@1157cb59
01/23/17 06:57:07 |
Sebastian Huber |
sys/endian.h: Document FreeBSD origin
5
@66bd19ea
01/19/17 13:10:42 |
Sebastian Huber |
JFFS2: Fix typo
5
@cb2cbec
01/13/17 18:54:11 |
Gedare Bloom |
classic: adjust names of RM postponed job functions
closes #2795
5
@3a46b72
12/21/16 16:42:39 |
c0066c |
Enhancement of the RMS manager for the overrun handling.
Three …
5
@ba776282
08/12/16 19:25:10 |
Gedare Bloom |
posix: shared memory support
Add POSIX shared memory manager (Shm). …
5
@2b442a8e
08/12/16 16:21:00 |
Gedare Bloom |
posix: fix typo in mmap arguments
5
@1ca8ee13
08/12/16 15:17:40 |
Gedare Bloom |
posix: add stub implementations for mman functions
5
@e7eeb38d
07/29/16 19:28:49 |
Gedare Bloom |
posix: move sys/mman.h to newlib and test it in psxhdrs
5
@ffa885a
01/13/17 10:44:22 |
Sebastian Huber |
configure: Remove RTEMS_DO_NOT_INLINE_THREAD_*
5
@714617e
01/13/17 10:43:40 |
Sebastian Huber |
configure: Remove RTEMS_HAVE_DECL_SIGALTSTACK
5
@9fad437
01/13/17 10:33:28 |
Sebastian Huber |
configure: Remove HAVE_STRUCTTHREAD_QUEUE_QUEUE
5
@6b13287
01/13/17 10:28:35 |
Sebastian Huber |
configure: Remove envlock support
This is provided by Newlib itself.
5
@4a03e752
01/13/17 08:45:59 |
Sebastian Huber |
configure: Remove SIZEOF_PTHREAD_SPINLOCK_T
5
@dc703190
01/13/17 08:39:32 |
Sebastian Huber |
configure: Remove HAVE_THREADS_H support
5
@544b59bf
01/13/17 08:35:01 |
Sebastian Huber |
configure: Remove HAVE_SEMAPHORE_H support
5
@7c499279
01/12/17 08:26:08 |
Sebastian Huber |
posix: Add pthread_getname_np(), ...
Add pthread_getname_np() and …
5
@da6ad56
01/12/17 12:46:55 |
Sebastian Huber |
score: Add _Thread_Set_name()
Add configuration option …
5
@7ced9d9b
01/12/17 08:25:56 |
Sebastian Huber |
score: Add and use _Thread_Get_name()
Update #2858.
5
@2b72162
01/12/17 09:15:56 |
Sebastian Huber |
score: Add Thread_queue_Queue::name
Update #2858.
5
@b8bcebe
01/12/17 07:28:57 |
Sebastian Huber |
score: Add and use _Objects_Name_to_string()
Update #2858.
5
@1772a04
01/12/17 09:00:22 |
Sebastian Huber |
configure: Add RTEMS_TOOL_CHAIN_ERROR
Stop the build with a common …
5
@61c14a3
01/12/17 09:14:06 |
Sebastian Huber |
cpuuse: Call printer only once
5
@3b784ba
01/12/17 07:56:48 |
Sebastian Huber |
Fix documentation comment
5
@96bb2e4b
01/12/17 06:53:12 |
Sebastian Huber |
rtems: Use header file for rtems_object_get_name()
5
@a3730b38
01/11/17 10:04:35 |
Sebastian Huber |
Add and use rtems_assoc_thread_states_to_string()
5
@b7f1fc3b
01/11/17 10:04:07 |
Sebastian Huber |
libdebugger: Fix const qualifier
5
@0c43130
01/11/17 10:03:24 |
Sebastian Huber |
Add rtems_assoc_32_to_string()
5
@fa9f964f
01/11/17 07:49:26 |
Sebastian Huber |
score: Remove unused _States_Is_*()
5
@d063e7b3
01/11/17 07:42:04 |
Sebastian Huber |
score: Replace STATES_DELAYING
Replace STATES_DELAYING with …
5
@7a4b2645
01/11/17 15:43:06 |
joel |
Remove obsolete RTEMS_HAVE_SYS_CPUSET_H
5
@ef362818
12/06/16 03:06:40 |
joel |
Add support for posix_devctl()
5
@5aa0fa1
01/11/17 12:47:22 |
Sebastian Huber |
posix: Fix alarm() in SMP configurations
Avoid to change the CPU of …
5
@3d35bc0
01/11/17 12:41:55 |
Sebastian Huber |
score: Improve SMP lock debug support
The CPU index starts with zero. …
5
@4e07d9b3
01/05/17 14:40:57 |
Sebastian Huber |
score: Optimize thread state values
5
@9a448aab
12/23/16 15:02:07 |
Sebastian Huber |
score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER
Add thread state bit …
5
@c6000d2b
12/23/16 06:09:02 |
Sebastian Huber |
score: Delete STATES_WAITING_FOR_BUFFER
5
@2e6d9865
12/23/16 05:47:11 |
Sebastian Huber |
score: Format thread state defines
Specify all 32-bits in a thread …
5
@45ae4a8
01/09/17 13:53:26 |
Sebastian Huber |
sys/event.h: Update to FreeBSD head 2017-01-02
5
@a7cfb4b
12/23/16 12:54:11 |
Sebastian Huber |
score: Relax <sys/lock.h> static assertions
Only require that the …
5
@0374ccd8
12/23/16 12:53:55 |
Sebastian Huber |
libio: Use CONSOLE_DEVICE_NAME
5
@eae4541d
12/21/16 08:26:43 |
Sebastian Huber |
Clarify simple timecounter documentation
5
@ab834d65
12/20/16 07:23:49 |
Sebastian Huber |
JFFS2: RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION
Update #2844.
