@b2ed712
08/25/17 08:58:58 |
Sebastian Huber |
Include missing <string.h>
Update #2133.
5
@695c9c50
08/10/17 09:37:30 |
Sebastian Huber |
bsp/qoriq: Add qoriq_e6500_64 variant
Update #3082.
5
@95a4b1f
08/02/17 13:48:03 |
Sebastian Huber |
bsp/qoriq: Enable > 2GiB memory
Update #3082.
5
@c693a3a
08/11/17 08:44:04 |
Sebastian Huber |
powerpc: PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE
In 64-bit mode, the …
5
@c8aeb76
08/02/17 12:36:32 |
Sebastian Huber |
bsp/qoriq: 64-bit MMU support
Update #3082.
5
@77c81016
08/10/17 12:14:26 |
Sebastian Huber |
bsp/qoriq: 64-bit support for interrupt controller
Update #3082.
5
@5f42a0e
08/02/17 07:16:10 |
Sebastian Huber |
bsp/qoriq: Enable 64-bit mode for exceptions
Update #3082.
5
@f14da45
08/01/17 06:42:45 |
Sebastian Huber |
bsp/qoriq: 64-bit support for spin table
Update #3082.
5
@0ae1916b
08/01/17 06:41:07 |
Sebastian Huber |
bsp/qoriq: Copy FDT later
We need a ready to use TOC section before …
5
@43cc2b4
08/10/17 09:39:43 |
Sebastian Huber |
bsp/qoriq: Add basic 64-bit support
Update #3082.
5
@c6994af
07/31/17 13:10:33 |
Sebastian Huber |
bsp/qoriq: Use LA to load an address
Add 64-bit support for LA.
5
@0e26c19a
08/01/17 13:35:16 |
Sebastian Huber |
bsps/powerpc: Add 64-bit CRT init/fini support
Update #3082.
5
@d50124d
08/01/17 09:54:25 |
Sebastian Huber |
bsps/powerpc: Rename ppc_exc_wrap_async_normal_end
Rename …
5
@50382788
07/31/17 13:25:12 |
Sebastian Huber |
bsps/powerpc: Add 64-bit SET_SELF_CPU_CONTROL
Update #3082.
5
@60d077f
08/10/17 09:38:46 |
Sebastian Huber |
bsps/powerpc: Add 64-bit linker sections
Update #3082.
5
@241d2f2
08/02/17 12:13:06 |
Sebastian Huber |
bsps: Fix integer types in bsp_fdt_copy()
Update #3082.
5
@d8012bbd
08/01/17 06:37:12 |
Sebastian Huber |
bsps: Add BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
5
@ec25c6ef
08/10/17 12:23:02 |
Sebastian Huber |
bsps: Fix integer to/from pointer
Update #3082.
5
@a6f84b27
08/01/17 08:57:46 |
Sebastian Huber |
powerpc: Add 64-bit context/interrupt support
Update #3082.
5
@7837728b
08/10/17 11:09:22 |
Sebastian Huber |
powerpc: 64-bit _CPU_Context_Initialize() support
Update #3082.
5
@5e1a831
08/22/17 09:37:41 |
Sebastian Huber |
libchip/serial: Fix integer types
Update #3082.
5
@b98e407
08/10/17 11:01:57 |
Sebastian Huber |
libchip/ata: Fix integer to/from pointer
Update #3082.
5
@ca9490c
08/04/17 12:46:17 |
Sebastian Huber |
bsp/imx: Fix UART interrupt
Update #3090.
5
@694c31f9
08/03/17 06:53:13 |
Sebastian Huber |
bsp/imx: New BSP
Update #3090.
5
@ffe7c0e
08/04/17 11:56:42 |
Sebastian Huber |
bsps/arm: Add ARMv7-AR Generic Timer clock driver
Update #3090.
5
@ef04443
08/04/17 11:51:42 |
Sebastian Huber |
bsps/arm: Add ARMv7-AR Generic Timer support
Update #3090.
5
@30be024a
08/03/17 12:48:04 |
Sebastian Huber |
Optional Clock_driver_support_shutdown_hardware()
Make …
5
@a8694035
08/01/17 09:43:57 |
Sebastian Huber |
bsps/powerpc: Add PPC_EXC_INTERRUPT_FRAME_SIZE
Use a specific define …
5
@23cb9af
08/01/17 09:38:32 |
Sebastian Huber |
Rename …
5
@b7be9439
07/31/17 12:14:46 |
Sebastian Huber |
bsps/powerpc: Do not set ouput format and arch
There is no need to …
5
@65ee42c
07/31/17 11:39:34 |
Sebastian Huber |
bsp/qoriq: Simplify fatal exceptions
Avoid use of small-data area, …
5
@2d0a805
07/31/17 11:35:21 |
Sebastian Huber |
bsps/powerpc: Fix format specifiers
5
@dd6992fd
07/28/17 19:15:36 |
joel |
Remove Edison BSP.
