@50d8d32
05/09/19 07:54:48 |
Sebastian Huber |
bsp/lpc24xx: Use fast slew rate for EMC pins
5
@0a6b81a
05/09/19 07:53:55 |
Sebastian Huber |
bsp/lpc24xx: Add LPC17XX_PIN_TYPE_FAST_SLEW_RATE
5
@6cad529
05/09/19 07:16:20 |
Sebastian Huber |
bsp/lpc24xx: Add SDRAM mode settings comment
5
@0b74d8f0
05/08/19 11:37:06 |
Sebastian Huber |
bsp/lpc24xx: Fix LPC24XX_EMC_MT48LC4M16A2 MPU cfg
5
@2ffbc4d
05/08/19 11:02:47 |
Sebastian Huber |
bsp/lpc24xx: Flexible LPC24XX_EMC_MT48LC4M16A2 cfg
5
@d49ff3e
05/08/19 11:02:04 |
Sebastian Huber |
bsp/lpc24xx: LPC24XX_EMC_MT48LC4M16A2 MPU support
5
@a6c08e8d
05/08/19 11:01:07 |
Sebastian Huber |
bsp/lpc24xx: Support LPC24XX_EMC_SST39VF3201 pins
5
@30d61a6
05/07/19 08:17:49 |
Sebastian Huber |
bsps/powerpc: Fix constructors with priority
Update #3339.
5
@f6895c6
05/07/19 08:16:46 |
Sebastian Huber |
bsps/powerpc: Fix C++ exception handling
Close #3736.
5
@f4db49a1
05/07/19 06:44:33 |
Sebastian Huber |
bsp/motorola_powerpc: Fix bootloader output
5
@8bd4f61c
05/06/19 05:56:01 |
Sebastian Huber |
bsps: Remove bogus config declaration
Replace it with a proper struct …
5
@be50969
04/12/19 12:37:05 |
Sebastian Huber |
bsp/motorola_powerpc: Fix debug output
Update #3122.
5
@ad40d05e
04/12/19 05:55:31 |
Sebastian Huber |
score: Remove _SMP_Before_multitasking_action()
Use …
5
@df8d7bd7
04/09/19 08:58:35 |
Sebastian Huber |
score: Use processor mask in _SMP_Multicast_action
Processor_mask is …
5
@ad87de4
04/11/19 06:54:29 |
Sebastian Huber |
score: Rename _SMP_Get_processor_count()
Rename …
5
@cfcd6dc9
04/11/19 06:52:36 |
Sebastian Huber |
score: Rename _SMP_Processor_count
Rename _SMP_Processor_count in …
5
@77f9a1b
04/10/19 23:38:55 |
jeff.kubascik |
bsp/xilinx-zynqmp: Implement Ultra96 target
Modifications to get …
5
@677d5167
04/10/19 23:38:54 |
jeff.kubascik |
bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP
Source files were copied …
5
@b004430
04/10/19 23:38:53 |
jeff.kubascik |
bsp/zynq-uart: Move Zynq UART driver to shared directory
This driver …
5
@b0c420b9
04/10/19 23:38:52 |
jeff.kubascik |
bsp/zynq-uart: Remove zynq_uart_instances from header
This variable …
5
@f1eedbd
04/09/19 05:12:21 |
Sebastian Huber |
bsp/xilinx-zynq: Relicense to BSD-2-Clause
Relicense contributions …
5
@f9219db
04/05/19 06:16:05 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_processor_maximum()
Add …
5
@03c9f24
04/05/19 06:03:12 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_processor()
Add …
5
@222570a
04/09/19 06:06:01 |
Sebastian Huber |
bsps/arm: Optimize ARMv7-M CPU counter
Update #3456.
5
@b8a0a496
04/08/19 09:59:29 |
Sebastian Huber |
bsps/arm: Fix ARMv7-M CPU counter
Read the current counter value …
5
@1964b268
04/02/19 10:30:22 |
andreas.dachsberger |
doxygen: Added subgroup Generic to BSP->SPARC64
Update #3706.
5
@a2aec0b7
04/03/19 09:34:53 |
Goetz.Pfeiffer |
Set the small data section size to max. for beatnik BSPs.
