Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @1b2681fe   04/12/18 15:13:48 joel Multiple BSP tcfg: Disable iconv files. 5
(edit) @223e22f   04/13/18 07:15:05 Sebastian Huber bsps: Move uart-output-char.c to bsps This patch is a part of the BSP … 5
(edit) @0a09ac58   04/13/18 07:14:56 Sebastian Huber bsps: Move stackalloc.c to bsps This patch is a part of the BSP … 5
(edit) @9d44ae7   04/13/18 07:14:36 Sebastian Huber bsps: Move bsp-uboot-board-info.c to bsps This patch is a part of the … 5
(edit) @1cba1de   04/13/18 07:11:58 Sebastian Huber bsps: Move bsp-fdt.c to bsps This patch is a part of the BSP source … 5
(edit) @90013f59   04/13/18 06:57:30 Sebastian Huber bsps: Move tod.c to bsps and rename This patch is a part of the BSP … 5
(edit) @4ff09d5b   04/12/18 05:27:41 Sebastian Huber build: Remove subdir-objects from BSP configure.ac The subdir-objects … 5
(edit) @ff24c90d   04/11/18 04:19:26 Sebastian Huber bsps: Remove empty gnatinstallhandler.c This patch is a part of the … 5
(edit) @c5fe4431   04/11/18 04:18:32 Sebastian Huber bsps: Move bootcard.c to bsps This patch is a part of the BSP source … 5
(edit) @4359c43   04/10/18 14:32:59 Sebastian Huber bsps: Simplify source file path in Makefile.am This patch is a part … 5
(edit) @b10caf8   04/10/18 05:16:30 Sebastian Huber bsps: Remove headers from librtemsbsp_a_SOURCES This was used by the … 5
(edit) @b78b814   04/10/18 04:36:19 Sebastian Huber bsps: Avoid source variables in Makefile.am This patch is a part of … 5
(edit) @6c4140c   04/10/18 04:17:10 Sebastian Huber bsps: Avoid line continuation in Makefile.am This patch is a part of … 5
(edit) @1032bf9   04/07/18 17:46:01 Sebastian Huber bsp/mvme5500: Avoid RTEMS_RELLDFLAGS 5
(edit) @b46f943c   04/07/18 17:38:55 Sebastian Huber bsp/motorola_powerpc: Move polled_io.c This file was used by this BSP … 5
(edit) @efb893f   04/07/18 17:28:42 Sebastian Huber bsp/beatnik: Avoid RTEMS_RELLDFLAGS Avoid extra CPPFLAGS. 5
(edit) @b43ea9f   04/05/18 15:07:20 Sebastian Huber bsps: Move legacy console driver to bsps This patch is a part of the … 5
(edit) @f0bcae38   04/05/18 14:45:26 Sebastian Huber bsps: Remove unused console_select_simple.c This patch is a part of … 5
(edit) @b8c59353   04/11/18 03:26:58 Chris Johns build: Fix make clean. Update #3254. 5
(edit) @aa567bc1   04/10/18 06:06:39 Chris Johns configure: Add subdir-objects to all automake flags. This option … 5
(edit) @7ff743d   04/10/18 00:32:25 Chris Johns Generate an error if a BSP in the --enable-rtemsbsp list is not valid … 5
(edit) @cb7b4dc4   04/09/18 03:47:36 Chris Johns bsp/lpc24xx: Exclude iconv POSIX tests. These are now built to … 5
(edit) @b606998   04/09/18 09:40:28 Sebastian Huber bsp/genmcf548x: Fix IRQ support This patch is a part of the BSP … 5
(edit) @01d34a3   04/09/18 09:37:27 Sebastian Huber bsp/csb337: Fix umon support This patch is a part of the BSP source … 5
(edit) @9edb72e   04/05/18 04:56:26 Sebastian Huber build: Remove DISTCLEANFILES A "make distclean" is not supported. So, … 5
