@a48bfc0f
10/20/15 09:25:06 |
maberg |
leon, grspw_pkt: Fixed txpkt flag for link error
There was a mixup …
5
@3395ca99
06/30/15 13:00:51 |
maberg |
leon, grspw_pkt: Fixed parameter check in grspw_dma_open()
5
@4431f7d
04/13/15 07:01:54 |
Daniel Hellstrom |
leon, gr1553b: RT status words register declarations fix
The fix does …
5
@d745297
01/02/15 12:18:33 |
Daniel Hellstrom |
leon, gr1553b: comment cleanup
5
@be66bbc1
01/02/15 12:16:10 |
Daniel Hellstrom |
leon, grspw: rxPktSize must set DMA RX max length
5
@c0dafd7b
03/02/17 15:53:45 |
Sebastian Huber |
bsp/qoriq: Use at most 2GiB of RAM
5
@d3f60af
03/02/17 14:25:34 |
Sebastian Huber |
bsp/qoriq: Adjust workspace according to FDT
5
@35136d3
03/02/17 14:20:52 |
Sebastian Huber |
bsp/qoriq: Use -O2
5
@62f16ad
03/02/17 14:20:19 |
Sebastian Huber |
bsp/qoriq: Enable linker garbage collection
5
@891b834f
03/02/17 14:17:35 |
Sebastian Huber |
bsp/qoriq: Do not overwrite configured baud
5
@08d85992
03/01/17 10:31:57 |
Sebastian Huber |
bsps/powerpc: Fix warnings
5
@3398602
02/21/17 14:25:03 |
Sebastian Huber |
Add rtems_interrupt_server_request_submit()
This function may be used …
5
@11f0d52
02/22/17 08:01:40 |
Sebastian Huber |
bsp/xilinx-zynq: Add interrupt support to UART
5
@6b2fcc4
02/21/17 09:30:30 |
Sebastian Huber |
bsp/xilinx-zynq: Use new Termios device driver
5
@7318e7db
02/15/17 12:41:02 |
Sebastian Huber |
bsp/lpc24xx: Remove debug output
5
@6afeeda
02/15/17 12:39:02 |
Sebastian Huber |
5
@f6f764c1
02/15/17 12:28:02 |
Sebastian Huber |
5
@bc744618
02/15/17 11:57:56 |
Sebastian Huber |
bsps/sparc: Fix warnings
5
@73f8d93
02/15/17 10:09:50 |
Sebastian Huber |
5
@180107e9
01/30/17 10:33:31 |
Christian.Mauderer |
bsps/arm: Fix Cortex-M DWT CPU counter.
It is necessary to enable the …
5
@b43c2e8
01/24/17 14:40:31 |
kevin-kirspel |
Adding ARM VFP V2 support
5
@2f8f951b
01/23/17 13:51:27 |
kevin-kirspel |
bsp/lpc32xx: Fix interrupt controller suppport
Enable/Disable? vector …
5
@e8606d5b
01/20/17 13:21:29 |
Sebastian Huber |
bsp/beatnik: Remove superfluous check
Close #2874.
5
@21267897
01/19/17 20:37:13 |
Gedare Bloom |
raspberrypi: fix math inside of sizeof
Move the subtraction of 1 for …
5
@70e8abf
01/19/17 20:34:18 |
Gedare Bloom |
raspberrypi: use signed int for return variable
Closes #2873.
5
@3f09d635
01/19/17 17:58:44 |
Gedare Bloom |
smdk2410: delete unused variables
Closes #2868.
5
@e397122c
01/17/17 23:57:43 |
joel |
m68k/mcf5225x/*/mc525x5-testsuite.tcfg: Add cdtest
5
@900f9857
01/17/17 23:56:53 |
joel |
m68k/mcf52235/*/mc52235-testsuite.tcfg: Add cdtest
5
@96ba863
01/17/17 23:56:19 |
joel |
arm/lpc32xx/*/lpc32xx_mzx_stage_1-testsuite.tcfg: Add dl05
5
@79ec730
01/17/17 18:39:26 |
joel |
powerpc/mpc55xxevb/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@09f6666
01/17/17 14:06:12 |
joel |
m68k/mcf5225x/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@dd14b45
01/17/17 14:05:49 |
joel |
m68k/mrm332/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@ba61311e
01/17/17 14:05:39 |
joel |
m68k/mcf52235/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@ddb28127
01/17/17 14:04:54 |
joel |
arm/stm32f4/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@9c834d1
01/17/17 14:04:33 |
joel |
arm/lpc24xx/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@ed1dcd2
01/17/17 14:04:13 |
joel |
arm/lpc32xx/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@2414497f
01/17/17 14:03:56 |
joel |
arm/lpc176x/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@6c42040
01/17/17 14:03:31 |
joel |
arm/lm3s69xx/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@1fcdd639
01/12/17 22:12:51 |
joel |
powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset
5
@2a583a00
01/16/17 12:13:36 |
Sebastian Huber |
atsam: Fix SC16IS752 documentation
5
@a1e4e3bf
01/12/17 15:36:26 |
Christian Spindeldreier |
GRETH: Interrupt Handler Uses Wrong Events
closes #2796.
