Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @fa3b4a2   04/16/19 05:54:11 andreas.dachsberger doxygen: score: adjust doc in stackimpl.h to doxygen guidelines … 5
(edit) @0e829b26   04/16/19 05:52:50 andreas.dachsberger doxygen: score: adjust doc in stackimpl.h to doxygen guidelines … 5
(edit) @0938899   04/16/19 05:46:47 andreas.dachsberger doxygen: score: adjust doc in stack.h to doxygen guidelines Update #3706. 5
(edit) @366dbf6   04/15/19 10:07:51 andreas.dachsberger doxygen: score: adjust doc in smplockticket.h to doxygen guidelines … 5
(edit) @c624340e   04/15/19 10:02:01 andreas.dachsberger doxygen: score: adjust doc in smplockstats.h to doxygen guidelines … 5
(edit) @2adc5f10   04/15/19 09:40:57 andreas.dachsberger doxygen: score: adjust doc in smplockseq.h to doxygen guidelines … 5
(edit) @93afceb2   04/15/19 09:38:21 andreas.dachsberger doxygen: score: adjust doc in smplockmcs.h to doxygen guidelines … 5
(edit) @9503db61   04/15/19 09:33:36 andreas.dachsberger doxygen: score: adjust doc in smplock.h to doxygen guidelines Update … 5
(edit) @79249a5   04/15/19 09:22:42 andreas.dachsberger doxygen: score: adjust doc in smpimpl.h to doxygen guidelines Update … 5
(edit) @d057bb29   04/15/19 09:06:20 andreas.dachsberger doxygen: score: adjust doc in smpbarrier.h to doxygen guidelines … 5
(edit) @6a9cb56   04/15/19 09:04:06 andreas.dachsberger doxygen: score: adjust doc in semaphoreimpl.h to doxygen guidelines … 5
(edit) @ee3351c   04/15/19 08:43:48 andreas.dachsberger doxygen: score: adjust doc in schedulerstrongapa.h to doxygen … 5
(edit) @6a1734a3   04/15/19 08:17:38 andreas.dachsberger doxygen: score: adjust doc in schedulersmpimpl.h to doxygen guidelines … 5
(edit) @ceff06f   04/15/19 06:21:20 andreas.dachsberger doxygen: score: adjust doc in schedulersmp.h to doxygen guidelines … 5
(edit) @1bfdc06   04/15/19 06:13:28 andreas.dachsberger doxygen: score: adjust doc in schedulersimplesmp.h to doxygen … 5
(edit) @f8047f14   04/15/19 05:48:42 andreas.dachsberger doxygen: score: adjust doc in schedulersimpleimpl.h to doxygen … 5
(edit) @d0839dd   04/12/19 11:26:40 andreas.dachsberger doxygen: score: adjust doc in scheduleredfsmp.h to doxygen guidelines … 5
(edit) @776ec05   04/12/19 11:16:01 andreas.dachsberger doxygen: score: adjust doc in schedulersimple.h to doxygen guidelines … 5
(edit) @391f92b9   04/12/19 11:07:54 andreas.dachsberger doxygen: score: adjust doc in schedulerprioritysmp.h to doxygen … 5
(edit) @ed6b2e0   04/12/19 10:58:30 andreas.dachsberger doxygen: score: adjust doc in schedulerpriorityimpl.h to doxygen … 5
(edit) @4aed194   04/12/19 10:47:23 andreas.dachsberger doxygen: score: adjust doc in schedulerpriority.h to doxygen … 5
(edit) @263fa5ef   04/12/19 10:37:52 andreas.dachsberger doxygen: score: adjust doc in schedulerpriorityaffinitysmp.h to … 5
(edit) @08901bf   04/12/19 10:08:07 andreas.dachsberger doxygen: score: adjust doc in schedulernodeimpl.h to doxygen … 5
(edit) @d5548b65   04/12/19 10:00:26 andreas.dachsberger doxygen: score: adjust doc in schedulernode.h to doxygen guidelines … 5
