@836f454
06/07/17 06:14:30 |
Sebastian Huber |
Fix CPU_COPY() usage
The original CPU_COPY() support of Newlib …
5
@a748603
05/14/17 01:52:52 |
Chris Johns |
build-system: Parallel build all subdirs.
5
@d5c8756
05/23/17 08:03:56 |
Sebastian Huber |
arm: Fix profiling support of Thumb-1 targets
Update #2751.
5
@03e4be12
04/26/17 01:02:09 |
joel |
score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning
5
@65807379
04/26/17 01:01:41 |
joel |
score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning
5
@f6bd41e
04/25/17 18:56:31 |
joel |
moxie/rtems/score/cpu.h: Fix printf() format warning
5
@fdfbb0a8
04/25/17 18:39:50 |
joel |
epiphany/rtems/score/cpu.h: Fix printf() format warning
5
@28e5749e
04/25/17 16:41:35 |
joel |
epiphany/cpu.c: Fix typo to eliminate warning
5
@0c334a5
04/23/17 17:57:27 |
joel |
epiphany/cpu.c: Fix not a prototype warning
5
@62c238e
04/08/17 10:30:50 |
cpodonnell8 |
cpukit/../i386/cpu.c: Use inttypes.h to fix 1 warning.
5
@46f05b92
04/05/17 09:28:46 |
Sebastian Huber |
SMP: Simplify SMP multicast actions
5
@cd3d747
03/27/17 06:01:38 |
Sebastian Huber |
arm: Optimize context switch
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to …
5
@b437a360
03/09/17 13:32:04 |
Sebastian Huber |
arm: Fix CPU context validation for Cortex-R4
Do not touch the …
5
@2433a8ab
03/07/17 13:32:42 |
Sebastian Huber |
arm: Remove legacy execption support
5
@088acbb0
03/07/17 12:07:02 |
Sebastian Huber |
score: Fix scheduler yield in SMP configurations
Check that no ask …
5
@f61195b2
03/06/17 10:16:25 |
Sebastian Huber |
powerpc: Fix PPC_CONTEXT_VOLATILE_SIZE
5
@c833970
02/21/17 07:58:29 |
Sebastian Huber |
score: Add RTEMS_WEAK_ALIAS()
5
@7a462cc
02/15/17 10:09:32 |
Sebastian Huber |
score: Fix warning
5
@6dbbafc6
02/14/17 07:42:48 |
Sebastian Huber |
score: Fix warning in _Thread_Set_name()
5
@bbfbfc8
02/03/17 07:57:18 |
Sebastian Huber |
score: Move _Thread_Scheduler_ask_for_help()
Move …
5
@ca1e546e
02/02/17 15:24:05 |
Sebastian Huber |
score: Improve scheduler helping protocol
Only register ask for help …
5
@e2b1c47d
02/03/17 09:16:40 |
Sebastian Huber |
sparc: Fix volatile clobber
Do not adjust the stack pointer, since …
5
@e366f77
01/31/17 07:08:24 |
Sebastian Huber |
score: Add _Thread_queue_Object_name
Add the special thread queue …
5
@70488f56
01/31/17 08:37:54 |
Sebastian Huber |
score: Fix _Thread_Initialize()
5
@c5430e06
01/30/17 11:29:31 |
Sebastian Huber |
score: Fix unused parameter warning
Close #2890.
5
@180107e9
01/30/17 10:33:31 |
Christian.Mauderer |
bsps/arm: Fix Cortex-M DWT CPU counter.
It is necessary to enable the …
5
@4ea92d1e
01/27/17 07:06:06 |
Sebastian Huber |
score: Clarify _Heap_Extend()
Update #1747.
5
@abc963d
01/27/17 06:42:29 |
Sebastian Huber |
score: Fix typo
5
@6f6da82c
01/26/17 10:06:50 |
Sebastian Huber |
score: Fix user extensions order
Use forward and reverse order for …
5
@27bfcd8
01/25/17 13:32:02 |
Sebastian Huber |
score: Delete _CPU_Context_Fp_start()
Since the FP area pointer is …
5
@b43c2e8
01/24/17 14:40:31 |
kevin-kirspel |
Adding ARM VFP V2 support
5
@3d20f5fb
01/23/17 14:04:44 |
Sebastian Huber |
sparc: Relax CPU_STACK_ALIGNMENT
Close #2352.
