@d404771
12/22/21 07:16:43 |
Sebastian Huber |
rtems: Fix Clock Manager parameter descriptions
Update #4572.
@75b3f48a
11/18/21 02:53:56 |
fnu.vikram |
libfdt: overlay: make overlay_get_target() public
This is done to get …
@c07e238
06/18/21 17:20:27 |
andre.przywara |
fdtget: Fix signedness comparisons warnings
With -Wsign-compare, …
@a582ab3
12/29/20 04:17:49 |
jujugoboom |
Set last_comp_version correctly in new dtb and fix potential version …
@03b601af
12/11/20 02:27:36 |
trini |
libfdt: Internally perform potentially unaligned loads
Commits …
@064a1d7
11/04/20 13:06:05 |
trini |
libfdt: Check for 8-byte address alignment in fdt_ro_probe_()
The …
@611a2a5a
10/12/20 16:53:31 |
andre.przywara |
libfdt: Fix kernel-doc comments
The API documentation in libfdt.h …
@f5379faf
06/16/20 01:12:17 |
patrick.oppenlander |
libfdt: add extern "C" for C++
Signed-off-by: Patrick Oppenlander …
@868e6d8
12/10/21 07:48:27 |
Sebastian Huber |
rtems: Improve ordering in <rtems/rtems/intr.h>
Move the data …
@fb17dfb1
10/14/20 08:47:44 |
Sebastian Huber |
Avoid ISR_LOCK_MEMBER() since it confuses Doxygen
If RTEMS_SMP is not …
@39e6f532
12/07/21 15:31:45 |
Sebastian Huber |
score: Fix _Workspace_Initialize_for_one_area()
In …
@69d643f7
12/05/21 15:37:33 |
Sebastian Huber |
score: Fix atomic stores for C++
Close #4566.
@9089bcc
12/02/21 14:06:48 |
Sebastian Huber |
rtems: Move all Interrupt Manager stuff to intr.h
Since the previous …
@0d83bed2
12/02/21 13:00:53 |
Sebastian Huber |
rtems: Move scheduler directives to own header
Move all …
@d7205f0
04/08/20 15:14:41 |
Sebastian Huber |
libc: Optimize malloc() initialization
The BSPs provide memory for …
@3d0620b
04/08/20 14:54:34 |
Sebastian Huber |
score: Optimize Workspace Handler initialization
The BSPs provide …
@675e879
11/23/21 14:15:27 |
Sebastian Huber |
rtems: Replace "precision" with "resolution"
Resolution is the right …
@5468464
11/11/21 07:44:29 |
Sebastian Huber |
score: Properly continue the thread during restart
The …
@2e56aab
11/11/21 08:00:03 |
Sebastian Huber |
score: Move _Thread_queue_Extract()
Move _Thread_queue_Extract() …
@e429e97
11/11/21 09:34:31 |
Sebastian Huber |
score: Simplify thread wait state handling
Remove the …
@50aef135
11/11/21 07:35:22 |
Sebastian Huber |
score: Add _Thread_MP_Extract_proxy()
Remove …
@c69a70a
11/08/21 10:08:24 |
Sebastian Huber |
rtems: Fix rtems_scheduler_remove_processor()
Return an error status …
@6443c9d
11/10/21 07:54:03 |
Sebastian Huber |
score: Fix assertion in SMP scheduler framework
Properly assert that …
@fc64e837
10/29/21 07:30:13 |
Sebastian Huber |
score: Rework ask for help requests
Process ask for help requests on …
@4d90289e
10/29/21 12:17:54 |
Sebastian Huber |
score: _Scheduler_SMP_Schedule_highest_ready()
Simplify callers of …
@d0434b88
10/29/21 12:45:28 |
Sebastian Huber |
score: Remove victim thread from CPU allocation
Update #4531.
@c6362f6
10/29/21 11:44:04 |
Sebastian Huber |
score: Move _Scheduler_Unblock_node()
Move _Scheduler_Unblock_node() …
@dcd8b93
10/29/21 11:38:43 |
Sebastian Huber |
score: Move _Scheduler_Block_node()
Move _Scheduler_Block_node() into …
@f767ef80
10/29/21 06:29:51 |
Sebastian Huber |
score: Simplify _Scheduler_SMP_Yield()
There is not need to actively …
@6d20f0c5
10/27/21 06:35:22 |
Sebastian Huber |
score: Add node to insert to Chain_Node_order
This allows to use …
@ff20bc9
10/20/21 12:21:20 |
Sebastian Huber |
score: Rework idle handling in SMP schedulers
This patch fixes an …
@3d6ebde1
10/15/21 09:21:31 |
Sebastian Huber |
score: Add SMP scheduler make/clean sticky
This patch fixes the …
@3781709
10/20/21 06:24:24 |
Sebastian Huber |
score: Add SMP scheduler idle exchange callback
Update #4531.
