Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @69537ca9   01/12/00 16:38:56 Joel Sherrill Patch rtems-rc-20000104-16.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @737a599   01/12/00 16:05:58 Joel Sherrill Patch rtems-rc-20000104-15.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @76c2b35   01/11/00 19:09:24 Joel Sherrill File removed as it was not being used. 4.104.114.84.95
(edit) @0dd1d44   01/11/00 17:34:20 Joel Sherrill Removed old hack of using Configuration Table entry … 4.104.114.84.95
(edit) @86c9eb0   01/11/00 14:57:41 Joel Sherrill Bug fix from Wayne Bullaughey <wayneb@…> to use the … 4.104.114.84.95
(edit) @0f59d63f   01/10/00 21:38:43 Joel Sherrill Now automake generated. 4.104.114.84.95
(edit) @710f76a   01/10/00 21:37:57 Joel Sherrill Added mpc6xx/timer/Makefile. 4.104.114.84.95
(edit) @01ab7019   01/10/00 21:36:34 Joel Sherrill Accidentally deleted. 4.104.114.84.95
(edit) @119204d8   01/10/00 20:40:41 Joel Sherrill Removed warning by changing %eax -> %ax as source of move to segment … 4.104.114.84.95
(edit) @f9bcb58   01/10/00 20:12:11 Joel Sherrill Corrected compilation problem in lgdt instruction. 4.104.114.84.95
(edit) @f4d21dd   01/10/00 19:07:40 Joel Sherrill Added include of <bsp/irq.h> per Jay Kulpinski <jskulpin@…>. 4.104.114.84.95
(edit) @f983d57   01/10/00 18:16:59 Joel Sherrill Patch rtems-rc-20000104-14.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @362ec23e   01/10/00 18:10:59 Joel Sherrill Patch rtems-rc-20000104-12.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @94a86c40   01/10/00 15:18:20 Joel Sherrill Per suggestions of Eric Valette <valette@…> and Jay … 4.104.114.84.95
(edit) @6e7b6ca   01/10/00 15:03:28 Joel Sherrill Fixed unterminated comment spotted by eagle eye Ralf Corsepius … 4.104.114.84.95
(edit) @bc2f04f   01/10/00 14:50:45 Joel Sherrill Patch rtems-rc-20000104-13.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @5fa14794   01/10/00 14:31:16 Joel Sherrill Patch rtems-rc-20000104-11.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @7068e246   01/10/00 14:29:44 Joel Sherrill Patch rtems-rc-20000104-10.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @53ab4823   01/10/00 14:23:56 Joel Sherrill Patch rtems-rc-20000104-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4200321a   01/10/00 14:17:28 Joel Sherrill Patch rtems-rc-20000104-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @1597ab4a   01/10/00 14:17:27 Joel Sherrill Patch rtems-rc-20000104-8.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @59909bf   01/10/00 14:09:12 Joel Sherrill Patch rtems-rc-20000104-6.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @d0a8b4b8   01/10/00 14:07:00 Joel Sherrill Patch rtems-rc-20000104-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @82f1f6d   01/10/00 14:06:59 Joel Sherrill Patch rtems-rc-20000104-6.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0cbfa283   01/10/00 14:04:50 Joel Sherrill Patch rtems-rc-20000104-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @1e562da6   01/10/00 14:04:49 Joel Sherrill Patch rtems-rc-20000104-5.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @49e05f41   01/10/00 14:03:32 Joel Sherrill Patch rtems-rc-20000104-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @10726095   01/10/00 13:59:35 Joel Sherrill Patch rtems-rc-20000104-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @94608578   01/10/00 13:56:35 Joel Sherrill Patch rtems-rc-20000104-2.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @338f1dc   01/10/00 13:26:00 Joel Sherrill Patch from Eric Valette <valette@…> that makes sure the … 4.104.114.84.95
(edit) @1d54d3b   01/07/00 20:39:45 Joel Sherrill Renaming mcp750 to motorola_shared since that is the basis for both … 4.104.114.84.95
