@26c142e5
04/17/15 10:05:16 |
Sebastian Huber |
score: Refactor SMP cache manager support
4.115
@c5d86ec0
04/17/15 14:45:05 |
Joel Sherrill |
or1k-utility.h: Add missing end of C++ header pattern
closes 2326.
4.115
@41b37e00
03/27/15 13:08:10 |
Martin Galvan |
score: Improve assert
While cpu_self->thread_dispatch_disable_level …
4.115
@c7a6508
04/17/15 07:18:05 |
Sebastian Huber |
Fix build for non-SPARC targets
4.115
@8d6fd40
04/17/15 06:45:50 |
Sebastian Huber |
sapi: Avoid declaration in source, fix type
4.115
@a211a732
04/16/15 20:24:59 |
Sebastian Huber |
score: Fix _TOD_Set_with_timestamp()
Update the current time before …
4.115
@291c5391
04/13/15 11:12:33 |
Daniel Hellstrom |
DRVMGR: remove struct driver registration func
4.115
@4c9c46d
04/13/15 10:58:37 |
Daniel Hellstrom |
DRVMGR: clean-up DRV_OPS_NUM
4.115
@bef5e23e
04/13/15 09:31:53 |
Daniel Hellstrom |
DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY
4.115
@4d3e70f4
04/13/15 09:26:52 |
Daniel Hellstrom |
DRVMGR: KEY_TYPE now a enum drvmgr_kt
4.115
@14d55deb
04/13/15 09:12:04 |
Daniel Hellstrom |
DRVMGR: renamed info_dev to get_info_dev
4.115
@246fe22
04/13/15 09:07:54 |
Daniel Hellstrom |
DRVMGR: change name of freq_get to get_freq
4.115
@bb2f220
04/13/15 08:49:47 |
Daniel Hellstrom |
DRVMGR: renamed private drv_mgr and its struct name
4.115
@bf2c3f8b
04/13/15 08:47:22 |
Daniel Hellstrom |
DRVMGR: updated README
4.115
@4f09060
04/13/15 08:32:50 |
Daniel Hellstrom |
DRVMGR: only build on SPARC platform
4.115
@e53daed
04/09/15 14:09:42 |
Daniel Hellstrom |
LIBPCI: updated license to rtems.org
4.115
@0decc806
04/09/15 14:09:13 |
Daniel Hellstrom |
DRVMGR: updated license to rtems.org
4.115
@cc3f87c0
04/09/15 06:36:39 |
Daniel Hellstrom |
DRVMGR: removed a goto and added comments
4.115
@f4bf22c
04/08/15 08:51:45 |
Daniel Hellstrom |
LIBPCI: new implementation private header file
- new implementation …
4.115
@1f4f1e2e
04/08/15 08:39:41 |
Daniel Hellstrom |
LIBPCI: various comment/unsed clean-ups
4.115
@346a9a5
04/08/15 08:16:51 |
Daniel Hellstrom |
LIBPCI: use enum with pci_system_type
4.115
@15620f5b
04/08/15 08:03:45 |
Daniel Hellstrom |
LIBPCI: use RTEMS_INLINE_ROUTINE
4.115
@dc623099
04/08/15 08:01:48 |
Daniel Hellstrom |
LIBPCI: moved comment out of license header
4.115
@e189f241
04/08/15 08:00:48 |
Daniel Hellstrom |
PCI BUS: moved comment out of license header
4.115
@2fb0912
04/08/15 07:50:28 |
Daniel Hellstrom |
DRVMGR: clean-up Makefile.am
4.115
@eff69891
04/08/15 07:49:11 |
Daniel Hellstrom |
DRVMGR: use RTEMS_INLINE_ROUTINE
4.115
@39937b6c
04/07/15 14:35:53 |
Daniel Hellstrom |
LIBPCI: added license and auto-gen comment to pci/ids.h
To be Merged.
