@135d527
05/15/22 20:10:44 |
karel |
bsp/stm32h7: remove system files from start directory
The files are …
@31f756b0
05/15/22 20:10:43 |
karel |
bsp/stm32h7: copy system files to nucleo-h743zi board directory
Also …
@f8a9a47d
05/15/22 20:10:42 |
karel |
bsp/stm32h7: copy system files to stm32h743i-eval board directory
@6b051182
05/15/22 20:10:41 |
karel |
bsp/stm32h7: remove stm32h7b3i-dk related changes from start system …
@d8017f20
05/15/22 20:10:40 |
karel |
bsp/stm32h7: update stm32h7b3i-dk board system_stm32h7xx.c file
@63e327f9
05/15/22 20:10:39 |
karel |
bsp/stm32h7: cleanup osc, clk, per files for stm32h7b3i-dk board
@7234516c
05/15/22 20:10:38 |
karel |
bsp/stm32h7: copy system files to stm32h7b3i-dk board directory
Also …
@409b566
04/06/22 12:13:32 |
karel |
bsp/stm32h7: update FMC configuration for SRAM and SDRAM usage
The …
@2b54d2e8
04/05/22 09:34:25 |
Sebastian Huber |
bsp/stm32h7: Convert to UNIX line endings
@ef2c5f70
04/01/22 16:01:07 |
karel |
bsp/stm32h7: bring all required changes into system_stm32h7xx for …
@e2b673d4
04/01/22 16:14:20 |
karel |
bsp/stm32h7: properly ifdef all unsupported features in start -hal …
@2c4331a
04/01/22 16:14:19 |
karel |
bsp/stm32h7: configure peripheral clocks for STM32H7B3xxQ (e.g. …
@074cb1c
04/01/22 16:14:18 |
karel |
bsp/stm32h7: configure oscillator for STM32H7B3xxQ (e.g. STM32H7B3I-DK BSP)
@b50f3e8
04/01/22 16:14:17 |
karel |
bsp/stm32h7: configure AHB clock divider for STM32H7B3xxQ (e.g. …
@27d1707
04/01/22 16:14:16 |
karel |
bsp/stm32h7: disable ethernet for STM32H7B3I-DK BSP variant
Note: the …
@c48bedd
04/01/22 16:14:12 |
karel |
bsp/stm32h7: add flash latency configuration
@0acc1360
04/01/22 16:14:11 |
karel |
bsp/stm32h7: add configuration for USART1 GPIO pins, registers and …
@044bc3c
04/01/22 16:14:09 |
karel |
bsp/stm32h7: add power supply configuration
@753873e5
03/22/22 20:03:30 |
joel |
Update Eric Norum contact info and start to normalize file headers
@e7a2470d
03/14/22 08:22:40 |
Sebastian Huber |
bsps/arm: Fix bsp_start_memcpy() for ARMv7-AR
Synchronize data and …
@ba619b7f
03/01/22 21:38:20 |
joel |
bsps/arm/: Scripted embedded brains header file clean up
Updates #4625.
@bafeff60
11/24/21 12:08:12 |
marcus.ritter |
bsp/altera-cyclone-v: fix the creation of reserved memory regions
@6fe66224
02/16/22 09:21:54 |
christian.mauderer |
bsp/imxrt: Enforce alignment for devicetree
A device tree binary has …
@1e0a1633
02/17/22 05:55:03 |
Chris Johns |
bsp/arm/zynq: Cadence I2C has moved, update to the new path
@cff16379
08/12/21 08:00:56 |
bsp/atsam: Improve UART / USART tx performance
Put the next character …
@0074c9ec
02/03/22 08:38:40 |
bsp/atsam/i2c: Add error return and fix edge cases
The driver didn't …
@974d24f8
02/03/22 08:39:39 |
bsp/atsam/i2c: Simplify driver
Do some clean ups. Remove superfluous …
@aa95122
01/13/22 07:38:07 |
bsp/atsam: Optionally use DMA for UART Rx
If the system is busy with …
@fbd18c0
01/13/22 07:38:06 |
bsp/atsam: Merge USART and UART driver
If no extended features of the …
@dd70c81
11/25/21 01:43:10 |
joel |
bsp_specs: Delete last remnants of these.
Updates #3937.
@1fc3f171
09/28/21 12:19:47 |
bsp/imx: Add cs_change support to SPI
@db8f598
04/26/21 12:00:41 |
Sebastian Huber |
build: Remove old build system
Close #3250.
Close #4081.
