Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @8c5707a   03/28/07 18:17:20 Joel Sherrill 2007-03-28 Joel Sherrill <joel@…> * Makefile.am: Modify to … 4.104.114.84.95
(edit) @166247f   03/28/07 18:15:49 Joel Sherrill 2007-03-28 Joel Sherrill <joel@…> * include/amba.h: Remove … 4.104.114.84.95
(edit) @d7cefbf6   03/28/07 18:15:06 Joel Sherrill 2007-03-28 Joel Sherrill <joel@…> * page.c: Redo print to … 4.104.114.84.95
(edit) @e4f62d9   03/28/07 18:08:38 Joel Sherrill 2007-03-28 Joel Sherrill <joel@…> PR 1233/bsps * … 4.104.114.84.95
(edit) @a185db7   03/28/07 18:03:38 Joel Sherrill 2007-03-28 Joel Sherrill <joel@…> PR 1232/bsps * … 4.104.114.84.95
(edit) @3041f69   03/26/07 22:28:07 Joel Sherrill 2007-03-26 Chris Johns <chrisj@…> * include/bsp.h: Terminate … 4.104.114.84.95
(edit) @82102a0   03/16/07 08:26:52 Thomas.Doerfler * startup/bspstart.c: set external clock to 0 for some boards to … 4.104.114.84.95
(edit) @bfdf5ebc   03/13/07 19:43:50 Joel Sherrill 2007-03-13 Joel Sherrill <joel@…> * include/bsp.h: Remove … 4.104.114.84.95
(edit) @cac81d1   03/12/07 11:18:49 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * console/uart.c, … 4.104.114.84.95
(edit) @e8d4bd3e   03/12/07 11:18:47 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * console/uarts.c, … 4.104.114.84.95
(edit) @0c0ae29   03/12/07 11:18:44 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * include/bsp.h, … 4.104.114.84.95
(edit) @688696e4   03/12/07 11:18:23 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * clock/clock.c, … 4.104.114.84.95
(edit) @a474e3c   03/12/07 11:18:19 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * include/coverhd.h, … 4.104.114.84.95
(edit) @e545bfa   03/12/07 11:18:16 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * console/console-io.c, … 4.104.114.84.95
(edit) @4b3756d7   03/12/07 11:18:06 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * console/console-io.c, … 4.104.114.84.95
(edit) @58e37d48   03/12/07 11:17:57 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * clock/ckinit.c, … 4.104.114.84.95
(edit) @e5ef747   03/12/07 11:17:51 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * clock/clockdrv.c, … 4.104.114.84.95
(edit) @46432d4   03/12/07 11:17:35 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * include/coverhd.h: … 4.104.114.84.95
(edit) @aa253a4   03/12/07 11:17:27 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * irq/irq_init.c: … 4.104.114.84.95
(edit) @c90d07c   03/12/07 11:17:23 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * clock/clock.c, … 4.104.114.84.95
(edit) @93f4a906   03/12/07 11:17:07 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @df2837ff   03/12/07 11:16:53 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @d7f31215   03/12/07 11:16:38 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @bbe4090   03/12/07 11:16:29 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * mpc6xx/mmu/mmuAsm.S: … 4.104.114.84.95
(edit) @3f0cfc56   03/11/07 15:24:18 Joel Sherrill 2007-03-11 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @47a5cf5   03/11/07 15:22:59 Joel Sherrill 2007-03-11 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @e523ebea   03/11/07 15:22:05 Joel Sherrill 2007-03-11 Joel Sherrill <joel@…> * shared/bspstart.c: … 4.104.114.84.95
(edit) @5d3d6d1a   03/10/07 15:53:53 Joel Sherrill 2007-03-10 Joel Sherrill <joel@…> PR 1227/bsps * … 4.104.114.84.95
(edit) @9f59157   03/09/07 14:59:00 Joel Sherrill 2007-03-09 Joel Sherrill <joel@…> * bootcard.c: Change XXX … 4.104.114.84.95
(edit) @3644d07   02/16/07 02:01:22 Ralf Corsepius 2007-02-16 Ralf Corsepius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @7be0ca2   02/09/07 14:53:16 Ralf Corsepius 2007-02-09 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @936362b3   02/06/07 18:23:00 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * smc/smc.c: … 4.104.114.84.95
(edit) @ccc8fc85   02/06/07 10:47:51 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c1b34d5   01/31/07 04:02:52 strauman 2007-01-30 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @32a0058   01/31/07 03:57:55 strauman 2007-01-29 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @9b28179d   01/31/07 03:50:13 strauman 2007-01-30 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @6623984   01/31/07 03:47:22 strauman 2007-01-30 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @1102f897   01/31/07 03:43:12 strauman 2007-01-30 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @a771462e   01/31/07 03:40:58 strauman 2007-01-30 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @668d44b   01/31/07 03:36:44 strauman 2007-01-30 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @a9a3e75   01/29/07 05:28:45 Ralf Corsepius 2007-01-29 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ea6c5d8   01/29/07 05:25:50 Ralf Corsepius 2007-01-29 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @40d5b64b   01/29/07 04:32:10 Ralf Corsepius 2007-01-29 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f2a90594   01/26/07 08:26:16 Ralf Corsepius 2007-01-26 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @33997695   01/26/07 08:22:26 Ralf Corsepius 2007-01-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @973bebfb   01/26/07 08:22:16 Ralf Corsepius Use MKDIR_P instead of mkdir_p. 4.104.114.84.95
