@38736c6
02/24/20 13:06:16 |
Sebastian Huber |
rtems: Add rtems_scheduler_map_priority_to_posix()
Update #3881.
5
@ca82a603
02/15/20 11:03:39 |
Sebastian Huber |
rtems: Change timer server task mode setting
Use the non-preempt mode …
5
@e50e42b8
02/15/20 10:52:00 |
Sebastian Huber |
score: _Scheduler_Is_non_preempt_mode_supported()
If the non-preempt …
5
@1ada3e55
02/15/20 10:09:16 |
Sebastian Huber |
score: Add _SMP_Need_inter_processor_interrupts()
Test for the proper …
5
@9bdb6aa3
02/14/20 08:48:41 |
Sebastian Huber |
config: Bring back RTEMS 4.11 configuration table
This improves API …
5
@a9bc7a5
02/14/20 08:34:03 |
Sebastian Huber |
rtems: Simplify _RTEMS_tasks_Initialize_user_task()
Due to the system …
5
@9520ec3
02/14/20 08:31:44 |
Sebastian Huber |
config: Simplify initialization task config
With the removal of the …
5
@01d5944
12/09/19 13:48:34 |
Sebastian Huber |
score: Move thread stack allocation
Move thread stack allocation to …
5
@a08dcb2
12/09/19 12:57:51 |
Sebastian Huber |
score: Add Thread_Configuration
Add the Thread_Configuration …
5
@453bb4b
12/29/19 16:43:46 |
Sebastian Huber |
rtems: Fix MPCI initialization
Update #2408.
5
@08bd7d3
11/12/19 15:33:41 |
joel |
Add TOD Hooks to allow BSP to take action when TOD is set
Two use …
5
@01f8c12e
12/07/19 10:48:36 |
Sebastian Huber |
rtems: Optimize semaphore control block
Move variant, discipline, and …
5
@667501a
10/02/19 21:49:00 |
joel |
termios: Add Capability to Generate SIGINTR and SIGQUIT
This patch …
5
@b4f895e
05/17/19 07:21:03 |
Sebastian Huber |
posix: Remove unused OBJECTS_POSIX_INTERRUPTS
5
@ad87de4
04/11/19 06:54:29 |
Sebastian Huber |
score: Rename _SMP_Get_processor_count()
Rename …
5
@f9219db
04/05/19 06:16:05 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_processor_maximum()
Add …
5
@03c9f24
04/05/19 06:03:12 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_processor()
Add …
5
@3fe2155
02/01/19 09:00:36 |
Sebastian Huber |
Remove superfluous <rtems/system.h> includes
5
@feea03b6
02/27/19 09:53:30 |
Sebastian Huber |
Remove explicit file names from @file
This makes the @file …
5
@e4ad14cc
02/12/19 11:19:38 |
Sebastian Huber |
score: Avoid some deadlocks in _Once()
Recursive usage of the same …
5
@3bd39999
01/08/19 08:53:26 |
Sebastian Huber |
Adjust interrupt mode tests for some CPU ports
In case the robust …
5
@1f285186
01/08/19 07:39:42 |
Sebastian Huber |
rtems: Allow to set ISR level 0 in SMP config
Update #3000.
5
@38cb59e
01/08/19 07:36:31 |
Sebastian Huber |
Separate task mode checks
Update #3000.
5
@21275b58
11/22/18 18:14:51 |
Sebastian Huber |
score: Static Objects_Information initialization
Statically allocate …
5
@8b0e752f
12/10/18 12:44:53 |
Sebastian Huber |
score: Remove Objects_Information::auto_extend
Use …
5
@1c2d178
11/25/18 19:15:26 |
Sebastian Huber |
score: Remove Objects_Information::maximum
This information is …
5
@3899bc1a
11/24/18 10:51:28 |
Sebastian Huber |
score: Optimize object lookup
Use the maximum ID for the ID to object …
5
@9c9c6a9
11/21/18 16:30:52 |
Sebastian Huber |
score: Remove Objects_Information::is_string
Use …
5
@7ee6437
12/06/18 08:57:01 |
Sebastian Huber |
rtems: Add rtems_scheduler_get_maximum_priority()
Update #3636.
5
@ef23838
12/03/18 12:10:21 |
Sebastian Huber |
score: Avoid sbintime_t in API headers
The sbintime_t is a non-POSIX …
5
@4e46ba8
12/06/18 09:49:43 |
Sebastian Huber |
rtems: Fix rtems_task_restart() argument type
Close #3637.
5
@6378978
11/26/18 09:14:00 |
Sebastian Huber |
rtems: Fix semaphore MPCI support
5
@3faa8459
11/08/18 05:25:32 |
Sebastian Huber |
rtems: Simplify rtems_interrupt_catch()
Remove casts and superfluous …
5
@e897c7d
11/08/18 11:57:26 |
Sebastian Huber |
rtems: Avoid include of <rtems/score/scheduler.h>
Update #3598.
