Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @10c4636   09/11/15 08:42:06 Sebastian Huber rbheap: Fix rtems_rbheap_free() Remove unused descriptor of merged … 5
(edit) @808230a   09/10/15 08:01:08 Sebastian Huber Upgrade to 4.11.99.0 5
(edit) @dafa5d88   09/03/15 08:27:16 Sebastian Huber score: Implement priority boosting 5
(edit) @3995e6d   09/02/15 09:58:54 Sebastian Huber score: Implement SMP-specific priority queue 5
(edit) @c4db18a0   09/01/15 08:38:17 Sebastian Huber score: Documentation 5
(edit) @41b5c915   09/03/15 20:55:52 Martin Galvan cpukit/libmisc/dumpbuf/dumpbuf.c: Fix compilation warnings Compiling … 5
(edit) @28a870c4   09/03/15 20:25:35 Martin Galvan cpukit/libnetworking/rtems/rtems_dhcp.c: Fix compilation error … 5
(edit) @cc93c83   09/02/15 21:54:24 Martin Galvan cpukit/libmisc/dumpbuf/dumpbuf.c: Fix undefined behavior for sprintf() … 5
(edit) @c83bad2f   09/02/15 21:54:25 Martin Galvan cpukit/libnetworking/rtems/rtems_dhcp.c: Fix leak on realloc failure … 5
(edit) @7def219   09/02/15 21:54:21 Martin Galvan various .h files: Add missing C++ extern wrappers Updates #2405. 5
(edit) @f8202273   08/31/15 09:30:36 Sebastian Huber JFFS2: Use RTEMS red-black tree implementation 5
(edit) @edf640f   08/31/15 11:11:04 Sebastian Huber rbtree: Add _RBTree_Replace_node() 5
(edit) @e9fbaa3b   08/21/15 03:59:49 Sebastian Huber rbtree: Replace implementation Use the BSD <sys/tree.h> … 5
(edit) @8c25e04   09/02/15 13:02:27 Sebastian Huber score: Optimize thread queue first operation In case the thread queue … 5
(edit) @3b3d1489   09/01/15 12:16:48 Sebastian Huber posix: glibc compatibility 5
(edit) @44f3ea9   08/31/15 11:37:52 Sebastian Huber score: Fix return status of mutex try acquire This fixes a copy and … 5
(edit) @95b43d0   09/01/15 07:47:12 Sebastian Huber arm: Replace sync_synchronize() implementation 5
(edit) @39e3e20   09/01/15 07:42:46 Sebastian Huber arm: Use compiler memory barrier by default 5
(edit) @509e8d7f   08/18/15 04:21:17 Sebastian Huber rbtree: Delete rtems_rbtree_find_control() This function is hard to … 5
(edit) @f71e67d   08/21/15 03:59:19 Sebastian Huber rbtree: Delete unused RBTREE_NODE_*() macros 5
(edit) @ddb6a49b   08/21/15 03:57:42 Sebastian Huber rbtree: Delete _RBTree_Initialize() This function has no internal use … 5
(edit) @b9877ee   08/21/15 03:55:04 Sebastian Huber rbtree: Delete _RBTree_Get() This function has no internal use case. 5
(edit) @2d48456   08/21/15 03:24:17 Sebastian Huber rbheap: Drop direction from _RBTree_Iterate() 5
(edit) @3f49446   08/21/15 03:40:07 Sebastian Huber rbtree: Delete _RBTree_Is_first() 5
(edit) @341f629   08/21/15 03:39:59 Sebastian Huber rbtree: Add _RBTree_Minimum(), _RBTree_Maximum() 5
(edit) @c72f132   08/18/15 04:05:05 Sebastian Huber rbheap: Avoid internal API 5
(edit) @1f242285   08/21/15 03:25:37 Sebastian Huber posix: Avoid _RBTree_Next() 5
(edit) @040ddd2   08/06/15 02:17:41 Nick Withers Respect 232 - 1 B NFSv2 maximum file size closes #2384 5
(edit) @7e798b4   08/01/15 10:43:12 summerspam Add synch_synchronize function for arm Fixes link failure when … 5
(edit) @9e9e61d   07/28/15 11:46:56 Sebastian Huber score: Add self-contained condition implementation 5
(edit) @a1b4af4b   07/20/15 07:05:30 Sebastian Huber score: Add scheduler <sys/lock.h> support 5
(edit) @40188718   07/13/15 08:00:28 Sebastian Huber score: Add self-contained futex implementation 5
(edit) @7237b3e   07/02/15 11:12:38 Sebastian Huber score: Add self-contained semaphore implementation 5
(edit) @214d8ed   06/28/15 20:06:36 Sebastian Huber score: Add self-contained mutex implementation This mutex … 5
(edit) @12f93fbb   07/27/15 11:19:17 Sebastian Huber score: Add thread queue for self-contained objects 5
