@f1b1668
12/20/13 09:17:22 |
Daniel Hellstrom |
AMBAPP: updated PnP IDs database with SPWTDP
4.115
@fa12bb43
11/29/13 13:58:58 |
Daniel Hellstrom |
GRTIMER: added to GPTIMER driver
GRTIMER is compatible with GPTIMER, …
4.115
@9b8e04e2
10/22/13 10:03:41 |
Daniel Hellstrom |
GRETH: avoid hw generated UDP/TCP cksum generation
Hardware generated …
4.115
@80b9c8ac
12/20/13 13:03:10 |
Daniel Hellstrom |
GR-RASTA-IO: updated for new version
From this driver's point of view …
4.115
@fc76056e
12/20/13 13:01:12 |
Daniel Hellstrom |
GR-RASTA-TMTC: updated for new version
From this driver's point of …
4.115
@9d88008
12/18/13 15:42:16 |
Daniel Hellstrom |
AT697PCI: fix PCI cfg writes
4.115
@ddc4002
11/22/13 09:22:56 |
Daniel Hellstrom |
AT697 PCI: abort whhen a peripheral PCI system detected
4.115
@3c236cc
02/05/14 16:17:53 |
Daniel Hellstrom |
LEON PCI: fix for PCI host bridge driver CFG space access
4.115
@acf7047e
09/10/13 11:46:29 |
Daniel Hellstrom |
GPTIMER: timer probing must not be on timer0
Timers are identical …
4.115
@51347053
07/01/13 13:00:21 |
Daniel Hellstrom |
LEON PCI: host bridge driver support for probing dev0=AD16
Before the …
4.115
@d936c1a
06/03/13 12:12:08 |
Daniel Hellstrom |
APBUART: debug bit was cleared incorrectly
4.115
@ab907e8e
05/21/13 08:10:21 |
Daniel Hellstrom |
NGMP PCI: added support for NGMP prototype boards
4.115
@bc89145
02/11/15 13:39:34 |
Daniel Hellstrom |
LEON GRSPW: updated to new DRVMGR translation interface
4.115
@ffd8002d
05/08/13 12:41:13 |
Daniel Hellstrom |
GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device
4.115
@8aa446a
05/08/13 12:38:10 |
Daniel Hellstrom |
GRPCI2: updated register layout to newer specification
4.115
@ecbd577
04/30/13 07:49:32 |
Daniel Hellstrom |
AMBAPP: update AMBA PnP ID database
4.115
@175b9a64
04/24/13 15:36:44 |
Daniel Hellstrom |
GRPCI2: work-around for rev0 bug by limiting prefetching
4.115
@819de55b
03/18/13 07:29:39 |
Daniel Hellstrom |
PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performance
4.115
@37ac3b86
03/14/13 09:20:15 |
Daniel Hellstrom |
GRETH: cleaned up parts of PHY init code
4.115
@107c5aea
03/13/13 15:40:05 |
Daniel Hellstrom |
GRETH: changed the PHY initialization sequence
1. read_mii() now …
4.115
@a79c36ad
03/12/13 14:30:09 |
Daniel Hellstrom |
GRETH: forcing autonegotiation during PHY initialization
Looking at …
4.115
@bee7c46f
03/12/13 13:49:33 |
Daniel Hellstrom |
GRETH: updated worker Deamon thread name
The name was probably copied …
4.115
@552d4a9
03/06/13 14:08:31 |
Daniel Hellstrom |
GRPCI: initialize cache-line-size and latency timer
In some GRPCI …
4.115
@5dd83de
01/18/13 12:16:05 |
Daniel Hellstrom |
GRSPW: fixed SET_RMAPEN and SET_RMAPBUFDIS
Both ioctl commands …
4.115
@4d249b9f
11/19/12 16:41:15 |
Daniel Hellstrom |
GPTIMER: support separate & shared irq by clearing pending bit after ISR
4.115
@7ebc28cd
11/19/12 14:24:21 |
Daniel Hellstrom |
GPTIMER: Only probe pending bit on timer0
4.115
@b583cc5f
02/23/15 12:47:32 |
Daniel Hellstrom |
leon,gpiolib: add mask/unmask interrupt support
4.115
@949d0d6
09/25/12 13:26:00 |
arvid |
GRSPW: Make sure buffers are 64-bit aligned
This is to improve odds …
4.115
@18564f5
06/19/12 12:49:40 |
Daniel Hellstrom |
APBUART: fix GRMON -u support for older UARTs
4.115
@0f49c0e
06/19/12 06:50:11 |
Daniel Hellstrom |
GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA
This patch adds …
4.115
@16d6e42
06/19/12 06:34:37 |
Daniel Hellstrom |
LEON3: fixed nano seconds support in TLIB
The …
4.115
@f00fee8e
05/24/12 15:23:37 |
Daniel Hellstrom |
GRTM: fixed bug where transmitter start loop was optimized away
4.115
@e9378fa
05/16/12 11:17:11 |
Daniel Hellstrom |
GRPCI: fix target BAR1 initialization
