@a5c56af
12/15/16 14:03:56 |
Sebastian Huber |
bsp/atsam: Move interrupt setup to PIO_Configure()
5
@a4936b5
12/15/16 13:55:45 |
Sebastian Huber |
bsp/atsam: System initialization for PIO IRQs
5
@8eb5fbb6
12/15/16 12:27:17 |
Sebastian Huber |
bsp/atsamv: Move XDMAD instance out of SPI driver
Use system …
5
@d1c771c
12/15/16 08:56:12 |
Sebastian Huber |
bsp/atsam: Move XDMA IRQ handler to XDMA module
The XDMA is shared by …
5
@cb59276
12/15/16 05:15:13 |
Sebastian Huber |
bsp/atsam: Use _Assert() instead of assert()
5
@fd12159
12/15/16 05:12:46 |
Sebastian Huber |
bsp/atsam: Use inline functions for XDMA access
5
@8dd83d3
12/14/16 10:52:01 |
Sebastian Huber |
bsp/atsam: Optimize SPI interrupt
5
@9686c614
12/14/16 10:42:28 |
Sebastian Huber |
bsp/atsam: Simplify SPI transfer status
5
@de7c171
12/14/16 08:41:30 |
Sebastian Huber |
bsp/atsam: Reduce context switches for SPI transf
5
@b52513b
12/14/16 07:32:02 |
Sebastian Huber |
bsp/atsam: Optimize SPI DMA transfer setup
5
@f104bd3
12/14/16 07:06:14 |
Sebastian Huber |
bsp/atsam: Simplify SPI DMA transfer setup
5
@49b6931
12/14/16 07:00:56 |
Sebastian Huber |
bsp/atsam: Simplify SPI DMA initialization
5
@d0452eb
12/14/16 06:46:18 |
Sebastian Huber |
bsp/atsam: Simplify SPI interrupt handler
5
@c78928f
12/14/16 06:44:34 |
Sebastian Huber |
bsp/atsam: Remove superfluous irq field
5
@9035630f
12/14/16 06:43:25 |
Sebastian Huber |
bsp/atsam: Remove duplicate SPI register field
5
@62e1e0ff
12/14/16 06:37:49 |
Sebastian Huber |
bsp/atsam: Simplify SPI initialization
5
@3afa95b
12/14/16 06:25:49 |
Sebastian Huber |
bsp/atsam: Hide details of SPI driver
5
@1505eca5
12/14/16 06:18:11 |
Sebastian Huber |
bsp/atsam: Align SPI API with PIO_Configure()
5
@5dd02e9
12/13/16 14:49:09 |
Sebastian Huber |
bsp/atsam: Avoid to power on/off the SPI module
5
@f74e2959
12/13/16 14:18:00 |
Sebastian Huber |
bsp/atsam: Speed up SPI DMA transfer start
5
@0396f60
12/13/16 13:28:57 |
Sebastian Huber |
bsp/atsam: Optimize transfer setup checks
5
@3417070d
12/13/16 13:28:32 |
Sebastian Huber |
bsp/atsam: No timeout for SPI DMA transfers
5
@c6eead1
12/07/16 06:20:38 |
Chris Johns |
libdl: Add C++ exception support to loaded modules.
This has been …
5
@6a9282d
12/09/16 09:49:49 |
Sebastian Huber |
Rename is_internal to always_set_to_false
Update #2825.
5
@b6606e8
12/08/16 15:41:30 |
Sebastian Huber |
score: Remove fatal is internal indicator
The fatal is internal …
5
@28fda62
12/05/16 03:53:54 |
Chris Johns |
testsuite: Add test states to the testsuit configuration files.
5
@f65dcc71
12/02/16 12:10:31 |
Sebastian Huber |
score: Fix ARM and PowerPC context initialization
Update #2751.
5
@e629076
11/29/16 22:19:05 |
Chris Johns |
libdebugger: Build for ARM's without a CP15.
5
@de7b174e
11/15/16 18:19:39 |
joel |
Remove sparc/sis BSP.
closes #2810.
5
@8fd465e
11/24/16 22:45:35 |
Chris Johns |
arm/zynq: Wait for the UART TX FIFO to empty on reset.