5
@48a7fa3
11/15/16 16:37:59 |
joel |
Remove texinfo format documentation. Replaced by Sphinx formatted …
5
@81af80e5
12/20/16 09:30:05 |
Sebastian Huber |
Rename *.s to *.S
Consistently use *.S for assembler files.
Close #2701.
5
@71f29c12
12/20/16 07:49:32 |
Sebastian Huber |
bsp/atsam: Use standard XDMA throughout
5
@4aba8d79
12/16/16 12:05:34 |
Sebastian Huber |
bsp/atsam: Use standard XDMA for QSPI support
5
@08f1d2f7
12/15/16 14:37:00 |
Sebastian Huber |
bsp/atsam: Add SC16IS752 support
5
@a5c56af
12/15/16 14:03:56 |
Sebastian Huber |
bsp/atsam: Move interrupt setup to PIO_Configure()
5
@a4936b5
12/15/16 13:55:45 |
Sebastian Huber |
bsp/atsam: System initialization for PIO IRQs
5
@8eb5fbb6
12/15/16 12:27:17 |
Sebastian Huber |
bsp/atsamv: Move XDMAD instance out of SPI driver
Use system …
5
@d1c771c
12/15/16 08:56:12 |
Sebastian Huber |
bsp/atsam: Move XDMA IRQ handler to XDMA module
The XDMA is shared by …
5
@cb59276
12/15/16 05:15:13 |
Sebastian Huber |
bsp/atsam: Use _Assert() instead of assert()
5
@fd12159
12/15/16 05:12:46 |
Sebastian Huber |
bsp/atsam: Use inline functions for XDMA access
5
@8dd83d3
12/14/16 10:52:01 |
Sebastian Huber |
bsp/atsam: Optimize SPI interrupt
5
@9686c614
12/14/16 10:42:28 |
Sebastian Huber |
bsp/atsam: Simplify SPI transfer status
5
@de7c171
12/14/16 08:41:30 |
Sebastian Huber |
bsp/atsam: Reduce context switches for SPI transf
5
@b52513b
12/14/16 07:32:02 |
Sebastian Huber |
bsp/atsam: Optimize SPI DMA transfer setup
5
@f104bd3
12/14/16 07:06:14 |
Sebastian Huber |
bsp/atsam: Simplify SPI DMA transfer setup
5
@49b6931
12/14/16 07:00:56 |
Sebastian Huber |
bsp/atsam: Simplify SPI DMA initialization
5
@d0452eb
12/14/16 06:46:18 |
Sebastian Huber |
bsp/atsam: Simplify SPI interrupt handler
5
@c78928f
12/14/16 06:44:34 |
Sebastian Huber |
bsp/atsam: Remove superfluous irq field
5
@9035630f
12/14/16 06:43:25 |
Sebastian Huber |
bsp/atsam: Remove duplicate SPI register field
5
@62e1e0ff
12/14/16 06:37:49 |
Sebastian Huber |
bsp/atsam: Simplify SPI initialization
5
@3afa95b
12/14/16 06:25:49 |
Sebastian Huber |
bsp/atsam: Hide details of SPI driver
5
@1505eca5
12/14/16 06:18:11 |
Sebastian Huber |
bsp/atsam: Align SPI API with PIO_Configure()
5
@5dd02e9
12/13/16 14:49:09 |
Sebastian Huber |
bsp/atsam: Avoid to power on/off the SPI module
5
@f74e2959
12/13/16 14:18:00 |
Sebastian Huber |
bsp/atsam: Speed up SPI DMA transfer start
5
@0396f60
12/13/16 13:28:57 |
Sebastian Huber |
bsp/atsam: Optimize transfer setup checks
5
@3417070d
12/13/16 13:28:32 |
Sebastian Huber |
bsp/atsam: No timeout for SPI DMA transfers
5
@c6eead1
12/07/16 06:20:38 |
Chris Johns |
libdl: Add C++ exception support to loaded modules.