4.115
@3bb4122
02/23/15 12:02:39 |
Daniel Hellstrom |
LEON: added new drivers to the LEON2/LEON3 BSPs
Most drivers use the …
4.115
@fe1aa9c0
12/21/11 12:21:49 |
Daniel Hellstrom |
LEON: added network device configuration helper function
4.115
@3681925
12/20/11 15:27:54 |
Daniel Hellstrom |
LEON: updated shared drivers to Driver Manger framework
Some bugfixes …
4.115
@e67b2b8d
12/20/11 14:58:05 |
Daniel Hellstrom |
LEON: updated and added PCI peripherals for LEON BSPs
The CCHIP …
4.115
@3e3fb0d
12/20/11 11:28:32 |
Daniel Hellstrom |
LEON2: added support for LEON2-GRLIB systems
In some non-standard …
4.115
@46e41c98
12/16/11 13:10:57 |
Daniel Hellstrom |
LEON: replaced old BSP PCI layer with new generic libpci PCI layer
4.115
@c1764100
12/16/11 10:39:23 |
Daniel Hellstrom |
LEON3: new Console driver, APBUART driver using Driver Manager
This …
4.115
@045de35
04/14/15 07:29:48 |
Daniel Hellstrom |
MERGE: new system clock implementation
4.115
@cd64fbf
12/16/11 09:37:49 |
Daniel Hellstrom |
LEON: GPTIMER driver, Timer Library and System Clock for LEON3
With …
4.115
@3db9e5b0
12/15/11 16:31:17 |
Daniel Hellstrom |
LEON2: implemented AMBA Bus Driver for Driver Manager
4.115
@e05c265
12/15/11 16:00:38 |
Daniel Hellstrom |
LEON3: implemented AMBA PnP Bus Driver for Driver Manager
4.115
@d11f228
12/15/11 15:39:54 |
Daniel Hellstrom |
sparc BSPs: implemented libpci IRQ BSP support
4.115
@e428dc4a
12/12/11 14:50:57 |
Daniel Hellstrom |
LEON3: implemented BSP DRVMGR startup initialization
4.115
@e7fade3
11/28/11 08:52:03 |
Daniel Hellstrom |
DRVMGR: added driver manager to cpukit/libdrvmgr
4.115
@e51eb80
02/19/15 08:25:09 |
Daniel Hellstrom |
leon3,ngmp: simplify cpucounter initialization
Remove support for …
4.115
@5da315ff
02/19/15 09:06:54 |
Daniel Hellstrom |
leon3: make timer initialization configurable
Its now possible to …
4.115
@ead16ae1
02/19/15 09:13:32 |
Daniel Hellstrom |
leon3: always clear interrupt controller
4.115
@60b0fd5
02/19/15 08:20:13 |
Daniel Hellstrom |
leon3: clock driver rely on previous found timer
No point in scanning …
4.115
@31e4e25d
12/14/11 10:28:18 |
Daniel Hellstrom |
LEON3: GPTIMER timer watchdog driver
Last timer instance of GPTIMER …
4.115
@cb02e8ac
04/15/15 15:02:44 |
Joel Sherrill |
bf537Stamp: Re-enable bsp_reset()
4.115
@74c4facd
04/14/15 15:08:37 |
Joel Sherrill |
tms570/startup/bspreset.c: Add include <bsp/bootcard.h> to fix warning
4.115
@1aaf2fb
04/14/15 20:01:53 |
Joel Sherrill |
lm32/shared/startup/bspreset.c: New file missed in previous commit
4.115
@0a73de2
04/14/15 15:22:35 |
Hesham Almatary |
or1ksim: Fix bug at UART driver.
Fix some UART register addresses and …
4.115
@a1d6f7a
04/10/15 06:23:00 |
Thomas.Volgmann |
bsp/altera-cyclone-v: Add RTC driver
4.115
@044c7d82
04/07/15 20:06:32 |
alan.cudmore |
Add hardware FPU flags for Raspberry Pi 2 BSP
4.115
@45491a88
04/05/15 20:49:32 |
Joel Sherrill |
lm32 BSPs: Add lm32_evr variant for running on gdb.
Lay groundwork …
4.115
@d0307c8a
04/03/15 21:18:40 |
Joel Sherrill |
or1ksim-testsuite.tcfg: new file
4.115
@475ff0a7
04/03/15 20:08:01 |
Joel Sherrill |
ods68302-testsuite.tcfg: Add fileio
4.115
@66016198
04/03/15 20:07:47 |
Joel Sherrill |
rtl22xx-testsuite.tcfg: Add fileio
4.115
@aae6c21
04/02/15 06:31:09 |
Sebastian Huber |
bsp/altera-cyclone-v: Fix define usage
4.115
@c966b4dc
04/01/15 14:38:26 |
Joel Sherrill |
simsh*: Disable interrupt critical section tests
These do not run …
4.115
@ef3bcef
03/31/15 22:45:52 |
Joel Sherrill |
jmr3904-testsuite.tcfg: New file
4.115
@ec8f3cb
03/26/15 20:16:38 |
Martin Galvan |
TMS570: Add board reset code to bsp_reset
4.115
@89fffa6
03/26/15 20:21:26 |
Martin Galvan |
TMS570: Enable FPU in makefile.