@73c182a
08/23/21 17:53:42 |
stephen.clark |
bsps/zynq: Moved general i2c files to shared directories
Certain …
@e495633
09/01/21 13:54:33 |
bsps/imxrt: Improve SPI driver
It wasn't possible to keep the CS line …
@1c060681
08/09/21 11:13:22 |
dangipranav |
bsps/raspberrypi: Add SEV Instruction for RPi SMP firmware changes.
@5947204
08/04/21 12:21:34 |
Sebastian Huber |
bsps/arm: More robust SMP start
Do not continue execution on …
@c7b4eca7
07/27/21 07:58:43 |
Sebastian Huber |
bsps/irq: bsp_interrupt_facility_initialize()
Do not return a status …
@b910e60
07/07/21 11:44:16 |
Sebastian Huber |
bsp/raspberrypi: Add interrupt get/set affinity
Add default …
@32f5a195
06/29/21 12:06:03 |
Sebastian Huber |
bsps/irq: bsp_interrupt_vector_disable()
Return a status code for …
@bc86a5fa
06/29/21 12:01:17 |
Sebastian Huber |
bsps/irq: bsp_interrupt_vector_enable()
@deb5afb
07/05/21 11:28:02 |
Sebastian Huber |
bsps/irq: Add rtems_interrupt_is_pending()
Add a default …
@eebecd0
06/28/21 07:36:29 |
Sebastian Huber |
bsps/irq: Add rtems_interrupt_get_attributes()
Add a default …
@9832652c
06/28/21 06:44:49 |
Sebastian Huber |
bsps/irq: Add rtems_interrupt_raise()
Add rtems_interrupt_raise_on() …
@781213f9
06/28/21 06:20:53 |
Sebastian Huber |
bsps/irq: Add rtems_interrupt_vector_is_enabled()
Add a default …
@5cc1695
04/19/21 08:55:33 |
robin.mueller.m |
Fixes for TMS570 BSP
When compiling the lwIP port for the TMS570, …
@b24e8142
07/16/21 12:32:03 |
robin.mueller.m |
STM32H7 ethernet pin corrections
These patches were submitted a few …
@7b2d569
07/09/21 08:39:01 |
Sebastian Huber |
bsp/imx: Fix SMP start
Flush imx_gic_dist_base so that secondary …
@a398909
07/09/21 08:40:35 |
Sebastian Huber |
bsps/arm: Fix SMP start
Skip the data cache initialization if we are …
@89b652a5
07/07/21 14:37:27 |
bsps/imxrt: Fix undefined symbol
@8b0e3334
07/06/21 15:53:12 |
dangipranav |
bsps/arm: Add start up support for ARMv6 RPi Models
@b28c0c66
07/07/21 12:38:40 |
Sebastian Huber |
bsp/raspberrypi: Fix <bsp/irq.h> header guard
@1b560731
07/07/21 07:52:56 |
Sebastian Huber |
bsp/imx: Fix pointer from integer warning
@0d3453a4
05/28/21 14:54:00 |
bsps/imxrt: Simplify linkcmds and make it flexible
Calling the memory …
@95a38dd
05/28/21 13:50:31 |
bsps/imxrt: Allow different ARM PLL setting
Update #4180
@6b7a3858
06/19/21 12:24:26 |
Sebastian Huber |
bsp/atsam: Fix BSP_INTERRUPT_VECTOR_COUNT
Fix an off by one error.
@94cf67c
06/19/21 10:48:27 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAX
This define is no longer …
@3fee6620
06/19/21 10:51:58 |
Sebastian Huber |
bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT
Use …
@cd5573c
06/19/21 10:40:57 |
Sebastian Huber |
bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNT
Assert …
@af73b7b6
06/18/21 05:37:18 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MIN
Remove …
@55ce66ca
06/07/21 07:37:51 |
Sebastian Huber |
arm/fvp: Fix integer from pointer without a cast
Update #4202.
@ea41722c
04/30/21 17:14:48 |
ryan.long |
Change filesystem utime_h handler to utimens_h
Also updated licenses. …
@15e26f4
05/12/21 09:34:52 |
bsps/imxrt: Enable DMA clock
The EDMA is intialized so make sure the …
@691fec40
05/11/21 11:46:56 |
bsps/imxrt: Fix OCRAM, ITCM and DTCM sizes
The sizes are configurable …
@988cc1a
04/12/21 14:53:43 |
bsps/imxrt: Add addresses and interrupts to dts
Add addresses and …
@c3056666
05/12/21 06:46:30 |
bsps/imxrt: Reduce devicetree size
Remove symbols that would be …
@08e4e6f2
04/07/21 13:05:26 |
bsps/imxrt: Fix documentation error
Update #4180
@98cb84e
05/17/21 06:04:07 |
Sebastian Huber |
arm/altera-cyclone-v: Fix compile error
Update #4406.