4.115
@07e5a0e
04/07/15 14:19:39 |
Daniel Hellstrom |
LIBPCI: clean-up pci_for_each_child() search arg
4.115
@4ab9296
04/07/15 14:08:05 |
Daniel Hellstrom |
LIBPCI: remove $Id in makefile.am
4.115
@c1c37a1
04/07/15 12:25:49 |
Daniel Hellstrom |
LIBPCI: converted to BSD header
4.115
@56ea46ba
04/07/15 12:25:23 |
Daniel Hellstrom |
DRVMGR: PCI BUS converted to BSD header
4.115
@1f66914
04/13/15 08:12:08 |
Daniel Hellstrom |
LIBPCI: moved pci_bus copyright into a single line
4.115
@71e8a5c
02/27/15 15:45:59 |
Daniel Hellstrom |
LIBPCI: moved copyright into a single line
4.115
@358b8543
02/27/15 15:45:20 |
Daniel Hellstrom |
LIBPCI: removed unused changes file
4.115
@a2e0e6e
02/27/15 15:44:48 |
Daniel Hellstrom |
LIBPCI: fixed RES2DEV in pci/cfg.h
4.115
@65d1f35
02/27/15 15:42:36 |
Daniel Hellstrom |
DRVMGR: updated copyright into one line only
4.115
@ab907e8e
05/21/13 08:10:21 |
Daniel Hellstrom |
NGMP PCI: added support for NGMP prototype boards
4.115
@ffd8002d
05/08/13 12:41:13 |
Daniel Hellstrom |
GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device
4.115
@0f49c0e
06/19/12 06:50:11 |
Daniel Hellstrom |
GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA
This patch adds …
4.115
@30594a9
02/04/15 09:18:20 |
Daniel Hellstrom |
DRVMGR: add LEON BSPs driver registration
4.115
@219d4045
11/28/11 09:28:23 |
Daniel Hellstrom |
DRVMGR: added drvmgr shell command
4.115
@1c5a7e5
11/28/11 09:16:09 |
Daniel Hellstrom |
LIBPCI: added DRVMGR model for PCI bus
4.115
@e7fade3
11/28/11 08:52:03 |
Daniel Hellstrom |
DRVMGR: added driver manager to cpukit/libdrvmgr
4.115
@02550220
11/28/11 09:25:15 |
Daniel Hellstrom |
LIBPCI: added PCI shell command
4.115
@a31845f7
11/28/11 09:11:10 |
Daniel Hellstrom |
LIBPCI: added PCI layer to cpukit/libpci
4.115
@04cf2c5
11/24/11 15:54:28 |
Daniel Hellstrom |
IO_MANAGER: early dynamic driver registration
Adds the possibility to …
4.115
@e98df4d
04/16/15 09:23:29 |
Sebastian Huber |
score: Add _ISR_lock_Flash()
4.115
@64548a3a
04/16/15 09:35:54 |
Sebastian Huber |
score: Add const qualifier
4.115
@72e846d
04/16/15 09:32:16 |
Sebastian Huber |
score: Fix _API_Mutex_Is_locked()
Remove superfluous ISR …
4.115
@45c9cf2a
04/15/15 18:23:31 |
Sebastian Huber |
score: Delete unused WATCHDOG_MAXIMUM_INTERVAL
4.115
@644caa20
04/15/15 06:46:51 |
Sebastian Huber |
score: Fix name
4.115
@1047f37
04/14/15 17:11:51 |
Joel Sherrill |
semdestroy.c: Add missing _Objects_Allocator_unlock()
closes 2319.
4.115
@5049dca
03/13/15 12:54:16 |
daniel.krueger |
semunlink.c: Add missing _Objects_Allocator_unlock()
updates 2319.
4.115
@fc0756e
04/14/15 15:01:05 |
Joel Sherrill |
Add test assertion for allocator mutex being unlocked
The Allocator …
4.115
@1dc6662
04/13/15 11:57:57 |
Sebastian Huber |
score: Rename _Watchdog_Reset()
Update #2307.
4.115
@54cf0e34
04/10/15 14:19:48 |
Sebastian Huber |
score: Add Watchdog_Header
This type is intended to encapsulate all …
4.115
@bcf536a
04/10/15 13:51:50 |
Sebastian Huber |
score: Split _Watchdog_Adjust()
Split _Watchdog_Adjust() into …
4.115
@a6c5a7e0
03/17/15 14:02:59 |
daniel.krueger |
arm: Align ARM exception frame to 8 bytes
The stack pointer must be …
4.115
@41814fa6
04/09/15 11:54:17 |
Sebastian Huber |
score: Fix thread queue race condition
On uni-processor …
4.115
@1461aba8
03/27/15 20:13:29 |
Sebastian Huber |
score: Use _Thread_Clear_state() for _Thread_Ready
4.115
@edcf89b
03/27/15 20:08:21 |
Sebastian Huber |
rtems: Atomically suspend/resume tasks
4.115
@342708b9
03/26/15 20:45:20 |
Sebastian Huber |
score: Return prev state in thread state set/clear
4.115
@ca10004
03/26/15 20:16:09 |
Sebastian Huber |
score: Simplify _Thread_Set_state()
4.115
@9baffdf
04/08/15 05:40:00 |
Sebastian Huber |
score: Move _Watchdog_Ticks_since_boot definition
4.115
@fd50acd
04/03/15 20:08:20 |
Joel Sherrill |
shell/main_rtrace.c: Fix warning
4.115
@1c846616
04/02/15 13:11:26 |
Hesham Almatary |
or1k: Send halt signal to or1k simulators when rtems terminates
4.115
@504e042
04/02/15 06:28:12 |
Sebastian Huber |
capture: Define rtld_tbg_lock
4.115
@a300920d
03/30/15 11:19:17 |
Chris Johns |
libmisc/shell: Add the rtrace command for buffered tracing support.
