@d91d50f
07/02/13 13:14:51 |
Sebastian Huber |
bsp/mpc55xx: Avoid integer overflow
4.115
@c97d3dd
07/02/13 13:13:54 |
Sebastian Huber |
bsp/mpc55xx: Round PLL divider up
4.115
@cd7db89
06/24/13 15:14:08 |
ralf.kirchner |
bsp/psim: Use EABI and System V small-data area
4.115
@3da02169
06/24/13 15:16:16 |
ralf.kirchner |
bsps/powerpc: Avoid placement in small-data area
4.115
@1b47871d
06/24/13 15:15:42 |
ralf.kirchner |
bsp/psim: Fix declaration
It declares a symbol defined in the linker …
4.115
@3b645c1
06/28/13 19:26:59 |
Sebastian Huber |
bsps/arm: Add PL050 support
4.115
@c8312b3
06/23/13 12:39:47 |
Sebastian Huber |
bsps/arm: Add PL111 support
4.115
@e310dcd
06/28/13 19:26:11 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@311ba73
06/23/13 15:50:55 |
Sebastian Huber |
framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME
4.115
@98db96e
06/29/13 12:00:39 |
Sebastian Huber |
make: Use C flags for C++ as default
In case a BSP selects special …
4.115
@40ce265
06/28/13 13:05:30 |
Sebastian Huber |
bsp/psim: Use plain symbol for PSIM
This avoids a linker assertion …
4.115
@4800ffe
06/28/13 07:07:13 |
Sebastian Huber |
bsps/powerpc: Update debug sections
4.115
@ca59217
06/28/13 07:03:11 |
Sebastian Huber |
bsps/arm: Set vector base on all processors
4.115
@a3a4cd5
06/26/13 07:40:44 |
Sebastian Huber |
bsps/arm: Move input sections
Move input sections to preserve order …
4.115
@56435e6
06/26/13 08:25:42 |
Sebastian Huber |
powerpc: Fix Altivec support
Use the right context.
4.115
@4b83e8f1
06/21/13 07:59:27 |
Sebastian Huber |
bsps/arm: Fix set exception handler for ARMv7
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@1df348b
06/24/13 09:00:36 |
Sebastian Huber |
bsps/arm: Rename function
Rename …
4.115
@e916b125
06/21/13 15:17:28 |
Sebastian Huber |
bsp/virtex: Use shared clock driver
4.115
@0110491
06/20/13 14:22:16 |
Sebastian Huber |
bsp/virtex: Add console devices only if present
4.115
@dbf62b3
06/20/13 14:20:43 |
Sebastian Huber |
bsp/virtex: Fix warnings
4.115
@c4cfc62
06/20/13 12:33:19 |
Sebastian Huber |
bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR
This define is also present …
4.115
@dfb5805
06/20/13 12:32:12 |
Sebastian Huber |
bsp/virtex: Remove unused configure macros
4.115
@53dc697
06/18/13 14:42:25 |
Sebastian Huber |
bsp/virtex: Delete BSP_ask_for_reset and BSP_panic
4.115
@39c1534f
06/18/13 15:20:28 |
Sebastian Huber |
bsp/virtex: Use generic interrupt support
4.115
@894e93f
06/18/13 14:44:40 |
Sebastian Huber |
bsp/virtex: Fix header includes
4.115
@bee7612e
06/18/13 14:39:24 |
Sebastian Huber |
bsp/virtex: Move timer config to new file
4.115
@48ab8465
06/18/13 14:27:42 |
Sebastian Huber |
bsp/virtex: Do not use PPC403 TTY driver
4.115
@ad094f4
06/18/13 14:26:25 |
Sebastian Huber |
4.115
@b45397fb
06/18/13 14:25:53 |
Sebastian Huber |
bsp/virtex: Delete bsp_XAssertHandler()
4.115
@ff538bbf
06/18/13 14:24:10 |
Sebastian Huber |
bsp/virtex: Delete unused variables
4.115
@0ba2736
06/18/13 14:12:56 |
Sebastian Huber |
bsp/virtex: Replace low-level BSP start code
Use linkcmds.base. Use …
4.115
@546c1056
06/18/13 13:19:19 |
Sebastian Huber |
bsp/virtex: Rename file dlentry.S in start.S
Use default bsp_specs file.
