: Add functions for entire cache operations Add functions for … 5