4.115
@1a6683a
03/26/15 20:37:33 |
Sebastian Huber |
libcsupport: Include missing header file
4.115
@cb4dd48
03/25/15 10:40:08 |
Sebastian Huber |
sparc: Ensure interrupt service after ISR enable
4.115
@10a699d
03/25/15 10:33:34 |
Sebastian Huber |
testsupport: Generate unique worker names
4.115
@a54866e9
03/24/15 10:28:32 |
Sebastian Huber |
monitor: Fix notepad dump
4.115
@ad57a59
03/24/15 07:29:44 |
Sebastian Huber |
score: Fix MrsP ISR/task sychronization
4.115
@4054c916
03/20/15 12:41:27 |
Sebastian Huber |
score: Add scheduler acquire/release
This is currently a global lock …
4.115
@3134eb8
03/24/15 09:47:02 |
Sebastian Huber |
score: Use a dedicated ISR lock for thread queues
This makes it …
4.115
@57947f1
03/23/15 14:05:32 |
Sebastian Huber |
score: Add thread lock
Update #2273.
4.115
@2e9c3d5
03/17/15 15:28:50 |
Sebastian Huber |
score: Add thread priority change handler
Since the thread current …
4.115
@e02b20a3
03/22/15 19:59:14 |
Joel Sherrill |
cpukit/libmisc/utf8proc/utf8proc.c: Avoid overflow
4.115
@0771936e
03/22/15 15:27:00 |
Joel Sherrill |
libdl/rtl-shell.c: Adjust printf() format for off_t based on target
4.115
@30ea9bf
03/22/15 14:42:46 |
Joel Sherrill |
libdl/rtl-mdreloc-moxie.c: Fix printf() format warnings
4.115
@0d36bfb3
03/20/15 22:56:08 |
Joel Sherrill |
rtems/score/tls.h: Add casts to eliminate warnings on some targets
4.115
@0a9345ed
03/20/15 15:44:42 |
Joel Sherrill |
shell/utils-cp.c: Avoid redefinition of TIMESPEC_TO_TIMEVAL
4.115
@54bfbe0
03/20/15 15:43:46 |
Joel Sherrill |
dummy/default-configuration.c: Tune configuration down for small targets
4.115
@735efe7
03/20/15 15:43:19 |
Joel Sherrill |
capture/capture_support.c: Fix printf() warning and formatting
4.115
@4727585
03/20/15 15:42:33 |
Joel Sherrill |
imfs.h: Add cast to remove warning for pointer/integer size mismatch
4.115
@5cd910b
03/18/15 15:42:14 |
Joel Sherrill |
cpukit/libmisc/shell/hexdump-conv.c: Eliminate printf() format warning
4.115
@5ce776ec
03/18/15 15:40:11 |
Joel Sherrill |
cpukit/libmisc/shell/main_df.c: Eliminate printf() format warning
4.115
@a6524b9
03/22/15 13:31:59 |
Sebastian Huber |
score: Simplify debug code and use _Assert()
4.115
@d2bdf5c
03/22/15 10:58:10 |
Sebastian Huber |
score: Move _Thread_queue_Requeue()
Now all the main thread queue …
4.115
@688fbc44
03/22/15 09:43:06 |
Sebastian Huber |
score: Move _Thread_queue_Extract()
Move _Thread_queue_Dequeue(). We …
4.115
@2429766
03/22/15 09:37:52 |
Sebastian Huber |
score: Move _Thread_blocking_operation_Cancel()
Move …
4.115
@d4edbdbc
03/20/15 13:09:26 |
Sebastian Huber |
Replace www.rtems.com with www.rtems.org
4.115
@c3803167
03/20/15 07:28:20 |
alexander.krutwig |
score: Delete unused _Timestamp_(To|From)_ticks()
4.115
@677d2b09
03/20/15 08:08:57 |
alexander.krutwig |
score: Delete unused _Timestamp_Divide_by_integer
4.115
@6a941e3
03/17/15 15:24:44 |
Sebastian Huber |
score: Fix _Thread_Change_priority()
Atomically update the current …
4.115
@e0a25fb
03/19/15 12:52:22 |
alexander.krutwig |
score: Delete unused _Timestamp_Is_valid()
4.115
@faf3ff8f
03/19/15 07:55:01 |
Sebastian Huber |
score: Fix _Debug_Is_owner_of_allocator()
4.115
@da30417b
03/19/15 07:23:12 |
Chris Johns |
libmisc/capture: Clean up formatting on ARM.
The printing of 64bit …
4.115
@55243d09
03/18/15 12:49:36 |
Sebastian Huber |
testsupport: Do not suspend worker tasks
4.115
@b9d16f7
03/18/15 05:09:52 |
Chris Johns |
libmisc/redirector: Fix unlock on exit from the handler.
4.115