5
@6a1b9e4
11/22/16 09:13:27 |
Sebastian Huber |
sparc: Optimize _ISR_Handler()
Use _Thread_Do_dispatch() instead of …
5
@9bf9068
11/25/16 18:21:44 |
martinerikwerner.aac |
or1k: Avoid multiple iterations over cache
Previously, if the cache …
5
@a59dd5c
11/25/16 18:21:43 |
or1k: Remove secondary functions in cache manager
Move the code of …
5
@3b4ddaf
11/25/16 18:21:42 |
or1k: Avoid excessive ISR toggle in cache manager
Previously …
5
@4dcaa48
11/25/16 18:21:41 |
or1k: Indent & comment fix in cache.c
* Fix indentation of variable …
5
@e639c026
11/25/16 18:21:40 |
or1k: Add functions for entire cache operations
Add functions for …
5
@562b0a0
11/24/16 09:49:17 |
Sebastian Huber |
bsps/arm: Add Cortex-M DWT CPU counter
5
@4b5ff47
11/23/16 15:15:13 |
Sebastian Huber |
score: Fix interrupt profiling
Callers of _Thread_Do_dispatch() must …
5
@01ac1db
11/24/16 07:32:01 |
Sebastian Huber |
powerpc: Fix interrupt profiling for e6500
5
@31427276
11/23/16 06:47:00 |
Sebastian Huber |
bsp/lpc23xx_tli800: Disable tar01 test
Close #2824.
5
@f730c25b
11/21/16 09:37:18 |
Sebastian Huber |
powerpc/mpc5xx: Rename CPU_Interrupt_frame
The MPC5XX support uses a …
5
@7ce60b3
11/14/16 14:23:40 |
Sebastian Huber |
powerpc: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@c11ac2d5
11/14/16 13:42:56 |
Sebastian Huber |
sparc: Use Per_CPU_Control::isr_dispatch_disable
Update #2751.
5
@d5e073c
11/11/16 13:37:51 |
Sebastian Huber |
score: Allow interrupts during thread dispatch
Use a …
5
@2599c8e
11/14/16 11:06:46 |
Sebastian Huber |
powerpc: Add up to date CPU_Interrupt_frame
Rename ppc_exc_min_frame …
5
@bf4fdb1
11/11/16 10:31:13 |
Sebastian Huber |
powerpc: Move legacy CPU_Interrupt_frame
The only remaining user of …
5
@40d592eb
11/11/16 10:25:37 |
Sebastian Huber |
bsps/powerpc: Avoid use of CPU_Interrupt_frame
This type is not …
5
@c539a865
11/14/16 10:34:54 |
Sebastian Huber |
sparc: Move CPU_Interrupt_frame related defines
Move …
5
@427dcee
11/11/16 10:17:02 |
Sebastian Huber |
sparc: Rename CPU_Minimum_stack_frame
Rename SPARC-specific …
5
@d18560a
11/11/16 10:16:33 |
Sebastian Huber |
sparc64: Rename CPU_Minimum_stack_frame
Rename SPARC64-specific …
5
@8ef8a32
11/11/16 09:48:14 |
Sebastian Huber |
bsps/mips: Use <libcpu/isr_entries.h>
Avoid duplicate …
5
@04bd261
11/13/16 14:18:58 |
Sebastian Huber |
arm: Use TPIDRPRW for current per-CPU control
Use the previously …
5
@bb5d97f3
11/17/16 13:56:53 |
Christian.Mauderer |
bsp/atsamv: Make size of nocache-memory configurable.
5
@38a1449
11/09/16 13:59:33 |
Sebastian Huber |
powerpc: Add _CPU_Get_current_per_CPU_control()
Add …
5
@1f5bee3
11/07/16 15:54:40 |
Sebastian Huber |
score: Add and use Thread_Control::is_idle
Update #2797.
5
@6cb234f
11/07/16 08:30:17 |
Sebastian Huber |
bsp/qoriq: Remove duplicate qoriq_gpio definition
Close #2800.
5
@11ae6f9
11/03/16 17:49:12 |
Tim Cussins |
virtex4, virtex5 bsp.h: Use BSP_INTERRUPT_STACK_SIZE not user space …
5
@0df50a6c
10/03/16 15:59:47 |
joel |
m68k/mrm332/make/custom/mrm332-testsuite.tcfg: Add dl05
5
@c2798633
10/03/16 15:59:31 |
joel |
m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg: Add dl05
5
@fbf4543
10/03/16 15:59:05 |
joel |
m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add dl05
5
@710302ae
10/03/16 15:58:45 |
joel |
mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg: Add dl05
5
@c7589640
08/08/16 16:33:21 |
joel |
moxiesim/bsp_specs: Add crtbegin/end to fix link issues
5
@fac8a3a
11/02/16 09:01:36 |
Sebastian Huber |
bsps/sparc: Fix copy of initialized data
The text and data sections …
5
@fc718cb8
10/22/16 15:46:56 |
jcmarsh |
Updated xilinx_zynq_a9_qemu bsp README instructions.
