@d88b0b78
03/12/15 08:04:20 |
cederman |
posix: Move function to file with matching name
mmap was previously …
4.115
@bfe6391
03/11/15 16:01:53 |
Joel Sherrill |
confdefs.h: Improve the Doxygen
4.115
@a2fe43b
03/10/15 21:56:14 |
Joel Sherrill |
cpukit/include/rtems/btimer.h: Add DOxygen comments
4.115
@a575af8
03/10/15 21:55:58 |
Joel Sherrill |
cpukit/include/rtems/bspIo.h: Add Doxygen comments
4.115
@bdf23b6c
03/10/15 17:39:59 |
Joel Sherrill |
cpukit: Remove old DESCRIPTION: in comments
These were remnants of …
4.115
@cf404563
03/10/15 19:28:19 |
Gedare Bloom |
cpukit: deprecate task variables. closes #2293.
4.115
@23e43f6
03/10/15 17:51:21 |
Gedare Bloom |
cpukit: deprecate rtems_clock_get(). closes #2294.
4.115
@3ac68119
03/06/15 17:41:49 |
Gedare Bloom |
cpukit: deprecate notepads
Deprecate Classic API Notepads. Mark …
4.115
@b05549fc
03/10/15 14:10:39 |
Joel Sherrill |
cpukit/libcrypt/misc.c: Reverse order of statements in ifdef
4.115
@f244bfc5
03/09/15 12:18:35 |
Sebastian Huber |
posix: Install <semaphore.h> only if not provided
4.115
@1f67156
03/09/15 12:18:36 |
Sebastian Huber |
libcsupport: Delete superfluous _gettimeofday()
4.115
@77e682ec
03/09/15 12:18:33 |
Sebastian Huber |
posix: Change sem_t to the 32-bit object type
This change is also …
4.115
@60bded9
03/10/15 07:48:26 |
Sebastian Huber |
posix: Use a value of 0 for SEM_FAILED
This is the standard NULL pointer.
4.115
@f0ff18e
03/09/15 12:18:32 |
Sebastian Huber |
score: Add rtems_set_errno_and_return_value()
Remove …
4.115
@34e0a569
03/09/15 21:56:08 |
Joel Sherrill |
cpukit/libmisc/fsmount/fsmount.h: Remove duplicate comments and copyright
4.115
@015211b
03/09/15 21:45:40 |
Joel Sherrill |
cpukit/dev/include/dev/i2c/i2c.h: Fix Doxygen grouping
4.115
@1aa7b8b
03/09/15 21:07:36 |
Joel Sherrill |
Move contents of libcsupport/include/zilog into libbsp/shared
Only a …
4.115
@6796d9c
03/09/15 20:50:27 |
Joel Sherrill |
Remove unused cpukit/libcsupport/include/zilog/z8536.h
4.115
@5bc6237
03/09/15 20:47:47 |
Joel Sherrill |
Move libcsupport/include/motorola/*.h to m68k/idp BSP
These header …
4.115
@865f10d1
03/09/15 12:50:07 |
Joel Sherrill |
cpukit/libcrypt/misc.c: Conditionally correct 16-bit unclean code
4.115
@d9cda35
03/08/15 23:30:44 |
Joel Sherrill |
cpukit/libdl/rtl-mdreloc-m32r.c: Add parentheses per Chris' suggestion
4.115
@2468aa3d
03/08/15 19:34:31 |
Joel Sherrill |
vprintk.c: Reorder switch and add default to eliminate warning
4.115
@ef598c37
03/08/15 19:08:31 |
Joel Sherrill |
or1k/rtems/score/cpu.h: Add no_return attribute to _CPU_Context_restore
4.115
@4f4e7bb6
03/08/15 18:52:33 |
Joel Sherrill |
cpukit/score/cpu/sh/context.c: Correct name of _CPU_Context_switch
4.115
@2a11a46f
03/08/15 18:52:00 |
Joel Sherrill |
or1k: Correct _CPU_Thread_Idle_body prototype
4.115
@40ecd11
03/09/15 14:23:20 |
Sebastian Huber |
sysconf: Add _SC_NPROCESSORS_(CONF|ONLN)
4.115
@8552df6
03/09/15 14:23:12 |
Sebastian Huber |
sysconf: Simplify
4.115
@bf11690
03/09/15 10:47:47 |
Sebastian Huber |
network: Avoid clash with FreeBSD <sys/time.h>
4.115
@25ce352b
03/09/15 10:43:55 |
Sebastian Huber |
score: Fix for GCC version 5 and later
4.115
@7b4e81d
03/09/15 07:51:55 |
Sebastian Huber |
score: Typo
Close #2286.
