Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit/score/cpu/unix
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @0a6fb22   04/22/97 20:19:25 Joel Sherrill Patch from Chris John <cjohns@…> to add use of a select … 4.104.114.84.95
(edit) @f2545552   04/22/97 19:57:02 Joel Sherrill multiprocessing fixed on linux by fixing cpu.c so correct form of … 4.104.114.84.95
(edit) @e71ce071   04/22/97 17:47:16 Joel Sherrill updated with new license information per Tony Bennett. 4.104.114.84.95
(edit) @d6ba279   04/07/97 21:24:02 Joel Sherrill added initialization of variable to eliminate warning. 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @a3cfa9f   03/10/97 19:37:44 Joel Sherrill initialized a stack variable to avoid a warning. 4.104.114.84.95
(edit) @855edec   09/30/96 20:15:01 Joel Sherrill fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. 4.104.114.84.95
(edit) @d1193c7   09/18/96 20:47:31 Joel Sherrill corrected white space problems added CPU_STRUCTURE_ALIGNMENT to … 4.104.114.84.95
(edit) @d196e48   05/23/96 15:34:54 Joel Sherrill updates from Tony Bennett. Broke the setjmp/longjmp pair in the … 4.104.114.84.95
(edit) @1c964ffa   05/08/96 21:53:50 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @cc4c1fe4   04/22/96 16:44:54 Joel Sherrill added stack allocation fields to the cpu table updates from Tony … 4.104.114.84.95
(edit) @75f09e5   02/21/96 14:43:34 Joel Sherrill Dispersal of internal thread handler resulted in IDLE thread becoming … 4.104.114.84.95
(edit) @8a38f3b   02/09/96 14:21:37 Joel Sherrill added clear of _ISR_Signals_to_thread_executing 4.104.114.84.95
(edit) @c64e4ed4   01/15/96 21:50:28 Joel Sherrill updates from Tony Bennett for PA and UNIX ports 4.104.114.84.95
(edit) @9700578   10/30/95 21:54:45 Joel Sherrill SPARC port passes all tests 4.104.114.84.95
(edit) @1ceface   10/06/95 16:33:30 Joel Sherrill moved to new development machine and went to gcc 2.7.0 4.104.114.84.95
(edit) @11290355   09/29/95 17:19:16 Joel Sherrill all targets compile .. tony's patches in place 4.104.114.84.95
(edit) @37f4c2d   09/27/95 20:53:58 Joel Sherrill Modified UNIX simulator port so all references to native unix stuff is … 4.104.114.84.95
(edit) @5e9b32b   09/26/95 19:27:15 Joel Sherrill posix support initially added 4.104.114.84.95
(edit) @3652ad35   09/19/95 14:53:29 Joel Sherrill Minor bug fixes to get all targets compilable and running. The single … 4.104.114.84.95
(edit) @3a4ae6c   09/11/95 19:35:39 Joel Sherrill The word "RTEMS" almost completely removed from the core. … 4.104.114.84.95
(edit) @e7e016f   08/04/95 22:18:45 Joel Sherrill cleanup and optimization from Tony 4.104.114.84.95
(edit) @0d55427   08/02/95 20:01:26 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @10aed1e3   07/18/95 19:58:45 Joel Sherrill fixed for Linux 4.104.114.84.95
(edit) @8044533   07/18/95 19:27:50 Joel Sherrill merged Linux UNIX simulator support (C) 4.104.114.84.95
(edit) @637df35   07/12/95 19:47:25 Joel Sherrill Ada95, gnat, go32 4.104.114.84.95
(edit) @88d594a   05/24/95 21:39:42 Joel Sherrill Fully tested on all in-house targets 4.104.114.84.95
(add) @ac7d5ef0   05/11/95 17:39:37 Joel Sherrill Initial revision 4.104.114.84.95