(edit) @35d9acb3   01/07/00 18:52:14 Joel Sherrill Patch from John M. Mills <jmills@…> to correct the baseline … 4.104.114.84.95
(edit) @c3538f3   01/07/00 14:52:48 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> which corrects the … 4.104.114.84.95
(edit) @0ff37e68   01/07/00 14:47:02 Joel Sherrill Patch rtems-rc-20000104-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0312d81f   01/05/00 23:01:05 Joel Sherrill Fixed comment thanks to John M. Mills <jmills@…>. 4.104.114.84.95
(edit) @3a8b95e   01/05/00 21:32:57 Joel Sherrill Spacing corrected. 4.104.114.84.95
(edit) @66fe6be6   01/05/00 18:40:20 Joel Sherrill patch from Eric Norum <eric@…> as follows: At the … 4.104.114.84.95
(edit) @69405459   01/05/00 18:40:14 Joel Sherrill Patch from Eric Norum <eric@…> as follows: At the … 4.104.114.84.95
(edit) @afe8c1b6   01/04/00 13:49:05 Joel Sherrill Added shared version of this file. 4.104.114.84.95
(edit) @7b0ff008   01/04/00 13:48:48 Joel Sherrill Made to compile again. 4.104.114.84.95
(edit) @393be8e   01/03/00 20:43:29 Joel Sherrill Fixed path to shared/include/coverhd.h. 4.104.114.84.95
(edit) @0af1b73f   01/03/00 17:27:06 Joel Sherrill Patch from Eric Norum <eric@…>: In another attempt to … 4.104.114.84.95
(edit) @110136a   01/03/00 16:53:07 Joel Sherrill Updated times. 4.104.114.84.95
(edit) @205d5645   01/03/00 16:44:04 Joel Sherrill Patch from John Mills <jmills@…> to correct some cut and paste … 4.104.114.84.95
(edit) @6b7cf9f   01/03/00 15:39:06 Joel Sherrill Patch rtems-rc-19991203-12.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @b84176b   01/03/00 15:36:18 Joel Sherrill Do not explicitly list pieces from libcpu used. 4.104.114.84.95
(edit) @32f19fb3   01/03/00 14:38:47 Joel Sherrill Share align_h.S from ppc403. VPATH was not picking it up. Discovered … 4.104.114.84.95
(edit) @e07b6868   01/03/00 14:14:37 Joel Sherrill Added tm27 stuff. 4.104.114.84.95
(edit) @95273a6   01/03/00 14:06:42 Joel Sherrill Combination of coverhd.h cleanup and MVME23xx/MCP750 patch from Eric … 4.104.114.84.95
(edit) @d5c4681e   01/03/00 14:04:22 Joel Sherrill Use shared coverhd.h. 4.104.114.84.95
(edit) @2116e33   12/21/99 20:29:57 Joel Sherrill Reverted the delay logic. 4.104.114.84.95
(edit) @ed46b47   12/21/99 20:29:40 Joel Sherrill Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to … 4.104.114.84.95
(edit) @56018097   12/21/99 20:28:13 Joel Sherrill Now use coverhd.h out of the libbsp/shared directory. 4.104.114.84.95
(edit) @0d6f0b4   12/21/99 20:10:04 Joel Sherrill Now use shared coverhd.h 4.104.114.84.95
(edit) @5d807b5   12/21/99 17:06:31 Joel Sherrill New files. 4.104.114.84.95
(edit) @a3ba9f98   12/21/99 17:05:15 Joel Sherrill New file. 4.104.114.84.95
(edit) @8437abd4   12/21/99 16:56:31 Joel Sherrill Removed as part of moving this driver to libchip. 4.104.114.84.95
(edit) @400c552   12/21/99 16:20:38 Joel Sherrill Removing Makefile.in and adding Makefile.am. These were missed in … 4.104.114.84.95
(edit) @fb16fed   12/21/99 15:25:05 Joel Sherrill Patch rtems-rc-19991203-10.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @9ba1f0a   12/21/99 15:04:48 Joel Sherrill Patch rtems-rc-19991203-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @35d7b15   12/21/99 14:41:43 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0fe48346   12/21/99 14:34:30 Joel Sherrill Patch rtems-rc-19991203-7.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @8b91282   12/21/99 14:27:52 Joel Sherrill Patch rtems-rc-19991203-5.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @947c27aa   12/16/99 14:30:34 Joel Sherrill Spelling error corrected. 4.104.114.84.95
(edit) @e8918ec   12/13/99 22:12:03 Joel Sherrill Patch from Eric Norum <eric@…> to change to gen68360 clock … 4.104.114.84.95