This …
5
@0a9b4513
04/01/19 10:22:37 |
doxygen: bsps: Added remaining Sparc64 groups
5
@294c6f4
03/29/19 22:58:31 |
Chris Johns |
Set the small data section size to max. for mvme5500 and mvme2100 BSPs …
5
@6163ab2
03/18/19 13:46:32 |
joel |
erc32/start/setvec.c: Fix warning
5
@a5f84c6a
03/19/19 09:04:33 |
Sebastian Huber |
bsp/atsam: Fix SPI driver DMA support
5
@5f813694
03/19/19 09:45:06 |
Sebastian Huber |
bsp/atsam: Simplify XDMAD_Handler()
Remove the channel status …
5
@007d4e12
02/25/19 06:07:19 |
Sebastian Huber |
bsp/lpc24xx: Convert I2C driver to Linux API
Change license to …
5
@9e48958
03/15/19 06:32:28 |
Sebastian Huber |
bsps/powerpc: Initialize stack earlier
The eabi() call may use the …
5
@90232bc
03/12/19 19:33:20 |
joel |
z85c30.c: Do not process 0 baud and return an error (CID 1399713)
5
@3fe2155
02/01/19 09:00:36 |
Sebastian Huber |
Remove superfluous <rtems/system.h> includes
5
@20d472d
01/31/19 13:45:17 |
Sebastian Huber |
Add rtems_board_support_package()
5
@51d11dd
03/13/19 07:12:54 |
Sebastian Huber |
bsp/lm3s69xx: Fix typo in test configuration
5
@d7e2e8bb
03/12/19 15:59:56 |
joel |
mpc5643l_evb-testsuite.tcfg: : Update to account for static allocation …
5
@f22a59de
03/12/19 15:59:28 |
joel |
mpc5643l_dpu-testsuite.tcfg: Update to account for static allocation …
5
@870b527
03/08/19 22:41:46 |
joel |
mcf5225x-testsuite.tcfg: Update to account for static allocation and …
5
@539caca
03/08/19 22:41:46 |
joel |
mcf52235-testsuite.tcfg: Update to account for static allocation and …
5
@d929c483
03/08/19 22:41:46 |
joel |
tms570ls3137_hdk_with_loader-testsuite.tcfg: Update to account for …
5
@0186e39
03/08/19 22:41:45 |
joel |
tms570ls3137_hdk_intram-testsuite.tcfg: Update to account for static …
5
@8ff85c6
03/08/19 22:41:45 |
joel |
tms570ls3137_hdk-testsuite.tcfg: Update to account for static …
5
@c5dca3b7
03/08/19 22:41:45 |
joel |
stm32f4-testsuite.tcfg: Update to account for static allocation and …
5
@4f67dbda
03/08/19 22:41:45 |
joel |
stm32f105rc-testsuite.tcfg: Update to account for static allocation …
5
@0abfdc3
03/08/19 22:41:45 |
joel |
lpc32xx_mzx_stage_1-testsuite.tcfg: Update to account for static …
5
@5f07bdac
03/08/19 22:41:45 |
joel |
lpc23xx_tli800-testsuite.tcfg: Update to account for static allocation …
5
@dc632e0
03/08/19 22:41:45 |
joel |
lpc2362-testsuite.tcfg: Update to account for static allocation and …
5
@aafae0d
03/08/19 22:41:45 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Update to account for static …
5
@774ea37a
03/08/19 22:41:45 |
joel |
lpc1768_mbed_ahb_ram-testsuite.tcfg: Update to account for static …
5
@17046c9b
03/08/19 22:41:45 |
joel |
lpc1768_mbed-testsuite.tcfg: Update to account for static allocation …
5
@1526b7b
03/08/19 22:41:45 |
joel |
lm4f120-testsuite.tcfg: Update to account for static allocation and …
5
@bb1f3b4
03/08/19 22:41:44 |
joel |
lm3s6965-testsuite.tcfg: Update to account for static allocation and …
5
@c8e71bf
03/08/19 22:41:44 |
joel |
lm3s3749-testsuite.tcfg: Update to account for static allocation and …
5
@1400210
03/08/19 10:12:31 |
Sebastian Huber |
bsp/lpc24xx: Convert SSP driver to Linux API
Use interrupts instead …
5
@b2eaa6c6
03/12/19 14:50:37 |
Sebastian Huber |
bsp/lpc24xx: Add alternative SSP2 pins
5
@ba34ed9c
03/11/19 06:12:38 |
Sebastian Huber |
bsp/atsam: Fix use after free
5
@529b5868
03/08/19 06:57:24 |
Sebastian Huber |
bsps: Adjust umon Doxygen groups
Update #3706.
5
@cbf773d3
03/07/19 12:29:58 |
Sebastian Huber |
bsp/atsam: Add Doxygen groups
Add Doxygen groups for contributed code …
5
@f3db3835
03/07/19 11:09:53 |
Sebastian Huber |
bsp/altera-cyclone-v: Add Doxygen groups
Add Doxygen groups for …
5
@15359bb
03/07/19 10:56:31 |
Sebastian Huber |
bsps/arm: Adjust CMSIS Doxygen groups
Update #3706.
5
@828276b
03/05/19 06:58:18 |
Sebastian Huber |
bsps: Adjust shared Doxygen groups
Update #3706.
5
@c991eeec
03/04/19 14:32:15 |
Sebastian Huber |
bsps: Adjust bsp.h Doxygen groups
Update #3706.
5
@3b68442
03/07/19 09:42:32 |
Sebastian Huber |
bsps/powerpc: Move mpc55xx header files
They are only used by this BSP.
5
@ec1dd51a
03/06/19 10:15:56 |
Chris Johns |
libdl: Add small data support to the remaining PowerPC BSPs.