(edit) @11e7893   04/12/19 09:55:49 andreas.dachsberger doxygen: score: adjust doc in schedulerimpl.h to doxygen guidelines … 5
(edit) @e2d575c2   04/12/19 08:24:34 andreas.dachsberger doxygen: score: adjust doc in scheduler.h to doxygen guidelines … 5
(edit) @6852f7e   04/12/19 07:30:38 andreas.dachsberger doxygen: score: adjust doc in scheduleredfimpl.h to doxygen guidelines … 5
(edit) @f660691   04/12/19 07:01:01 andreas.dachsberger doxygen: score: adjust doc in scheduleredf.h to doxygen guidelines … 5
(edit) @06821fa5   04/12/19 06:19:15 andreas.dachsberger doxygen: score: adjust doc in schedulercbsimpl.h to doxygen guidelines … 5
(edit) @65f19f0   04/12/19 06:14:23 andreas.dachsberger doxygen: score: adjust doc in schedulercbs.h to doxygen guidelines … 5
(edit) @334de12e   04/11/19 08:00:17 andreas.dachsberger doxygen: score: adjust doc in rbtreeimpl.h to doxygen guidelines … 5
(edit) @f61a3f85   04/11/19 07:58:04 andreas.dachsberger doxygen: score: adjust doc in rbtree.h to doxygen guidelines Update #3706. 5
(edit) @1e6a7c7a   04/11/19 07:36:03 andreas.dachsberger doxygen: score: adjust doc in protectedheap.h to doxygen guidelines … 5
(edit) @ee8eb21   04/11/19 07:12:25 andreas.dachsberger doxygen: score: adjust doc in profiling.h to doxygen guidelines … 5
(edit) @acdb99eb   04/11/19 06:57:09 andreas.dachsberger doxygen: score: adjust doc in processormask.h to doxygen guidelines … 5
(edit) @35a07c4   04/11/19 06:17:17 andreas.dachsberger doxygen: score: adjust doc in priorityimpl.h to doxygen guidelines … 5
(edit) @1d6e6b1f   04/10/19 09:06:35 andreas.dachsberger doxygen: score: adjust doc in priority.h to doxygen guidelines Update … 5
(edit) @536458a   04/10/19 09:05:31 andreas.dachsberger doxygen: score: adjust doc in prioritybitmapimpl.h to doxygen … 5
(edit) @96d37510   04/10/19 08:55:53 andreas.dachsberger doxygen: score: adjust doc in prioritybitmap.h to doxygen guidelines … 5
(edit) @0bef82f   04/10/19 08:54:48 andreas.dachsberger doxygen: score: adjust doc in percpudata.h to doxygen guidelines … 5
(edit) @316894e6   04/10/19 08:47:55 andreas.dachsberger doxygen: score: adjust doc in objectmp.h to doxygen guidelines Update … 5
(edit) @c389f5b7   04/10/19 08:29:08 andreas.dachsberger doxygen: score: adjust doc in objectimpl.h to doxygen guidelines … 5
(edit) @ae8be3f   04/10/19 07:20:24 andreas.dachsberger doxygen: score: adjust doc in object.h to doxygen guidelines Update #3706. 5
(edit) @0b1bfab   04/10/19 07:12:01 andreas.dachsberger doxygen: score: adjust doc in mrspimpl.h to doxygen guidelines Update … 5
(edit) @b817de6d   04/10/19 06:07:50 andreas.dachsberger doxygen: score: adjust doc in mrsp.h to doxygen guidelines Update #3706. 5
(edit) @3da777e   04/10/19 06:06:14 andreas.dachsberger doxygen: score: adjust doc in mppkt.h to doxygen guidelines Update #3706. 5
(edit) @57cd05cf   04/10/19 05:50:15 andreas.dachsberger doxygen: score: adjust doc in mpciimpl.h to doxygen guidelines Update … 5
(edit) @976c095   04/09/19 09:35:55 andreas.dachsberger doxygen: score: adjust doc in mpci.h to doxygen guidelines Update #3706. 5