(edit) @c629812   12/13/99 22:10:45 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @da8ae79b   12/13/99 21:21:31 Joel Sherrill Warning removal patch from Philip A. Prindeville <philipp@…>. 4.104.114.84.95
(edit) @1c98d28   12/13/99 20:35:09 Joel Sherrill Patch rtems-19991203.sh2.diff from John M. Mills <jmills@…> … 4.104.114.84.95
(edit) @f9669ce5   12/13/99 20:06:27 Joel Sherrill Patch from Silverio Diquigiovanni <silverio.di@…> to correct TPC … 4.104.114.84.95
(edit) @5dae90a   12/13/99 17:37:25 Joel Sherrill Patch rtems-rc-19991203-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @ad0c286   12/13/99 16:02:57 Joel Sherrill Patch rtems-rc-19991203-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @fa178d49   12/13/99 15:57:41 Joel Sherrill Patch rtems-rc-19991203-3.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @d9230ea   12/13/99 14:49:38 Joel Sherrill Added RTEMS_IO_ERROR. 4.104.114.84.95
(edit) @49be66d   12/13/99 14:48:58 Joel Sherrill Now builds and installs properly. 4.104.114.84.95
(edit) @76c356f   12/03/99 15:46:17 Joel Sherrill Patch from Aleksey (Quality Quorum <qqi@…>) to change the … 4.104.114.84.95
(edit) @eb17041   12/03/99 14:01:11 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @ad9a21a   12/03/99 13:53:01 Joel Sherrill New file. 4.104.114.84.95
(edit) @a0a6f67f   12/03/99 13:48:53 Joel Sherrill Added more timing information. 4.104.114.84.95
(edit) @5707fe9   12/03/99 13:46:13 Joel Sherrill New file based on information from <valette@…>. 4.104.114.84.95
(edit) @5a820308   12/03/99 13:42:34 Joel Sherrill Modification from Emmanuel Raguet <raguet@…> to merge the … 4.104.114.84.95
(edit) @5ea0bd37   12/03/99 13:14:08 Joel Sherrill Patch from Rosimildo DaSilva? <rdasilva@…> for Cygwin to … 4.104.114.84.95
(edit) @43283456   12/02/99 17:45:14 Joel Sherrill Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @3a96054   12/02/99 14:58:38 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @acc25ee   12/02/99 14:31:19 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @e4ab88f   12/02/99 14:00:01 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @48bfd992   11/30/99 19:58:02 Joel Sherrill Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h. … 4.104.114.84.95
(edit) @1563d8c   11/30/99 16:52:21 Joel Sherrill Removed duplicate definition of rtems_filesystem_umask. 4.104.114.84.95
(edit) @79f2e19   11/30/99 13:58:59 Joel Sherrill Split from console.c to eliminate dependencies. 4.104.114.84.95
(edit) @e4b25c4   11/30/99 13:46:28 Joel Sherrill Corrected so they would compile with POSIX disabled. 4.104.114.84.95
(edit) @1d9a2fc   11/29/99 15:45:11 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @3dfe0b27   11/29/99 15:10:30 Joel Sherrill Fixed spacing. 4.104.114.84.95
(edit) @49da88c   11/23/99 15:53:09 Joel Sherrill Patch rtems-rc-19991117-16.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @3772e2c   11/23/99 14:54:42 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @7e642ba   11/22/99 19:27:13 Joel Sherrill Patch rtems-rc-19991117-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @6b910bd   11/22/99 14:27:04 Joel Sherrill Use PGM consistently. 4.104.114.84.95
(edit) @c99d395   11/22/99 14:26:36 Joel Sherrill Made it agree on PGM versus PGM/PGMS. 4.104.114.84.95
(edit) @561e4ff6   11/22/99 14:03:16 Joel Sherrill Adding files missed by earlier merger of SH-2. 4.104.114.84.95
(edit) @875fbdbb   11/22/99 13:48:10 Joel Sherrill Added files missed by previous merger of SH-2 port. 4.104.114.84.95
(edit) @b22a19e   11/22/99 13:46:50 Joel Sherrill Adding files not added as part of merger of SH2 port. 4.104.114.84.95
(edit) @27ea47c   11/22/99 13:45:55 Joel Sherrill Removed unneeded directory. 4.104.114.84.95