5
@4aa23c96
01/23/17 07:12:18 |
Sebastian Huber |
Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN
Use de-facto standard …
5
@ba776282
08/12/16 19:25:10 |
Gedare Bloom |
posix: shared memory support
Add POSIX shared memory manager (Shm). …
5
@9fad437
01/13/17 10:33:28 |
Sebastian Huber |
configure: Remove HAVE_STRUCTTHREAD_QUEUE_QUEUE
5
@da6ad56
01/12/17 12:46:55 |
Sebastian Huber |
score: Add _Thread_Set_name()
Add configuration option …
5
@7ced9d9b
01/12/17 08:25:56 |
Sebastian Huber |
score: Add and use _Thread_Get_name()
Update #2858.
5
@2b72162
01/12/17 09:15:56 |
Sebastian Huber |
score: Add Thread_queue_Queue::name
Update #2858.
5
@b8bcebe
01/12/17 07:28:57 |
Sebastian Huber |
score: Add and use _Objects_Name_to_string()
Update #2858.
5
@fa9f964f
01/11/17 07:49:26 |
Sebastian Huber |
score: Remove unused _States_Is_*()
5
@d063e7b3
01/11/17 07:42:04 |
Sebastian Huber |
score: Replace STATES_DELAYING
Replace STATES_DELAYING with …
5
@7a4b2645
01/11/17 15:43:06 |
joel |
Remove obsolete RTEMS_HAVE_SYS_CPUSET_H
5
@3d35bc0
01/11/17 12:41:55 |
Sebastian Huber |
score: Improve SMP lock debug support
The CPU index starts with zero. …
5
@4e07d9b3
01/05/17 14:40:57 |
Sebastian Huber |
score: Optimize thread state values
5
@9a448aab
12/23/16 15:02:07 |
Sebastian Huber |
score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER
Add thread state bit …
5
@c6000d2b
12/23/16 06:09:02 |
Sebastian Huber |
score: Delete STATES_WAITING_FOR_BUFFER
5
@2e6d9865
12/23/16 05:47:11 |
Sebastian Huber |
score: Format thread state defines
Specify all 32-bits in a thread …
5
@a7cfb4b
12/23/16 12:54:11 |
Sebastian Huber |
score: Relax <sys/lock.h> static assertions
Only require that the …
5
@fe7012a0
12/12/16 14:03:35 |
score: Prevent thread_dispatch_disable_level < 0.
5
@e203b65e
12/09/16 08:28:31 |
Sebastian Huber |
Add INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED
Update #2825.
5
@a5ba08eb
12/09/16 08:27:15 |
Sebastian Huber |
Add INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED
Update #2825.
5
@9622f779
12/09/16 07:44:49 |
Sebastian Huber |
Add INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED
Update #2825.
5
@82529688
12/09/16 07:44:22 |
Sebastian Huber |
INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED
Update #2825.
5
@3a659b04
12/09/16 06:19:22 |
Sebastian Huber |
score: Introduce _Internal_error()
5
@0a81a58
12/09/16 05:51:44 |
Sebastian Huber |
Add INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED
Update #2825.
5
@279d5260
12/09/16 05:49:25 |
Sebastian Huber |
Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
Update #2825.
5
@6a9282d
12/09/16 09:49:49 |
Sebastian Huber |
Rename is_internal to always_set_to_false
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@4b579c5f
12/06/16 10:35:34 |
Sebastian Huber |
score: Simplify linker set API
Resurrect RTEMS_LINKER_SET_BEGIN() and …
5
@f65dcc71
12/02/16 12:10:31 |
Sebastian Huber |
score: Fix ARM and PowerPC context initialization
Update #2751.
5
@5b6c290
12/01/16 19:42:48 |
Sebastian Huber |
score: Initialize thread queue context early
Initialize thread queue …
5
@b3cb2c1
12/01/16 21:24:02 |
Sebastian Huber |
score: Fix debug thread queue context init
On ARM Thumb we may have …
5
@6a1b9e4
11/22/16 09:13:27 |
Sebastian Huber |
sparc: Optimize _ISR_Handler()
Use _Thread_Do_dispatch() instead of …
5
@c09db57
11/28/16 12:28:32 |
Sebastian Huber |
score: Fix thread queue context initialization
Initialize the thread …
5
@bd0d585
11/24/16 10:53:59 |
Sebastian Huber |
arm: Fix _CPU_ISR_Is_enabled() for ARMv7-M
Update #2811.
5
@620b23e
11/24/16 05:13:11 |
Sebastian Huber |
score: Optimize _Thread_queue_Enqueue()
Move thread state for …
5
@4b5ff47
11/23/16 15:15:13 |
Sebastian Huber |
score: Fix interrupt profiling
Callers of _Thread_Do_dispatch() must …
5
@f6edd880
11/23/16 12:43:12 |
Sebastian Huber |
score: Explicitly define the fatal source numbers
Update #2825.
