@ca10004
03/26/15 20:16:09 |
Sebastian Huber |
score: Simplify _Thread_Set_state()
4.115
@9baffdf
04/08/15 05:40:00 |
Sebastian Huber |
score: Move _Watchdog_Ticks_since_boot definition
4.115
@ad57a59
03/24/15 07:29:44 |
Sebastian Huber |
score: Fix MrsP ISR/task sychronization
4.115
@4054c916
03/20/15 12:41:27 |
Sebastian Huber |
score: Add scheduler acquire/release
This is currently a global lock …
4.115
@57947f1
03/23/15 14:05:32 |
Sebastian Huber |
score: Add thread lock
Update #2273.
4.115
@2e9c3d5
03/17/15 15:28:50 |
Sebastian Huber |
score: Add thread priority change handler
Since the thread current …
4.115
@0d36bfb3
03/20/15 22:56:08 |
Joel Sherrill |
rtems/score/tls.h: Add casts to eliminate warnings on some targets
4.115
@a6524b9
03/22/15 13:31:59 |
Sebastian Huber |
score: Simplify debug code and use _Assert()
4.115
@688fbc44
03/22/15 09:43:06 |
Sebastian Huber |
score: Move _Thread_queue_Extract()
Move _Thread_queue_Dequeue(). We …
4.115
@2429766
03/22/15 09:37:52 |
Sebastian Huber |
score: Move _Thread_blocking_operation_Cancel()
Move …
4.115
@c3803167
03/20/15 07:28:20 |
alexander.krutwig |
score: Delete unused _Timestamp_(To|From)_ticks()
4.115
@677d2b09
03/20/15 08:08:57 |
alexander.krutwig |
score: Delete unused _Timestamp_Divide_by_integer
4.115
@6a941e3
03/17/15 15:24:44 |
Sebastian Huber |
score: Fix _Thread_Change_priority()
Atomically update the current …
4.115
@e0a25fb
03/19/15 12:52:22 |
alexander.krutwig |
score: Delete unused _Timestamp_Is_valid()
4.115
@46d3c6d8
03/16/15 20:15:55 |
Gedare Bloom |
cpukit: add and use CPU_Uint32ptr type
4.115
@1ff449c
03/16/15 16:15:27 |
Gedare Bloom |
rtems: make error codes uintptr_t
4.115
@6db5e650
03/15/15 09:16:24 |
Sebastian Huber |
score: Add _Objects_ISR_disable_and_acquire()
4.115
@bdf23b6c
03/10/15 17:39:59 |
Joel Sherrill |
cpukit: Remove old DESCRIPTION: in comments
These were remnants of …
4.115
@f0ff18e
03/09/15 12:18:32 |
Sebastian Huber |
score: Add rtems_set_errno_and_return_value()
Remove …
4.115
@25ce352b
03/09/15 10:43:55 |
Sebastian Huber |
score: Fix for GCC version 5 and later
4.115
@7b4e81d
03/09/15 07:51:55 |
Sebastian Huber |
score: Typo
Close #2286.
4.115
@a7e4de2
03/06/15 20:33:08 |
Joel Sherrill |
Fix even more Doxygen issues
4.115
@325a61d5
03/06/15 20:06:49 |
Joel Sherrill |
coremuteximpl.h: Reorder macro names to match body and fix Doxygen …
4.115
@e0eb07a
03/06/15 19:26:12 |
Joel Sherrill |
Fix more Doxygen typos
4.115
@cc69334f
03/06/15 16:35:40 |
Joel Sherrill |
Fix a number of minor Doxygen formatting issues
4.115
@bf9d387
03/06/15 13:40:56 |
Sebastian Huber |
score: Allow NULL for SMP lock name
4.115
@da06fe9
03/06/15 12:20:44 |
Sebastian Huber |
score: Fix SMP lock implementation
See also:
4.115
@7183f1cd
03/05/15 10:51:25 |
Sebastian Huber |
score: Add compiler memory barrier to atomic ops
4.115
@4c8a0ac
03/04/15 07:02:09 |
Sebastian Huber |
score: Add thread wait flags
Update #2273.
4.115
@5b393fa5
03/01/15 12:50:55 |
Sebastian Huber |
score: Add thread acquire
Update #2273.
