@186c891
05/16/22 11:59:20 |
karel |
bsps/stm32h7: set default SDRAM x sizes on stm32h757i-eval BSP
This …
@42ed4a63
05/16/22 11:28:57 |
karel |
bsps/stm32h7: provide linkcmds for SRAM, FLASH_SDRAM and SRAM_SDRAM …
@3aab95f
05/16/22 11:18:24 |
karel |
bsps/stm32h7: add and enable test set exclusion for stm32h757i-eval …
@1ea6540c
05/16/22 11:11:09 |
karel |
bsps/stm32h7: disable all U(S)ARTs except USART1 on stm32h757i-eval …
@12491244
05/16/22 11:01:39 |
karel |
bsps/stm32h7: add configuration and enable build of stm32h757i-eval …
@6553bf4
05/20/22 09:30:03 |
gabriel.moyano |
testsuites/sptests: Add sppps01 test
Update #2349.
@31f756b0
05/15/22 20:10:43 |
karel |
bsp/stm32h7: copy system files to nucleo-h743zi board directory
Also …
@f8a9a47d
05/15/22 20:10:42 |
karel |
bsp/stm32h7: copy system files to stm32h743i-eval board directory
@7234516c
05/15/22 20:10:38 |
karel |
bsp/stm32h7: copy system files to stm32h7b3i-dk board directory
Also …
@836eeb6
05/15/22 20:10:37 |
karel |
bsp/stm32h7: move compilation of system files to BSPs spec. files
The …
@4e449f49
05/05/22 06:17:05 |
Sebastian Huber |
build: Check for psxtests prerequisites
Close #4645.
@7beb4fa
04/06/22 14:23:43 |
Sebastian Huber |
build: Remove obsolete test excludes
@9abcaae
03/14/22 14:04:51 |
Sebastian Huber |
bsps: Add <dev/irq/arm-gicv3.h>
Separate the Interrupt Manager …
@c1a6e62
10/06/21 06:13:00 |
Sebastian Huber |
unit: Test red-black trees
@7ca6eeee
09/17/20 11:11:47 |
Sebastian Huber |
unit: Add test for misaligned builtin memcpy()
@95e3ade
09/17/20 11:10:41 |
Sebastian Huber |
unit: Add a unit test suite
@39439d4
04/06/22 07:36:38 |
Sebastian Huber |
bsp/stm32h7: Disable some tests for a variant
Making this BSP a small …
@282fba3
04/05/22 12:16:07 |
karel |
bsps/stm32h7: link to flash on STM32H7B3I-DK
The patch is needed due …
@bf64ff2
04/01/22 16:14:15 |
karel |
bsp/stm32h7: use appropriate STM32H7B3xxQ define for STM32H7B3I-DK BSP …
@2414d9b1
04/01/22 16:14:14 |
karel |
bsp/stm32h7: configure S(D)RAM values for STM32H7B3I-DK BSP variant
@c2e4128f
04/01/22 16:14:13 |
karel |
bsp/stm32h7: HSE clock value configuration for STM32H7B3I-DK BSP variant
@c48bedd
04/01/22 16:14:12 |
karel |
bsp/stm32h7: add flash latency configuration
@0acc1360
04/01/22 16:14:11 |
karel |
bsp/stm32h7: add configuration for USART1 GPIO pins, registers and …
@51db61a
04/01/22 16:14:10 |
karel |
bsp/stm32h7: disable UART 5, 7, 8, 9 and USART 3, 6, 10 for …
@044bc3c
04/01/22 16:14:09 |
karel |
bsp/stm32h7: add power supply configuration
@1050b629
04/01/22 16:14:08 |
karel |
bsp/stm32h7: add spec file for the STM32H7B3I-DK BSP variant
@9f9f140
03/29/22 13:23:29 |
Sebastian Huber |
rtems: Clarify scheduler of created task
@c2d7376
03/29/22 14:31:25 |
Sebastian Huber |
validation: Use individual names for ident tests
Make the task …
@3661518
03/10/22 13:11:12 |
Sebastian Huber |
smp: Add fatal error
Add SMP-specifc …
@14de245d
12/09/21 15:25:29 |
Sebastian Huber |
validation: Test support functions
The test source code is generated …
@ab2c04a
12/09/21 15:25:12 |
Sebastian Huber |