4.115
@8aa967c
03/25/15 09:55:32 |
Sebastian Huber |
bsp/altera-cyclone-v: Typo
4.115
@28a8206c
03/22/15 13:58:30 |
Joel Sherrill |
moxie machine type not supported by rtems-syms. See #2213
updates #2313.
4.115
@36ad3c7
03/21/15 19:42:55 |
Joel Sherrill |
mrm332/console/sci.c: Make routines static
4.115
@90f25440
03/21/15 19:41:53 |
Joel Sherrill |
nds/libnds/source/arm9/image.c: Add needed cast
4.115
@e2192d9f
03/21/15 19:41:27 |
Joel Sherrill |
nds/libnds/source/arm7/clock.c: Avoid over indexing array
4.115
@e836c7c1
03/21/15 19:40:42 |
Joel Sherrill |
lpc176x/console/console-config.c: Conditionalize code to avoid unused …
4.115
@7a6c7fe3
03/20/15 15:41:33 |
Joel Sherrill |
m32csim-testsuite.tcfg: Add tests with data size issues
4.115
@8b5f911
03/20/15 15:41:13 |
Joel Sherrill |
h8sim*-testsuite.tcfg: Add tests with data size issues
4.115
@14655d35
03/20/15 15:40:35 |
Joel Sherrill |
avrtest-testsuite.tcfg: Add tests with data size issues
4.115
@c69f236
03/19/15 17:30:10 |
Joel Sherrill |
m32cbsp: Disable jffs2 and mrfs tests
4.115
@83f11c2
03/19/15 17:29:57 |
Joel Sherrill |
h8sim: Disable jffs2 and mrfs tests
4.115
@1d09732
03/19/15 17:29:40 |
Joel Sherrill |
avrtest: Disable jffs2 and mrfs tests
4.115
@d4edbdbc
03/20/15 13:09:26 |
Sebastian Huber |
Replace www.rtems.com with www.rtems.org
4.115
@665928a
03/11/15 09:53:59 |
cederman |
rtems: Use atomic operation with correct type
4.115
@9f34aa5
03/20/15 08:45:02 |
Sebastian Huber |
bsp/rtl22xx: Add prefix due to name conflicts
Close #2303.
4.115
@7b35a36
03/11/15 19:57:23 |
Martin Galvan |
Add CAN, PWM, ADC and UART1/2/3 support to the LPC176x BSP.
This …
4.115
@fb1a9ad
03/17/15 15:58:21 |
Joel Sherrill |
m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add tmfine01
4.115
@d48d08c
03/17/15 15:58:21 |
Joel Sherrill |
arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg: Add tmfine01
4.115
@d10e331
03/17/15 15:58:21 |
Joel Sherrill |
arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg: Add tmfine01
4.115
@487642f
03/17/15 15:58:21 |
Joel Sherrill |
arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add …
4.115
@77d558c
03/17/15 15:58:21 |
Joel Sherrill |
arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg: Add tmfine01
4.115
@13d5033
03/17/15 15:58:20 |
Joel Sherrill |
arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg: Add tmfine01
4.115
@a7c7bdc
03/17/15 15:58:20 |
Joel Sherrill |
arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg: Add tmfine01
4.115
@195efa43
03/15/15 14:55:42 |
Joel Sherrill |
powerpc/shared/flash/intelFlash.c: Eliminate use of deprecated method
4.115
@38d91667
03/15/15 02:17:20 |
Joel Sherrill |
powerpc/mvme5500/vectors/exceptionhandler.c: Turn off deprecated …
4.115
@24868ecb
03/14/15 16:00:20 |
Joel Sherrill |
libcpu/bfin/clock/rtc.c: Do not use rtems_clock_get()
4.115
@c1479edf
03/14/15 15:59:52 |
Joel Sherrill |
powerpc/shared/flash/intelFlash.c: Do not use rtems_clock_get()
4.115
@fe0eb1b
03/14/15 15:59:35 |
Joel Sherrill |
score603e/tod/tod.c: Do not use rtems_clock_get()
4.115
@05af8b9
03/14/15 15:57:55 |
Joel Sherrill |
beatnik/network/porting/if_xxx_rtems.c: Do not use rtems_clock_get()
4.115
@0cc35f0
03/14/15 15:57:14 |
Joel Sherrill |
mvme167/network/network.c: Do not use rtems_clock_get()
4.115
@8164ebd
03/14/15 15:56:43 |
Joel Sherrill |
mvme162/tod/tod.c: Do not use rtems_clock_get()
4.115
@ac8339a
03/17/15 10:28:44 |
Sebastian Huber |
bsp/mpc55xx: Fix flash settings
4.115
@8e10f62
03/17/15 07:54:39 |
Sebastian Huber |
bsp/qoriq: Add register blocks for T variants
4.115
