@ec230fc7
06/15/17 17:40:25 |
joel |
i386/shared/comm/i386-stub-glue.c: Fix duplicate const warning
5
@9177426
06/15/17 17:40:04 |
joel |
lpc176x/misc/restart.c: Fix duplicate const warning
5
@c6810c8
06/19/17 12:09:28 |
Sebastian Huber |
bsps: Improve interrupt vector enable/disable API
Change …
5
@b361cb6c
06/16/17 04:22:21 |
Sebastian Huber |
bsps/powerpc: Fix warning
Close #3051.
5
@369372c3
06/15/17 11:35:20 |
1473996754 |
Fix beagle i2c file bbb-i2c.c comment issues
5
@8f550d2
06/14/17 14:53:44 |
1473996754 |
Add the i2c driver for Beaglebone Black
Update ticket #2891 and my …
5
@7741545b
06/05/17 12:49:49 |
1473996754 |
Remove beagle old i2c code
modify …
5
@fd10817
05/11/17 13:33:10 |
m09123874 |
Remove excessive locking from cache operations.
According to manual, …
5
@3f884b4
06/13/17 09:38:39 |
Sebastian Huber |
bsp: Fixes due to header file changes
Update #2833.
5
@0af8bb6
06/12/17 13:40:37 |
Sebastian Huber |
bsp: Include missing <sys/param.h>
Update #2833.
5
@74a13c8
06/12/17 13:30:13 |
Sebastian Huber |
bsp/beatnik: Fixes due to header file changes
Update #2833.
5
@7b0c74ff
06/09/17 13:42:36 |
Sebastian Huber |
i386: Support thread-local storage (TLS)
Update #2468.
5
@f256685
06/09/17 05:55:16 |
Sebastian Huber |
bsp/psim: Include missing <sys/param.h>
5
@6081ef3
06/09/17 05:54:45 |
Sebastian Huber |
if_fxp: Include missing <inttypes.h>
Fix format warnings.
5
@32b4a0c
06/09/17 05:25:02 |
Sebastian Huber |
Simplify TLS support in context switch
There is no need to save the …
5
@ce3ac00
06/06/17 13:41:48 |
Christian.Mauderer |
bsps/arm: Fix ARMv7-M interrupt suppport
Enable/disable vector …
5
@787f51f
06/06/17 09:08:16 |
Sebastian Huber |
Do not include <sys/ioctl.h> in kernel-space
Update #2833.
5
@93531e9b
06/06/17 06:03:45 |
Sebastian Huber |
Move RTEMS-specific Termios API content
Remove obsolete support for …
5
@cf54965
06/07/17 05:22:38 |
Sebastian Huber |
network: Include missing <inttypes.h>
Update #2833.
5
@3623c40
05/29/17 10:09:34 |
Sebastian Huber |
ada-tests/spatcb01: New test
Update #2289.
5
@7203b70
06/01/17 17:04:05 |
Sebastian Huber |
bsp/motorola_powerpc: Fix for Binutils 2.28+
There are mismatched …
5
@697a6ca
06/01/17 17:00:38 |
Sebastian Huber |
bsps/powerpc: Set output format in linker script
Set the proper …
5
@848007c
05/07/17 21:08:17 |
phamp |
Add support for IBM PowerPC 750 chip.
Closes #3015.
5
@afa5b89
05/23/17 09:34:45 |
Sebastian Huber |
ada: Remove task notepad support
Update #2493.
5
@783fbce
05/23/17 09:33:29 |
Sebastian Huber |
ada: Update due to Clock Manager API changes
Update #2676.
5
@9ff0f40
05/23/17 09:32:21 |
Sebastian Huber |
ada: Remove <rtems/debug.h> support
Update #2477.
5
@7ec982bf
05/26/17 00:35:17 |
Chris Johns |
build-system: Fix the targets support for the parallel build.
5
@ff781cc
05/25/17 05:10:11 |
Chris Johns |
m32c/m32csim: Exclude linpack from the tests.
Closes #3025.
5
@a748603
05/14/17 01:52:52 |
Chris Johns |
build-system: Parallel build all subdirs.
5
@9935c23
05/23/17 23:26:29 |
Chris Johns |
arm/tms570: Update preinstall.am after bootstrap.