5
@ade135d4
12/19/16 09:19:44 |
Sebastian Huber |
JFFS2: Add RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION
Add IO control to …
5
@07c833f
12/19/16 08:54:16 |
Sebastian Huber |
JFFS2: Add RTEMS_JFFS2_GET_INFO
Add IO control RTEMS_JFFS2_GET_INFO …
5
@9edc7301
09/16/16 13:21:26 |
alexander.krutwig |
dev: Add NXP SC16IS752 serial device driver
Update #2841.
5
@e34fe38
10/17/16 12:15:34 |
alexander.krutwig |
termios: Add TERMIOS_IRQ_SERVER_DRIVEN
Add a new interrupt server …
5
@c3764ce
10/05/16 08:37:56 |
Sebastian Huber |
termios: Use mutex for task driven mode
Termios has a task driven …
5
@c6eead1
12/07/16 06:20:38 |
Chris Johns |
libdl: Add C++ exception support to loaded modules.
This has been …
5
@fe7012a0
12/12/16 14:03:35 |
Christian.Mauderer |
score: Prevent thread_dispatch_disable_level < 0.
5
@c69d6aa
12/12/16 14:49:59 |
Sebastian Huber |
libblock: Fix for RTEMS_DEBUG
5
@e203b65e
12/09/16 08:28:31 |
Sebastian Huber |
Add INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED
Update #2825.
5
@a5ba08eb
12/09/16 08:27:15 |
Sebastian Huber |
Add INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED
Update #2825.
5
@af8ced5
12/09/16 08:18:57 |
Sebastian Huber |
libio: Ensure proper std file descriptors
5
@9622f779
12/09/16 07:44:49 |
Sebastian Huber |
Add INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED
Update #2825.
5
@82529688
12/09/16 07:44:22 |
Sebastian Huber |
INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED
Update #2825.
5
@3a659b04
12/09/16 06:19:22 |
Sebastian Huber |
score: Introduce _Internal_error()
5
@0a81a58
12/09/16 05:51:44 |
Sebastian Huber |
Add INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED
Update #2825.
5
@279d5260
12/09/16 05:49:25 |
Sebastian Huber |
Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
Update #2825.
5
@6a9282d
12/09/16 09:49:49 |
Sebastian Huber |
Rename is_internal to always_set_to_false
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@4b579c5f
12/06/16 10:35:34 |
Sebastian Huber |
score: Simplify linker set API
Resurrect RTEMS_LINKER_SET_BEGIN() and …
5
@f65dcc71
12/02/16 12:10:31 |
Sebastian Huber |
score: Fix ARM and PowerPC context initialization
Update #2751.
5
@7da78cf
12/02/16 10:51:16 |
Sebastian Huber |
rtems: Use _Thread_Dispatch_direct()
Update #2797.
5
@d10716f
12/02/16 10:18:32 |
Sebastian Huber |
rtems: Fix rtems_scheduler_add_processor()
Fix thread dispatch …
5
@5b6c290
12/01/16 19:42:48 |
Sebastian Huber |
score: Initialize thread queue context early
Initialize thread queue …
5
@6cc83b32
12/02/16 11:40:32 |
Sebastian Huber |
posix: Fix typo
5
@b3cb2c1
12/01/16 21:24:02 |
Sebastian Huber |
score: Fix debug thread queue context init
On ARM Thumb we may have …
5
@aadd318
12/02/16 08:56:40 |
Sebastian Huber |
posix: Fix fall back spinlock implementation
Update #2674.
