@f4fee72b
06/07/18 04:17:02 |
Sebastian Huber |
tools: Remove cklength
This program has no license information and is …
5
@ea092ccc
06/07/18 04:13:38 |
Sebastian Huber |
tools: Remove rtems-bin2c
This tool is now included in the RTEMS …
5
@9eb1494f
06/11/18 12:18:53 |
Sebastian Huber |
tools: Remove size_rtems
This script is horribly out of date. A new …
5
@46c2da69
06/06/18 14:18:49 |
Sebastian Huber |
tools: Remove nios2gen
All tools should be removed from the RTEMS …
5
@8c62cf4
06/06/18 14:21:22 |
Sebastian Huber |
tools: Remove shgen
All tools should be removed from the RTEMS source …
5
@3248137
04/30/18 05:35:09 |
Sebastian Huber |
build: Force warnings
Always append some standard warning flags.
5
@5249a4c
06/07/18 05:18:23 |
Sebastian Huber |
powerpc: Fix ss555 build
The mpc555 define is provided via …
5
@07c5976
06/07/18 04:58:59 |
Sebastian Huber |
bsps/powerpc: Hack to fix the build
The ppc405 define must be checked …
5
@de9b7d7
06/01/18 05:04:45 |
Sebastian Huber |
Add RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE
An invalid heap usage such …
5
@c934365f
06/05/18 06:06:15 |
Sebastian Huber |
Update rtems_fatal_source_text()
Add RTEMS_FATAL_SOURCE_PANIC to …
5
@dea4bbe3
06/01/18 05:00:37 |
Sebastian Huber |
bsps: Avoid malloc() in generic IRQ support
Use …
5
@b8774933
05/25/18 12:12:22 |
Sebastian Huber |
score: Simplify _Objects_Name_to_string()
Do not use isprint() from …
5
@7d7c50de
05/25/18 12:09:46 |
Sebastian Huber |
rtems: Move _Status_Object_name_errors_to_status
Move …
5
@75933d5d
06/04/18 05:33:55 |
Sebastian Huber |
capture: Use unlimited objects
Avoid resource allocation problems …
5
@baee0dc5
05/15/18 09:21:55 |
martinerikwerner.aac |
Fix and extend error message in posix timer test
_Timespec_Equal_to() …
5
@4b3c8b82
05/25/18 06:21:18 |
christian.mauderer |
bsp/atsam: Remove side effect from gmac functions.
Quite a number of …
5
@0fe48afa
05/28/18 05:07:18 |
Sebastian Huber |
build: Really fix RTEMS_ENABLE_RTEMSBSP()
The …
5
@877f5d6
05/25/18 08:35:39 |
Sebastian Huber |
sptests: Remove CONFIGURE_MILLISECONDS_PER_TICK
This configuration …
5
@61d5c886
05/25/18 08:27:40 |
Sebastian Huber |
config: Hide CONFIGURE_SCHEDULER_COUNT
Rename …
5
@2292ca22
05/25/18 08:13:14 |
Sebastian Huber |
config: Hide CONFIGURE_INITIAL_EXTENSION_TABLE
Rename …
5
@a03178ba
05/28/18 04:59:16 |
Sebastian Huber |
build: Fix typo in RTEMS_ENABLE_RTEMSBSP()
5
@3b2817b6
05/25/18 08:19:32 |
Sebastian Huber |
gumstix: Remove CONFIGURE_INTERRUPT_STACK_MEMORY
This define is not …
5
@ef61d89
05/24/18 08:32:35 |
bsp/atsam: Reserve one region for applications.
This allows a user to …
5
@df71100c
05/21/18 22:57:50 |
joel |
dltests-broken-on-this-bsp.tcfg: Add dl06
5
@eaf5bec
05/16/18 15:07:26 |
joel |
virtex5: Move -Dxxx to configure.ac
Updates #3425.
5
@17f69e4
05/16/18 15:01:26 |
joel |
virtex4: Move -Dxxx to configure.ac
Updates #3425.
5
@4afc1efa
05/16/18 15:01:09 |
joel |
virtex: Move -Dxxx to configure.ac
Updates #3425.
5
@3d43c475
05/16/18 14:58:13 |
joel |
tqm8xx: Move -Dxxx to configure.ac
Updates #3425.
5
@3274ec75
05/16/18 14:57:54 |
joel |
t32mppc: Move -Dxxx to configure.ac
Updates #3425.
5
@c20001c4
05/16/18 14:57:37 |
joel |
ss555: Move -Dxxx to configure.ac
Updates #3425.
5
@1a41818
05/16/18 14:55:14 |
joel |
qoriq: Move -Dxxx to configure.ac
Updates #3425.
5
@b06e8d61
05/16/18 14:54:50 |
joel |
qemuppc: Move -Dxxx to configure.ac
Updates #3425.