This has been …
5
@6a9282d
12/09/16 09:49:49 |
Sebastian Huber |
Rename is_internal to always_set_to_false
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@28fda62
12/05/16 03:53:54 |
Chris Johns |
testsuite: Add test states to the testsuit configuration files.
5
@e629076
11/29/16 22:19:05 |
Chris Johns |
libdebugger: Build for ARM's without a CP15.
5
@de7b174e
11/15/16 18:19:39 |
joel |
Remove sparc/sis BSP.
closes #2810.
5
@8fd465e
11/24/16 22:45:35 |
Chris Johns |
arm/zynq: Wait for the UART TX FIFO to empty on reset.
5
@6a1b9e4
11/22/16 09:13:27 |
Sebastian Huber |
sparc: Optimize _ISR_Handler()
Use _Thread_Do_dispatch() instead of …
5
@562b0a0
11/24/16 09:49:17 |
Sebastian Huber |
bsps/arm: Add Cortex-M DWT CPU counter
5
@31427276
11/23/16 06:47:00 |
Sebastian Huber |
bsp/lpc23xx_tli800: Disable tar01 test
Close #2824.
5
@c11ac2d5
11/14/16 13:42:56 |
Sebastian Huber |
sparc: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@d5e073c
11/11/16 13:37:51 |
Sebastian Huber |
score: Allow interrupts during thread dispatch
Use a …
5
@2599c8e
11/14/16 11:06:46 |
Sebastian Huber |
powerpc: Add up to date CPU_Interrupt_frame
Rename ppc_exc_min_frame …
5
@bf4fdb1
11/11/16 10:31:13 |
Sebastian Huber |
powerpc: Move legacy CPU_Interrupt_frame
The only remaining user of …
5
@c539a865
11/14/16 10:34:54 |
Sebastian Huber |
sparc: Move CPU_Interrupt_frame related defines
Move …
5
@427dcee
11/11/16 10:17:02 |
Sebastian Huber |
sparc: Rename CPU_Minimum_stack_frame
Rename SPARC-specific …
5
@d18560a
11/11/16 10:16:33 |
Sebastian Huber |
sparc64: Rename CPU_Minimum_stack_frame
Rename SPARC64-specific …
5
@8ef8a32
11/11/16 09:48:14 |
Sebastian Huber |
bsps/mips: Use <libcpu/isr_entries.h>
Avoid duplicate …
5
@04bd261
11/13/16 14:18:58 |
Sebastian Huber |
arm: Use TPIDRPRW for current per-CPU control
Use the previously …
5
@bb5d97f3
11/17/16 13:56:53 |
bsp/atsamv: Make size of nocache-memory configurable.
5
@38a1449
11/09/16 13:59:33 |
Sebastian Huber |
powerpc: Add _CPU_Get_current_per_CPU_control()
Add …
5
@1f5bee3
11/07/16 15:54:40 |
Sebastian Huber |
score: Add and use Thread_Control::is_idle
Update #2797.
5
@6cb234f
11/07/16 08:30:17 |
Sebastian Huber |
bsp/qoriq: Remove duplicate qoriq_gpio definition
Close #2800.
5
@11ae6f9
11/03/16 17:49:12 |
Tim Cussins |
virtex4, virtex5 bsp.h: Use BSP_INTERRUPT_STACK_SIZE not user space …
5
@0df50a6c
10/03/16 15:59:47 |
joel |
m68k/mrm332/make/custom/mrm332-testsuite.tcfg: Add dl05
5
@c2798633
10/03/16 15:59:31 |
joel |
m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg: Add dl05
5
@fbf4543
10/03/16 15:59:05 |
joel |
m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add dl05
5
@710302ae
10/03/16 15:58:45 |
joel |
mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg: Add dl05
5
@c7589640
08/08/16 16:33:21 |
joel |
moxiesim/bsp_specs: Add crtbegin/end to fix link issues
5
@fac8a3a
11/02/16 09:01:36 |
Sebastian Huber |
bsps/sparc: Fix copy of initialized data
The text and data sections …
5
@fc718cb8
10/22/16 15:46:56 |
jcmarsh |
Updated xilinx_zynq_a9_qemu bsp README instructions.
5
@f94155b
10/18/16 22:22:57 |
Sebastian Huber |
bsps/sparc: Add interrupt controller registers
5