5
@e629076
11/29/16 22:19:05 |
Chris Johns |
libdebugger: Build for ARM's without a CP15.
5
@a0d4e99
11/25/16 04:13:36 |
Chris Johns |
cpukit: Add libdebugger, a remote debugger agent for GDB.
5
@6a1b9e4
11/22/16 09:13:27 |
Sebastian Huber |
sparc: Optimize _ISR_Handler()
Use _Thread_Do_dispatch() instead of …
5
@c09db57
11/28/16 12:28:32 |
Sebastian Huber |
score: Fix thread queue context initialization
Initialize the thread …
5
@0a9b6eb0
11/24/16 11:04:15 |
Sebastian Huber |
5
@bd0d585
11/24/16 10:53:59 |
Sebastian Huber |
arm: Fix _CPU_ISR_Is_enabled() for ARMv7-M
Update #2811.
5
@620b23e
11/24/16 05:13:11 |
Sebastian Huber |
score: Optimize _Thread_queue_Enqueue()
Move thread state for …
5
@4b5ff47
11/23/16 15:15:13 |
Sebastian Huber |
score: Fix interrupt profiling
Callers of _Thread_Do_dispatch() must …
5
@d42cf33
11/23/16 14:12:28 |
Sebastian Huber |
posix: Fix typo
Update #2674.
5
@f6edd880
11/23/16 12:43:12 |
Sebastian Huber |
score: Explicitly define the fatal source numbers
Update #2825.
5
@bee0323
11/23/16 11:48:57 |
Sebastian Huber |
score: Uncomment unused internal error codes
Update #2825.
5
@c42be504
11/16/16 13:50:09 |
Sebastian Huber |
posix: Add self-contained pthread spinlock
Turn pthread_spinlock_t …
5
@520e07db
11/22/16 07:46:02 |
Sebastian Huber |
score: Add RTEMS_ALIAS()
5
@a4217c6
11/22/16 09:53:03 |
Sebastian Huber |
score: Rename _Thread_queue_Enqueue_critical()
Delete unused …
5
@125f248
11/16/16 15:39:43 |
Sebastian Huber |
score: Add thread queue enqueue callout
Replace the expected thread …
5
@84e6f15
11/10/16 11:02:28 |
Sebastian Huber |
score: Robust thread dispatch
On SMP configurations, it is a fatal …
5
@ec17ad4
11/23/16 06:16:41 |
Sebastian Huber |
score: Delete obsolete scheduler debug aid
5
@1d18a902
11/23/16 09:15:07 |
Sebastian Huber |
arm: Fix _ARMV4_Exception_interrupt
Use the right register to …
5
@a550b3f
11/23/16 06:47:57 |
Sebastian Huber |
score: Force Per_CPU_Control::executing alignment
This fixes the CPU …
5
@4e2bc0a
11/21/16 10:40:00 |
Sebastian Huber |
arm: Fix Thumb-1 targets
We cannot use the MRS or MSR instructions in …
5
@ccc92b8
11/21/16 09:26:32 |
Sebastian Huber |
score: Group Per_CPU_Control members by alignment
Close #2820.
5
@27eccda
11/21/16 09:25:58 |
Sebastian Huber |
sparc64: Fix _CPU_ISR_Is_enabled()
Update #2820.
5
@fd6d3f1
11/21/16 09:13:37 |
Sebastian Huber |
nios2: Fix _CPU_ISR_Is_enabled()
Close #2818.
5
@9f225dea
11/21/16 09:11:18 |
Sebastian Huber |
arm: Fix ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE
Close #2816.
5
@c6f446b
11/21/16 09:06:36 |
Sebastian Huber |
bfin: ASM compatibility for <rtems/score/cpu.h>
Close #2817.
5
@142628e
11/17/16 06:40:05 |
Sebastian Huber |
score: Optimize self-contained objects
Avoid use of the stack for the …
5
@1b87f27
11/17/16 06:20:07 |
Sebastian Huber |
score: Constify _MRSP_Get_owner()
5
@408609f6
11/10/16 14:17:28 |
Sebastian Huber |
score: Add _ISR_Is_enabled()
In contrast to _ISR_Get_level() the …
5
@537f00eb
11/10/16 15:25:41 |
Sebastian Huber |
score: Restrict task interrupt level to 0 on SMP
Update #2811.
5
@7ce60b3
11/14/16 14:23:40 |
Sebastian Huber |
powerpc: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@d59585d
11/14/16 08:53:57 |
Sebastian Huber |
arm: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@2668e4f6
11/13/16 14:20:59 |
Sebastian Huber |
arm: Simplify _ARMV4_Exception_interrupt
Move profiling code closer …
5
