- Timestamp:
01/21/11 00:42:42 (13 years ago)
- Author:
Jennifer
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v15
v16
41 | 41 | {| border="1" style="margin: 1em auto 1em auto;text-align: center;" |
42 | 42 | |+ |
43 | | |'''BSP Variant''' || '''rad750_3u''' || '''rad750_6u''' || '''BSP_DIRTY_MEMORY''' || '''BSP_PRESS_KEY_FOR_RESET''' |
| 43 | |'''BSP Variant''' || '''rad750_3u''' || '''rad750_6u''' || '''ENABLE_SHADOWED_DATA''' || '''BSP_RESET_BOARD_AT_EXIT''' |
44 | 44 | |- |
45 | 45 | | rad750_3u || defined || undefined || 0 || 1 |
46 | 46 | |- |
47 | | | rad750_3u_debug || defined || undefined || 0 || 0 |
| 47 | | rad750_3u_debug || defined || undefined || 1 || 0 |
48 | 48 | |- |
49 | 49 | | rad750_6u || undefined || defined || 0 || 1 |
50 | 50 | |- |
51 | | | rad750_6u_debug || undefined || defined || 0 || 0 |
| 51 | | rad750_6u_debug || undefined || defined || 1 || 0 |
52 | 52 | |- |
53 | 53 | |} |
| 54 | |
| 55 | The following constants are the same for all configurations: |
| 56 | * BSP_DIRTY_MEMORY = 0 |
| 57 | * BSP_PRESS_KEY_FOR_RESET = 0 |
| 58 | * CONSOLE_USE_INTERRUPTS = 0 |
| 59 | * ENHANCED_PPCI = 1 |
54 | 60 | |
55 | 61 | The constants are defined as follows: |
56 | 62 | |
57 | 63 | * BSP_DIRTY_MEMORY - When set to 1, the BSP Framework will not put a non-zero pattern into the RTEMS Workspace and C program heap. |
58 | | == = |
59 | | |
60 | | * BSP_PRESS_KEY_FOR_RESET = 0 The application will not print a message and wait until pressed before resetting board when application exits |
61 | | * BSP_RESET_BOARD_AT_EXIT = 1 The board will be reset when the application exits. |
62 | | * CONSOLE_USE_INTERRUPTS = 0 The console operates in polled mode |
63 | | * ENABLE_SHADOWED_DATA = 1 A sh ==- When filling in the box, |
| 64 | * BSP_PRESS_KEY_FOR_RESET - The application will not print a message and wait until pressed before resetting board when application exits |
| 65 | * ENHANCED_PPCI - Indicating that the board has the enhanced PPCI chip |
| 66 | * CONSOLE_USE_INTERRUPTS - The console operates in polled mode |
| 67 | * ENABLE_SHADOWED_DATA - A shadow copy of initialized data is made on the first run and is reloaded on subsequent runs. |
| 68 | * BSP_RESET_BOARD_AT_EXIT = 1 The board will be reset when the application exits.== ==- When filling in the box, |
64 | 69 | + Try to include links to other Wiki pages and websites. |
65 | 70 | + If a field is not applicable, not setting the variable will result in it not being displayed |
100 | 105 | {| border="1" style="margin: 1em auto 1em auto;text-align: center;" |
101 | 106 | |+ |
102 | | |'''BSP Variant''' || '''rad750_3u''' || '''rad750_6u''' || '''BSP_DIRTY_MEMORY''' || '''BSP_PRESS_KEY_FOR_RESET''' |
| 107 | |'''BSP Variant''' || '''rad750_3u''' || '''rad750_6u''' || '''ENABLE_SHADOWED_DATA''' || '''BSP_RESET_BOARD_AT_EXIT''' |
103 | 108 | |- |
104 | 109 | | rad750_3u || defined || undefined || 0 || 1 |
105 | 110 | |- |
106 | | | rad750_3u_debug || defined || undefined || 0 || 0 |
| 111 | | rad750_3u_debug || defined || undefined || 1 || 0 |
107 | 112 | |- |
108 | 113 | | rad750_6u || undefined || defined || 0 || 1 |
109 | 114 | |- |
110 | | | rad750_6u_debug || undefined || defined || 0 || 0 |
| 115 | | rad750_6u_debug || undefined || defined || 1 || 0 |
111 | 116 | |- |
112 | 117 | |} |
| 118 | |
| 119 | The following constants are the same for all configurations: |
| 120 | * BSP_DIRTY_MEMORY = 0 |
| 121 | * BSP_PRESS_KEY_FOR_RESET = 0 |
| 122 | * CONSOLE_USE_INTERRUPTS = 0 |
| 123 | * ENHANCED_PPCI = 1 |
113 | 124 | |
114 | 125 | The constants are defined as follows: |
115 | 126 | |
116 | 127 | * BSP_DIRTY_MEMORY - When set to 1, the BSP Framework will not put a non-zero pattern into the RTEMS Workspace and C program heap. |
117 | | = == |
| 128 | * BSP_PRESS_KEY_FOR_RESET - The application will not print a message and wait until pressed before resetting board when application exits |
| 129 | * ENHANCED_PPCI - Indicating that the board has the enhanced PPCI chip |
| 130 | * CONSOLE_USE_INTERRUPTS - The console operates in polled mode |
| 131 | * ENABLE_SHADOWED_DATA - A shadow copy of initialized data is made on the first run and is reloaded on subsequent runs. |
| 132 | * BSP_RESET_BOARD_AT_EXIT = 1 The board will be reset when the application exits.= == |
118 | 133 | |
119 | | * BSP_PRESS_KEY_FOR_RESET = 0 The application will not print a message and wait until pressed before resetting board when application exits |
120 | | * BSP_RESET_BOARD_AT_EXIT = 1 The board will be reset when the application exits. |
121 | | * CONSOLE_USE_INTERRUPTS = 0 The console operates in polled mode |
122 | | * ENABLE_SHADOWED_DATA = 1 A shadow copy of initialized data is made on the first run and is reloaded on subsequent runs. |
123 | | * ENHANCED_PPCI = 1 Indicating that the board has the enhanced PPCI chip |
| 134 | |
| 135 | |
124 | 136 | * PPC_USE_DATA_CACHE = 0 Data cache is disabled |
125 | 137 | * PPC_USE_INSTRUCTION_CACHE = 1 Instruction cache is enabled |
