@828ea6e
12/23/20 09:25:33 |
Sebastian Huber |
Update header.am
@81c7f5be
12/03/20 14:31:40 |
Sebastian Huber |
arm/fvp: New BSP
This BSP supports the Arm Fixed Virtual Platform. …
@016bcb3
12/22/20 12:10:53 |
Sebastian Huber |
bsps/arm: Rely on initialized vector table
The …
@9f3a08e
12/22/20 12:00:27 |
Sebastian Huber |
bsps: Use header file for GIC architecture support
This avoids a …
@23d9223a
12/21/20 09:08:30 |
Sebastian Huber |
bsps/arm: Invalidate TLB in start.S
Update #4202.
@e164df5e
12/18/20 21:00:54 |
Sebastian Huber |
bsps/arm: Clear SCTLR[M, I, A, C] in start.S
Initialize the data and …
@b32fd227
12/21/20 07:08:00 |
Sebastian Huber |
bsps/arm: Add arm-data-cache-loop-set-way.h
This makes it possible to …
@46a3c04
12/21/20 08:40:50 |
Sebastian Huber |
bsps/arm: Remove optional start hook arguments
The start hook …
@76a1a53
12/21/20 06:29:41 |
Sebastian Huber |
bsps/arm: Invalidate branch predictors earlier
Make sure the branch …
@272534e
12/18/20 09:11:51 |
Sebastian Huber |
bsps/arm: Set VBAR in start.S
Set the VBAR to the vector table in the …
@854ea2b
12/15/20 09:59:21 |
Sebastian Huber |
arm: Add support for Arm PMSAv8-32
Update #4202.
@6944cd10
12/17/20 14:26:57 |
Sebastian Huber |
arm: Add header file for AArch32 System Registers
Update #4202.
@39ef7e5
12/21/20 12:13:57 |
Sebastian Huber |
bsps: Fix includes
Update #4202.
@be5eee57
12/22/20 10:51:53 |
Sebastian Huber |
libdebugger: Fix for Armv8-R
This architecture variant has no MMU.
@a299c4fe
12/10/20 06:52:03 |
Sebastian Huber |
arm: Optimize arm_interrupt_disable()
Update #4202.
@b5aceef
12/10/20 09:49:37 |
Sebastian Huber |
bsps: Remove gicvx_interrupt_dispatch()
Avoid one level of …
@747fb65
12/10/20 08:09:10 |
Sebastian Huber |
bsps: Add GICv3 arm_gic_irq_processor_count()
Update #4202.
@7cf7e1d
12/16/20 09:59:09 |
Sebastian Huber |
build: Add ABI flags to gnatmake compiler flags
@d3f2ecc
12/16/20 06:11:57 |
Sebastian Huber |
build: Fix duplicate install of jffs2.h
@0deeb02
12/15/20 10:24:14 |
Sebastian Huber |
bsps/arm: Fix MMU configuration
Update #4184.
@eb2b915
12/14/20 09:38:49 |
christian.mauderer |
cpu/armv7m: Fix table based init for ARMV7M_MPU
Somehow the table …
@9b3def2
11/24/20 09:55:14 |
bsps/arm/imx*: Fix location of shared headers
When moving the headers …
@b63a187
12/04/20 08:44:51 |
bsps/imxrt: Split up dts.
This allows simpler creation of own dts …
@1618e69
11/18/20 07:36:48 |
shell: Add i2c and spi commands
This adds some commands that are …
@66723ee6
11/07/20 13:07:26 |
bsp/rtl22xx: Fix non-ASCII character
@2f509b5
11/07/20 13:05:11 |
bsp/mpc83xx: Fix non-ASCII characters
@21a0d20
11/07/20 10:12:56 |
bsps: Replace non-ASCII bullet points
@86d3c275
11/07/20 10:11:07 |
bsps: Replace non-ASCII trademark symbol
@2fbc889
11/07/20 10:03:29 |
bsps: Replace non-ASCII copyright character
@fcd9618a
12/11/20 12:57:31 |
Sebastian Huber |
config: Fix invalid static assertions in C
Expressions in static …
@9edca35d
12/10/20 20:41:07 |
kinsey.moore |
bsps/gicv3: Resolve build warnings on 64bit
@9e7b5eb
12/10/20 20:27:27 |
kinsey.moore |
tm27: Use generic cpu index accessor
The arm_cp15 function for …
@bb57361b
12/11/20 10:39:31 |
Sebastian Huber |
build: Clarify ARM_MMU_USE_SMALL_PAGES description
@cadbd7d1
11/27/20 13:43:19 |
jan.sommer |
bsp/xilinx_zynq: Enable support for 4kiB MMU pages
- Disabled by …
@1a7afb5
11/24/20 08:40:38 |
jan.sommer |
bsps/arm: Fix MMU small pages support
- For small tables only round …
@d188e6e8
12/08/20 15:11:34 |
kinsey.moore |
cpukit/aarch64: Add explanation of exception flow
@f046af5
12/07/20 20:51:10 |
kinsey.moore |
cpukit/aarch64: Use hex consistently for offsets
@105e520
12/10/20 07:08:00 |
Sebastian Huber |
bsps: Remove ARM GIC SGI target filter
Remove the target filter for …
@b6925e1
12/09/20 13:29:47 |
Sebastian Huber |
bsps: Fix GICv3 arm_gic_trigger_sgi()
Use the targets parameter to …
@6b79abfb
12/10/20 08:41:54 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix smpfatal04 test
@617aeaf5
12/08/20 08:33:54 |
Sebastian Huber |
bsps/arm: Move BSP_START_IN_HYP_SUPPORT option
Clarify documentation. …
@bd7bef52
12/08/20 06:56:53 |
Sebastian Huber |
bsps/arm: Support system level ARM Generic Timer
Update #4202.