4.115
@43e1573c
02/28/15 17:06:37 |
Sebastian Huber |
score: Add ISR lock to Objects_Control
This enables per-object SMP …
4.115
@1512761
02/28/15 16:24:52 |
Sebastian Huber |
score: Thread dispatch dis/enable without Giant
Update #2273.
4.115
@222dc775
02/26/15 09:32:08 |
Sebastian Huber |
score: Add and use _Thread_Do_dispatch()
The _Thread_Dispatch() …
4.115
@6157743
02/23/15 15:54:54 |
Sebastian Huber |
score: Simplify and fix signal delivery
Deliver the POSIX signals …
4.115
@b8a5abf
02/26/15 09:33:36 |
Sebastian Huber |
score: Update _Thread_Heir only if necessary
Previously, the …
4.115
@81b03c6
03/05/15 07:11:27 |
Sebastian Huber |
score: Add and use PRIORITY_PSEUDO_ISR
4.115
@b8aa1c1
03/05/15 08:53:09 |
Sebastian Huber |
score: C/C++ compatibility macros for ISR locks
Update #2273.
4.115
@51acbdc
03/04/15 12:07:02 |
alexander.krutwig |
score: Documentation
4.115
@e50297e
03/04/15 09:15:02 |
Sebastian Huber |
score: ISR lock C/C++ compatiblity issue
Empty structures are …
4.115
@d2ffb7dc
02/26/15 10:35:28 |
Sebastian Huber |
score: Add and use _Thread_Enable_dispatch_body()
Update #2273.
4.115
@b99be6e
02/26/15 10:32:45 |
Sebastian Huber |
score: Inline _Thread_Disable_dispatch() for SMP
4.115
@2b7fe356
02/26/15 09:29:02 |
Sebastian Huber |
score: Add parameter to Giant acquire/release
Update #2273.
4.115
@4ccb79bc
03/02/15 11:23:20 |
Sebastian Huber |
score: Enable SMP barriers for all configurations
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@8d6e6eeb
02/17/15 09:00:43 |
Sebastian Huber |
score: Fix FP context restore via _Thread_Handler
After a context …
4.115
@50a50313
01/21/15 14:22:46 |
Sebastian Huber |
score: Delete superfluous Heap_Statistics::instance
This value …
4.115
@2a4f9d7
12/23/14 07:28:24 |
Sebastian Huber |
smp: Add and use _SMP_Should_start_processor()
4.115
@864d3475
12/17/14 14:11:00 |
Sebastian Huber |
smp: Fix timeout for MrsP semaphores
The previous timeout handling …
4.115
@d006b46d
11/28/14 10:53:55 |
Sebastian Huber |
score: Add heap statistics
Add lifetime bytes allocated and freed …
4.115
@2c3c657
11/27/14 12:25:22 |
Sebastian Huber |
score: Return heap stats via _Heap_Get_information
Print out heap …
4.115
@5bd822a7
11/26/14 10:51:34 |
Sebastian Huber |
smp: Fix scheduler helping protocol
Ensure that scheduler nodes in …
4.115
@79569ae
11/26/14 09:00:13 |
Sebastian Huber |
smp: Fix scheduler helping protocol assertions
4.115
@c562d0c
11/19/14 20:47:57 |
josh.oguin |
objectimpl.h: Add _Assert() to _Objects_Invalidate_Id()
CodeSonar? …
4.115
@fbafb8f2
11/19/14 20:46:43 |
josh.oguin |
chainimpl.h: Add _Assert() to _Chain_Initialize_empty()
CodeSonar? …
4.115
@26f4cdd
11/24/14 07:35:45 |
Sebastian Huber |
_Scheduler_FIXME_thread_priority_queues_are_broken
Delete this …
4.115
@cceb19f4
11/21/14 10:01:34 |
lohathe |
New test case for …
4.115
@89be4e7
11/23/14 00:25:12 |
Santosh Vattam |
rtems/score/object.h: Correct types on _Objects_Build_id
close 1423
4.115
@b2db1f5c
11/20/14 14:00:29 |
dolezj21 |
cpukit: basedefs: macro for packed attribute
4.115
@f9b19d9
09/19/14 19:04:49 |
Jennifer Averett |
score: Move is_executing_on_a_core from cpuusagereport.c to threadimpl.h
4.115
@134a181
09/08/14 14:46:43 |
Jennifer Averett |
score: Add capture data to tcb.