5
@bc470d3c
10/31/16 10:01:39 |
jacob.hansen |
sparc: only define start if it is different from SYM(start)
The SYM …
5
@8639685
10/28/16 14:05:56 |
jacob.hansen |
sparc: Adjust assembly to improve compability with LLVM
- All …
5
@1ea73e2b
05/11/17 11:43:53 |
Daniel Hellstrom |
leon, grtc: SMP support by using spin-locks
5
@818f10bc
05/11/17 10:54:46 |
Daniel Hellstrom |
leon, grtc: updated overrun condition handling
The following …
5
@6fdded2c
05/10/17 10:39:23 |
Daniel Hellstrom |
leon, gr1553bm: SMP support by using spin-locks
5
@3feae3b
05/10/17 08:46:01 |
Daniel Hellstrom |
leon, gr1553bc: SMP support by using spin-locks
Since DMA buffers are …
5
@84e4d10c
05/09/17 14:00:56 |
Daniel Hellstrom |
leon, apbuart: remove old RAW UART driver
This driver was initially …
5
@c92f402c
05/09/17 11:13:44 |
Daniel Hellstrom |
leon, grtm: SMP support by using spin-locks
5
@f767fe74
05/08/17 14:10:14 |
Daniel Hellstrom |
leon, ahbstat: remove printf warnings
5
@ce76b9d2
05/08/17 12:58:41 |
Daniel Hellstrom |
leon, pci-peripherals: SMP support by spin-locks and updated genirq
5
@8670c464
05/05/17 13:42:45 |
Daniel Hellstrom |
leon, genirq: SMP support for PCI peripherals
The common interrupt …
5
@aa19873
04/24/17 14:39:49 |
maberg |
leon: allow SMP boot from any CPU
5
@039edd2a
04/13/17 12:12:31 |
maberg |
leon, grcan: removed unused txerror, rxerror
5
@ee078c21
04/13/17 12:06:04 |
maberg |
leon, grcan: fixed historical comment
5
@91541551
04/11/17 10:30:02 |
Daniel Hellstrom |
leon, grcan: semaphore reset count required after flushing
It is also …
5
@9855690
04/11/17 08:47:39 |
Daniel Hellstrom |
leon, grcan: split hw_stop() into hw and sw stop
this is to avoid …
5
@3a650d3b
04/13/17 12:08:50 |
maberg |
leon, grcan: RTEMS_NO_TIMEOUT on tx_sem
5
@2d3d8f96
04/03/17 11:27:49 |
maberg |
leon, grcan: redesigned bus-off and AHB error handling
When bus-off …
5
@ca4c4164
03/09/17 14:44:08 |
Daniel Hellstrom |
leon, grcan: updated device name and use it for ISR
5
@05749690
01/26/17 10:01:10 |
maberg |
leon, grcan: fixed race on interrupt mask register
There was a …
5
@5d367c56
01/26/17 09:54:57 |
maberg |
leon, grcan: unregister interrupt handler at close
5
@c297060
03/13/17 11:44:58 |
maberg |
leon, grcan: protect statistics on copy to user
Locking the stats …
5
@7b8a920
01/26/17 09:52:31 |
maberg |
leon, grcan: use RTEMS 4.12 SMP interrupt lock
5
@bc40b4d
01/24/17 10:16:41 |
maberg |
leon, grcan: consistent indentation
This commit does not contain any …
5
@ad203e58
01/24/17 09:00:07 |
maberg |
leon, grcan: function based user interface
This commit preserves all …
5
@229c4249
04/27/17 11:14:53 |
maberg |
bsp/leon3: Cleaner namespace for LEON3 debug UART
Prefix BSP specific …
5
@011efee8
04/25/17 07:10:03 |
Daniel Hellstrom |
leon, irq: single CPU SMP configuration does not need IPI ISR
5
@fa27fe5c
04/25/17 13:26:18 |
Daniel Hellstrom |
leon, greth: new option and change soft-reset logic for EDCL
5
@8ac070a
04/24/17 14:36:16 |
Daniel Hellstrom |
leon, greth: 10/100 modes should be assigned in fastest priority
5
@e6fbd26
04/24/17 14:32:17 |
Daniel Hellstrom |
leon, greth: speed modes advertising now configurable
5
@12718134
04/24/17 13:10:41 |
Daniel Hellstrom |
leon, greth: EDCL and DD is disabled during reset
The EDCL and …
5
@a9859d1
05/07/17 20:52:50 |
phamp |
interrupt vector indexing is assuming BSP_INTERRUPT_VECTOR_MIN = 0
5
@f219adc
05/07/17 21:13:24 |
phamp |
missing a couple register names + a #ifndef_ASM around serial.h …
5
@0e494170
05/11/17 07:53:05 |
Sebastian Huber |
bsps/arm: Fix bit field offset in GIC support
Update #3002.