5
@f94155b
10/18/16 22:22:57 |
Sebastian Huber |
bsps/sparc: Add interrupt controller registers
5
@9361412
10/18/16 22:21:21 |
Sebastian Huber |
bsp/leon3: Avoid implicit integer conversions
5
@24fe213
10/17/16 12:36:49 |
alexander.krutwig |
atsam: multiple messages on one cs low level
5
@20625a5
10/12/16 07:47:00 |
pisa |
bsps/i386: use Pentimum instructions for pc586 and pc686 builds.
When …
5
@6b54dcb
10/12/16 07:40:41 |
pisa |
bsps/i386: replace global interrupt disable by SMP build supporting …
5
@f45ddeea
10/13/16 05:51:55 |
Sebastian Huber |
bsp/atsamv: Fix typo
5
@facebbb
10/02/16 10:19:12 |
pisa |
bsps/i386: Separate variable for i8259 IRQs disable due to in progress …
5
@282de10
10/11/16 08:42:15 |
Sebastian Huber |
bsp/qoriq: Add GPIO register map
5
@00bac95
10/11/16 06:25:39 |
Sebastian Huber |
bsps/sparc: Support GR740 GPIO
5
@a899549e
10/05/16 12:04:23 |
Sebastian Huber |
bsp/atsam: Provide default buffer counts
5
@10eedb9f
10/05/16 12:04:07 |
Sebastian Huber |
bsp/atsam: Fix PHY detection
5
@8ace7ee4
09/23/16 06:17:00 |
Sebastian Huber |
bsp/mvme147*: Fix linker issue
The GNU linker does not allow a …
5
@bbe8833
09/23/16 06:03:41 |
Sebastian Huber |
bsps/m68k: Add libatomic support to some bsp_specs
Update #2695.
5
@d6e58a0
09/23/16 04:44:08 |
Sebastian Huber |
bsps/m68k: Fix linker command file
Prevent garbage collection of …
5
@425f6cfa
09/22/16 07:56:06 |
pisa |
arm/tms570: document BSP setup with included hardware initialization.
5
@aae17bf3
09/22/16 07:48:26 |
pisa |
arm/tms570: update bootstrap generated preinstall.am
5
@98b6874
09/22/16 07:23:17 |
pisa |
arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare …
5
@29430a3
09/22/16 07:50:59 |
pisa |
arm/tms570: include hardware initialization and selftest based on Ti …
5
@5746f10
09/12/16 08:46:58 |
pisa |
arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.
5
@a396ed4
09/17/16 15:09:11 |
pisa |
bsps/arm: Export bsp_start_hook_0_done symbol from ARM start.S.
The …
5
@8c83cbc
08/04/16 21:32:06 |
pisa |
classic networking: do not reference BSP_irq_enabled_at_i8259s which …
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@0ab86d09
09/13/16 14:32:51 |
alexander.krutwig |
bsp/atsam: Add SPI bus driver
5
@c186de5c
09/14/16 12:46:03 |
alexander.krutwig |
bsp/atsam: Use normal memory for QSPI flash area
This is a …
5
@5eb769ca
09/08/16 21:40:21 |
pisa |
arm/raspberrypi: define bsp_reset to restart board by watchdog.
5
@275032b
09/08/16 07:31:47 |
Sebastian Huber |
powerpc: Fix SMP context switch
We need the unmodified r4 for …
5
@d4160618
09/07/16 03:59:16 |
Chris Johns |
testsuite: Add libdl/dl05 reloc test.
5
@531924d
09/08/16 05:24:29 |
Sebastian Huber |
bsp/raspberrypi: Rename file
5
@5d369c85
09/03/16 12:10:52 |
pisa |
arm/raspberrypi: use GPU/system timer as clock source.
It has …
5
@40f49d1
09/03/16 12:04:16 |
pisa |
arm/raspberrypi: correct and extend definitions for GPU timer.
5
@df2ee9d
09/07/16 18:28:33 |
pisa |
arm/raspberrypi: basic BCM2836 SMP implementation.
The BSP support is …
5
@38a5385
09/01/16 19:55:51 |
pisa |
arm/raspberrypi: propagate number of configured CPUs into linker script.
5
@dfbedf3
09/01/16 19:40:09 |
pisa |
arm/raspberrypi: rename linkcmds to linkcmds.in to allow their …
5
@4c53be1
09/03/16 01:37:36 |
pisa |
arm/raspberrypi: more definitions of BCM2836 core local peripherals.
5
@bf62c39
09/03/16 00:26:10 |
krohini1593 |
arm/raspberrypi: include definitions of BCM2836 SMP mailboxes.
5
@6e6a77a6
09/02/16 23:59:21 |
pisa |
bsps/arm: reorganize CP15 code to allow clean and invalidate ARMv7 …
5
