@d420b67
04/14/17 20:18:56 |
joel |
Merge tmacros.h PRIxxx constants from testsuites/ into …
5
@54bdf0c
04/14/17 18:55:48 |
joel |
rtems/inttypes.h: New file. Uses contents from cpukit
Provide …
5
@b53ad46
04/14/17 07:12:44 |
Chris Johns |
libdebugger: Work around assert when using _Thread_Executing.
Using …
5
@62c238e
04/08/17 10:30:50 |
cpodonnell8 |
cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning.
5
@d2390ce4
04/10/17 13:41:02 |
kevin-kirspel |
Updating default termios initialization for dedicated input/output …
5
@2c23639
04/07/17 20:40:11 |
cpodonnell8 |
libdl/rtl-obj-cache.c: Using inttypes macros fixes 4 format warnings
5
@c475924d
04/06/17 23:24:58 |
joel |
xz_config.h: Define XZ_USE_CRC64
close #2909.
5
@46f05b92
04/05/17 09:28:46 |
Sebastian Huber |
SMP: Simplify SMP multicast actions
5
@b3bfc242
04/04/17 08:39:45 |
Sebastian Huber |
sys/event.h: Update to FreeBSD head 2017-02-13
5
@1301468
04/03/17 10:51:51 |
Sebastian Huber |
bsps: Fix baud settings
Update #2897.
5
@36f0ac2
03/30/17 11:59:16 |
Sebastian Huber |
configure: Remove defunct configure stuff
5
@bba48d9
03/30/17 00:06:24 |
Chris Johns |
libdl: Support link ordered loading of ELF sections.
The ARM C++ …
5
@cd3d747
03/27/17 06:01:38 |
Sebastian Huber |
arm: Optimize context switch
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to …
5
@82c0836
03/28/17 05:51:16 |
Sebastian Huber |
posix: Fix pthread_detach() internal lock acquire
5
@70ddaa0e
03/28/17 06:18:06 |
Sebastian Huber |
rtems: Fix error return path
5
@5f382713
03/27/17 12:23:52 |
Sebastian Huber |
cpukit: Fix Makefile.am and update preinstall.am
Update #2897.
5
@94a4865
03/27/17 08:30:23 |
Sebastian Huber |
termios: Avoid invalid memory access
Update #2897.
5
@1c6926c1
03/21/17 19:39:48 |
kevin-kirspel |
termios: Synchronize with latest FreeBSD headers
Adding modified …
5
@d50ab079
03/16/17 14:12:20 |
Sebastian Huber |
dosfs: Fix file name search
Do not use our long file name entry count …
5
@dfd879fa
03/16/17 10:59:23 |
Sebastian Huber |
dosfs: Fix race condition msdos_dir_read()
Obtain file system …
5
@6c988987
03/16/17 07:03:42 |
Sebastian Huber |
dosfs: Rename fat_entries to lfn_entries
The name "fat_entries" for …
5
@5f8ed0d
03/16/17 06:44:38 |
Sebastian Huber |
dosfs: Fix long file name padding
Update #2934.
5
@e625a57
03/16/17 06:37:20 |
Sebastian Huber |
dosfs: msdos_filename_utf8_to_short_name_for_save
Simplify.
5
@b1daf0f
03/14/17 10:41:18 |
Sebastian Huber |
dosfs: Fix msdos_add_file()
Make sure that long file names work …
5
@1a9483e2
03/14/17 09:28:19 |
Sebastian Huber |
dosfs: Simplify msdos_add_file()
Update #2929.
5
@3efe749
03/14/17 08:36:07 |
Sebastian Huber |
dosfs: Add and use msdos_lfn_checksum()
Update #2929.
5
@063eb574
03/14/17 07:26:40 |
Sebastian Huber |
dosfs: Simplify fat_file_open()
Update #2929.
5
@ccd4a7f
03/14/17 07:13:07 |
Sebastian Huber |
dosfs: Simplify msdos_creat_node()
Update #2929.