5
@bee0323
11/23/16 11:48:57 |
Sebastian Huber |
score: Uncomment unused internal error codes
Update #2825.
5
@c42be504
11/16/16 13:50:09 |
Sebastian Huber |
posix: Add self-contained pthread spinlock
Turn pthread_spinlock_t …
5
@520e07db
11/22/16 07:46:02 |
Sebastian Huber |
score: Add RTEMS_ALIAS()
5
@a4217c6
11/22/16 09:53:03 |
Sebastian Huber |
score: Rename _Thread_queue_Enqueue_critical()
Delete unused …
5
@125f248
11/16/16 15:39:43 |
Sebastian Huber |
score: Add thread queue enqueue callout
Replace the expected thread …
5
@84e6f15
11/10/16 11:02:28 |
Sebastian Huber |
score: Robust thread dispatch
On SMP configurations, it is a fatal …
5
@ec17ad4
11/23/16 06:16:41 |
Sebastian Huber |
score: Delete obsolete scheduler debug aid
5
@1d18a902
11/23/16 09:15:07 |
Sebastian Huber |
arm: Fix _ARMV4_Exception_interrupt
Use the right register to …
5
@a550b3f
11/23/16 06:47:57 |
Sebastian Huber |
score: Force Per_CPU_Control::executing alignment
This fixes the CPU …
5
@4e2bc0a
11/21/16 10:40:00 |
Sebastian Huber |
arm: Fix Thumb-1 targets
We cannot use the MRS or MSR instructions in …
5
@ccc92b8
11/21/16 09:26:32 |
Sebastian Huber |
score: Group Per_CPU_Control members by alignment
Close #2820.
5
@27eccda
11/21/16 09:25:58 |
Sebastian Huber |
sparc64: Fix _CPU_ISR_Is_enabled()
Update #2820.
5
@fd6d3f1
11/21/16 09:13:37 |
Sebastian Huber |
nios2: Fix _CPU_ISR_Is_enabled()
Close #2818.
5
@9f225dea
11/21/16 09:11:18 |
Sebastian Huber |
arm: Fix ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE
Close #2816.
5
@c6f446b
11/21/16 09:06:36 |
Sebastian Huber |
bfin: ASM compatibility for <rtems/score/cpu.h>
Close #2817.
5
@142628e
11/17/16 06:40:05 |
Sebastian Huber |
score: Optimize self-contained objects
Avoid use of the stack for the …
5
@1b87f27
11/17/16 06:20:07 |
Sebastian Huber |
score: Constify _MRSP_Get_owner()
5
@408609f6
11/10/16 14:17:28 |
Sebastian Huber |
score: Add _ISR_Is_enabled()
In contrast to _ISR_Get_level() the …
5
@537f00eb
11/10/16 15:25:41 |
Sebastian Huber |
score: Restrict task interrupt level to 0 on SMP
Update #2811.
5
@7ce60b3
11/14/16 14:23:40 |
Sebastian Huber |
powerpc: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@d59585d
11/14/16 08:53:57 |
Sebastian Huber |
arm: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@2668e4f6
11/13/16 14:20:59 |
Sebastian Huber |
arm: Simplify _ARMV4_Exception_interrupt
Move profiling code closer …
5
@4924756
11/12/16 15:52:55 |
Sebastian Huber |
arm: Use local labels
5
@c11ac2d5
11/14/16 13:42:56 |
Sebastian Huber |
sparc: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@d5e073c
11/11/16 13:37:51 |
Sebastian Huber |
score: Allow interrupts during thread dispatch
Use a …
5
@f9aa34d
11/11/16 13:12:03 |
Sebastian Huber |
score: Add Per_CPU_Control::Interrupt_frame
Update #2809.
5
@2072dd2
11/11/16 14:45:10 |
Sebastian Huber |
score: Add Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@dbeccf0e
11/11/16 11:37:17 |
Sebastian Huber |
arm: Provide CPU_Interrupt_frame for ARMv4
Update #2809.
5
@2599c8e
11/14/16 11:06:46 |
Sebastian Huber |
powerpc: Add up to date CPU_Interrupt_frame
Rename ppc_exc_min_frame …
5
@bf4fdb1
11/11/16 10:31:13 |
Sebastian Huber |
powerpc: Move legacy CPU_Interrupt_frame
The only remaining user of …
5
@c539a865
11/14/16 10:34:54 |
Sebastian Huber |
sparc: Move CPU_Interrupt_frame related defines
Move …
5
@427dcee
11/11/16 10:17:02 |
Sebastian Huber |
sparc: Rename CPU_Minimum_stack_frame
Rename SPARC-specific …
5