5
@430949aa
04/13/17 19:23:28 |
Daniel Hellstrom |
leon, greth: let Gbit full duplex override half
5
@998e34ad
04/13/17 12:57:01 |
Daniel Hellstrom |
leon, greth: SMP support by using spin-lock protection
5
@8927c0f
04/11/17 11:55:02 |
maberg |
leon, gptimer: offset intnum with subtimer index
If separate …
5
@256e083f
04/10/17 17:07:04 |
maberg |
leon, gptimer: fixed probing separate interrupts
Probing of separate …
5
@6234abe
03/08/17 11:59:07 |
javier.jalle |
leon, l4stat: Initial driver commit
5
@21b3319f
03/07/17 11:50:48 |
javier.jalle |
leon, ambapp: Added L4STAT driver to ambapp ids
5
@a8595605
03/06/17 12:08:04 |
maberg |
leon, occan: Converted disable/enable to SMP locks
This commit …
5
@c609ccea
01/19/17 17:57:58 |
maberg |
leon, ahbstat: Use RTEMS 4.12 SMP interrupt lock
5
@c241236
03/15/17 13:38:21 |
javier.jalle |
leon, memscrub: add GR740 memory scrubber driver
5
@d79429f
03/15/17 14:04:33 |
javier.jalle |
leon, griommu: add GR740 IOMMU driver
The driver is limited to the …
5
@3e948cc
02/15/17 15:51:33 |
javier.jalle |
leon, ambapp: Added GRIOMMU driver to ambapp ids
5
@dfa86338
02/21/17 08:14:46 |
javier.jalle |
leon, l2cache: add GR740 L2-Cache driver
5
@d24ed54
03/15/17 13:58:04 |
javier.jalle |
leon, ambapp: Added L2CACHE driver to ambapp ids
5
@93c5e63
02/09/17 13:09:17 |
javier.jalle |
leon, grpci2dma: add GR740 PCI DMA driver
5
@31ba1f21
02/15/17 10:14:13 |
javier.jalle |
leon, grpci2: prepare for GRPCI2DMA driver
5
@8e45d55
02/15/17 10:09:23 |
javier.jalle |
leon, grpci2: Make driver SMP safe
5
@9631e5a9
03/17/17 13:44:25 |
Daniel Hellstrom |
leon, ambapp: updated AMBA PnP IDs and names database
5
@e5e44bdb
03/14/17 16:46:12 |
maberg |
leon, apbuart: Wait for shift register on close
Do not disable …
5
@6860ddb
03/14/17 16:27:57 |
maberg |
leon, apbuart: Optimized RX processing in ISR
Limit the number of …
5
@3df6710
03/13/17 09:53:47 |
maberg |
leon, apbuart: support termios task driven mode
The APBUART control …
5
@f164a294
03/10/17 14:32:38 |
maberg |
leon, apbuart: Inherit HW parameters on sysconsole
The cons layer …
5
@6e2e1299
03/10/17 13:03:11 |
maberg |
leon, apbuart: Assign proper device name
Always assign a device/file …
5
@1fefc719
03/09/17 17:51:47 |
maberg |
leon, apbuart: RX delayed interrupt
Utilize the APBUART RX delayed …
5
@fd9fb21
02/01/17 15:48:51 |
maberg |
leon, cons: drvmgr cons interface uses new TERMIOS
LEON driver …
5
@7cb93250
03/06/17 10:14:23 |
maberg |
leon, apbuart: added register defines: FIFO, delay int
The FIFOs …
5
@f600458d
02/23/17 15:33:21 |
maberg |
leon, clock: new driver manager clock driver
- Compatible with SMP
5
@78e56096
04/10/17 12:52:16 |
Daniel Hellstrom |
leon, tlib: added timer width mask information
5
@ae203e0d
04/07/17 06:31:48 |
Daniel Hellstrom |
leon, ambapp_bus: IRQ affinity for on-chip AMBAPP bus
5
@61788e76
01/31/17 09:13:41 |
javier.jalle |
leon, GR-CPCI-GR740: Added peripheral PCI driver
5
@0e6542fb
04/29/17 13:20:28 |
Pavel Pisa |
bsp/tms570: include package balls and PINMMR registers mapping for …
5
@61568e6
04/26/17 15:53:56 |
joel |
virtex5/startup/dummy_console.c: Use <rtems/bspIo.h> and …
5
@c0ea829
04/26/17 15:50:08 |
joel |
virtex4/startup/dummy_console.c: Use <rtems/bspIo.h> and …
5
@ab77827
04/26/17 01:01:10 |
joel |
or1k/generic_or1k/irq/irq.c: Include <rtems/inttypes.h> and fix …
5
@7db09923
04/25/17 16:42:18 |
joel |
rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number …
5
@485222e
04/24/17 17:00:15 |
joel |
genmcf548x/irq/irq.c: Fix incompatible pointer warning
5
@0d01cdd6
04/24/17 16:18:03 |
joel |
sh/sh7750/sci/sh4uart.c: ix misleading indentation warning
5