4.115
@509e0f3f
06/21/13 15:16:37 |
Sebastian Huber |
bsps/powerpc: Add PPC405 support for shared clock
4.115
@7d0e88f2
06/21/13 14:19:46 |
Sebastian Huber |
bsps/powerpc: Delete clock_4xx.c
4.115
@27b207a8
06/21/13 13:10:48 |
Sebastian Huber |
bsps: Delete bspreset_fatal.c
Use bspreset_loop.c instead. This …
4.115
@f97f46ce
06/20/13 09:03:45 |
Sebastian Huber |
libchip/serial: Fix warning
4.115
@c9db7f9
06/18/13 15:47:41 |
Sebastian Huber |
bsps: Use CONSOLE_DEVICE_NAME
4.115
@a4bc725e
06/18/13 15:45:50 |
Sebastian Huber |
bsps: Remove debug output in shared console driver
4.115
@37220fac
06/20/13 10:00:29 |
Sebastian Huber |
bsps: Do not use printk() in shared console driver
4.115
@6307b1a
06/20/13 09:57:34 |
Sebastian Huber |
bsps: Add fatal errors for shared console driver
4.115
@ade27c6
06/20/13 09:44:04 |
Sebastian Huber |
bsps: Move bsp_generic_fatal_code to new file
Add bsp_generic_fatal().
4.115
@5f91272
06/20/13 09:17:23 |
Sebastian Huber |
bsps/powerpc: Delete bsp_exceptions_in_RAM
Delete …
4.115
@cddb8f4
06/20/13 07:48:27 |
Ric Claus |
bsps/arm: Fix some GIC functions
4.115
@9a037da9
06/19/13 09:20:06 |
Sebastian Huber |
bsps/arm: Set vector base address if necessary
4.115
@45fecbb6
06/16/13 13:40:03 |
Jiri Gaisler |
greth: do not advertise 1000M capability if MAC does not support it.
4.115
@1bdc6d1
06/16/13 13:28:20 |
Jiri Gaisler |
greth: prefer full duplex if available
4.115
@cb6b9ba
06/19/13 10:57:54 |
Sebastian Huber |
bsp/xilinx-zynq: Use magic UART baud divisor
Use a baud divisor …
4.115
@3f6a823
06/19/13 10:57:26 |
Sebastian Huber |
bsp/xilinx-zynq: Do not start transmitter break
4.115
@49bc9f81
06/18/13 07:18:21 |
Sebastian Huber |
bsp/xilinx-zynq: Use second UART for console
This is in now line with …
4.115
@cf46db85
06/17/13 07:57:42 |
Sebastian Huber |
bsps: Provide simple console selection
4.115
@9f868a16
06/17/13 07:57:08 |
Sebastian Huber |
bsps: Add missing include
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@49cdf40
06/12/13 07:25:39 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_is_enabled()
Delete …
4.115
@15f3a91
06/10/13 12:11:07 |
Sebastian Huber |
libchip: Use Termios API change for NS16550
This avoids a race …
4.115
@6896ca2
06/10/13 12:07:13 |
Sebastian Huber |
libchip: Delete superfluous assignments
4.115
@aec0e195
06/10/13 08:10:43 |
Sebastian Huber |
configure: Documentation
4.115
@18e2fbe7
06/07/13 09:50:37 |
Sebastian Huber |
smp: Fix PowerPC context switch
4.115
@8bed603
06/03/13 08:03:44 |
Sebastian Huber |
bsp/lm3s69xx: Typos
4.115
@94c17af
06/03/13 08:03:10 |
Sebastian Huber |
bsp/qoriq: Add missing #ifdef RTEMS_SMP
4.115
@db42c079
05/31/13 11:59:47 |
Sebastian Huber |
bsps/arm: Add SMP support
4.115
@f2f211c5
05/31/13 11:59:34 |
Sebastian Huber |
smp: Add ARM support
4.115
@bd39add
05/31/13 08:08:43 |
Sebastian Huber |
bsp/qoriq: Add SMP support
4.115
@ffbeb6f
01/18/13 08:42:49 |
Sebastian Huber |
smp: Add PowerPC support
4.115
@e3be6915
05/27/13 15:31:46 |
Sebastian Huber |
score: Remove idle field of Per_CPU_Control
This field is unused …
4.115
@17e09f8e
05/27/13 15:29:47 |
Sebastian Huber |
bsps: Use _Objects_Information_table
Eliminate copy and paste. Use …
4.115
@5b391f85
05/31/13 08:00:07 |
Sebastian Huber |
bsps/arm: Use Write-Allocate cache for ARMv7
4.115
@1dcf5fe
05/31/13 07:59:27 |