(edit) @0e3c59d6   06/26/15 10:54:33 Sebastian Huber score: Use a plain ticket lock for thread locks This enables external … 5
(edit) @10e32a26   06/29/15 12:23:42 Sebastian Huber score: Add potpourri lock statistics These SMP lock statistics are … 5
(edit) @e421936b   06/29/15 12:24:14 Sebastian Huber score: Provide struct _Thread_queue_Heads Use a leading underscore in … 5
(edit) @4827470   06/29/15 08:41:01 Sebastian Huber score: Rename struct Thread_Control Add a leading underscore to the … 5
(edit) @74ef2c10   07/26/15 13:27:10 Michael Davidsaver tftpDriver: close() false error closes #2376. 5
(edit) @21789a21   07/28/15 12:45:42 Sebastian Huber score: Rename _POSIX_Absolute_timeout_to_ticks() Rename … 5
(edit) @f7d95581   07/24/15 08:47:25 Sebastian Huber m68k: Include proper header file 5
(edit) @9c53910   07/24/15 07:12:54 Sebastian Huber score: Add comment 5
(edit) @9780fa93   07/22/15 19:14:30 Sebastian Huber monitor: Sort alphabetically 5
(edit) @d70f530   07/22/15 13:41:44 Sebastian Huber monitor: Add current CPU of thread 5
(edit) @0910e9d4   07/22/15 07:05:52 Sebastian Huber monitor: Print the wait queue to ease debugging 5
(edit) @1f199799   07/22/15 07:03:44 Sebastian Huber monitor: Print addresses like identifiers This avoids the "0x0xabc" … 5
(edit) @975e1918   07/22/15 05:37:19 Sebastian Huber monitor: Remove notepad support 5
(edit) @98a41f41   07/23/15 18:34:19 Sebastian Huber arm: Include proper header file 5
(edit) @08135c85   07/23/15 07:00:31 Sebastian Huber i2c: Fix return status of i2c dev read/write 5
(edit) @e709aa85   07/13/15 11:49:35 Sebastian Huber score: Move wait flag update to tq extract This makes it possible to … 5
(edit) @d7665823   06/24/15 13:43:19 Sebastian Huber score: Introduce Thread_queue_Heads Move the storage for the thread … 5
(edit) @e2735012   06/24/15 09:05:39 Sebastian Huber score: Introduce Thread_queue_Queue Separate the thread queue heads … 5
(edit) @db01d0c   07/16/15 18:15:10 Joel Sherrill sparc64/rtems/score/cpu.h: Delete dead declaration 4.115
(edit) @93f5adb   07/15/15 08:51:12 Sebastian Huber powerpc: Do not use the ATB for e500 multilib The e500v1 has no … 4.115
(edit) @e2fcb7d   07/15/15 06:55:42 Nick Withers powerpc: Fix _CPU_Counter_read() The mftb is not available on Book E … 4.115
(edit) @c5d0ca9   07/13/15 08:19:04 Sebastian Huber libcsupport: Workaround for GCC 5.1 and later Disable an optimization … 4.115
(edit) @083e6d6   05/20/15 05:21:53 Chris Johns libnetworking: Send the hostname if set in the network configuration. … 4.115
(edit) @f5d4570f   07/11/15 19:14:46 Sebastian Huber score: Simplify _Thread_Lock_set() Exploit the fact that the current … 4.115
(edit) @9341773   07/11/15 20:04:32 Sebastian Huber score: Typo 4.115
(edit) @8406d94   07/01/15 09:05:37 Sebastian Huber libmisc: Use SMP application by default on SMP 4.115
(edit) @4c68431   07/02/15 11:11:14 Sebastian Huber powerpc: Add BUCSR register defines 4.115
(edit) @372bee84   06/26/15 13:51:28 Sebastian Huber score: Simplify _SMP_ticket_lock_Release() Add a SMP lock statistics … 4.115
(edit) @f59f2fe9   06/25/15 04:50:04 Sebastian Huber score: Accept NULL pointer in _Freechain_Put() With this a … 4.115
(edit) @fdb45d6   06/24/15 12:00:08 Sebastian Huber score: Freechain handler API changes Replace the extend function with … 4.115
(edit) @d811dac   06/25/15 09:24:44 Sebastian Huber score: Hide SMP lock profiling impl if disabled The problem is that … 4.115
(edit) @5f31bbe   06/25/15 12:22:31 Sebastian Huber libmisc: Simplify <rtems/stackchk.h> Drop the <rtems/score/percpu.h> … 4.115
(edit) @96316d1b   06/26/15 07:15:36 Sebastian Huber score: Simplify <rtems/score/scheduler.h> Drop the … 4.115