4.115
@19a1f6b
03/06/15 14:34:03 |
Joel Sherrill |
Temporarily disable libdl for h8300
The h8300 gets a linking error …
4.115
@7af34c13
03/05/15 15:51:40 |
Joel Sherrill |
Always disable networking for h8300
4.115
@a726ca64
03/05/15 23:33:38 |
Joel Sherrill |
Temporarily disable libdl for lm32
There is a GCC ICE when building …
4.115
@1d061ee
03/04/15 21:13:24 |
Joel Sherrill |
Temporarily disable libdl for v850
There is an issue linking dl0* …
4.115
@9bef63e
03/04/15 21:10:42 |
Joel Sherrill |
Temporarily disable libdl for bfin
4.115
@a7e4de2
03/06/15 20:33:08 |
Joel Sherrill |
Fix even more Doxygen issues
4.115
@325a61d5
03/06/15 20:06:49 |
Joel Sherrill |
coremuteximpl.h: Reorder macro names to match body and fix Doxygen …
4.115
@e0eb07a
03/06/15 19:26:12 |
Joel Sherrill |
Fix more Doxygen typos
4.115
@cc69334f
03/06/15 16:35:40 |
Joel Sherrill |
Fix a number of minor Doxygen formatting issues
4.115
@33b72fd
03/06/15 15:13:40 |
alexander.krutwig |
testsupport: Add cascade option to parallel test
4.115
@2bd71d95
03/06/15 13:41:24 |
Sebastian Huber |
shell: Add PROFREPORT command
4.115
@bf9d387
03/06/15 13:40:56 |
Sebastian Huber |
score: Allow NULL for SMP lock name
4.115
@da06fe9
03/06/15 12:20:44 |
Sebastian Huber |
score: Fix SMP lock implementation
See also:
4.115
@7183f1cd
03/05/15 10:51:25 |
Sebastian Huber |
score: Add compiler memory barrier to atomic ops
4.115
@7d6e94b
03/04/15 07:02:19 |
Sebastian Huber |
score: Implement fine-grained locking for events
Use the ISR lock of …
4.115
@4c8a0ac
03/04/15 07:02:09 |
Sebastian Huber |
score: Add thread wait flags
Update #2273.
4.115
@5b393fa5
03/01/15 12:50:55 |
Sebastian Huber |
score: Add thread acquire
Update #2273.
4.115
@43e1573c
02/28/15 17:06:37 |
Sebastian Huber |
score: Add ISR lock to Objects_Control
This enables per-object SMP …
4.115
@1512761
02/28/15 16:24:52 |
Sebastian Huber |
score: Thread dispatch dis/enable without Giant
Update #2273.
4.115
@222dc775
02/26/15 09:32:08 |
Sebastian Huber |
score: Add and use _Thread_Do_dispatch()
The _Thread_Dispatch() …
4.115
@6157743
02/23/15 15:54:54 |
Sebastian Huber |
score: Simplify and fix signal delivery
Deliver the POSIX signals …
4.115
@b8a5abf
02/26/15 09:33:36 |
Sebastian Huber |
score: Update _Thread_Heir only if necessary
Previously, the …
4.115
@81b03c6
03/05/15 07:11:27 |
Sebastian Huber |
score: Add and use PRIORITY_PSEUDO_ISR
4.115
@77510c7
03/05/15 09:53:20 |
Sebastian Huber |
libmd: Disable SHA modules for m32c
Close #2219.
4.115
@16b2de35
03/05/15 10:11:25 |
Sebastian Huber |
capture: Fix warnings
4.115
@c735cd5
03/05/15 09:34:28 |
Sebastian Huber |
dosfs: Fix warnings
4.115
@6fd5b4e
03/05/15 09:26:30 |
Sebastian Huber |
tests: Fix warning
4.115
@2c88438
03/05/15 09:26:22 |
Sebastian Huber |
IMFS: Fix warning
4.115
@29d36fa
03/05/15 08:58:43 |
Sebastian Huber |
IMFS: Include missing header file
4.115
@81c73acf
03/05/15 08:58:22 |
Sebastian Huber |
IMFS: Fix warning
4.115
@5d428576
03/05/15 08:57:18 |
Sebastian Huber |
libblock: Fix warning
4.115
@b8aa1c1
03/05/15 08:53:09 |
Sebastian Huber |
score: C/C++ compatibility macros for ISR locks
Update #2273.
4.115
@5b5d2fd4
03/05/15 08:37:36 |
Sebastian Huber |
Filesystem: Delete unused null_op_fsmount_me()
4.115
@7f577d3
03/05/15 08:06:44 |
alexander.krutwig |
tests: Refactor parallel test execution
4.115
@51acbdc
03/04/15 12:07:02 |
alexander.krutwig |
score: Documentation
4.115
@18d0a49
03/05/15 07:44:59 |
Sebastian Huber |
Move test support from sapi to libmisc/testsupport
4.115
@8ac3549
03/04/15 15:13:49 |
Sebastian Huber |
score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITY
4.115
@3358d62
03/04/15 23:15:41 |
Hesham Almatary |
score/cpu/or1k: Add cpuatomic.h to fix broken build.