(edit) @9b7c456   04/05/18 04:40:02 Sebastian Huber bsps: Move generic IRQ support to bsps This patch is a part of the … 5
(edit) @d584269   04/04/18 14:44:52 Sebastian Huber bsps: Remove librtemsbsp.a wrapup This patch is a part of the BSP … 5
(edit) @4b28d3c   04/04/18 14:39:58 Sebastian Huber bsps: Move shmdr to bsps This patch is a part of the BSP source … 5
(edit) @814eccb4   04/03/18 14:41:16 Sebastian Huber bsps: Move VME support to bsps The VME support is only used by … 5
(edit) @671c31fc   04/03/18 14:24:31 Sebastian Huber bsp: Move umon support to bsps The umon support is only used by the … 5
(edit) @d03ec77d   04/04/18 14:26:28 Sebastian Huber bsps/powerpc: Rename to shared-sources.am This patch is a part of the … 5
(edit) @6799a78   04/04/18 14:25:21 Sebastian Huber bsps/powerpc: Rename to exceptions-sources.am This patch is a part of … 5
(edit) @0f0f249c   04/04/18 14:24:15 Sebastian Huber bsps/m68k: Rename fpsp.am to fpsp-sources.am This patch is a part of … 5
(edit) @82bc976   04/04/18 14:23:09 Sebastian Huber bsps/bfin: Rename shared.am to shared-sources.am This patch is a part … 5
(edit) @27de4e1f   04/03/18 05:20:11 Sebastian Huber bsps: Move libchip to bsps This patch is a part of the BSP source … 5
(edit) @8621ed38   04/03/18 05:28:03 Sebastian Huber bsps: Move config macros to RTEMS_BSP_CONFIGURE Provide … 5
(edit) @4f0dca3a   04/03/18 05:09:11 Sebastian Huber bsps: Move version.c and use bspopts.h This patch is a part of the … 5
(edit) @ce0ea6f   04/03/18 05:08:24 Sebastian Huber bsps: Add shared-sources.am This patch is a part of the BSP source … 5
(edit) @66b99a1   04/03/18 04:28:00 Sebastian Huber bsps: Add RTEMS_BSP to bspopts.h This patch is a part of the BSP … 5
(edit) @2d0bc83   03/30/18 18:42:21 Sebastian Huber build: Remove EXTRA_DIST A "make dist" is not supported. So, it makes … 5
(edit) @0b8a6d7   03/28/18 16:17:45 joel Eliminate PowerPC libcpu/page.h Started to eliminate warnings and … 5
(edit) @4f0dcb69   03/27/18 11:07:57 Sebastian Huber bsps/riscv: Fix warnings 5
(edit) @699fee43   03/26/18 11:33:29 Sebastian Huber bsps: Remove libcpu This patch is a part of the BSP source … 5
(edit) @5d39512   03/26/18 11:25:36 Sebastian Huber bsps/m68k: Remove libcpu/m68k This patch is a part of the BSP source … 5
(edit) @b54558ac   03/26/18 11:20:43 Sebastian Huber bsps/mcf5225x: Move libcpu content to bsps This patch is a part of … 5
(edit) @945095d   03/26/18 11:08:07 Sebastian Huber bsps/genmcf548x: Move libcpu content to bsps This patch is a part of … 5
(edit) @ddf3ea2   03/26/18 10:23:22 Sebastian Huber bsps/csb360: Move libcpu content to bsps This patch is a part of the … 5
(edit) @2190bc6   03/26/18 10:20:45 Sebastian Huber bsps/mcf5206elite: Move libcpu content to bsps This patch is a part … 5
(edit) @3cf2bf63   03/26/18 10:17:06 Sebastian Huber bsps/m68k: Move fpsp support to bsps This patch is a part of the BSP … 5