@5efa15b
12/04/20 11:07:44 |
Sebastian Huber |
bsps/arm: Unify ARM Generic Timer options
Update #4202.
@e68827e
12/04/20 10:42:42 |
Sebastian Huber |
arm/cache-cp15: Support Armv8
Update #4202.
@9955487d
12/07/20 13:15:10 |
Sebastian Huber |
arm: Support Armv8 in <rtems/score/arm.h>
Update #4202.
@368fab5
12/09/20 13:25:15 |
Sebastian Huber |
bsps: Print CPU in default fatal error extension
@293cde73
12/07/20 15:43:06 |
Sebastian Huber |
build: Exclude performance-0 in small mem BSPs
@9ce47a5
12/08/20 10:20:09 |
Sebastian Huber |
bsps: Add SMP support to ARM GICv3
Update #4202.
@0e779a4c
12/09/20 07:20:44 |
Sebastian Huber |
smptests/smpipi01: Fix sporadic test failure
@2365c937
12/03/20 16:58:26 |
kinsey.moore |
spec: Move zynq-uart into its own object
Currently, zynq-uart code is …
@74c1c402
12/02/20 16:24:21 |
kinsey.moore |
spec/optconminor: Fix value type
The option for defining the console …
@a92d4ae
11/16/20 19:36:51 |
kinsey.moore |
Add AArch64 ZynpMP BSP
This adds a BSP family that runs on the Xilinx …
@5686b44d
12/02/20 19:20:36 |
kinsey.moore |
zynq-uart: Fix set_attributes implementation
The zynq-uart …
@2b56f5a
12/02/20 16:27:22 |
kinsey.moore |
samples/unlimited: Prevent compile error
For architectures with …
@5b064a4
12/03/20 09:08:23 |
Sebastian Huber |
bsps: Remove unused bsp_stack_main_size
@7930fbdd
12/03/20 14:32:14 |
Sebastian Huber |
score: Fix discard 'const' qualifier warning
@768327d0
06/22/20 11:36:21 |
Sebastian Huber |
rtems: Generate <rtems/rtems/timer.h>
Change license to BSD-2-Clause …
@e2f888d1
11/24/20 12:36:32 |
Sebastian Huber |
score: Free old name in _Objects_Set_name()
This is the behaviour …
@766009b4
11/23/20 16:24:39 |
Sebastian Huber |
rtems: Fix rtems_object_set_name()
Return RTEMS_NO_MEMORY if there is …
@13bab34
11/23/20 16:22:10 |
Sebastian Huber |
score: Return a status in _Objects_Set_name()
@65969c1
06/24/20 06:59:35 |
Sebastian Huber |
rtems: Generate <rtems/rtems/object.h>
@dfa34e0d
12/02/20 16:23:27 |
kinsey.moore |
spec/a53: Fix SPDX lines
@a151ee1
10/29/20 18:40:54 |
kinsey.moore |
bsps: Move ARM GICv2 driver to bsps/shared
This moves the ARM GICv2 …
@f085957
10/26/20 15:26:49 |
kinsey.moore |
bsps: Move zynq-uart to bsps/shared
This moves the zynq-uart driver …
@ef0fe8e
12/02/20 12:18:42 |
Sebastian Huber |
dosfs: Fix Doxygen group placement
Update #3706.
@3393ff1d
12/02/20 12:10:49 |
Sebastian Huber |
libfs: Fix Doxygen group placement
Update #3706.