Intel has obsoleted this hardware and the BSP was …
5
@9cb874d
07/28/17 16:27:54 |
joel |
beagle/i2c/bbb-i2c.c: Eliminiate set but not used warning
5
@8966e8a
07/28/17 13:39:39 |
Sebastian Huber |
bsp/qoriq: Fix pre-processor expansion
Update #3082.
Update #3085.
5
@5d0fa047
07/28/17 13:03:47 |
Sebastian Huber |
bsp/t32mppc: Set PPC_PER_CPU_CONTROL_REGISTER
5
@585706a4
07/28/17 12:42:53 |
Sebastian Huber |
bsp/t32mppc: Add SMP support
5
@cd7991b8
07/28/17 11:50:12 |
Sebastian Huber |
bsps/powerpc: Fix warning
5
@9379c70
07/28/17 11:40:45 |
Sebastian Huber |
bsps/sparc64: Fix warning
5
@0684f35
07/28/17 11:10:19 |
Sebastian Huber |
bsp/i386: Fix warning
5
@fd3437c
07/28/17 11:06:55 |
Sebastian Huber |
bsp/gen5200: Fix warnings
5
@a9f5812
07/28/17 11:06:41 |
Sebastian Huber |
bsp/qoriq: Fix warning
5
@0db7c55
07/27/17 13:36:11 |
Sebastian Huber |
bsp/qoriq: New BSP names
Due to the FDT support we can now reduce the …
5
@b615e9b
07/27/17 13:16:36 |
Sebastian Huber |
bsp/qoriq: Simplify initialization
Do not flush/invalidate the …
5
@146adb1
07/17/17 05:30:46 |
Sebastian Huber |
sparc: Add lazy floating point switch
The SPARC ABI is a bit special …
5
@600d88d
07/19/17 07:07:17 |
Sebastian Huber |
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT
Add new fatal error …
5
@a400d06f
07/18/17 13:11:41 |
Sebastian Huber |
sparc: Rename SPARC_USE_SAFE_FP_SUPPORT
Rename …
5
@671efc50
07/19/17 12:06:06 |
Sebastian Huber |
bsp/leon2: Add at697f variant
5
@9f84bdb
07/19/17 12:05:24 |
Sebastian Huber |
bsp/leon2: Use hard-float by default
5
@7ed8ad0
07/19/17 13:54:16 |
Sebastian Huber |
bsps/sparc: Fix cache support
Fix infinite loop in …
5
@734444ce
07/19/17 12:29:41 |
Sebastian Huber |
libchip: Fix format warning
5
@dcc3ccc
07/19/17 12:26:19 |
Sebastian Huber |
bsps: Fix warning
Update #3071.
5
@4debaca6
07/14/17 12:12:07 |
cederman |
bsps/sparc: Add leon3 BSP variants
Rename NGMP to GR740 and add …
5
@2f8704b6
07/13/17 07:26:50 |
cederman |
sparc: Add assembly workaround for LEON3FT B2BST errata
This patch …
5
@e19da87a
07/12/17 08:55:59 |
Sebastian Huber |
bsps: Include missing header file
Update #3071.
5
@f6115d7c
07/11/17 10:51:19 |
1473996754 |
bsp/beagle: Add FDT support for Beaglebone Black
5
@af207fa9
07/11/17 09:54:30 |
Sebastian Huber |
Add interrupt vector set/get affinity
Close #3071.
5
@ccc87c8b
07/11/17 09:20:06 |
Sebastian Huber |
Add interrupt server move
Update #3071.
5
@d184140
07/11/17 07:08:15 |
Sebastian Huber |
Add interrupt server set affinity
Update #3071.
5
@a961e198
07/11/17 06:48:15 |
Sebastian Huber |
Add interrupt server suspend/resume
This mechanism can be used to …
5
@e7ee719f
07/11/17 06:25:09 |
Sebastian Huber |
Create one interrupt server per processor
This allows load balancing …
5
@c29eb085
07/11/17 12:15:47 |
Sebastian Huber |
bsps/sparc: Fix ambapp_int_set_affinity()
Update #3059.
5
@76d1198
07/07/17 05:45:57 |
Sebastian Huber |
score: Introduce _SMP_Get_online_processors()
Update #3059.
5
@3dfe55ee
07/03/17 09:46:12 |
Sebastian Huber |
score: Use <sys/bitset.h> for Processor_mask
Implement the …
5
@5bfeab95
06/23/17 09:51:14 |
Sebastian Huber |
Add rtems_interrupt_server_handler_iterate()
5
@ec230fc7
06/15/17 17:40:25 |
joel |
i386/shared/comm/i386-stub-glue.c: Fix duplicate const warning
5
@9177426
06/15/17 17:40:04 |
joel |
lpc176x/misc/restart.c: Fix duplicate const warning
5
@c6810c8
06/19/17 12:09:28 |
Sebastian Huber |
bsps: Improve interrupt vector enable/disable API
Change …
5
@b361cb6c
06/16/17 04:22:21 |
Sebastian Huber |
Close #3051.
