@7b8a920
01/26/17 09:52:31 |
maberg |
leon, grcan: use RTEMS 4.12 SMP interrupt lock
5
@bc40b4d
01/24/17 10:16:41 |
maberg |
leon, grcan: consistent indentation
This commit does not contain any …
5
@ad203e58
01/24/17 09:00:07 |
maberg |
leon, grcan: function based user interface
This commit preserves all …
5
@229c4249
04/27/17 11:14:53 |
maberg |
bsp/leon3: Cleaner namespace for LEON3 debug UART
Prefix BSP specific …
5
@011efee8
04/25/17 07:10:03 |
Daniel Hellstrom |
leon, irq: single CPU SMP configuration does not need IPI ISR
5
@fa27fe5c
04/25/17 13:26:18 |
Daniel Hellstrom |
leon, greth: new option and change soft-reset logic for EDCL
5
@8ac070a
04/24/17 14:36:16 |
Daniel Hellstrom |
leon, greth: 10/100 modes should be assigned in fastest priority
5
@e6fbd26
04/24/17 14:32:17 |
Daniel Hellstrom |
leon, greth: speed modes advertising now configurable
5
@12718134
04/24/17 13:10:41 |
Daniel Hellstrom |
leon, greth: EDCL and DD is disabled during reset
The EDCL and …
5
@a9859d1
05/07/17 20:52:50 |
phamp |
interrupt vector indexing is assuming BSP_INTERRUPT_VECTOR_MIN = 0
5
@f219adc
05/07/17 21:13:24 |
phamp |
missing a couple register names + a #ifndef_ASM around serial.h …
5
@0e494170
05/11/17 07:53:05 |
Sebastian Huber |
bsps/arm: Fix bit field offset in GIC support
Update #3002.
5
@430949aa
04/13/17 19:23:28 |
Daniel Hellstrom |
leon, greth: let Gbit full duplex override half
5
@998e34ad
04/13/17 12:57:01 |
Daniel Hellstrom |
leon, greth: SMP support by using spin-lock protection
5
@8927c0f
04/11/17 11:55:02 |
maberg |
leon, gptimer: offset intnum with subtimer index
If separate …
5
@256e083f
04/10/17 17:07:04 |
maberg |
leon, gptimer: fixed probing separate interrupts
Probing of separate …
5
@6234abe
03/08/17 11:59:07 |
javier.jalle |
leon, l4stat: Initial driver commit
5
@21b3319f
03/07/17 11:50:48 |
javier.jalle |
leon, ambapp: Added L4STAT driver to ambapp ids
5
@a8595605
03/06/17 12:08:04 |
maberg |
leon, occan: Converted disable/enable to SMP locks
This commit …
5
@c609ccea
01/19/17 17:57:58 |
maberg |
leon, ahbstat: Use RTEMS 4.12 SMP interrupt lock
5
@c241236
03/15/17 13:38:21 |
javier.jalle |
leon, memscrub: add GR740 memory scrubber driver
5
@d79429f
03/15/17 14:04:33 |
javier.jalle |
leon, griommu: add GR740 IOMMU driver
The driver is limited to the …
5
@3e948cc
02/15/17 15:51:33 |
javier.jalle |
leon, ambapp: Added GRIOMMU driver to ambapp ids
5
@dfa86338
02/21/17 08:14:46 |
javier.jalle |
leon, l2cache: add GR740 L2-Cache driver
5
@d24ed54
03/15/17 13:58:04 |
javier.jalle |
leon, ambapp: Added L2CACHE driver to ambapp ids
5
@93c5e63
02/09/17 13:09:17 |
javier.jalle |
leon, grpci2dma: add GR740 PCI DMA driver
5
@31ba1f21
02/15/17 10:14:13 |
javier.jalle |
leon, grpci2: prepare for GRPCI2DMA driver
5
@8e45d55
02/15/17 10:09:23 |
javier.jalle |
leon, grpci2: Make driver SMP safe
5
@9631e5a9
03/17/17 13:44:25 |
Daniel Hellstrom |
leon, ambapp: updated AMBA PnP IDs and names database
5
@e5e44bdb
03/14/17 16:46:12 |
maberg |
leon, apbuart: Wait for shift register on close
Do not disable …
5
@6860ddb
03/14/17 16:27:57 |
maberg |
leon, apbuart: Optimized RX processing in ISR
Limit the number of …
5
@3df6710
03/13/17 09:53:47 |
maberg |
leon, apbuart: support termios task driven mode
The APBUART control …
5
@f164a294
03/10/17 14:32:38 |
maberg |
