@ccd5434
01/07/16 08:55:45 |
Sebastian Huber |
score: Introduce Thread_Entry_information
This avoids potential dead …
5
@44e9871
12/22/15 08:40:48 |
Sebastian Huber |
score: Avoid dead code in global construction
Update #2514.
5
@f5201df
12/15/15 17:25:01 |
Joel Sherrill |
Remove M32R architecture
updates #2446.
5
@a061f9d
01/04/16 08:55:59 |
Sebastian Huber |
score: Fix watchdog insert
Under certain conditions a new watchdog …
5
@a48b7c44
12/20/15 20:47:12 |
Sebastian Huber |
score: Fix watchdog removal
5
@07b76fd
12/15/15 10:25:47 |
Sebastian Huber |
score: Avoid dependency on bcopy()
5
@54c3fbd
12/11/15 10:09:13 |
Sebastian Huber |
score: Initialize thread control to zero
This reduces the code size …
5
@00dbecb8
12/11/15 08:48:09 |
Sebastian Huber |
score: Help GCC to inline a function
5
@df55d07f
12/10/15 13:10:48 |
Sebastian Huber |
score: Untangle thread actions
Remove the thread action handler …
5
@bd91f446
12/08/15 07:34:08 |
Sebastian Huber |
score: Delete unused API extensions
Update #2408.
5
@60c5461
12/08/15 07:33:08 |
Sebastian Huber |
score: Statically initialize API extensions
Update #2408.
5
@ac5f2442
11/25/15 07:33:31 |
Sebastian Huber |
Require getreent()
This function is used by Newlib since 2013-07-09 …
5
@8ce0b0cb
11/25/15 06:55:00 |
Sebastian Huber |
Fix _Assert() statement
5
@b84a51c
11/10/15 16:23:12 |
Sebastian Huber |
score: Fix race condition on SMP
We must ensure that the …
5
@eab538c
11/04/15 06:39:45 |
Sebastian Huber |
score: Fix warning
Close #2454.
5
@f97536d
10/16/15 06:21:48 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_UNUSED
5
@314ff3c4
09/14/15 05:10:24 |
Sebastian Huber |
score: Fix resource count for self-contained mutex
5
@dafa5d88
09/03/15 08:27:16 |
Sebastian Huber |
score: Implement priority boosting
5
@3995e6d
09/02/15 09:58:54 |
Sebastian Huber |
score: Implement SMP-specific priority queue
5
@edf640f
08/31/15 11:11:04 |
Sebastian Huber |
rbtree: Add _RBTree_Replace_node()
5
@e9fbaa3b
08/21/15 03:59:49 |
Sebastian Huber |
rbtree: Replace implementation
Use the BSD <sys/tree.h> …
5
@8c25e04
09/02/15 13:02:27 |
Sebastian Huber |
score: Optimize thread queue first operation
In case the thread queue …
5
@44f3ea9
08/31/15 11:37:52 |
Sebastian Huber |
score: Fix return status of mutex try acquire
This fixes a copy and …
5
@ddb6a49b
08/21/15 03:57:42 |
Sebastian Huber |
rbtree: Delete _RBTree_Initialize()
This function has no internal use …
5
@2d48456
08/21/15 03:24:17 |
Sebastian Huber |
rbheap: Drop direction from _RBTree_Iterate()
5
@341f629
08/21/15 03:39:59 |
Sebastian Huber |
rbtree: Add _RBTree_Minimum(), _RBTree_Maximum()
5
@9e9e61d
07/28/15 11:46:56 |
Sebastian Huber |
score: Add self-contained condition implementation
5
@a1b4af4b
07/20/15 07:05:30 |
Sebastian Huber |
score: Add scheduler <sys/lock.h> support
5
@40188718
07/13/15 08:00:28 |
Sebastian Huber |
score: Add self-contained futex implementation
5
@7237b3e
07/02/15 11:12:38 |
Sebastian Huber |
score: Add self-contained semaphore implementation
5
@214d8ed
06/28/15 20:06:36 |
Sebastian Huber |
score: Add self-contained mutex implementation
This mutex …
5
@12f93fbb
07/27/15 11:19:17 |
Sebastian Huber |
score: Add thread queue for self-contained objects
5
@0e3c59d6
06/26/15 10:54:33 |
Sebastian Huber |
score: Use a plain ticket lock for thread locks
This enables external …
5
@10e32a26
06/29/15 12:23:42 |
Sebastian Huber |
score: Add potpourri lock statistics
These SMP lock statistics are …
5
@21789a21
07/28/15 12:45:42 |
Sebastian Huber |
score: Rename _POSIX_Absolute_timeout_to_ticks()
Rename …
5
@e709aa85
