@beba41b
04/18/16 15:10:03 |
Sebastian Huber |
posix: _POSIX_Condition_variables_Wait_support()
Simplify …
5
@8765c57
04/18/16 05:00:55 |
Sebastian Huber |
score: Remove id parameter _CORE_mutex_Seize()
Parameter was unused.
5
@90f1265e
04/18/16 04:23:27 |
Sebastian Huber |
score: Fix _CORE_semaphore_Flush()
Use proper CORE_semaphore_Status …
5
@5cc6bf4
04/17/16 13:47:33 |
Sebastian Huber |
score: Simplify _CORE_message_queue_Close()
Drop status parameter …
5
@bbd6d27a
04/15/16 14:27:56 |
Sebastian Huber |
score: Delete unused CORE_RWLock_Attributes
5
@714efce
02/29/16 16:25:42 |
joel |
conddefaultattributes.c: Add default clock to structure.
5
@04da96c7
03/09/16 21:14:43 |
joel |
posix/src/condattr*etpshared.c: Clean up and improve comments
5
@8228548
02/19/16 22:00:48 |
joel |
Add pthread_getconcurrency() and pthread_setconcurrency()
This is the …
5
@6efa349
04/14/16 06:56:53 |
Sebastian Huber |
posix: Run key destructors during thread restart
POSIX key …
5
@3c293cc
04/12/16 05:58:35 |
Sebastian Huber |
posix: Rename killinfo()
Apparently killinfo() is not defined by …
5
@9555341
04/06/16 14:26:22 |
Sebastian Huber |
posix: Use a dedicated lock for scheduler changes
Update #2555.
5
@44ed384
04/05/16 14:23:39 |
Sebastian Huber |
posix: Use proper lock for sigaction()
Update #2555.
5
@9ea69dee
04/04/16 06:18:07 |
Sebastian Huber |
score: Add node map to _RBTree_Find_inline()
5
@8b922aa
04/05/16 04:58:16 |
Sebastian Huber |
posix: Fix _POSIX_signals_Check_signal()
Do not save and restore the …
5
@3c895256
04/05/16 04:44:07 |
Sebastian Huber |
posix: Make _POSIX_signals_Check_signal() static
5
@7d21700
04/04/16 04:47:41 |
Sebastian Huber |
posix: Use proper lock for signals
5
@8f96581
04/01/16 09:38:47 |
Sebastian Huber |
score: Rework MP thread queue callout support
The thread queue …
5
@9809d6e0
03/30/16 09:39:58 |
Sebastian Huber |
score: _Thread_queue_Flush() parameter changes
Change …
5
@6ca60e5d
04/01/16 13:10:08 |
Sebastian Huber |
score: Delete MP support for RW locks
MP support was not implemented.
5
@97312fcc
04/05/16 12:36:30 |
Sebastian Huber |
score: Delete Thread_Wait_information::id
This field was only by the …
5
@97bbf02
03/22/16 07:52:50 |
Sebastian Huber |
score: Use constant for maximum count of CORE sema
5
@1e1a91ed
03/23/16 09:01:31 |
Sebastian Huber |
score: Remove Thread_queue_Queue::operations field
Remove the …
5
@2518516
03/22/16 06:24:56 |
Sebastian Huber |
posix: pthread_exit() is a no-return function
5
@5a5fb3b
03/18/16 13:03:01 |
Sebastian Huber |
score: Avoid Giant lock for CORE spinlock
Use an ISR lock to protect …
5
@c904df5
03/18/16 06:25:23 |
Sebastian Huber |
score: Add _Objects_Get_by_name()
Replace …
5
@5eaf0e7
03/17/16 06:56:31 |
Sebastian Huber |
posix: Use per-thread lookup tree for POSIX Keys
Yields higher …
5
@75aef54
03/17/16 05:16:23 |
Sebastian Huber |
posix: Avoid Giant lock in sched_yield()
Update #2555.
5
@77e6eba7
03/07/16 15:01:57 |
Sebastian Huber |
score: Add and use _Objects_Get_local()
This simplifies the handling …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@3bc12a8f
01/26/16 10:16:56 |
Sebastian Huber |
Delete unused API extensions
5
@4210114
01/26/16 10:13:45 |
Sebastian Huber |
Use linker set for POSIX User Threads init
Update #2408.
5
@2605a489
12/15/15 08:32:55 |
Sebastian Huber |
Optional POSIX Keys initialization
Update #2408.
5
@4eee8781
12/14/15 15:40:28 |
Sebastian Huber |
Optional POSIX Spinlock initialization
Update #2408.
5
@76a8328
12/14/15 15:39:10 |
Sebastian Huber |
Optional POSIX RWLock initialization
Update #2408.
5
@e4e7f14
12/14/15 15:37:34 |
Sebastian Huber |
Optional POSIX Barrier initialization
Update #2408.