5
@98c01a5
11/08/18 10:32:13 |
Sebastian Huber |
rtems: Avoid <rtems/score/timecounter.h> in API
Use a real function …
5
@b7af3e44
11/08/18 09:57:21 |
Sebastian Huber |
rtems: Move internal structures to tasksdata.h
Update #3598.
5
@739df1f5
11/08/18 09:45:44 |
Sebastian Huber |
rtems: Move internal structures to semdata.h
Update #3598.
5
@bdd4eb87
11/08/18 08:13:59 |
Sebastian Huber |
rtems: Remove Modes_Control
Use rtems_mode directly. This is in line …
5
@54f35888
10/25/18 08:54:12 |
Sebastian Huber |
posix: Provide threads by default
Update #2514.
5
@fe7aefd5
10/25/18 08:12:39 |
Sebastian Huber |
posix: Provide message queues by default
Update #2514.
5
@701057e0
10/25/18 08:07:46 |
Sebastian Huber |
posix: Provide shared memory objects by default
Update #2514.
5
@9318cfb0
10/14/18 10:43:13 |
Sebastian Huber |
posix: Provide named semaphores by default
Update #2514.
5
@5090a71b
10/25/18 09:32:01 |
Sebastian Huber |
score: Remove bogus thread object name support
Update #2514.
5
@1d39e96
10/05/18 06:11:09 |
Sebastian Huber |
score: Fix legacy RTEMS_STATIC_ASSERT()
In standard C pointer …
5
@e50e3f70
10/01/18 07:25:06 |
Sebastian Huber |
rtems: Add rtems_task_exit()
Update #3533.
5
@7097962
08/29/18 07:43:44 |
Sebastian Huber |
score: Add thread pin/unpin support
Add support to temporarily pin a …
5
@b2de426
08/06/18 09:53:42 |
Sebastian Huber |
score: Fix _Addresses_Subtract()
Use architecture-specific integer …
5
@66cb142
08/06/18 08:51:00 |
Sebastian Huber |
rtems: Parameter types in rtems_partition_create()
Use uintptr_t to …
5
@83ca9f0a
08/02/18 12:52:12 |
Sebastian Huber |
rtems: Relax partition buffer area alignment
The partition buffer …
5
@27bbc05
08/02/18 12:49:01 |
Sebastian Huber |
score: Remove CPU_PARTITION_ALIGNMENT
Use the CPU_SIZEOF_POINTER …
5
@7d7c50de
05/25/18 12:09:46 |
Sebastian Huber |
rtems: Move _Status_Object_name_errors_to_status
Move …
5
@ed24ed4e
02/08/18 09:47:16 |
Sebastian Huber |
Use _Thread_Dispatch_direct()
Use _Thread_Dispatch_direct() for …
5
@a49dfb1
02/08/18 09:46:11 |
Sebastian Huber |
rtems: Use _Per_CPU_Get_executing()
5
@9480815a
12/21/17 13:36:52 |
Sebastian Huber |
score: Introduce new monotonic clock
Rename …
5
@3a4e044
12/22/17 09:35:47 |
Sebastian Huber |
score: Rename _Watchdog_Realtime_from_*()
Rename …
5
@a5b4db4b
12/21/17 13:59:54 |
Sebastian Huber |
rtems: Fix rtems_task_mode()
A rtems_configuration_is_smp_enabled() …
5
@d2711c37
12/05/17 15:54:56 |
joel |
taskmode.c: Ensure all error checking is done before modifying …
5
@6c2b8a4b
11/29/17 05:23:27 |
Sebastian Huber |
score: Use self-contained API mutex
Use a self-contained recursive …
5
@a7dcef97
11/17/17 05:36:54 |
Sebastian Huber |
score: Simplify global construction
Update #3243.
5
@702e820
11/20/17 17:53:22 |
martinerikwerner.aac |
Fix comments for object lookup error to RTEMS status map
Based on …
5
@888da71
11/16/17 06:17:05 |
Sebastian Huber |
score: Check thread resource count in timer server
The watchdog …
5
@34799c3b
10/24/17 07:35:06 |
Sebastian Huber |
rtems: rtems_clock_get_ticks_per_second()
Add macro implementation …
5
@c3105894
10/19/17 11:47:57 |
Sebastian Huber |
score: Move thread queue timeout handling
Update #3117.
Update #3182.