@9d3e8212
10/19/21 12:28:48 |
Sebastian Huber |
score: Rework affine ready queue handling
Rework the handling of the …
@a53229bb
10/19/21 11:06:09 |
Sebastian Huber |
score: Use extract from scheduled callbacks
Use the extract from …
@757a1096
10/21/21 09:07:21 |
Sebastian Huber |
score: Remove return value from enqueue scheduled
The return value …
@6286a40
10/19/21 10:43:47 |
Sebastian Huber |
score: Scheduler insert after move
Insert nodes after moving the …
@81659420
10/20/21 06:23:07 |
Sebastian Huber |
score: Add missing idle thread exchanges
Update #4531.
@e787091
10/20/21 06:20:58 |
Sebastian Huber |
score: Add missing idle thread releases
Update #4531.
@bd55f69
10/19/21 09:25:25 |
Sebastian Huber |
score: Simplify _Scheduler_Exchange_idle_thread()
Remove superfluous …
@f0f60a1e
10/19/21 09:21:49 |
Sebastian Huber |
score: Change _Scheduler_Try_to_schedule_node()
Add the victim node …
@7ae4f569
10/18/21 07:07:07 |
Sebastian Huber |
score: Not set CPU in _Scheduler_Use_idle_thread()
Do not set the CPU …
@45e942d
10/18/21 07:05:30 |
Sebastian Huber |
score: Rename _Scheduler_Set_idle_thread()
Rename …
@577262a7
10/22/21 05:31:46 |
Sebastian Huber |
score: Add red-black tree append/prepend
These functions are a faster …
@3c076041
10/29/21 11:57:27 |
Sebastian Huber |
score: Simplify _Scheduler_Generic_block()
If we block the executing …
@50cf1932
11/16/21 16:26:00 |
kinsey.moore |
cpukit: Enable debug for SMP AArch64
Ensure when both RTEMS_DEBUG is …
@9b6362da
11/18/21 11:13:53 |
Sebastian Huber |
rtems: Use RTEMS_WHO_AM_I for rtems_task_ident()
@99fdfcd
11/17/21 19:05:52 |
Sebastian Huber |
rtems: Add signal header to implementation group
@c47daf6f
11/16/21 16:00:29 |
Sebastian Huber |
config: Fix IO driver table initialization
Check all IO driver table …
@32cee883
11/15/21 18:15:27 |
Sebastian Huber |
config: CONFIGURE_DISABLE_BSP_SETTINGS
Evaluate …
@ccbcfb6
10/11/21 15:07:50 |
Sebastian Huber |
rtems: Add new clock manager directives
Update #4527.
@ee57a7f1
03/23/21 14:34:26 |
Sebastian Huber |
score: Fix _CORE_ceiling_mutex_Set_priority()
We have to use a second …
@16b50ac6
04/16/21 07:21:57 |
Sebastian Huber |
score: Always check if a prio ceiling is defined
Priority ceiling …
@7a591d0c
05/12/21 08:53:48 |
Sebastian Huber |
score: Fix thread pinning assertions
@ffb8833d
10/28/21 09:14:57 |
Sebastian Huber |
score: Add _Timecounter_Set_NTP_update_second()
Allow the …
@240a1f7
10/27/21 10:59:09 |
Sebastian Huber |
score: Introduce CPU budget operations
This patch set replaces the …
@4812a8b5
04/06/21 14:02:20 |
kinsey.moore |
cpukit: Add signal mapping support
This adds a confdef option …
@24922d0
10/25/21 06:15:37 |
Sebastian Huber |
rtems: rtems_rate_monotonic_get_status()
Mention that resetting the …
@f1723d12
10/19/21 14:29:48 |
Sebastian Huber |
rtems: Regenerate for IDLE task allocator option
Update #4524.
@28632b5
10/20/21 17:14:53 |
Sebastian Huber |
score: Fix typo
@0221da5f
10/12/21 06:26:39 |
Sebastian Huber |
rtems: Fix rate monotonic statistics
The rate monotonic period …
@a4112bd
10/09/21 14:12:07 |
Sebastian Huber |
score: Simplify _Watchdog_Next_first()
@822ebb4c
10/07/21 22:28:26 |
joel |
Add support for IDLE Thread stack allocator
Add a stack allocator …
@3bb97a30
10/06/21 08:37:53 |
Sebastian Huber |
score: Always check queue in _Thread_Wait_cancel()
Commit …
@226d0e92
10/05/21 18:23:08 |
Sebastian Huber |
score: Optimize EDF SMP scheduler ops
The schedule operation is only …
@344bb536
10/01/21 17:32:28 |
Sebastian Huber |
rtems: Generate <rtems/cpuuse.h>
Write the documentation from scratch.