@523867d
05/11/21 15:27:20 |
Sebastian Huber |
rtems: Constify rtems_task_wake_when()
Add a parameter to …
@3af2dc7
05/11/21 14:26:55 |
frank.kuehndel |
_TOD_Validate(): Fix incorrect return code
This patch fixes bug …
@e10dec0
04/30/21 13:47:10 |
Sebastian Huber |
bsps: Support RTEMS_NOINIT in linkcmds
Update #3866.
@263e00b
04/29/21 11:42:00 |
Sebastian Huber |
bsps/arm: ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX
Change the …
@3764935
04/26/21 09:20:32 |
robin.mueller.m |
Implementation for STM32 HAL_GetTick using RTEMS
Uses configured …
@d75b29d
04/10/21 19:15:27 |
niteesh.gs |
bsps/beagle: Refactored i2c driver
Refactored the i2c driver to parse …
@2a24f99d
04/16/21 05:50:21 |
Sebastian Huber |
bsps/arm: Set MSP in ARMv7-M start code
Set the Main Stack Pointer …
@100c050c
04/20/21 16:31:31 |
robin.mueller.m |
Updated tick implementation for HAL_GetTick
This now uses …
@c90fa83
02/25/21 02:09:56 |
vijay |
bsps: Remove networking drivers
Update #3850
@05cd707d
04/06/21 07:56:41 |
Sebastian Huber |
arm/stm32h7: Add STM32H7_USART3_GPIO_*
@6bb6b69b
04/06/21 07:43:23 |
Sebastian Huber |
arm/stm32h7: Add STM32H7_HSE_FREQUENCY
@8fd29cfb
03/02/21 15:14:41 |
stm32h7: Add init for sdmmc pins
Update #4372
@aa9e3c62
03/02/21 13:00:50 |
stm32h7: Add SDMMC modules to clock
Update #4372
@5607464
03/13/21 11:02:03 |
niteesh.gs |
bsp/beagle: Ported Beagle pinmux driver to RTEMS
The following files …
@7589f1e0
03/13/21 11:02:02 |
niteesh.gs |
bsps/beagle: Added SOC detection using FDT
Detects the SOC type using …
@65ab1cda
02/04/21 13:27:50 |
bsps/arm/imxrt: Add FDT and FDT helper for QTMR
Makes it simpler to …
@320cb42
02/23/21 08:18:40 |
james.fitzsimons |
bsps/beagle: Updating licences to latest BSD 2 clause
@db86c3eb
02/23/21 08:18:39 |
james.fitzsimons |
bsps/beagle: Adding QEP driver support to BeagleBoneBlack? BSP
@de7df04
02/26/21 08:48:41 |
Sebastian Huber |
bsps: Fix legacy build
@32b0d6f8
02/24/21 10:13:30 |
Sebastian Huber |
bsps: Change license to BSD-2-Clause of some files
Change license to …
@b361eabd
01/28/21 05:28:33 |
Sebastian Huber |
bsps: Replace bsp_specs with an empty file
This fixes an issue with …
@9eb9813
01/26/21 14:29:00 |
Sebastian Huber |
bsps: Add missing DWARF 5 sections
Sort alphabetically.
@33c12d5
01/25/21 10:19:21 |
Sebastian Huber |
bsps: Support DWARF 5 sections
GCC 11 uses DWARF 5 by default.
@7b99d76
01/18/21 09:02:40 |
bsp/imx: Fix system counter init for imx6
For i.MX7 U-Boot …
@36b4e8c
12/14/20 13:12:21 |
bsps/imxrt: Add ioctl to LPSPI to get registers
This allows an …
@d9794a1
12/14/20 13:54:47 |
bsps/imxrt: Add DMA numbers to dtsi
Also currently no driver uses …
@a434cc8
11/24/20 16:22:38 |
bsps/shared: Adapt fsl-edma driver for imxrt
Note: The changes have …
@22e9dafb
12/14/20 13:09:11 |
bsps/imxrt: Use standard names to avoid warnings
If spi or i2c slaves …
@6600585f
01/04/21 18:21:11 |
Sebastian Huber |
bsp/stm32h7: Split console configuration
This allows applications to …
@affc8de
01/04/21 17:58:24 |
Sebastian Huber |
bsp/stm32h7: Split start configuration
@828ea6e
12/23/20 09:25:33 |
Sebastian Huber |
Update header.am
@81c7f5be
12/03/20 14:31:40 |
Sebastian Huber |
arm/fvp: New BSP
This BSP supports the Arm Fixed Virtual Platform. …
@016bcb3
12/22/20 12:10:53 |
Sebastian Huber |
bsps/arm: Rely on initialized vector table
The …