(edit) @318b70b   04/09/19 09:34:40 andreas.dachsberger doxygen: score: adjust doc in isrlock.h to doxygen guidelines Update … 5
(edit) @bb0ccc1   04/09/19 09:32:40 andreas.dachsberger doxygen: score: adjust doc in isrlevel.h to doxygen guidelines Update … 5
(edit) @24787d08   04/09/19 09:30:21 andreas.dachsberger doxygen: score: adjust doc in isr.h to doxygen guidelines Update #3706. 5
(edit) @5ad74fd6   04/09/19 09:24:45 andreas.dachsberger doxygen: score: adjust doc in interr.h to doxygen guidelines Update #3706. 5
(edit) @4c99921   04/09/19 06:50:24 andreas.dachsberger doxygen: score: adjust doc in heapimpl.h to doxygen guidelines Update … 5
(edit) @cf6ce4a   04/08/19 10:37:53 andreas.dachsberger doxygen: score: adjust doc in heap.h to doxygen guidelines Update #3706. 5
(edit) @d69b7a5   04/08/19 10:22:37 andreas.dachsberger doxygen: score: adjust doc in freechain.h to doxygen guidelines … 5
(edit) @54733e6   04/08/19 10:08:56 andreas.dachsberger doxygen: score: adjust doc in cpustdatomic.h to doxygen guidelines … 5
(edit) @d5b63c2   04/08/19 09:18:36 andreas.dachsberger doxygen: score: adjust doc in coresemimpl.h to doxygen guidelines … 5
(edit) @eab90bf   04/08/19 08:29:29 andreas.dachsberger doxygen: score: adjust doc in coresem.h to doxygen guidelines Update … 5
(edit) @d16a9019   04/08/19 08:27:58 andreas.dachsberger doxygen: score: adjust doc in corerwlockimpl.h to doxygen guidelines … 5
(edit) @86b05bf6   04/08/19 08:09:54 andreas.dachsberger doxygen: score: adjust doc in coremuteximpl.h to doxygen guidelines … 5
(edit) @d369903   04/08/19 07:11:24 andreas.dachsberger doxygen: score: adjust doc in coremutex.h to doxygen guidelines … 5
(edit) @0865cd2   04/05/19 10:39:51 andreas.dachsberger doxygen: score: adjust doc in coremsgimpl.h to doxygen guidelines … 5
(edit) @accbe670   04/05/19 08:59:58 andreas.dachsberger doxygen: score: adjust doc in corebarrierimpl.h to doxygen guidelines … 5
(edit) @62128be0   04/05/19 08:55:44 andreas.dachsberger doxygen: score: added dox in assert.h according to doxygen guidelines … 5
(edit) @4bd8757   04/05/19 07:13:16 andreas.dachsberger doxygen: score: adjust doc in coremsg.h to doxygen guidelines Update … 5
(edit) @37ab908   04/05/19 07:09:19 andreas.dachsberger doxygen: score: adjust doc in corebarrier.h to doxygen guidelines … 5
(edit) @4bb0f00   04/05/19 07:07:10 andreas.dachsberger doxygen: score: adjust doc in copyrt.h to doxygen guidelines Also … 5
(edit) @59de8ef   04/05/19 07:03:31 andreas.dachsberger doxygen: score: adjust doc in context.h to doxygen guidelines Update … 5
(edit) @0153acf2   04/04/19 10:05:38 andreas.dachsberger doxygen: score: adjust doc in chainimpl.h to doxygen guidelines … 5
(edit) @827e260   04/04/19 08:23:18 andreas.dachsberger doxygen: score: adjust doc in chain.h to doxygen guidelines Update #3706. 5
(edit) @3b977b86   04/04/19 07:50:10 andreas.dachsberger doxygen: score: adjust doc in basedefs.h to doxygen guidelines Update … 5
(edit) @76a9857c   04/04/19 07:43:03 andreas.dachsberger doxygen: score: adjust doc in apimutex.h to doxygen guidelines Update … 5
(edit) @93dcd2b   04/04/19 07:01:43 andreas.dachsberger doxygen: score: adjust doc in address.h to doxygen guidelines Update … 5