07/13/15 11:49:35 |
Sebastian Huber |
score: Move wait flag update to tq extract
This makes it possible to …
5
@d7665823
06/24/15 13:43:19 |
Sebastian Huber |
score: Introduce Thread_queue_Heads
Move the storage for the thread …
5
@e2735012
06/24/15 09:05:39 |
Sebastian Huber |
score: Introduce Thread_queue_Queue
Separate the thread queue heads …
5
@f59f2fe9
06/25/15 04:50:04 |
Sebastian Huber |
score: Accept NULL pointer in _Freechain_Put()
With this a …
4.115
@fdb45d6
06/24/15 12:00:08 |
Sebastian Huber |
score: Freechain handler API changes
Replace the extend function with …
4.115
@d811dac
06/25/15 09:24:44 |
Sebastian Huber |
score: Hide SMP lock profiling impl if disabled
The problem is that …
4.115
@48fed9a
06/25/15 12:11:53 |
Sebastian Huber |
score: Simplify <rtems/system.h>
Drop the <rtems/score/percpu.h> …
4.115
@0b268b8b
06/25/15 11:37:40 |
Sebastian Huber |
score: Move default _ISR_Is_in_progress()
4.115
@8042107a
06/25/15 09:28:59 |
Sebastian Huber |
score: Move SMP CPU_USE_DEFERRED_FP_SWITCH check
4.115
@a3fc33f
06/24/15 11:36:40 |
Sebastian Huber |
score: Assert proper node size
4.115
@e6b31b27
05/27/15 15:13:58 |
Joel Sherrill |
Remove use ticks for statistics configure option.
This was obsolete …
4.115
@80fca28
06/13/15 13:29:04 |
Sebastian Huber |
score: Add _Watchdog_Preinitialize()
Add an assert to ensure that the …
4.115
@258d580c
06/13/15 12:49:23 |
Sebastian Huber |
score: Delete unused state WATCHDOG_REMOVE_IT
4.115
@f718e79
06/11/15 07:56:18 |
Sebastian Huber |
Revert "timecounter: No _Timecounter_Tick_simple() for SMP"
This …
4.115
@46ae1d7a
06/09/15 19:31:27 |
Sebastian Huber |
4.115
@e1d61fe
06/09/15 11:49:56 |
kib |
timecounter: Synchronize with FreeBSD
When updating/accessing the …
4.115
@7e1a9ac
05/04/15 17:59:39 |
ian |
Implement a mechanism for …
4.115
@cb6fde65
03/14/15 23:16:12 |
ian |
Use sbuf_printf() for sysctl …
4.115
@b5b8116
03/07/15 18:23:32 |
hselasky |
Add mutex support to the …
4.115
@335e5ca
06/02/15 19:43:54 |
Sebastian Huber |
score: Add Thread_Control::is_fp
Store the floating-point unit …
4.115
@863dcf4
06/02/15 12:01:29 |
Sebastian Huber |
score: Remove assert
With the introduction of fine grained locking …
4.115
@ec84273d
05/27/15 09:43:44 |
Sebastian Huber |
score: Replace _API_Mutex_Is_locked()
Replace _API_Mutex_Is_locked() …
4.115
@7cd2484
05/12/15 12:32:47 |
alexander.krutwig |
timecounter: Use in RTEMS
Replace timestamp implementation with …
4.115
@31be416
04/20/15 09:08:22 |
alexander.krutwig |
timecounter: Port to RTEMS
New test sptests/timecounter01.
Update #2271.
4.115
@cc693845
05/12/15 10:12:18 |
alexander.krutwig |
timecounter: Honor FFCLOCK define
Update #2271.
4.115
@664f844
05/12/15 10:10:04 |
alexander.krutwig |
timecounter: Use uint32_t instead of u_int
FreeBSD assumes that u_int …
4.115
@4117cd1
03/19/15 10:38:14 |
alexander.krutwig |
timecounter: Import from FreeBSD
Update #2271.
4.115
@d5423295
05/18/15 09:09:14 |
Sebastian Huber |
score: _Thread_Dispatch_disable_critical()
Thread dispatching is …
4.115
@aa05cfbb
05/11/15 12:56:49 |
Sebastian Huber |
score: Replace _Thread_Delay_ended()
Use _Thread_Timeout() instead. …
4.115
@9052f88
05/11/15 08:14:31 |
Sebastian Huber |
score: Do not inline SMP lock if profiling enabled
This reduces the …
4.115
@a816f084
05/07/15 12:02:46 |
Sebastian Huber |
score: Fine grained locking for MrsP
Update #2273.
4.115
@900d337f
05/05/15 11:05:54 |
Sebastian Huber |
score: Rework _Thread_Change_priority()
Move the writes to …
4.115
@4438ac25
05/02/15 12:27:24 |
Sebastian Huber |
score: Fine grained locking for mutexes
Update #2273.