Updates #3687
5
@96e4b22
03/06/19 09:39:29 |
Chris Johns |
testsuite: Make the OPERATION_COUNT a test configuration parameter.
5
@85d5f6c
03/06/19 12:26:29 |
Sebastian Huber |
bsp/atsam: Accept only 8/16 bits per word
For proper 16 bits per word …
5
@b82a4b4
03/06/19 12:06:27 |
Sebastian Huber |
bsp/atsam: Optimize XDMAD_Handler()
Load the channel interrupt mask …
5
@847638af
03/06/19 11:48:31 |
Sebastian Huber |
bsp/atsam: Fix SPI CS change support
The previous approach contained …
5
@923a033f
03/06/19 10:48:00 |
Sebastian Huber |
bsp/atsam: Change CS delay after transfer
5
@b934898
03/06/19 08:48:41 |
Sebastian Huber |
bsp/atsam: Make SPI CS delays configurable
5
@02926290
03/06/19 08:38:12 |
Sebastian Huber |
bsp/atsam: Simplify SPI configuration
Do not use SPID_Configure() …
5
@7604a130
03/05/19 08:03:58 |
Sebastian Huber |
bsps: Move VME header files
They are only used by PowerPC BSPs.
5
@dbe6e0ad
03/04/19 08:22:32 |
Sebastian Huber |
bsps/powerpc: Move .rtemstack section
Move the .rtemsstack section …
5
@e1fc23f0
03/04/19 08:20:43 |
Sebastian Huber |
bsps/powerpc: Fix PAGE_ALIGN() macros
Previous warning fixes which …
5
@9d41fca
02/27/19 10:39:29 |
Sebastian Huber |
bsp/altera-cyclone-v: Adjust Doxygen file groups
Update #3707.
5
@631ccd7
02/27/19 08:24:22 |
Sebastian Huber |
bsp/altera-cyclone-v: Adjust Doxygen groups
Update #3706
5
@212663be
02/26/19 14:44:50 |
Sebastian Huber |
bsps: Adjust architecture Doxygen groups
- Use CamelCase as it is …
5
@6016894e
02/25/19 14:33:31 |
Sebastian Huber |
bsp/lpc1768_mbed*: Disable unsupported tests
5
@5ff61810
02/25/19 13:37:45 |
Sebastian Huber |
bsp/mpc5643l_*: Disable unsupported tests
5
@77971b6
02/25/19 12:47:42 |
Sebastian Huber |
bsp/lm4f120: Disable unsupported tests
5
@e6dd36ca
03/01/19 10:00:35 |
Sebastian Huber |
bsp/gen5200: Remove offending @mainpage
Update #3705.
5
@a3db5001
02/28/19 10:21:40 |
Sebastian Huber |
bsp/altera-cyclone-v: Enable FIQ for group 0 irqs
5
@76918e1
02/28/19 09:40:10 |
Sebastian Huber |
bsps/arm: Add BSP_ARM_GIC_ENABLE_FIQ_FOR_GROUP_0
The following …
5
@8e8e269
02/28/19 10:35:53 |
Sebastian Huber |
bsps/arm: Fix typo
5
@e33be09
02/27/19 14:10:53 |
Sebastian Huber |
bsps/arm: Support GIC group 0/1
5
@feea03b6
02/27/19 09:53:30 |
Sebastian Huber |
Remove explicit file names from @file
This makes the @file …
5
@262cb534
02/27/19 10:43:49 |
Sebastian Huber |
bsp/altera-cyclone-v: Move header file
This gets rid of a special …
5
@68a5f751
02/25/19 22:30:11 |
garnie_a |
arm/beagle: Fix sdcard.sh tool
5
@ecf62845
02/25/19 22:30:09 |
garnie_a |
arm/beagle: SPI driver
5
@bdec62c4
02/18/19 08:01:27 |
Sebastian Huber |
bsps/arm: Move device tree copy
Move device tree copy operation after …
5
@af80b0a
02/18/19 07:24:37 |
Sebastian Huber |
bsp/altera-cyclone-v: Use FDT for clock frequency
5
@43fbb50f
02/15/19 11:07:23 |
Sebastian Huber |
bsp/altera-cyclone-v: Make FDT support optional
5
@eec706e2
02/11/19 06:34:14 |
Sebastian Huber |
bsps/powerpc: Fix small data area section
Fix small data area in case …
5
@6c9f017
02/02/19 04:09:53 |
Chris Johns |
libdl: Add powerpc large memory and small data support.
- Add support …
5
@b08278e
02/02/19 04:32:38 |
Chris Johns |
powerpc/psim: Increase the psim memory to 256M
This allows test dl09 …
5
@568490a
02/08/19 11:40:45 |
Jiri Gaisler |
griscv: add additional cpu configurations
* Also switch default …
5
@4e686261
02/07/19 10:13:01 |
Sebastian Huber |
bsps/irq: Fix interrupt server init (SMP)
5