(edit) @48fed9a   06/25/15 12:11:53 Sebastian Huber score: Simplify <rtems/system.h> Drop the <rtems/score/percpu.h> … 4.115
(edit) @270ccc59   06/25/15 12:10:57 Sebastian Huber score: Fix extern "C" in <rtems/score/heap.h> 4.115
(edit) @bd67d7d2   06/25/15 11:48:00 Sebastian Huber score: Simplify <rtems/score/thread.h> Avoid Thread_Control typedef … 4.115
(edit) @0b268b8b   06/25/15 11:37:40 Sebastian Huber score: Move default _ISR_Is_in_progress() 4.115
(edit) @8042107a   06/25/15 09:28:59 Sebastian Huber score: Move SMP CPU_USE_DEFERRED_FP_SWITCH check 4.115
(edit) @a3fc33f   06/24/15 11:36:40 Sebastian Huber score: Assert proper node size 4.115
(edit) @cdf30f05   06/19/15 12:57:44 Sebastian Huber rtems: Add rtems_interrupt_local_disable|enable() Add … 4.115
(edit) @1cfe012   06/19/15 12:24:27 Sebastian Huber nfsclient: Use an interrupt lock 4.115
(edit) @9d838902   06/15/15 18:45:56 Sebastian Huber arm: Implement _CPU_ISR_Get_level() for ARMv7-M 4.115
(edit) @e6b31b27   05/27/15 15:13:58 Joel Sherrill Remove use ticks for statistics configure option. This was obsolete … 4.115
(edit) @80fca28   06/13/15 13:29:04 Sebastian Huber score: Add _Watchdog_Preinitialize() Add an assert to ensure that the … 4.115
(edit) @258d580c   06/13/15 12:49:23 Sebastian Huber score: Delete unused state WATCHDOG_REMOVE_IT 4.115
(edit) @aa2a62c   06/11/15 08:44:18 Sebastian Huber rtems: Do not switch off the FP attribute This is necessary after … 4.115
(edit) @f718e79   06/11/15 07:56:18 Sebastian Huber Revert "timecounter: No _Timecounter_Tick_simple() for SMP" This … 4.115
(edit) @46ae1d7a   06/09/15 19:31:27 Sebastian Huber timecounter: No _Timecounter_Tick_simple() for SMP 4.115
(edit) @6f55315   06/09/15 17:54:26 Gedare Bloom cpukit/rtems: Fix doc for rtems_clock_get_ticks_per_second closes #2357. 4.115
(edit) @e1d61fe   06/09/15 11:49:56 kib timecounter: Synchronize with FreeBSD When updating/accessing the … 4.115
(edit) @7e1a9ac   05/04/15 17:59:39 ian timecounter: Synchronize with FreeBSD Implement a mechanism for … 4.115
(edit) @cb6fde65   03/14/15 23:16:12 ian timecounter: Synchronize with FreeBSD Use sbuf_printf() for sysctl … 4.115
(edit) @b5b8116   03/07/15 18:23:32 hselasky timecounter: Synchronize with FreeBSD Add mutex support to the … 4.115
(edit) @7919f70   06/09/15 12:52:53 Sebastian Huber score: Fix compiler memory barriers for atomic ops 4.115
(edit) @a51b352   05/30/15 15:48:27 Sebastian Huber sparc: Add SPARC_USE_SAFE_FP_SUPPORT The SPARC ABI is a bit special … 4.115
(edit) @335e5ca   06/02/15 19:43:54 Sebastian Huber score: Add Thread_Control::is_fp Store the floating-point unit … 4.115
(edit) @f455cdea   06/02/15 22:20:54 Sebastian Huber rtems: Change CONTEXT_FP_SIZE define Define CONTEXT_FP_SIZE to zero … 4.115
(edit) @863dcf4   06/02/15 12:01:29 Sebastian Huber score: Remove assert With the introduction of fine grained locking … 4.115
(edit) @f9a2d36   06/02/15 11:57:35 Sebastian Huber posix: Fix _POSIX_Timer_Insert_helper() locking Close #2358. 4.115
(edit) @2764bd43   05/29/15 13:54:27 alexander.krutwig sparc: Disable FPU in interrupt context Update #2270. 4.115
(edit) @1f6cdba6   05/29/15 13:54:29 Sebastian Huber sparc: Remove superfluous FP enable The FP context save/restore makes … 4.115
(edit) @8a1dc71b   05/29/15 13:54:28 Sebastian Huber sparc: Avoid new window for FP save/restore Update #2270. 4.115
(edit) @4a5a4504   05/29/15 08:18:19 alexander.krutwig sparc: Improve _CPU_Context_validate() Write the pattern only once to … 4.115
(edit) @8f6a3145   05/29/15 13:03:02 Sebastian Huber posix: Fix clock_gettime() The … 4.115
(edit) @92422be   03/10/15 13:54:30 Gedare Bloom dosfs: avoid buffer-overread. closes #2292. 4.115