5
@ecef3698
10/17/17 14:19:03 |
Sebastian Huber |
score: Rename _Watchdog_Ticks_from_*()
Rename …
5
@27cfe7c
10/20/17 06:31:36 |
Sebastian Huber |
score: Add _Watchdog_Ticks_per_second
This value is frequently used. …
5
@02878626
10/17/17 14:15:31 |
Sebastian Huber |
score: Add _Thread_Add_timeout_ticks()
Replace …
5
@91ce012c
10/16/17 07:32:37 |
Sebastian Huber |
score: Rename _Watchdog_Per_CPU_insert_monotonic()
Rename …
5
@bf2a53d2
10/14/17 13:14:53 |
Sebastian Huber |
score: Rename watchdog variants
Rename PER_CPU_WATCHDOG_RELATIVE in …
5
@b2dbb634
10/10/17 09:36:23 |
Sebastian Huber |
score: Remove CPU_set_Control
Use Processor_mask instead.
Update #2514.
5
@db3a3de
10/10/17 08:03:48 |
Sebastian Huber |
score: Add _Thread_queue_Dispatch_disable()
5
@2256946
10/06/17 13:30:47 |
Sebastian Huber |
score: Use struct timespec for TOD
Use the timestamps only for uptime …
5
@900fda45
10/06/17 07:42:32 |
Sebastian Huber |
rtems: Fix format warnings
Update #3111.
5
@de59c065
09/27/17 13:08:33 |
Sebastian Huber |
posix: Implement self-contained POSIX mutex
POSIX mutexes are now …
5
@5222488
09/26/17 05:49:17 |
Sebastian Huber |
posix: Implement self-contained POSIX condvar
POSIX condition …
5
@89fc9345
09/21/17 13:42:45 |
Sebastian Huber |
posix: Implement self-contained POSIX rwlocks
POSIX rwlocks are now …
5
@e67929c
09/21/17 12:13:16 |
Sebastian Huber |
posix: Implement self-contained POSIX barriers
POSIX barriers are now …
5
@ecabd384
07/11/17 07:51:43 |
Sebastian Huber |
rtems: Add rtems_scheduler_ident_by_processor_set
Update #3070.
5
@548d65a5
07/11/17 05:24:39 |
Sebastian Huber |
rtems: Add rtems_scheduler_ident_by_processor()
Update #3069.
5
@3b14e7aa
07/11/17 11:51:10 |
Sebastian Huber |
rtems: Fix warning
Update #3059.
5
@1ec9c86
07/03/17 08:38:31 |
Sebastian Huber |
rtems: Fix rtems_scheduler_remove_processor()
Account for the thread …
5
@6b1d8c7
07/04/17 05:28:44 |
Sebastian Huber |
score: Add processor set to scheduler context
Replace the simple …
5
@a300ca1b
04/24/17 01:35:41 |
joel |
ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and 64 …
5
@70ddaa0e
03/28/17 06:18:06 |
Sebastian Huber |
rtems: Fix error return path
5
@e366f77
01/31/17 07:08:24 |
Sebastian Huber |
score: Add _Thread_queue_Object_name
Add the special thread queue …
5
@0794197
01/27/17 22:15:50 |
c0066c |
rtems: Fix _Rate_monotonic_Renew_deadline()
Prepare a precondition to …
5
@d7feb86
01/25/17 20:47:48 |
c0066c |
Remove rtems_rate_monotonic_postponed_job_count()
Add a variable …
5
@b8d6eb7
01/24/17 14:05:22 |
Sebastian Huber |
rtems: rtems_rate_monotonic_postponed_job_count()
Use proper locking …
5
@625bd6a
01/24/17 14:04:11 |
Sebastian Huber |
rtems: Fix _Rate_monotonic_Release_postponed_job()
5
@1240aade
01/24/17 13:37:42 |
Sebastian Huber |
Make …
5
@cb2cbec
01/13/17 18:54:11 |
Gedare Bloom |
classic: adjust names of RM postponed job functions
closes #2795
5
@3a46b72
12/21/16 16:42:39 |
c0066c |
Enhancement of the RMS manager for the overrun handling.
Three …
5
@ba776282
08/12/16 19:25:10 |
Gedare Bloom |
posix: shared memory support
Add POSIX shared memory manager (Shm). …
5
@96bb2e4b
01/12/17 06:53:12 |
Sebastian Huber |
rtems: Use header file for rtems_object_get_name()
5
@d063e7b3
01/11/17 07:42:04 |
Sebastian Huber |
score: Replace STATES_DELAYING
Replace STATES_DELAYING with …
5
@7a4b2645
01/11/17 15:43:06 |
joel |
Remove obsolete RTEMS_HAVE_SYS_CPUSET_H
5
@3a659b04
12/09/16 06:19:22 |
Sebastian Huber |
score: Introduce _Internal_error()
5
@279d5260
12/09/16 05:49:25 |
Sebastian Huber |
Add INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@7da78cf
12/02/16 10:51:16 |
Sebastian Huber |
rtems: Use _Thread_Dispatch_direct()
Update #2797.
5
@d10716f
12/02/16 10:18:32 |
Sebastian Huber |
rtems: Fix rtems_scheduler_add_processor()
Fix thread dispatch …
5