validation: Test thread implementation
The test source code is …
@4a8f4b7
12/09/21 15:24:46 |
Sebastian Huber |
validation: Test SMP-specific aspects
@ff50664
12/09/21 15:22:28 |
Sebastian Huber |
validation: Test scheduler operations
@9f283e7
12/09/21 15:22:11 |
Sebastian Huber |
validation: Test C libary functions
@c24747a6
12/09/21 15:21:26 |
Sebastian Huber |
validation: Test <sys/lock.h> mutex operations
The test source code …
@5fb7ce8
12/09/21 15:21:08 |
Sebastian Huber |
validation: Test futex support
The test source code is generated from …
@fa660c4d
12/09/21 15:20:45 |
Sebastian Huber |
validation: Test status code directives
@7eb4fc8d
12/09/21 15:19:41 |
Sebastian Huber |
validation: Test timecounter
@bc0cd69
12/09/21 15:19:24 |
Sebastian Huber |
validation: Test object services
@c88db0f
12/09/21 15:17:23 |
Sebastian Huber |
validation: Test User Extensions Manager
@565a7e66
12/09/21 15:17:07 |
frank.kuehndel |
validation: Test Timer Manager
@6b293904
09/07/21 11:56:42 |
Sebastian Huber |
validation: Test Task Manager
@32e472a7
09/07/21 11:56:42 |
Sebastian Huber |
validation: Test Signal Manager
@43adf2e
12/09/21 15:16:34 |
Sebastian Huber |
validation: Test Semaphore Manager
@1c87bb5
12/09/21 15:15:46 |
Sebastian Huber |
validation: Test Scheduler Manager
@98091b6d
12/09/21 15:14:37 |
frank.kuehndel |
validation: Test Rate Monotonic Manager
@5c85024
12/09/21 15:14:24 |
Sebastian Huber |
validation: Test Partition Manager
@372ff26
12/09/21 15:14:08 |
Sebastian Huber |
validation: Test options
@b63084a
12/09/21 15:13:58 |
Sebastian Huber |
validation: Test task modes
@04fb7b6
12/09/21 15:12:55 |
frank.kuehndel |
validation: Test Message Manager
@134b4cb7
12/09/21 15:12:23 |
Sebastian Huber |
validation: Test IO Manager
@aebf6b6
09/02/21 13:29:10 |
Sebastian Huber |
validation: Test Interrupt Manager
@8d3fe04
12/09/21 15:11:43 |
Sebastian Huber |
validation: Test Event Manager
@32ca0c47
12/09/21 15:11:08 |
Sebastian Huber |
validation: Test rtems_cpu_usage_reset()
@034d0b2
12/09/21 15:10:46 |
frank.kuehndel |
validation: Test Clock Manager
@b322a3ba
12/09/21 15:10:25 |
Sebastian Huber |
validation: Test Cache Manager
@99544e3
12/09/21 15:09:47 |
frank.kuehndel |
validation: Test <rtems/score/basedefs.h>
@1410d5b8
07/15/21 08:02:40 |
Sebastian Huber |
validation: Test Barrier Manager
@0b26e099
12/09/21 15:09:03 |
Sebastian Huber |
validation: Test attributes
@ca4d9ea
12/09/21 15:08:42 |
Sebastian Huber |
validation: Test application configuration
@d9a07fd8
12/09/21 15:05:48 |
Sebastian Huber |
validation: Test object identification
@a4b77184
12/09/21 15:05:27 |
Sebastian Huber |
validation: Test mutex operations
@a6b4a3b0
12/09/21 15:05:09 |
Sebastian Huber |
validation: Test semaphore operations
@7db4c14b
12/09/21 15:02:20 |
Sebastian Huber |
validation: Test thread queues
@c39133b8
12/10/21 08:41:22 |
Sebastian Huber |
validation: Add system termination test suites
@212b0ca
12/09/21 14:58:14 |
Sebastian Huber |
validation: Add test suites
@40cc4f5
12/09/21 14:49:53 |
Sebastian Huber |
validation: Improve support library
Update #3716.