(edit) @fc2ec62   03/26/18 10:10:15 Sebastian Huber bsps/m68k: Move libcpu content to bsps This patch is a part of the … 5
(edit) @1e23c47   03/26/18 10:01:18 Sebastian Huber bsps/m68k: Remove unused define This patch is a part of the BSP … 5
(edit) @f8e4755f   03/26/18 09:59:23 Sebastian Huber bsps/m68k: Use namespace header This patch is a part of the BSP … 5
(edit) @1048a165   03/26/18 08:36:52 Sebastian Huber bsp/tqm8xx: Use shared linker command file Update #3339. 5
(edit) @11a8296   03/26/18 05:57:53 Sebastian Huber bsp/mvme3100: Simplify Makefile.am 5
(edit) @5f59e2a   03/26/18 05:52:57 Sebastian Huber bsps/powerpc: Move dec timer driver This patch is a part of the BSP … 5
(edit) @6882be7   03/26/18 05:47:02 Sebastian Huber bsps/powerpc: Remove libcpu/powerpc This patch is a part of the BSP … 5
(edit) @2d33672a   03/26/18 05:43:09 Sebastian Huber bsps/powerpc: Move ppc403 clock driver to bsps This patch is a part … 5
(edit) @d7c232f   03/26/18 05:18:20 Sebastian Huber bsps/powerpc: Remove unused files This patch is a part of the BSP … 5
(edit) @4fd1ff0f   03/26/18 04:57:10 Sebastian Huber bsps/powerpc: Move AltiVec? support to bsps This patch is a part of … 5
(edit) @d813d9aa   03/26/18 04:24:55 Sebastian Huber bsps/powerpc: Move dec clock driver to bsps This patch is a part of … 5
(edit) @11fe8c59   03/26/18 04:18:51 Sebastian Huber bsps/powerpc: Move MMU support to bsps This patch is a part of the … 5
(edit) @b8c468b   03/23/18 15:11:55 Sebastian Huber bsp/tqm8xx: Move libcpu content to bsps This patch is a part of the … 5
(edit) @a12dcff8   03/23/18 15:04:18 Sebastian Huber bsp/mpc8260: Move libcpu content to bsps This patch is a part of the … 5
(edit) @0cab067   03/23/18 14:54:12 Sebastian Huber bsps/powerpc: Move libcpu content to bsps This patch is a part of the … 5
(edit) @e2bd1f6   03/21/18 15:38:43 Sebastian Huber bsp/bfin: Move libcpu content to bsps This patch is a part of the BSP … 5
(edit) @96400050   03/26/18 07:04:43 Sebastian Huber bsp/pc386: Remove unused RTEMS_CPU_MODEL This patch is a part of the … 5
(edit) @b1b7390   03/26/18 06:58:42 Sebastian Huber bsp/pc386: Fix build This patch is a part of the BSP source … 5
(edit) @f17df94   03/26/18 07:14:16 Sebastian Huber build: configure.ac is a file 5
(edit) @d7fd3bc   03/23/18 16:33:45 Gedare Bloom sparc64: remove header file with duplicated macros The boot/stack.h … 5
(edit) @b1d3b0f   03/23/18 02:46:49 Chris Johns libcpu: Only build if there is a valid configure.ac 5
(edit) @df8a31d   03/22/18 13:50:02 thomas.doerfler bsp/tqm8xx: Fix network interface driver 5
(edit) @28a6bb8   03/22/18 05:36:11 Sebastian Huber mpci: Avoid use of RTEMS_RELLDFLAGS 5
(edit) @dc1ea01   03/22/18 05:27:31 Sebastian Huber bsps/mpc55xx: Move libcpu content to bsps This patch is a part of the … 5
(edit) @3f3f246a   03/22/18 05:19:16 Sebastian Huber bsps/mpc55xx: Remove unused files This patch is a part of the BSP … 5
(edit) @bb22a3f3   03/21/18 05:27:24 Sebastian Huber bsp/powerpc: Move libcpu timer to bsps Use only one timer driver … 5