leon, apbuart: Inherit HW parameters on sysconsole
The cons layer …
5
@6e2e1299
03/10/17 13:03:11 |
maberg |
leon, apbuart: Assign proper device name
Always assign a device/file …
5
@1fefc719
03/09/17 17:51:47 |
maberg |
leon, apbuart: RX delayed interrupt
Utilize the APBUART RX delayed …
5
@fd9fb21
02/01/17 15:48:51 |
maberg |
leon, cons: drvmgr cons interface uses new TERMIOS
LEON driver …
5
@7cb93250
03/06/17 10:14:23 |
maberg |
leon, apbuart: added register defines: FIFO, delay int
The FIFOs …
5
@f600458d
02/23/17 15:33:21 |
maberg |
leon, clock: new driver manager clock driver
- Compatible with SMP
5
@78e56096
04/10/17 12:52:16 |
Daniel Hellstrom |
leon, tlib: added timer width mask information
5
@ae203e0d
04/07/17 06:31:48 |
Daniel Hellstrom |
leon, ambapp_bus: IRQ affinity for on-chip AMBAPP bus
5
@61788e76
01/31/17 09:13:41 |
javier.jalle |
leon, GR-CPCI-GR740: Added peripheral PCI driver
5
@0e6542fb
04/29/17 13:20:28 |
Pavel Pisa |
bsp/tms570: include package balls and PINMMR registers mapping for …
5
@61568e6
04/26/17 15:53:56 |
joel |
virtex5/startup/dummy_console.c: Use <rtems/bspIo.h> and …
5
@c0ea829
04/26/17 15:50:08 |
joel |
virtex4/startup/dummy_console.c: Use <rtems/bspIo.h> and …
5
@ab77827
04/26/17 01:01:10 |
joel |
or1k/generic_or1k/irq/irq.c: Include <rtems/inttypes.h> and fix …
5
@7db09923
04/25/17 16:42:18 |
joel |
rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number …
5
@485222e
04/24/17 17:00:15 |
joel |
genmcf548x/irq/irq.c: Fix incompatible pointer warning
5
@0d01cdd6
04/24/17 16:18:03 |
joel |
sh/sh7750/sci/sh4uart.c: ix misleading indentation warning
5
@646df54c
04/24/17 16:17:41 |
joel |
powerpc/new-exceptions/bspsupport/ppc_exc_print.c: Fix printf() format …
5
@2808c26
04/24/17 16:17:12 |
joel |
powerpc/mpc5xx/console-generic/console-generic.c: Use updated struct …
5
@3ed2cf60
04/24/17 16:16:37 |
joel |
leon2/console/debugputs.c: Fix misleading indentation warning
5
@fd48b43
04/24/17 16:15:53 |
joel |
virtex5/startup/dummy_console.c: Fix no prototype warning
5
@9beada51
04/24/17 16:15:44 |
joel |
virtex4/startup/dummy_console.c: Fix no prototype warning
5
@523b4fb
04/24/17 16:15:18 |
joel |
mcf5235/console/console.c: Fix indentation and add braces
5
@5e899b5
04/24/17 01:35:05 |
joel |
sparc64/shared/helenos/boot/sparc64/loader/main.c: Fix printf() format …
5
@436008c
04/24/17 01:34:42 |
joel |
sparc64/shared/clock/ckinit.c: Include <rtems/bspIo.h>
5
@38d0a94
04/24/17 01:17:54 |
joel |
shared/drvmgr/leon2_amba_bus.c: Include <rtems/bspIo.h>
5
@5796c21
04/24/17 01:05:53 |
joel |
shared/startup/panic.c: Fix printf() format warnings
5
@3f12cfe
04/24/17 01:05:41 |
joel |
shared/pci/detect_raven_bridge.c: Fix printf() format warnings
5
@31908b12
04/24/17 01:05:12 |
joel |
shared/bootloader/mm.c: Fix printf() format warnings
5
@79d45cbd
04/24/17 01:05:03 |
joel |
shared/bootloader/misc.c: Fix printf() format warnings
5
@1b24a9b
04/24/17 01:04:41 |
joel |
beatnik/pci/gt_pci_init.c: Fix printf() format warnings
5
@c44a7402
04/24/17 01:04:19 |
joel |
beatnik/startup/bspstart.c: Fix printf() format warnings
5
@93206c12
04/24/17 01:03:58 |
joel |
beatnik/marvell/discovery.c: Fix printf() format warnings
5
@bd4072b
04/24/17 01:03:32 |
joel |
gensh2/console/config.c: Fix to reflect struct termios change
5
@ecd4cd4
04/24/17 00:42:34 |