5
@6c678557
12/14/15 15:36:21 |
Sebastian Huber |
Optional POSIX Timer initialization
Update #2408.
5
@2189b3e
12/14/15 15:34:50 |
Sebastian Huber |
Optional POSIX Semaphore initialization
Update #2408.
5
@3015ed64
12/14/15 15:33:39 |
Sebastian Huber |
Optional POSIX Message Queue initialization
Update #2408.
5
@9871f5dc
12/14/15 15:31:44 |
Sebastian Huber |
Optional POSIX Mutex initialization
Update #2408.
5
@f4fee477
12/14/15 15:29:19 |
Sebastian Huber |
Optional POSIX Condition Variable initialization
Update #2408.
5
@cef5675
12/14/15 10:47:47 |
Sebastian Huber |
Optional POSIX Cleanup initialization
Update #2408.
5
@ef1a985f
12/11/15 09:47:22 |
Sebastian Huber |
Optional POSIX Threads initialization
Update #2408.
5
@04436ae7
12/10/15 12:46:07 |
Sebastian Huber |
Optional POSIX Signals initialization
Update #2408.
5
@22bb1b61
01/19/16 18:11:47 |
joel |
posix/src/exec*: Remove all variants already in Newlib
The RTEMS …
5
@e39cdb8
01/18/16 20:28:00 |
joel |
posix: Remove clock_getenable_attr() and clock_setenable_attr()
These …
5
@1506658c
01/08/16 11:11:03 |
Sebastian Huber |
score: Simplify _Thread_Start()
5
@ccd5434
01/07/16 08:55:45 |
Sebastian Huber |
score: Introduce Thread_Entry_information
This avoids potential dead …
5
@44e9871
12/22/15 08:40:48 |
Sebastian Huber |
score: Avoid dead code in global construction
Update #2514.
5
@fe100e16
12/22/15 08:13:08 |
Sebastian Huber |
score: Add fatal errors for NULL entry init tasks
This simplifies the …
5
@173d1f8
12/14/15 12:10:24 |
Sebastian Huber |
posix: Store unblocked signals
Store the unblock signals to exploit …
5
@54c3fbd
12/11/15 10:09:13 |
Sebastian Huber |
score: Initialize thread control to zero
This reduces the code size …
5
@df55d07f
12/10/15 13:10:48 |
Sebastian Huber |
score: Untangle thread actions
Remove the thread action handler …
5
@f6a1ef9
11/24/15 14:58:26 |
Sebastian Huber |
posix: Require struct _pthread_cleanup_context
This structure is …
5
@f97536d
10/16/15 06:21:48 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_UNUSED
5
@3b3d1489
09/01/15 12:16:48 |
Sebastian Huber |
posix: glibc compatibility
5
@1f242285
08/21/15 03:25:37 |
Sebastian Huber |
posix: Avoid _RBTree_Next()
5
@21789a21
07/28/15 12:45:42 |
Sebastian Huber |
score: Rename _POSIX_Absolute_timeout_to_ticks()
Rename …
5
@d7665823
06/24/15 13:43:19 |
Sebastian Huber |
score: Introduce Thread_queue_Heads
Move the storage for the thread …
5
@e2735012
06/24/15 09:05:39 |
Sebastian Huber |
score: Introduce Thread_queue_Queue
Separate the thread queue heads …
5
@fdb45d6
06/24/15 12:00:08 |
Sebastian Huber |
score: Freechain handler API changes
Replace the extend function with …
4.115
@48fed9a
06/25/15 12:11:53 |
Sebastian Huber |
score: Simplify <rtems/system.h>
Drop the <rtems/score/percpu.h> …
4.115
@80fca28
06/13/15 13:29:04 |
Sebastian Huber |
score: Add _Watchdog_Preinitialize()
Add an assert to ensure that the …
4.115
@258d580c
06/13/15 12:49:23 |
Sebastian Huber |
score: Delete unused state WATCHDOG_REMOVE_IT
4.115
@335e5ca
06/02/15 19:43:54 |
Sebastian Huber |
score: Add Thread_Control::is_fp
Store the floating-point unit …
4.115
@f9a2d36
06/02/15 11:57:35 |
Sebastian Huber |
posix: Fix _POSIX_Timer_Insert_helper() locking
Close #2358.
4.115
@8f6a3145
05/29/15 13:03:02 |
Sebastian Huber |
posix: Fix clock_gettime()
The …
4.115
@7cd2484
05/12/15 12:32:47 |
alexander.krutwig |
timecounter: Use in RTEMS
Replace timestamp implementation with …
4.115
@aa05cfbb
05/11/15 12:56:49 |
Sebastian Huber |
score: Replace _Thread_Delay_ended()
Use _Thread_Timeout() instead. …
4.115
@900d337f
05/05/15 11:05:54 |
Sebastian Huber |
score: Rework _Thread_Change_priority()
Move the writes to …
4.115
@4438ac25
05/02/15 12:27:24 |
Sebastian Huber |
score: Fine grained locking for mutexes
Update #2273.