(edit) @dda1922   05/10/19 07:09:40 Sebastian Huber score: Adjust PER_CPU_CONTROL_SIZE_APPROX Account for recent … 5
(edit) @b36c5209   05/03/19 00:15:20 Chris Johns libdl: Do not access the ELF file while the allocator is locked. - … 5
(edit) @ef9d20f6   04/12/19 09:13:32 Sebastian Huber score: More robust _SMP_Multicast_action() If the caller already … 5
(edit) @ad40d05e   04/12/19 05:55:31 Sebastian Huber score: Remove _SMP_Before_multitasking_action() Use … 5
(edit) @f410b31b   04/11/19 13:39:36 Sebastian Huber score: Improve _SMP_Multicast_action() Let it work during system … 5
(edit) @e90486a   04/11/19 13:16:40 Sebastian Huber score: Rework SMP multicast action Use a FIFO list of jobs per … 5
(edit) @df8d7bd7   04/09/19 08:58:35 Sebastian Huber score: Use processor mask in _SMP_Multicast_action Processor_mask is … 5
(edit) @e97b7c9a   04/11/19 11:47:50 Sebastian Huber score: Use an ISR lock for Per_CPU_Control::Lock The use of a hand … 5
(edit) @18d45d9   04/11/19 10:10:53 Sebastian Huber score: Add _ISR_lock_Set_name() Add _ISR_lock_Set_name() to optimize … 5
(edit) @5ca8190b   04/11/19 09:48:18 Sebastian Huber score: Remove unused macros 5
(edit) @ad87de4   04/11/19 06:54:29 Sebastian Huber score: Rename _SMP_Get_processor_count() Rename … 5
(edit) @cfcd6dc9   04/11/19 06:52:36 Sebastian Huber score: Rename _SMP_Processor_count Rename _SMP_Processor_count in … 5
(edit) @8aaa055   04/06/19 12:30:05 Sebastian Huber posix: Avoid fatal error in Shm object create 5
(edit) @1bf2f16   04/06/19 12:26:00 Sebastian Huber posix: Avoid workspace for queued signals 5
(edit) @e6a8410   04/06/19 12:28:19 Sebastian Huber posix: _Configuration_POSIX_Minimum_stack_size Rename to use proper … 5
(edit) @b0e335c2   04/06/19 12:19:11 Sebastian Huber posix: _Configuration_POSIX_Maximum_queued_signals Rename to use … 5
(edit) @369bf2c4   04/06/19 08:32:46 Sebastian Huber config: Obsolete Go configuration options Update #2832. 5
(edit) @581cce26   04/09/19 07:51:50 Chris Johns libdebugger: Fix for ARMv7-M with -O0 optimization 5
(edit) @f9219db   04/05/19 06:16:05 Sebastian Huber rtems: Add rtems_scheduler_get_processor_maximum() Add … 5
(edit) @03c9f24   04/05/19 06:03:12 Sebastian Huber rtems: Add rtems_scheduler_get_processor() Add … 5
(edit) @3c50c328   04/05/19 06:42:01 Sebastian Huber score: Add RTEMS_CONST Close #3734. 5
(edit) @e0dcf294   04/05/19 07:58:07 Sebastian Huber Remove superfluous run-time check The _Objects_Information_table[ … 5
(edit) @2c09b71f   04/08/19 03:17:08 Chris Johns libdebugger: Use an offset table to format GDB g packets. Adding … 5
(edit) @8a8b95aa   04/04/19 07:54:27 Sebastian Huber doxygen: Update _Objects_Build_name() This is intended as an example … 5
(edit) @4c20da4b   04/04/19 07:18:11 Sebastian Huber doxygen: Rename Score* groups in RTEMSScore* Update #3706 5
(edit) @7b09032   04/03/19 06:49:07 andreas.dachsberger doxygen: Split up "libmisc" subgroups and removed libmisc Update #3706. 5
(edit) @c9bd696   04/03/19 06:31:25 andreas.dachsberger doxygen: New API subgroup Tracing Update #3706. 5