5
@e69ee36
03/13/17 14:20:20 |
Sebastian Huber |
dosfs: Fix fat_file_write()
Remove forced overwrite which leads to …
5
@1becaa9
03/14/17 12:59:09 |
Sebastian Huber |
dosfs: Fix msdos_utf8_normalize_and_fold()
It is all right in case …
5
@66fac03
03/16/17 10:54:29 |
Sebastian Huber |
libio: Fix deadlock in location management
Perform a …
5
@b437a360
03/09/17 13:32:04 |
Sebastian Huber |
arm: Fix CPU context validation for Cortex-R4
Do not touch the …
5
@2433a8ab
03/07/17 13:32:42 |
Sebastian Huber |
arm: Remove legacy execption support
5
@36338fb
03/07/17 12:41:37 |
Sebastian Huber |
monitor: Do not zero sema id and name
5
@088acbb0
03/07/17 12:07:02 |
Sebastian Huber |
score: Fix scheduler yield in SMP configurations
Check that no ask …
5
@f61195b2
03/06/17 10:16:25 |
Sebastian Huber |
powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE
5
@84557ef
02/06/17 14:11:55 |
cederman |
libdrvmgr: remove braces
5
@418149c8
02/01/17 09:48:38 |
Daniel Hellstrom |
libdrvmgr: added default BSP init level hook
5
@91df5a69
01/02/15 12:17:18 |
Daniel Hellstrom |
libpci: code cleanup
5
@1f618ab0
03/02/17 06:54:52 |
Sebastian Huber |
posix_devctl: Fix for pre C99
Use restrict just like in <devctl.h> …
5
@a60db69
02/27/17 10:50:30 |
Sebastian Huber |
dosfs: Fix FAT32 formatter
The second FAT entry contains a bit to …
5
@267de79a
02/27/17 09:40:49 |
Sebastian Huber |
dosfs: Directories should have a file size of 0
Close #2755.
5
@f71ccc34
02/28/17 08:12:13 |
Sebastian Huber |
termios: Simplify some calculations
Use the modular arithmetic …
5
@36635433
02/24/17 13:44:04 |
Sebastian Huber |
termios: Implement non-blocking write
5
@a165a96
02/23/17 14:43:41 |
Sebastian Huber |
termios: Make write POSIX compatible
Currently only blocking …
5
@c41b47e3
02/23/17 14:19:47 |
Sebastian Huber |
termios: Introduce doTransmit()
5
@5244d31e
02/23/17 13:04:24 |
Sebastian Huber |
termios: Simplify oproc()
Call rtems_termios_puts() only once. …
5
@c80f6aa9
02/24/17 09:29:05 |
Sebastian Huber |
termios: Fix infinite loop in receive path
In canonical mode, the raw …
5
@9fa0f54
02/23/17 10:35:44 |
Sebastian Huber |
termios: Change receive callback invocation
Call the receive callback …
5
@49d8f653
02/23/17 08:38:54 |
Sebastian Huber |
termios: Change tty_rcvwakeup to bool
Optimize callout invocation check.
5
@9f69ac2
02/23/17 09:35:16 |
Sebastian Huber |
termios: Ignore carriage return early if desired
In case carriage …
5
@bb087cb0
02/23/17 09:06:52 |
Sebastian Huber |
termios: Protect raw input buffer with device lock
Use the device …
5
@d60c2d79
02/23/17 08:12:36 |
Sebastian Huber |
termios: Simplify rtems_termios_read_tty()
Remove dead code.
Update …
5
@5bfeddc0
02/21/17 08:01:49 |
Sebastian Huber |
termios: Add kqueue() and poll() support
Real implementation is …
5
@c833970
02/21/17 07:58:29 |
Sebastian Huber |
score: Add RTEMS_WEAK_ALIAS()
5
@3398602
02/21/17 14:25:03 |
Sebastian Huber |
Add rtems_interrupt_server_request_submit()
This function may be used …
5
@df184eb
08/10/15 04:21:02 |
Nick Withers |
Remove old CVS keywords
Update #2388.
5
@c847451b
02/15/17 12:22:36 |
Sebastian Huber |
sapi: Fix warnings
5
@661be20
02/15/17 12:05:27 |
Sebastian Huber |
shell: Fix warnings
5
@f5cf2fe
02/15/17 10:19:50 |
Sebastian Huber |
libdl: Fix warning
5
@7a462cc
02/15/17 10:09:32 |
Sebastian Huber |
score: Fix warning
5
@468e9a4
02/14/17 10:10:40 |
Sebastian Huber |
monitor: Print short and long task names
Print wait object identifier …
5
@54835ae
02/01/17 13:10:18 |
Sebastian Huber |
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS
Rename …
5
@5eee718
02/14/17 07:46:22 |
Sebastian Huber |
shell: Fix warnings
5
@6dbbafc6
02/14/17 07:42:48 |
Sebastian Huber |
score: Fix warning in _Thread_Set_name()
5
@d9c65429
02/13/17 14:13:02 |
Sebastian Huber |
dosfs: Fix msdos_find_file_in_directory()
For a filename match the …
5
@07d71279
02/01/17 13:48:17 |
Sebastian Huber |
Prefix confdefs.h internal def with an underscore
Close #2895.