(edit) @565a65e5   01/23/07 21:49:00 Thomas.Doerfler fixed typo in uart error handling function 4.104.114.84.95
(edit) @6200dc9   01/22/07 23:02:02 Joel Sherrill Formatting. 4.104.114.84.95
(edit) @3d14a45   01/21/07 18:25:31 Thomas.Doerfler mproved gen5200 MSCAN driver fixed synchronization bug between ata.c … 4.104.114.84.95
(edit) @bc2083c1   01/19/07 23:01:21 strauman * mvme5500/Makefile.am, mvme5500/preinstall.am, * … 4.104.114.84.95
(edit) @7996b53   01/19/07 22:58:08 strauman * Makefile.am, * ep1a/Makefile.am, ep1a/preinstall.am, * … 4.104.114.84.95
(edit) @1687b05   01/19/07 22:54:46 strauman * vmeUniverse/VME.h: moved VME.h from libbsp/powerpc/shared/vme to … 4.104.114.84.95
(edit) @6f457e8   01/19/07 22:51:42 strauman 2007-01-19 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @adac8ab   01/17/07 06:33:29 strauman 2007-01-16 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @531aa81   01/17/07 05:57:29 strauman 2007-01-16 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @f774fc06   01/17/07 05:45:14 strauman 2007-01-16 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @b7180c8b   01/08/07 11:05:12 Ralf Corsepius 2007-01-08 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @504d23c   01/08/07 11:04:32 Ralf Corsepius New. 4.104.114.84.95
(edit) @63a88eb   01/08/07 08:43:28 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @972fa2c   12/15/06 09:31:22 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * smc/smc.c: … 4.104.114.84.95
(edit) @b8d28b5   12/15/06 09:31:10 Ralf Corsepius Comment out sm_status (unused). 4.104.114.84.95
(edit) @b6ffe83   12/15/06 07:33:10 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @e281050   12/15/06 07:32:58 Ralf Corsepius Remove bogus casts. 4.104.114.84.95
(edit) @de7e68db   12/15/06 07:31:14 Ralf Corsepius Use ioctl_command_t as arg to ioctl functions. 4.104.114.84.95
(edit) @038e9fb9   12/15/06 07:30:24 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @bb2c924   12/15/06 07:27:36 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0c72fd6   12/15/06 07:26:43 Ralf Corsepius Remove K'n'R macros. 4.104.114.84.95
(edit) @20777a5e   12/15/06 06:00:10 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ff73cf6   12/15/06 06:00:03 Ralf Corsepius Use ioctl_command_t as arg in ioctl-functions. 4.104.114.84.95
(edit) @18c0e30   12/15/06 05:56:01 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @cdf41adb   12/15/06 05:53:50 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @bb2a2253   12/15/06 05:48:16 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @7a5265ff   12/15/06 05:48:07 Ralf Corsepius Use ioctl_command_t. 4.104.114.84.95
(edit) @9994f29   12/15/06 05:46:15 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2a0951e5   12/15/06 05:44:51 Ralf Corsepius 2006-12-15 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @215e019   12/15/06 04:37:55 strauman * startup/bspstart.c: Changed BSP_installVME_isr() so that the … 4.104.114.84.95
(edit) @0c3167b   12/14/06 23:13:07 strauman * m68k/mcf5282/include/mcf5282.h: added may_alias attribute to … 4.104.114.84.95
(edit) @fd8f417   12/14/06 23:11:08 strauman 2006-12-14 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @7c3b2dd3   12/14/06 12:22:49 Joel Sherrill Fixed line length -- must be < 80. 4.104.114.84.95
(edit) @0efdeff   12/14/06 05:45:58 Ralf Corsepius 2006-12-14 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2bced8f   12/14/06 05:45:51 Ralf Corsepius Remove unused var. 4.104.114.84.95
(edit) @60b8e96   12/13/06 22:03:42 strauman * mvme5500/Makefile.am, mvme5500/preinstall.am: need to install … 4.104.114.84.95
(edit) @ff221cf4   12/13/06 21:53:54 strauman 2006-12-13 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @de8174fe   12/13/06 20:50:20 strauman 2006-12-13 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @afd4c7b   12/13/06 20:04:05 strauman * vmeUniverse/vme_am_defs.h: Added address modifiers for 2eVME. Added … 4.104.114.84.95
(edit) @460cd5b7   12/13/06 14:46:41 Joel Sherrill 2006-12-13 Joel Sherrill <joel@…> PR 1190/bsps * … 4.104.114.84.95
(edit) @0ab63e50   12/13/06 14:43:44 Ralf Corsepius 2006-12-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @71ce7e7   12/13/06 12:35:01 Joel Sherrill 2006-12-13 Alexey Shamrin <shamrin@…> PR 1189/bsps * … 4.104.114.84.95
(edit) @6b1e9217   12/12/06 14:48:05 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @f1d96dbd   12/12/06 14:47:57 Ralf Corsepius Add RTEMS_AMPOLISH3. 4.104.114.84.95
(edit) @34e7be2   12/12/06 10:43:30 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0b933d6a   12/12/06 10:26:29 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ec76139c   12/12/06 10:26:18 Ralf Corsepius Use uint32_t instead of unsigned32. 4.104.114.84.95
(edit) @4ce019ce   12/12/06 10:24:26 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1408ea8d   12/12/06 10:24:16 Ralf Corsepius Use uint32_t instead of rtems_unsigned32/unsigned32. 4.104.114.84.95
(edit) @b8e42a76   12/12/06 10:22:18 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @fcb0cd46   12/02/06 06:06:55 Ralf Corsepius 2006-12-02 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @fe6f68c   11/30/06 16:05:50 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @43ea369   11/30/06 02:28:49 strauman * vmeUniverse/vmeTsi148.h: user now must define a symbol for the … 4.104.114.84.95
(edit) @c73ba8b5   11/20/06 05:51:08 Ralf Corsepius Regenerate. 4.104.114.84.95