@e9063644
09/30/21 06:51:30 |
Sebastian Huber |
posix: Remove "RTEMS" from POSIX API group
Clarify group description. …
@8b762a88
09/30/21 06:37:01 |
Sebastian Huber |
scoe: Move workspace group definition
Define the group in the header …
@5a6f94d
09/30/21 06:33:25 |
Sebastian Huber |
rtems: Add ASR implementation to existing group
Update #3706.
@a950c135
09/30/21 06:30:58 |
Sebastian Huber |
score: Add Hash Handler to group
Update #3706.
@4c0b006
09/30/21 06:19:01 |
Sebastian Huber |
rtems: Canonicalize Doxygen in <rtems/counter.h>
Update #3706.
@dba2e690
09/30/21 06:15:11 |
Sebastian Huber |
rtems: Canonicalize Doxygen in <rtems/seterr.h>
Update #3706.
@61ef22b
09/24/21 18:15:52 |
Sebastian Huber |
score: Add Thread_queue_Deadlock_status
Replace the boolen return …
@25f126e
07/21/21 17:17:29 |
Sebastian Huber |
score: Regenerate <rtems/score/basedefs.h>
Reflect renamed …
@cd198a5
09/17/21 06:30:57 |
Sebastian Huber |
score: Remove unused default scheduler ops
If SMP support is enabled …
@3291b2a
09/17/21 06:49:56 |
Sebastian Huber |
score: Ensure only one CPU if required
Issue the new fatal SMP error …
@0036ddf
09/17/21 06:12:35 |
Sebastian Huber |
score: Provide two thread pin/unpin defaults
The uniprocessor …
@59537c9
09/17/21 06:54:58 |
Sebastian Huber |
score: SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY
Rename …
@92b9f65
09/17/21 05:57:09 |
Sebastian Huber |
score: SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP
Rename …
@dbb7c956
09/15/21 09:44:40 |
Sebastian Huber |
rtems: Fix message manager documentation
Correct the description of …
@1567d927
09/15/21 11:56:16 |
Sebastian Huber |
rtems: Add header files to Doxygen groups
@79efc81a
09/15/21 11:38:12 |
Sebastian Huber |
rtems: Move Doxygen group definition
Move the definition of the …
@a45bc321
10/13/20 13:57:36 |
Sebastian Huber |
rtems: Improve Classic API group description
@fe818cd
09/15/21 05:36:45 |
Sebastian Huber |
Remove bogus return status …
@466cd917
06/22/20 09:29:45 |
Sebastian Huber |
rtems: Generate <rtems/extension.h>
Remove the duplicated description …
@606c9a6
06/22/20 06:50:02 |
Sebastian Huber |
rtems: Generate <rtems/rtems/cache.h>
Change license to BSD-2-Clause …
@c0435b5e
09/03/21 14:55:18 |
Sebastian Huber |
rtems: Document time of day constraints
Update #4338.
@ad41c179
09/03/21 09:09:02 |
Sebastian Huber |
score: Change TOD_LATEST_YEAR to 2099
This simplifies the …
@6d2becb
09/03/21 13:04:49 |
Sebastian Huber |
score: Limit the CLOCK_REALTIME setting
Limit the CLOCK_REALTIME …
@54b4b1f8
09/03/21 07:46:36 |
Sebastian Huber |
score: Add _TOD_Is_valid_new_time_of_day()
Move the TOD validation to …
@c8e4de9
09/03/21 07:36:55 |
Sebastian Huber |
score: Remove TOD_TICKS_PER_SECOND_method()
Use …
@8abd1756
09/03/21 07:33:01 |
Sebastian Huber |
score: Return status in _TOD_Adjust()
@2647e76
09/02/21 05:48:55 |
Sebastian Huber |
score: Document thread queue operations
@34099baa
07/28/21 14:29:54 |
Sebastian Huber |
libtest: Return fixture context in T_case_begin()
This makes it …
@25b0fdd
08/30/21 16:12:13 |
Sebastian Huber |
score: Update priority only if necessary
In …
@ac9f115b
08/31/21 11:00:55 |
Sebastian Huber |
score: Remove _Thread_queue_Unblock_critical()
This function was only …
@317774c
08/31/21 10:42:29 |
Sebastian Huber |
score: Remove _Thread_queue_First_locked()
The …
@d9249c9
08/31/21 09:03:57 |
Sebastian Huber |
score: Fix blocking message queue receive
In order to ensure FIFO …
@9c0591f1
03/25/21 08:11:26 |
Sebastian Huber |
score: Fix priority discipline handling
The priority queues in …
@1dff0a38
08/13/21 06:49:54 |
Sebastian Huber |
score: Delete unused rtems_ada_self