4.115
@cfa5aab
05/02/15 12:02:20 |
Sebastian Huber |
score: Delete _CORE_semaphore_Seize()
Rename …
4.115
@e76c517
05/01/15 18:52:51 |
Sebastian Huber |
score: Fine grained locking for semaphores
Update #2273.
4.115
@cc18d7b
04/30/15 11:12:54 |
Sebastian Huber |
score: Fine grained locking for message queues
Aggregate several …
4.115
@f5d6c8b
04/27/15 14:25:52 |
Sebastian Huber |
score: Delete Thread_queue_Control::timeout_status
Use a parameter …
4.115
@383cf42
04/22/15 09:15:46 |
Sebastian Huber |
score: More thread queue operations
Move thread queue discipline …
4.115
@02c4c441
04/23/15 08:01:22 |
Sebastian Huber |
score: Add Thread_queue_Control::Lock
Move the complete thread queue …
4.115
@2903090
04/15/15 09:26:46 |
Sebastian Huber |
score: Add header to _Watchdog_Remove()
Add watchdog header parameter …
4.115
@56729d8
04/23/15 19:29:56 |
Sebastian Huber |
score: Delete STATES_WAITING_ON_THREAD_QUEUE
Avoid the usage of the …
4.115
@d83127e
04/24/15 06:36:33 |
Sebastian Huber |
posix: Use right thread dispatch disable function
4.115
@f329353
04/23/15 13:25:13 |
Sebastian Huber |
score: Fix POSIX thread join
A thread join is twofold. There is one …
4.115
@9f10911
04/22/15 19:29:21 |
Sebastian Huber |
score: Delete Thread_queue_Control::state
Use a parameter for …
4.115
@49d4364
04/22/15 09:35:14 |
Sebastian Huber |
score: Delete bogus THREAD_QUEUE_WAIT_FOREVER
It makes no sense to …
4.115
@3bf4a9fa
04/20/15 06:52:52 |
Sebastian Huber |
score: _Objects_Get_isr_disable()
Do not disable thread dispatching …
4.115
@4db0ae8e
04/20/15 06:45:41 |
Sebastian Huber |
Use ISR_lock_Context instead of …
4.115
@1047f37
04/14/15 17:11:51 |
Joel Sherrill |
semdestroy.c: Add missing _Objects_Allocator_unlock()
closes 2319.
4.115
@5049dca
03/13/15 12:54:16 |
daniel.krueger |
semunlink.c: Add missing _Objects_Allocator_unlock()
updates 2319.
4.115
@1dc6662
04/13/15 11:57:57 |
Sebastian Huber |
score: Rename _Watchdog_Reset()
Update #2307.
4.115
@d937d36
03/11/15 20:53:44 |
Joel Sherrill |
posix/src/nanosleep.c: Address issue when delay is longer than desired …
4.115
@b0f8bb4e
03/12/15 08:04:21 |
cederman |
posix: Return error code if mmap is used
4.115
@d88b0b78
03/12/15 08:04:20 |
cederman |
posix: Move function to file with matching name
mmap was previously …
4.115
@77e682ec
03/09/15 12:18:33 |
Sebastian Huber |
posix: Change sem_t to the 32-bit object type
This change is also …
4.115
@f0ff18e
03/09/15 12:18:32 |
Sebastian Huber |
score: Add rtems_set_errno_and_return_value()
Remove …
4.115
@40ecd11
03/09/15 14:23:20 |
Sebastian Huber |
sysconf: Add _SC_NPROCESSORS_(CONF|ONLN)
4.115
@8552df6
03/09/15 14:23:12 |
Sebastian Huber |
sysconf: Simplify
4.115
@6157743
02/23/15 15:54:54 |
Sebastian Huber |
score: Simplify and fix signal delivery
Deliver the POSIX signals …
4.115
@c0e01a28
02/24/15 15:27:08 |
Gedare Bloom |
posix: fix error return code for pthread_mutex_trylock
4.115
@172e953
12/12/14 12:16:11 |
Sebastian Huber |
posix: Delete key/value if value is set to NULL
4.115
@dac340dd
12/12/14 10:19:10 |
Sebastian Huber |
posix: Simplify _POSIX_Keys_Find()
4.115
@e106aa73
11/19/14 20:44:54 |
josh.oguin |
cpukit/posix/src/timertsr.c: Add _Assert()
CodeSonar? flagged this as …
4.115
@287843f
11/06/14 22:16:56 |
Joel Sherrill |
sys/mman.h: New file. Clean up and add supporting stubs
4.115