@ab85383
12/02/20 12:03:49 |
Sebastian Huber |
nfsclient: Remove from Doxygen output
The libnetworking is excluded …
@295b05f9
12/02/20 12:02:58 |
Sebastian Huber |
nfsclient: Rework Doxygen groups
Update #3706.
@7f1ba9c7
12/02/20 10:41:09 |
Sebastian Huber |
build: Add <rtems/rtems/clockimpl.h>
@1fa3821
12/02/20 10:34:33 |
Sebastian Huber |
score: Fix Doxygen group membership
Update #3706.
@1c60622
12/02/20 10:34:03 |
Sebastian Huber |
score: Fix Doxygen group name
Update #3706.
@c296d150
12/01/20 13:09:23 |
Sebastian Huber |
rtems: Fix Doxygen return description
@1af4493
12/02/20 07:32:44 |
Sebastian Huber |
rtems: Clarify invalid identifier descriptions
Update #3993.
@5a285e3
12/01/20 15:51:40 |
Sebastian Huber |
rtems: Clarify rtems_partition_delete()
Move the PTCB sentence to the …
@8756d5c
12/01/20 15:35:05 |
Sebastian Huber |
rtems: Clarify rtems_partition_create()
The rtems_partition_create() …
@5555c0c
12/02/20 07:15:32 |
Sebastian Huber |
rtems: Fix Doxygen group name
Update #3706.
@226b90b4
12/02/20 07:13:26 |
Sebastian Huber |
rtems: Fix Doxygen group memberships
Update #3706.
@70dbafb
11/30/20 13:00:08 |
Sebastian Huber |
config: Canonicalize @defgroup and @file comments
Adjust group …
@3db9c820
11/28/20 10:16:28 |
Sebastian Huber |
sapi: Canonicalize @defgroup and @file comments
Adjust group …
@9278f3d
11/27/20 16:21:23 |
Sebastian Huber |
score: Canonicalize Doxygen @file comments
Use common phrases for the …
@6b5f22dc
11/26/20 10:45:47 |
Sebastian Huber |
rtems: Canonicalize Doxygen @file comments
@23494c2
11/30/20 18:32:22 |
Sebastian Huber |
score: Always define RTEMSScoreMRSP group
This fixes a Doxygen warning.
@c81ac0e
11/26/20 09:42:03 |
Sebastian Huber |
score: Canonicalize Doxygen groups
Adjust group identifier and names …
@e07088d9
11/25/20 15:42:08 |
Sebastian Huber |
rtems: Canonicalize implementation Doxygen groups
Rename Classic API …
@9c20b987
11/26/20 18:53:25 |
Sebastian Huber |
rtems: Add <rtems/rtems/clockimpl.h>
@501bd46f
11/28/20 08:44:08 |
Sebastian Huber |
shell: Rename "IO" typedef for better Doxygen
An automatic link from …
@b1a8be4
11/30/20 11:53:06 |
Sebastian Huber |
rtems: Simplify includes in version.c
@3732c93
11/30/20 10:43:09 |
Sebastian Huber |
posix: Delete unused _POSIX_Fatal_error()
@b48b1808
11/27/20 18:51:59 |
Sebastian Huber |
score: Delete empty pheapinit.c
@7995329
12/01/20 13:39:43 |
Sebastian Huber |
rtems: Fix documentation in <rtems/rtems/part.h>
Update #3993.
@6c8c774
11/27/20 15:14:22 |
Sebastian Huber |
rtems: Remove empty and unused rtclock.c
@6e566bad
11/27/20 08:52:07 |
Sebastian Huber |
config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Fix the …
@3a5c33a7
11/26/20 10:29:20 |
Sebastian Huber |
sapi: Remove obsolete README file
@2406fe8
11/20/20 17:46:04 |
Sebastian Huber |
rtems: Delete rtems_object_id_api_maximum_class()
This directive has …
@06386fc7
11/19/20 15:07:20 |
Sebastian Huber |
Use CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
Update #4181.
@6c1afc19
11/24/20 07:05:43 |
Sebastian Huber |
config: Check CONFIGURE_INIT_TASK_STACK_SIZE
@657e30c1
11/19/20 15:07:04 |
Sebastian Huber |
In order to better …
@bc175a1
11/19/20 14:30:17 |
Sebastian Huber |
Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
Replace a runtime …
@ef8c4ebc
11/25/20 06:59:30 |
Sebastian Huber |
config: Clarify the use of pragmas
@b2a677b
11/26/20 10:08:54 |
Sebastian Huber |
rtems: Move "Set Errno" group to the API