5
@c3b609d5
05/16/18 14:54:33 |
joel |
psim: Move -Dxxx to configure.ac
Updates #3425.
5
@beb4468
05/16/18 14:54:13 |
joel |
mvme5500: Move -Dxxx to configure.ac
Updates #3425.
5
@5aa8ac2
05/16/18 14:50:11 |
joel |
mvme3100: Move -Dxxx to configure.ac
Updates #3425.
5
@a03f73c
05/16/18 14:49:51 |
joel |
mpc8260ads: Move -Dxxx to configure.ac
Updates #3425.
5
@1e84462
05/16/18 14:49:22 |
joel |
mpc55xxevb: Move -Dxxx to configure.ac
Updates #3425.
5
@2261ef2
05/16/18 14:47:40 |
joel |
motorola_powerpc: Move -Dxxx to configure.ac
Updates #3425.
5
@01da0ac
05/16/18 14:47:07 |
joel |
haleakala: Move -Dxxx to configure.ac
Updates #3425.
5
@b1b5afba
05/16/18 14:43:24 |
joel |
beatnik: Move -Dxxx to configure.ac
Updates #3425.
5
@7bf072b
02/21/18 11:40:40 |
Sebastian Huber |
bsp/powerpc: Remove wildcards in linkcmds.base
This reverts commit …
5
@70502b48
03/20/18 15:07:14 |
Sebastian Huber |
libtests/block05: Use rtems_blkdev_create()
Update #3358.
5
@c4d35fb
03/03/18 12:30:01 |
Sebastian Huber |
libchip: Use rtems_blkdev_create()
Update #3358.
5
@30c3898
03/03/18 12:24:42 |
Sebastian Huber |
libblock: Init deps in rtems_blkdev_create()
Update #3358.
5
@9d62874
05/15/18 14:17:03 |
joel |
sparc64 BSPs: Hard define configuration required settings
Updates #3425.
5
@003b192
05/14/18 20:11:15 |
joel |
rtems-bsps: Change 4.12 to 5
5
@a3fe23c
04/30/18 22:21:16 |
joel |
Drop executable permissions on .[S] files
5
@02c46f85
05/04/18 13:25:46 |
Sebastian Huber |
spcpucounter01: Enable floating-point output
5
@d542af2e
05/11/18 04:22:49 |
Sebastian Huber |
build: Fix RTEMS_ENABLE_RTEMSBSP()
The riscv32 and riscv64 targets …
5
@4387010
04/30/18 16:34:50 |
amaan.cheval |
no_cpu/no_bsp: Fix Makefile
5
@c4f5cc54
05/03/18 06:54:02 |
dev/sc16is752: Add ioctl calls for modem controll.
This add ths …
5
@c8dcdf54
05/09/18 20:22:04 |
joel |
sparc64 niagara, usiii: Remove -D options from cfg file and move to …
5
@85602e0d
05/09/18 19:47:37 |
joel |
smdk2410: Move define of CPU_S3C2410 to bspopts.h
Updates #3425.
5
@2a1171d8
05/08/18 22:34:49 |
joel |
rtl22xx_t.cfg: Remove comment with -D THUMB_INTERWORK
Updates #3425.
5
@eaa1709
05/08/18 06:05:48 |
Sebastian Huber |
ftpd: Fix infinite recursion in yield()
Update #3419.
5
@8d52a0e2
04/30/18 09:05:36 |
Sebastian Huber |
telnetd: Use syslog() instead of printk()
Update #3419.
5
@b80b34c3
04/30/18 08:54:50 |
Sebastian Huber |
telnetd: Always build telnet daemon
Add support for libbsd …
5
@b771cb48
04/30/18 08:11:37 |
Sebastian Huber |
ftpd: Always build FTP daemon
Add support for libbsd initialization.
5
@32b5b23
04/30/18 08:12:37 |
Sebastian Huber |
ftpd: Use floating-point tasks due to syslog()
Update #3419.
5
@4fed5ac
04/30/18 08:05:46 |
Sebastian Huber |
ftpd: Fairplay with libbsd
Update #3419.
5
@bf76d5fe
04/30/18 08:37:59 |
Sebastian Huber |
network: Import latest <arpa/ftp.h> from FreeBSD
Update #3419.
5
@fea9a7a
04/30/18 07:48:13 |
Sebastian Huber |
ftpfs: Always build FTP client
Move FTP client filesystem to separate …
5
@c3bab73b
04/30/18 07:24:44 |
Sebastian Huber |
tftpfs: Always build TFTP client
Move TFTP client filesystem to …
5
@dd8e4b7
04/30/18 07:09:27 |
Sebastian Huber |
libdebugger: Move to separate library
Always build remote TCP support …
5
@97a48209
04/27/18 04:18:41 |
Sebastian Huber |
tests: Move rtems-test-check.py
Remove shell script variant.