4.115
@d12b313
05/02/15 12:06:38 |
Sebastian Huber |
score: Inline _CORE_semaphore_Surrender()
4.115
@b76dd97
05/02/15 12:04:21 |
Sebastian Huber |
score: Inline _CORE_semaphore_Flush()
4.115
@cfa5aab
05/02/15 12:02:20 |
Sebastian Huber |
score: Delete _CORE_semaphore_Seize()
Rename …
4.115
@e76c517
05/01/15 18:52:51 |
Sebastian Huber |
score: Fine grained locking for semaphores
Update #2273.
4.115
@cc18d7b
04/30/15 11:12:54 |
Sebastian Huber |
score: Fine grained locking for message queues
Aggregate several …
4.115
@c654b525
04/30/15 11:18:45 |
Sebastian Huber |
score: Delete _CORE_message_queue_Flush_support()
Check the number of …
4.115
@f5d6c8b
04/27/15 14:25:52 |
Sebastian Huber |
score: Delete Thread_queue_Control::timeout_status
Use a parameter …
4.115
@cc366ec
04/24/15 10:02:20 |
Sebastian Huber |
score: New thread queue implementation
Use thread wait flags for …
4.115
@383cf42
04/22/15 09:15:46 |
Sebastian Huber |
score: More thread queue operations
Move thread queue discipline …
4.115
@568af83
04/21/15 08:17:13 |
Sebastian Huber |
score: Add Thread_queue_Operations
Replace the …
4.115
@02c4c441
04/23/15 08:01:22 |
Sebastian Huber |
score: Add Thread_queue_Control::Lock
Move the complete thread queue …
4.115
@08fe84b
04/22/15 08:06:05 |
Sebastian Huber |
score: Generalize _Event_Timeout()
Add a thread wait timeout code. …
4.115
@a382010c
04/10/15 13:31:31 |
Sebastian Huber |
score: New timer server implementation
Use mostly the standard …
4.115
@fd53d25
04/24/15 07:53:58 |
Sebastian Huber |
score: Move _Watchdog_Tickle()
Make internal function …
4.115
@1ccbd052
04/15/15 08:53:29 |
Sebastian Huber |
score: Add Watchdog_Iterator
Rewrite the _Watchdog_Insert(), …
4.115
@6d253941
04/15/15 14:28:42 |
Sebastian Huber |
score: Add _Watchdog_Acquire|Release|Flash()
Update #2307.
4.115
@2903090
04/15/15 09:26:46 |
Sebastian Huber |
score: Add header to _Watchdog_Remove()
Add watchdog header parameter …
4.115
@a61d385
04/24/15 08:51:24 |
Sebastian Huber |
score: Optimize _Thread_queue_Compare_priority()
4.115
@56729d8
04/23/15 19:29:56 |
Sebastian Huber |
score: Delete STATES_WAITING_ON_THREAD_QUEUE
Avoid the usage of the …
4.115
@22788bc
04/23/15 11:01:05 |
Sebastian Huber |
score: _Thread_queue_Extract()
Remove thread queue parameter from …
4.115
@7e19330e
05/19/15 09:37:26 |
Sebastian Huber |
score: Fix assert
4.115
@47c9c083
05/12/15 08:53:47 |
Sebastian Huber |
score: Avoid Giant lock in _Objects_Id_to_name()
This prevents a …
4.115
@a6502a58
05/06/15 09:54:19 |
Sebastian Huber |
score: Fix Thread_Control and Thread_Proxy_control
Fix layout of the …
4.115
@be6c461
04/23/15 08:27:07 |
Sebastian Huber |
score: _CORE_mutex_Seize_interrupt_blocking()
Move some code into …
4.115
@9f10911
04/22/15 19:29:21 |
Sebastian Huber |
score: Delete Thread_queue_Control::state
Use a parameter for …
4.115
@d349e8a4
04/21/15 07:21:29 |
Sebastian Huber |
score: Fix priority message queue insert
Move the linear search into …
4.115
@b0686b4
04/22/15 11:57:18 |
Sebastian Huber |
score: Delete _CORE_RWLock_Timeout()
This function was identical to …
4.115
@d3802bb5
04/20/15 07:50:01 |
Sebastian Huber |
score: Delete object control block ISR lock
The Objects_Control::Lock …
4.115
@1041de1
04/20/15 07:45:10 |
Sebastian Huber |
score: Add _Thread_Get_interrupt_disable()
Remove _Thread_Acquire() …
4.115
@3bf4a9fa
04/20/15 06:52:52 |
Sebastian Huber |
score: _Objects_Get_isr_disable()
Do not disable thread dispatching …
4.115
@4db0ae8e
04/20/15 06:45:41 |
Sebastian Huber |
Use ISR_lock_Context instead of …
4.115
@26c142e5
04/17/15 10:05:16 |
Sebastian Huber |
score: Refactor SMP cache manager support
4.115