4.115
@8237b2d
10/15/14 14:15:07 |
Joel Sherrill |
rtems/score/object.h: Include <rtems/score/cpu.h> to honor 16-bit Ids
4.115
@a38ced2
10/10/14 07:09:19 |
Sebastian Huber |
score: Rework global construction
Ensure that the global construction …
4.115
@dadd7cd
09/22/14 10:01:49 |
Sebastian Huber |
score: Delete Thread_Wait_information::Block2n
This field is no …
4.115
@80ad7090
09/08/14 12:13:31 |
pisa |
score: More strict RTEMS_DEQUALIFY implementation.
This …
4.115
@a72f16e
09/05/14 06:32:28 |
Sebastian Huber |
score: Add RTEMS_DECONST|DEVOLATILE|DEQUALIFY()
4.115
@3bff410
09/02/14 23:07:36 |
Joel Sherrill |
rtems/score/assert.h: Rework to allow use of NDEBUG
4.115
@f553c6e
08/22/14 14:39:47 |
Sebastian Huber |
rtems: Inline rtems_clock_get_ticks_since_boot()
Update documentation.
4.115
@ddbc3f8d
07/11/14 14:37:56 |
cederman |
score: Add SMP support to the cache manager
Adds functions that …
4.115
@aed38189
07/08/14 09:35:14 |
cederman |
score: Rename SMP broadcast message function
Change message type to …
4.115
@a68cc1b
07/08/14 09:33:55 |
cederman |
score: Add function to send a SMP message to a set of CPUs
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@4cd55724
07/26/14 10:52:22 |
Sebastian Huber |
Delete unused *_Is_null() functions
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@9113798c
07/23/14 20:39:17 |
Joel Sherrill |
todimpl.h: Add missing Doxygen
4.115
@875fff0a
07/23/14 20:35:35 |
Joel Sherrill |
Add _TOD_Adjust to SCORE TOD Handler.
This lays the proper structure …
4.115
@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@0ea6d07
07/09/14 18:22:28 |
Joel Sherrill |
Use Shared Method for Thread Unblock Cleanup
When a thread is removed …
4.115
@3250664
07/15/14 17:37:36 |
Joel Sherrill |
Thread Queue: Merge discipline subroutines into main methods
There …
4.115
@ed7a028
07/07/14 19:26:13 |
Joel Sherrill |
Thread Queue Priority Discipline Reimplemented with RBTree
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@7e119990
07/12/14 19:22:21 |
Sebastian Huber |
rbtree: Delete unused functions
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@333f9426
07/10/14 10:49:43 |
Sebastian Huber |
score: Fix assertions
4.115
@c6048ee
07/09/14 09:20:23 |
Sebastian Huber |
score: _Scheduler_Thread_get_own_node()
Provide this function also …
4.115
@5c3d250
07/04/14 12:34:23 |
Sebastian Huber |
score: Implement scheduler helping protocol
The following scheduler …
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@ac532f3
07/04/14 11:40:10 |
Sebastian Huber |
score: Add _Scheduler_Help()
Manage the help state of threads with …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@19e41767
07/08/14 08:38:19 |
Sebastian Huber |
score: Simplify SMP processor allocation
Avoid copy and paste and set …
4.115
@835b88b
07/07/14 14:41:03 |
Sebastian Huber |
score: Rename _Scheduler_SMP_Update_heir()
Rename and move …
4.115
@5c632c4
07/07/14 11:31:07 |
Sebastian Huber |
score: Fix warning
4.115
@46cd17a
07/04/14 12:32:35 |
Sebastian Huber |
score: Fix MrsP resource root change
Use the root of the owner for …
4.115
@bec4730
06/30/14 10:55:50 |
Sebastian Huber |
score: Add PER_CPU_OFFSET_EXECUTING
Add PER_CPU_OFFSET_HEIR. Move …
4.115
@89f8eab5
05/07/14 12:55:37 |
Sebastian Huber |
score: Workaround for GCC 4.9 for atomic ops
The GCC 4.9 ships its …
4.115