Sebastian Huber |
bsps/arm: Merge ARMv7 MMU section definitions
4.115
@2f6108f9
05/28/13 08:58:19 |
Sebastian Huber |
smp: Simplify SMP initialization sequence
Delete bsp_smp_wait_for(). …
4.115
@8cacceb
05/14/13 11:23:10 |
Sebastian Huber |
smp: Delete bsp_smp_secondary_cpu_initialize()
Do not call …
4.115
@baf8f4d
05/14/13 08:12:52 |
Sebastian Huber |
smp: Simplify main CPU initialization
Call _SMP_Handler_initialize() …
4.115
@9344677
05/21/13 13:58:12 |
Sebastian Huber |
bsp/qoriq: Avoid NULL pointer access
4.115
@9984acd
05/13/13 07:42:51 |
Sebastian Huber |
bsps/arm: Add CLOCK_DRIVER_USE_FAST_IDLE option
4.115
@0d671d70
05/27/13 10:43:53 |
Sebastian Huber |
bsps/arm: Move .fast_text section
Move the .fast_text section after …
4.115
@cab410f
05/21/13 12:19:24 |
Sebastian Huber |
bsps: Update due to linker changes
In case the VMA and LMA regions …
4.115
@6c2eedc
05/13/13 11:37:06 |
Sebastian Huber |
smp: Add maximum_processors field to config
Delete …
4.115
@5e45d36
05/15/13 15:46:37 |
dchabot |
Add c++ guard to header.
4.115
@cfd8d7a
05/08/13 07:30:31 |
Sebastian Huber |
arm: Support VFP-D32 and Neon
4.115
@a94d46c8
05/06/13 12:34:55 |
Sebastian Huber |
bsp/xilinx-zynq: New BSP
4.115
@12d182c4
05/06/13 12:01:10 |
Sebastian Huber |
bsps/arm: Fix register usage
4.115
@e37d57bc
05/06/13 08:59:07 |
Sebastian Huber |
bsps/arm: Add shared GIC tmtests/tm27 support
4.115
@33c98fd
05/06/13 08:20:26 |
Sebastian Huber |
bsps/arm: Remove superfluous parameter
4.115
@f2e9d0d
05/06/13 07:59:16 |
Sebastian Huber |
bsp/raspberrypi: Use shared start code
4.115
@86b79fb
05/06/13 07:54:02 |
Sebastian Huber |
bsp/lm3s69xx: Fix initialization value
4.115
@9bc1913e
05/05/13 22:02:07 |
eugen |
bsp/lm3s69xx: Use interrupts for UART receive
This makes continuous …
4.115
@847e2cac
05/05/13 22:02:06 |
eugen |
bsp/lm3s69xx: More access macros for UART data register
Add mask for …
4.115
@9159711
05/06/13 07:37:12 |
alan.cudmore |
bsp/raspberrypi: Enable unaligned access
4.115
@a91dc98b
04/26/13 13:06:32 |
Sebastian Huber |
bsp/realview-pbx-a9: New BSP
4.115
@9ce65803
05/02/13 11:37:30 |
Sebastian Huber |
bsps/arm: Copy vector table only if necessary
4.115
@27690ec3
05/02/13 11:36:03 |
Sebastian Huber |
bsps/arm: Move .vector section
The .vector section contains …
4.115
@ecf7dd9
05/02/13 09:41:22 |
Sebastian Huber |
bsps/arm: Move CP15 start initialization
4.115
@fd51f7e
05/02/13 09:09:24 |
Sebastian Huber |
bsps/arm: Support ARMv7 VMSA sections and control
4.115
@88cf23f8
04/30/13 13:23:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_exception_handler()
4.115
@037e8ae5
05/02/13 15:42:20 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_trans*_table_entries()
4.115
@544615d
05/02/13 15:41:11 |
Sebastian Huber |
bsps/arm: Add arm_cp15_mmu_disable()
4.115
@d2d02961
05/02/13 15:40:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_get_min_cache_line_size()
4.115
@962e0fac
05/02/13 09:18:09 |
Sebastian Huber |
bsps/arm: Add and use bsp_translation_table_base
4.115
@fb0584f
05/03/13 08:39:26 |
Sebastian Huber |
bsps/arm: Move implementation to inline functions
4.115
@5aa4ed9
04/30/13 17:31:29 |
Joel Sherrill |
i386: PR2010: Remove pc386 BSPs using soft-float
i386 soft-float is …
4.115
@024a572
04/29/13 07:28:58 |
Sebastian Huber |
bsp/mpc55xx: Avoid empty enum
4.115
