- Timestamp:
11/06/18 16:56:51 (6 years ago)
- Author:
Madhav Mehndiratta
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v2
v3
1 | 1 | = Mbx821-001 = |
2 | 2 | |
| 3 | ||BSP_name||MBX821-001|| |
| 4 | ||Manufacturer||Motorola|| |
| 5 | ||Image|||| |
| 6 | ||Caption||optional image caption|| |
| 7 | ||Board_URL||http://www.equinox-tech.com/downloads/freescale/MBXA_IH1.pdf|| |
| 8 | ||Architecture||PowerPc|| |
| 9 | ||CPU_model||MPC821|| |
| 10 | ||Simulator||N/A|| |
| 11 | ||RAM||4 MB DRAM|| |
| 12 | ||NVRAM||32 KB NVRAM with battery backup and low battery indication|| |
| 13 | ||Non-Volatile Memory||2 MB Flash|| |
| 14 | ||Serial||1xCOM1 serial port and 1xIEEE1284 bidirectional parallel port|| |
| 15 | ||Other||The board has an lcd panel connector and has an SCC1 port that is coupled to an Ethernet transceiver that supports both AUI and 10Base-T connections|| |
3 | 16 | |
4 | | {{Infobox BSP |
5 | | |BSP_name = MBX821-001 |
6 | | |Manufacturer = Motorola |
7 | | |image = |
8 | | |caption = optional image caption |
9 | | |Board_URL = http://www.equinox-tech.com/downloads/freescale/MBXA_IH1.pdf |
10 | | |Architecture = PowerPc |
11 | | |CPU_model = MPC821 |
12 | | |Simulator = N/A |
13 | | |RAM = 4 MB DRAM |
14 | | |NVRAM = 32 KB NVRAM with battery backup and low battery indication |
15 | | |Non-Volatile Memory = 2 MB Flash |
16 | | |Serial = 1xCOM1 serial port and 1xIEEE1284 bidirectional parallel port |
17 | | |Other = The board has an lcd panel connector and has an SCC1 port that is coupled to an Ethernet transceiver that supports both AUI and 10Base-T connections |
18 | | }} |
| 17 | |
19 | 18 | = Overview = |
20 | 19 | = Processor = |