5
@85ed95e
02/03/17 09:49:13 |
Sebastian Huber |
termios: Fix static device initalization
This enables early printk() …
5
@bbfbfc8
02/03/17 07:57:18 |
Sebastian Huber |
score: Move _Thread_Scheduler_ask_for_help()
Move …
5
@ca1e546e
02/02/17 15:24:05 |
Sebastian Huber |
score: Improve scheduler helping protocol
Only register ask for help …
5
@e2b1c47d
02/03/17 09:16:40 |
Sebastian Huber |
sparc: Fix volatile clobber
Do not adjust the stack pointer, since …
5
@d4ff66e
02/03/17 07:43:56 |
Sebastian Huber |
confdefs.h: Simplify
5
@f9db6fd
02/02/17 22:44:31 |
kevin-kirspel |
confdefs.h: Only define _CONFIGURE_SMP_APPLICATION if RTEMS_SMP defined
5
@6dd96af
02/02/17 08:16:53 |
Sebastian Huber |
rtems: Fix RTEMS_NO_TIMEOUT define
Cast the internal …
5
@f95fa387
02/01/17 11:11:33 |
Sebastian Huber |
Remove CONFIGURE_SMP_APPLICATION
Enable the SMP support if …
5
@70f559d8
02/01/17 12:00:15 |
Sebastian Huber |
rtems: Fix RTEMS_MAXIMUM_PRIORITY define
Cast the internal …
5
@f7ba2945
01/31/17 08:01:37 |
Sebastian Huber |
monitor: Add support for BSD wakeup messages
5
@e366f77
01/31/17 07:08:24 |
Sebastian Huber |
score: Add _Thread_queue_Object_name
Add the special thread queue …
5
@70488f56
01/31/17 08:37:54 |
Sebastian Huber |
score: Fix _Thread_Initialize()
5
@c5430e06
01/30/17 11:29:31 |
Sebastian Huber |
score: Fix unused parameter warning
Close #2890.
5
@575c2e21
01/30/17 10:24:57 |
Stavros Passas |
Complete STACK_CHECKER_EXTENSION. Fixes #2889
5
@180107e9
01/30/17 10:33:31 |
Christian.Mauderer |
bsps/arm: Fix Cortex-M DWT CPU counter.
It is necessary to enable the …
5
@0794197
01/27/17 22:15:50 |
c0066c |
rtems: Fix _Rate_monotonic_Renew_deadline()
Prepare a precondition to …
5
@4ea92d1e
01/27/17 07:06:06 |
Sebastian Huber |
score: Clarify _Heap_Extend()
Update #1747.
5
@abc963d
01/27/17 06:42:29 |
Sebastian Huber |
score: Fix typo
5
@6f6da82c
01/26/17 10:06:50 |
Sebastian Huber |
score: Fix user extensions order
Use forward and reverse order for …
5
@d1505a1
01/26/17 10:05:00 |
Sebastian Huber |
sapi: Add rtems_task_terminate_extension
5
@d7feb86
01/25/17 20:47:48 |
c0066c |
Remove rtems_rate_monotonic_postponed_job_count()
Add a variable …
5
@27bfcd8
01/25/17 13:32:02 |
Sebastian Huber |
score: Delete _CPU_Context_Fp_start()
Since the FP area pointer is …
5
@090bdc7e
01/25/17 10:45:49 |
Sebastian Huber |
posix: Fix use of uninitialized variable
Update #2859.
5
@b43c2e8
01/24/17 14:40:31 |
kevin-kirspel |
Adding ARM VFP V2 support
5
@b8d6eb7
01/24/17 14:05:22 |
Sebastian Huber |
rtems: rtems_rate_monotonic_postponed_job_count()
Use proper locking …
5
@625bd6a
01/24/17 14:04:11 |
Sebastian Huber |
rtems: Fix _Rate_monotonic_Release_postponed_job()
5
@1240aade
01/24/17 13:37:42 |
Sebastian Huber |
Make …
5
@3d20f5fb
01/23/17 14:04:44 |
Sebastian Huber |
sparc: Relax CPU_STACK_ALIGNMENT
Close #2352.
5
@4aa23c96
01/23/17 07:12:18 |
Sebastian Huber |
Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN
Use de-facto standard …
5
@2711914f
01/23/17 07:06:41 |
Sebastian Huber |
Use <sys/endian.h>
Update #2803.
5
@dc9b704
01/23/17 06:58:42 |
Sebastian Huber |
Provide <endian.h> for glibc compatibility
Update #2803.
5
@c0151e6
01/23/17 13:38:35 |
Sebastian Huber |
nfsclient: Fix suspicious condition
Close #2700.
5
@1157cb59
01/23/17 06:57:07 |
Sebastian Huber |
sys/endian.h: Document FreeBSD origin
5