@cc1c944
04/08/21 06:18:20 |
Sebastian Huber |
libtest: Add scheduler test support
Add support to record scheduler …
@d0de6fd
07/15/21 14:51:17 |
Sebastian Huber |
score: Add _IO_Relax()
This function may be used to burn a couple of …
@5b1b2aa
03/23/22 16:17:56 |
Sebastian Huber |
build: Exclude rcxx01 test for sh BSPs
There seems to be a code size …
@14381c4
02/16/22 19:32:30 |
alex.white |
microblaze: Add JFFS2 AXI QSPI driver
This driver has been tested …
@1a23ee6
01/26/22 09:59:02 |
Sebastian Huber |
bsp/fvp: Use only vector table of start section
@b08ba92
03/08/22 08:22:43 |
Sebastian Huber |
smptests/smpstart01: New test program
Update #4627.
@3cf618b3
02/25/22 14:02:05 |
Sebastian Huber |
bsps/riscv: Support .riscv.attributes
@fa944c5
02/23/22 16:11:34 |
kinsey.moore |
spec/microblaze: Use configurable RAM size
When committed, the …
@3317d1e
01/26/22 16:57:49 |
kinsey.moore |
cpukit/libdebugger: Add MicroBlaze? support
Add MicroBlaze? support for …
@8f1e8f8f
02/07/22 15:10:45 |
Sebastian Huber |
kern_ntptime.c: Port to RTEMS
Remove previous adjtime() …
@ace9955
01/26/22 16:56:54 |
kinsey.moore |
cpukit/microblaze: Add exception extensions
Add the functions …
@530a8c2
01/26/22 16:33:31 |
kinsey.moore |
cpukit/microblaze: Add debug vector and handler
This patch adds a …
@127980c
01/26/22 16:18:46 |
kinsey.moore |
cpukit/microblaze: Add exception framework
This patch updates the …
@37543e19
12/23/21 23:33:39 |
alex.white |
microblaze: Add support for libbsd networking
This includes fixes and …
@50a6580
12/20/21 16:55:41 |
Jennifer Averett |
microblaze: Add support for libbsd.
@20ca3b09
01/28/22 07:42:03 |
Sebastian Huber |
sparc: Mark dl06 as expected fail
@b539af8
01/26/22 22:00:04 |
kinsey.moore |
cpukit: Prevent error with disabled stack checker
When the stack …
@2145e0c7
01/26/22 10:01:44 |
Sebastian Huber |
Remove obsolete rtems_gxx_*() implementation
GCC versions prior to …
@4e530464
01/15/22 18:45:46 |
Sebastian Huber |
bsps: Default to CPU counter benchmark timer
Most BSPs which used the …
@944c210
01/14/22 15:06:44 |
Sebastian Huber |
bsp/imx7: dl06 fails expectedly
@6c36cb7a
01/06/22 20:28:34 |
Gedare Bloom |
aarch64: always boot into EL1NS
Always start the executive in …
@b982b8d4
01/11/22 15:15:51 |
Sebastian Huber |
build: Fix build item format
@18e47db5
12/11/21 10:43:44 |
Sebastian Huber |
bsp/mrm332: Fix TLS support in linker command file
@e92bc254
12/17/21 16:25:52 |
joel |
Remove powerpc/haleakala board
Closes #4302.
@2d75d5d
12/11/21 10:44:44 |
Sebastian Huber |
bsps/arm: Add missing Cache Manager source file
@0f5fa026
12/09/21 01:06:29 |
kinsey.moore |
spec: Update location of cadence I2C
When the cadence I2C code was …
@4c20360d
12/09/21 12:31:10 |
Sebastian Huber |
build: Move test header to right library item
@0d83bed2
12/02/21 13:00:53 |
Sebastian Huber |
rtems: Move scheduler directives to own header
Move all …
@d7205f0
04/08/20 15:14:41 |
Sebastian Huber |
libc: Optimize malloc() initialization
The BSPs provide memory for …
@3d0620b
04/08/20 14:54:34 |
Sebastian Huber |
score: Optimize Workspace Handler initialization
The BSPs provide …
@2de3a6e
11/29/21 07:35:43 |
Sebastian Huber |
build: Use common objects item for get memory
@0bd28da
04/09/20 07:31:28 |
Sebastian Huber |
score: Split wkspace.c
Splitting the file avoids unnecessary …
@dd70c81
11/25/21 01:43:10 |
joel |
bsp_specs: Delete last remnants of these.
Updates #3937.