joel |
uC5282/startup/bspstart.c: Fix printf() format warnings
5
@0a84172b
04/24/17 00:42:09 |
joel |
uC5282/console/console.c: Add braces and correct indentation to fix …
5
@edec6dd
04/23/17 17:56:12 |
joel |
libbsp/shared/pci/pci_bus_count.c: Add include <rtems/bspIo.h>
5
@12c12e0
04/23/17 17:55:25 |
joel |
gen68340/startup/dumpanic.c: Fix printf() format warnings
5
@90033411
04/23/17 17:54:23 |
joel |
fb/fb.c: Include <rtems/inttypes.h> and use PRI constant to fix warning
5
@29129822
04/23/17 17:03:22 |
joel |
amba/ahbstat.c: Correct printf() format
5
@35e523d9
04/23/17 16:49:54 |
joel |
uart/apbuart.c: Correct printk() format
5
@76052e6
04/23/17 16:49:05 |
joel |
spw/grspw_router.c: Include <rtems/bspIo.h>
5
@d968826
04/23/17 16:48:32 |
joel |
irq/genirq.c: Include <rtems/bspIo.h>
5
@5c93fb3b
04/23/17 16:48:15 |
joel |
drvmgr/ambapp_bus.c: Include <rtems/bspIo.h>
5
@9ed3266
04/23/17 16:47:53 |
joel |
amba/ahbstat.c: Include <rtems/bspIo.h>
5
@8ed5889f
04/21/17 01:52:09 |
joel |
elnk.c: Fix printf() format warnings
5
@9f55bfb
04/21/17 01:49:07 |
joel |
elnk.c: rtems_elnk_driver_attach() prototype added
5
@814bd025
04/21/17 01:47:34 |
joel |
elnk.c: Make elnk_txDaemon() static to fix warning
5
@8477652
04/21/17 01:44:49 |
joel |
if_fxp.c: Add prototype of rtems_fxp_attach()
5
@169d6f6e
04/21/17 01:43:04 |
joel |
if_fxp.c: Remove unused variable
5
@fc91f51
04/21/17 01:40:51 |
joel |
dec21140.c: Add prototype of dec21140_txDaemon()
5
@5ce0489
04/21/17 01:38:42 |
joel |
dec21140.c: Fix printk() warnings
5
@40d0a468
04/21/17 01:36:49 |
joel |
dec21140.c: Include <libcpu/page.h> to eliminate warnings
5
@bedd927
04/21/17 01:27:32 |
joel |
dec21140.c: Fix PRIxx formatter
5
@50b1269
04/08/17 11:25:43 |
cpodonnell8 |
m68k/mrm332/./sci.c: Use inttypes.h constants removes 6 warnings.
5
@28593c6e
04/08/17 11:21:44 |
cpodonnell8 |
powerpc/haleakala/./mmu_405.c: Use inttypes.h constants removes 11 …
5
@53e7393
04/08/17 11:17:56 |
cpodonnell8 |
powerpc/mvme550/./pci.c: Use inttypes.h constant to fix 1 warning.
5
@4191647
04/08/17 11:12:54 |
cpodonnell8 |
virtex4/startup/bspstart.c: Use %p to fix 11 warnings.
5
@913ed81b
04/08/17 10:55:24 |
cpodonnell8 |
virtex5/startup/bspstart.c: Use %p to fix 11 warnings.
5
@27920db
04/08/17 10:32:28 |
cpodonnell8 |
libbsp/.../sparc64/loader/main.c: Use inttypes.h constants to remove 1 …
5
@52597b9
04/08/17 10:28:46 |
cpodonnell8 |
libchip/network/dec21140.c: Use inttypes.h to fix 1 warning.
5
@006ac513
04/08/17 10:25:28 |
cpodonnell8 |
libbsp/powerpc/./pci/detect_raven_bridge.c: Use inttypes.h to fix 1 …
5
@1731757c
04/13/17 17:13:59 |
Gedare Bloom |
bootstrap: regenerate files after sort order fix
Updates #2965.
5
@7acdb10
04/07/17 14:11:20 |
cpodonnell8 |
libcpu/../mpc5xx/.../vectors_init.c: Using inttype macros fixes 39 …
5
@d8753abd
04/05/17 16:17:43 |
joel |
lm32/shared/timer/timer.c: Include <rtems/bspIo.h>
5
@db46b5f8
04/05/17 16:17:17 |
joel |
lm32/shared/milkymist_video/video.c: Include <rtems/bspIo.h>
5
@c44de850
04/05/17 16:16:47 |
joel |
lm32/shared/milkymist_pfpu/pfpu.c: Fix indentation and braces
5
@505898f6
04/05/17 16:15:53 |
joel |
lm32/shared/milkymist_timer/timer.c: Include <rtems/bspIo.h>
5
@6b5fd3a3
04/05/17 16:15:14 |
joel |
lm32/shared/milkymist_framebuffer/framebuffer.c: Fix indentation and braces
5