4.115
@76f37656
02/25/15 19:52:10 |
Gedare Bloom |
libcsupport: scale times() call to microseconds
4.115
@e50297e
03/04/15 09:15:02 |
Sebastian Huber |
score: ISR lock C/C++ compatiblity issue
Empty structures are …
4.115
@d2ffb7dc
02/26/15 10:35:28 |
Sebastian Huber |
score: Add and use _Thread_Enable_dispatch_body()
Update #2273.
4.115
@b99be6e
02/26/15 10:32:45 |
Sebastian Huber |
score: Inline _Thread_Disable_dispatch() for SMP
4.115
@2b7fe356
02/26/15 09:29:02 |
Sebastian Huber |
score: Add parameter to Giant acquire/release
Update #2273.
4.115
@396ce49
03/03/15 20:51:24 |
Joel Sherrill |
xdr_float.c: Fix typo
4.115
@262a0d7
03/03/15 20:09:41 |
Hesham Almatary |
or1k/or1k-exception-default.c: Eliminate dependency on BSP provided .h file
4.115
@39655741
03/03/15 18:48:14 |
Hesham Almatary |
librpc: Include or1knd part of the recongnized CPUs at xdr_float.c
4.115
@4ccb79bc
03/02/15 11:23:20 |
Sebastian Huber |
score: Enable SMP barriers for all configurations
4.115
@63e91fe6
02/26/15 17:39:05 |
Martin Galvan |
ARM: Fix _ARMV4_Exception_fiq_default
In …
4.115
@c0e01a28
02/24/15 15:27:08 |
Gedare Bloom |
posix: fix error return code for pthread_mutex_trylock
4.115
@ee870077
12/22/14 00:50:31 |
Chris Johns |
Panic on RTEMS_FAST_MUTEX network semaphore claim/release.
Fix the …
4.115
@9d090fb7
02/23/15 20:42:59 |
Gedare Bloom |
sparc64: fix copyright notices.
The sparc64 port had some incorrect …
4.115
@ced84fc0
02/23/15 17:27:05 |
Jeffrey Hill |
rpc: misaligned pointer dereference in clnt_udp.c line 363
closes #2248
4.115
@49ff36b
02/23/15 17:06:21 |
Jeffrey Hill |
rpc: misaligned address exception in get_myaddress.c
closes #2249 see …
4.115
@25e14e31
02/23/15 15:46:22 |
strauman |
networking: alignment exception in ioctl(SIOCGIFCONF)
Access memory …
4.115
@a45dfa14
02/20/15 08:42:15 |
Sebastian Huber |
IMFS: Fix copy on write for linfiles
4.115
@5eb27ce
02/20/15 04:00:47 |
Nick Withers |
Don't fail to create passwd and group files if /etc already exists
4.115
@7f1bb40a
02/19/15 20:48:47 |
Gedare Bloom |
bfin: do not reset dispatch needed
Closes #2148
Fix suggested in …
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@fd14430
02/18/15 16:06:05 |
Sebastian Huber |
IMFS: Silence warning
4.115
@7fcb71a
02/17/15 12:43:57 |
Sebastian Huber |
score: Fix _Thread_Start_multitasking() on SMP
Close #2268.
4.115
@8d6e6eeb
02/17/15 09:00:43 |
Sebastian Huber |
score: Fix FP context restore via _Thread_Handler
After a context …
4.115
@c34f94f7
02/16/15 10:55:03 |
Sebastian Huber |
score: Add _CPU_SMP_Prepare_start_multitasking()
Update #2268.
4.115
@a43a3466
02/15/15 09:38:15 |
Sebastian Huber |
IMFS: Implement variable length node names
This reduces the average …
4.115
@f785492
02/14/15 19:07:19 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_READDIR
4.115
@2d84c4e
02/13/15 21:07:45 |
Sebastian Huber |
score: Mention ticket in comment
4.115
@249766c5
02/13/15 20:26:17 |
Sebastian Huber |
IMFS: Rename CONFIGURE_IMFS_DISABLE_FCHMOD
Rename …
4.115
@40a18d7f
02/13/15 20:11:55 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_MKNOD_FILE
4.115
@12eee4fd
02/13/15 19:53:41 |
Sebastian Huber |
IMFS: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
Resurrect …
4.115
@50f8bfd
02/13/15 17:52:43 |
Joel Sherrill |
sapi/Makefile.am: Do not install libsapi.a
sapi/preinstall.am: …
4.115
@353506b9
02/02/15 13:55:23 |
Sebastian Huber |
sys/event.h: Update to FreeBSD 9.3
4.115