5
@397df7a
04/26/18 14:15:01 |
Sebastian Huber |
tests: Remove difftest and sorttimes tools
Close #3418.
5
@b422aa3f
04/26/18 14:05:45 |
Sebastian Huber |
tests: Remove configure feature checks
Update #3409.
5
@c77cd426
04/30/18 22:18:49 |
joel |
Drop executable permissions on .[ch] files
5
@6ac6a5c8
03/27/18 11:01:56 |
Sebastian Huber |
jffs2: Do not use command line defines
Update #3375.
5
@3ef7e744
04/30/18 05:44:56 |
Sebastian Huber |
config: Fix -Wint-in-bool-context warnings
5
@8b5a801
04/27/18 05:20:27 |
Sebastian Huber |
smptests/smpschededf02: Add test case
5
@3d703f4
04/26/18 05:29:28 |
Sebastian Huber |
bsp/pc386: Remove bin2boot support
Update #3408.
Close #3410.
5
@419d1e9
04/25/18 14:06:34 |
Sebastian Huber |
bsp/mcf5206elite: Do not install runtest script
Provide the runtest …
5
@eb36d11
04/25/18 13:06:08 |
Sebastian Huber |
bsps: Move documentation, etc. files to bsps
This patch is a part of …
5
@8eb264d3
04/25/18 12:58:50 |
Sebastian Huber |
bsps: Remove unmaintained times files
This patch is a part of the BSP …
5
@1554415e
04/25/18 12:54:27 |
Sebastian Huber |
bsp/sparc64: Move asm.S to bsps and rename
5
@a5bf9b6
04/25/18 12:53:33 |
Sebastian Huber |
bsps/mips: Move liblnk to bsps
This patch is a part of the BSP source …
5
@3460c522
04/25/18 12:51:49 |
Sebastian Huber |
bsps/powerpc: Move bsp-start-zero.S to bsps
5
@b80be135
04/25/18 12:51:01 |
Sebastian Huber |
bsp/psim: Move align_h.S to bsps
5
@0b60c54
04/25/18 12:50:36 |
Sebastian Huber |
bsp/haleakala: Move assembler files to bsps
5
@b3e5aa5
04/25/18 18:33:20 |
Sebastian Huber |
bsp/qemuppc: Install linkcmds.base
Update #3339.
Close #3411.
5
@1913eb16
04/25/18 09:03:31 |
Sebastian Huber |
bsps/arm: Remove unused files
5
@f7eaf316
04/25/18 09:01:45 |
Sebastian Huber |
bsps: Remove unused u-boot-generic-board-info.h
This patch is a part …
5
@531d160
04/25/18 08:50:12 |
Sebastian Huber |
bsp/beagle: Move source files to bsps
5
@720ebc0
04/25/18 08:49:53 |
Sebastian Huber |
bsp/gumstix: Move fb.c to bsps
5
@82bfda92
04/25/18 08:49:39 |
Sebastian Huber |
bsp/lm3s69xx: Move ssi.c to bsps
5
@e945b049
04/25/18 08:43:38 |
Sebastian Huber |
bsp/lpc176x: Move source files to bsps
This patch is a part of the …
5
@74df15c
04/25/18 08:40:40 |
Sebastian Huber |
bsp/lpc24xx: Move source files to bsps
5
@43250167
04/25/18 08:36:52 |
Sebastian Huber |
bsp/lpc32xx: Move source files to bsps
5
@fc1bdb83
04/25/18 08:36:01 |
Sebastian Huber |
bsp/raspberrypi: Move source files to bsps
5
@ede0eb3
04/25/18 08:34:09 |
Sebastian Huber |
bsp/smdk2410: Move smc.c to bsps
5
@4183b711
04/25/18 08:33:35 |
Sebastian Huber |
bsp/tms570: Move cpucounterread.c to bsps
5
@a79d650
04/25/18 08:32:28 |
Sebastian Huber |
bsp/mcf5206elite: Move nvram.c to bsps
5
@0e15ba3
04/25/18 08:32:09 |
Sebastian Huber |
bsp/mrm332: Move interr.c to bsps
5
@100c9723
04/25/18 08:31:53 |
Sebastian Huber |
bsp/mrm332: Move spinit.c to bsps
5
@64d4fc7
04/25/18 08:26:24 |
Sebastian Huber |
bsp/gen5200: Move source files to bsps
5
@95d5426c
04/25/18 08:26:05 |
Sebastian Huber |
bsp/haleakala: Move mmu_405.c to bsps
5
@8266fb53
04/25/18 08:25:00 |
Sebastian Huber |
bsp/beatnik: Move source files to bsps
5
@bf16ee5
04/25/18 08:24:49 |
Sebastian Huber |
bsp/mvme3100: Move flashcfg.c to bsps
5
@8f12ee32
04/25/18 08:22:37 |
Sebastian Huber |
bsp/mvme5500: Move source files to bsps
5