(edit) @f3a51d62   03/21/18 07:11:33 Sebastian Huber bsps/powerpc: Remove bsp_timer_internal_clock The only consumer of … 5
(edit) @a7fa9e91   03/20/18 15:16:53 Sebastian Huber bsp/pc386: Move libcpu content to bsps This patch is a part of the … 5
(edit) @5cf0656   03/20/18 13:14:39 Eric Tremblay bsps/powerpc: Support more than 256MiB of RAM Close #3322. 5
(edit) @5d44981c   03/20/18 06:34:22 Sebastian Huber bsp/qoriq: Fix bsp_restart() Update #3085. 5
(edit) @09dd82a5   03/13/18 15:43:25 Sebastian Huber bsp/ss555: Move libcpu content to bsps This patch is a part of the … 5
(edit) @bd150801   03/13/18 15:24:16 Sebastian Huber bsps/powerpc: Move exceptions support to bsps This patch is a part of … 5
(edit) @ff3b9aa   03/13/18 05:23:40 Sebastian Huber bsps/powerpc: Remove unused files This patch is a part of the BSP … 5
(edit) @7dbc43d   03/13/18 05:18:38 Sebastian Huber bsps/powerpc: Move basic support to bsps This patch is a part of the … 5
(edit) @ac04bb85   03/12/18 15:42:16 Sebastian Huber bsps/powerpc: Move legacy IRQ support This patch is a part of the BSP … 5
(edit) @efa0039e   03/13/18 16:14:15 amaan.cheval i386/smp: Export _CPU_SMP_Prepare_start_multitasking as a function … 5
(edit) @51614c01   03/13/18 16:14:14 amaan.cheval i386/smp: Have ld use incremental build for appstart.o With HAS_SMP … 5
(edit) @2e5cf7f   03/16/18 14:09:36 Sebastian Huber bsps/powerpc: Use shared linker command file Close #3339. 5
(edit) @9860cc7   03/16/18 10:01:03 Sebastian Huber bsps/powerpc: Fix linker command files Update #3339. 5
(edit) @0a7a30d   03/12/18 19:53:09 joel Add PowerPC paravirtualization support Cannot read or write MSR when … 5
(edit) @71c5552f   03/12/18 15:43:28 christian.mauderer bsp/atsam: Allow setting the drive strength. This adds a simple … 5
(edit) @7633f5b   03/12/18 05:59:15 Sebastian Huber sparc64: Move libcpu content to cpukit This patch is a part of the … 5
(edit) @8b5778e   03/12/18 05:37:36 Sebastian Huber sparc: Move libcpu content to cpukit This patch is a part of the BSP … 5
(edit) @c4905d8d   03/10/18 09:17:35 Sebastian Huber bsps/arm: Move libcpu content to bsps This patch is a part of the BSP … 5
(edit) @b6755af   03/09/18 15:45:56 Sebastian Huber bsps/mips: Move libcpu content to bsps This patch is a part of the … 5
(edit) @961e2ef   03/12/18 05:23:08 Sebastian Huber bsps/mips: Remove Mongoose-V README This patch is a part of the BSP … 5
(edit) @4c83f292   03/12/18 07:16:17 Sebastian Huber bsps: Remove unused RTEMS_CPU_MODEL This patch is a part of the BSP … 5
(edit) @a4570829   03/09/18 15:22:25 Sebastian Huber bsps: Remove unused memcpy() implementations This patch is a part of … 5
(edit) @0706581   03/07/18 20:31:31 joel misc sh: Remove includes of rtems/score/types.h 5
(edit) @d39cc068   03/07/18 05:37:55 Sebastian Huber bsps: More verbose bsp_fatal_extension() Close #3318. 5
(edit) @befae6ab   03/07/18 09:32:42 Sebastian Huber bsp/genmcf548x: Fix printk() support 5