5
@369372c3
06/15/17 11:35:20 |
1473996754 |
Fix beagle i2c file bbb-i2c.c comment issues
5
@8f550d2
06/14/17 14:53:44 |
1473996754 |
Add the i2c driver for Beaglebone Black
Update ticket #2891 and my …
5
@7741545b
06/05/17 12:49:49 |
1473996754 |
Remove beagle old i2c code
modify …
5
@fd10817
05/11/17 13:33:10 |
m09123874 |
Remove excessive locking from cache operations.
According to manual, …
5
@3f884b4
06/13/17 09:38:39 |
Sebastian Huber |
bsp: Fixes due to header file changes
Update #2833.
5
@0af8bb6
06/12/17 13:40:37 |
Sebastian Huber |
bsp: Include missing <sys/param.h>
Update #2833.
5
@74a13c8
06/12/17 13:30:13 |
Sebastian Huber |
bsp/beatnik: Fixes due to header file changes
Update #2833.
5
@7b0c74ff
06/09/17 13:42:36 |
Sebastian Huber |
i386: Support thread-local storage (TLS)
Update #2468.
5
@f256685
06/09/17 05:55:16 |
Sebastian Huber |
bsp/psim: Include missing <sys/param.h>
5
@6081ef3
06/09/17 05:54:45 |
Sebastian Huber |
if_fxp: Include missing <inttypes.h>
Fix format warnings.
5
@32b4a0c
06/09/17 05:25:02 |
Sebastian Huber |
Simplify TLS support in context switch
There is no need to save the …
5
@ce3ac00
06/06/17 13:41:48 |
Christian.Mauderer |
bsps/arm: Fix ARMv7-M interrupt suppport
Enable/disable vector …
5
@787f51f
06/06/17 09:08:16 |
Sebastian Huber |
Do not include <sys/ioctl.h> in kernel-space
Update #2833.
5
@93531e9b
06/06/17 06:03:45 |
Sebastian Huber |
Move RTEMS-specific Termios API content
Remove obsolete support for …
5
@cf54965
06/07/17 05:22:38 |
Sebastian Huber |
network: Include missing <inttypes.h>
Update #2833.
5
@3623c40
05/29/17 10:09:34 |
Sebastian Huber |
ada-tests/spatcb01: New test
Update #2289.
5
@7203b70
06/01/17 17:04:05 |
Sebastian Huber |
bsp/motorola_powerpc: Fix for Binutils 2.28+
There are mismatched …
5
@697a6ca
06/01/17 17:00:38 |
Sebastian Huber |
bsps/powerpc: Set output format in linker script
Set the proper …
5
@848007c
05/07/17 21:08:17 |
phamp |
Add support for IBM PowerPC 750 chip.
Closes #3015.
5
@afa5b89
05/23/17 09:34:45 |
Sebastian Huber |
ada: Remove task notepad support
Update #2493.
5
@783fbce
05/23/17 09:33:29 |
Sebastian Huber |
ada: Update due to Clock Manager API changes
Update #2676.
5
@9ff0f40
05/23/17 09:32:21 |
Sebastian Huber |
ada: Remove <rtems/debug.h> support
Update #2477.
5
@7ec982bf
05/26/17 00:35:17 |
Chris Johns |
build-system: Fix the targets support for the parallel build.
5
@ff781cc
05/25/17 05:10:11 |
Chris Johns |
m32c/m32csim: Exclude linpack from the tests.
Closes #3025.
5
@a748603
05/14/17 01:52:52 |
Chris Johns |
build-system: Parallel build all subdirs.
5
@9935c23
05/23/17 23:26:29 |
Chris Johns |
arm/tms570: Update preinstall.am after bootstrap.
5
@bc470d3c
10/31/16 10:01:39 |
jacob.hansen |
sparc: only define start if it is different from SYM(start)
The SYM …
5
@8639685
10/28/16 14:05:56 |
jacob.hansen |
sparc: Adjust assembly to improve compability with LLVM
- All …
5
@1ea73e2b
05/11/17 11:43:53 |
Daniel Hellstrom |
leon, grtc: SMP support by using spin-locks
5
@818f10bc
05/11/17 10:54:46 |
Daniel Hellstrom |
leon, grtc: updated overrun condition handling
The following …
5
@6fdded2c
05/10/17 10:39:23 |
Daniel Hellstrom |
leon, gr1553bm: SMP support by using spin-locks
5
