@4940dc2a
04/03/17 21:11:33 |
joel |
mcf52235-testsuite.tcfg: Add linpack
5
@f570590c
04/03/17 20:22:13 |
joel |
gensh1-testsuite.tcfg: Add linpack
5
@a66a8934
04/03/17 20:14:51 |
joel |
simsh*-testsuite.tcfg: Add linpack
5
@a5b885d
04/03/17 20:14:18 |
joel |
gensh2-testsuite.tcfg: Add linpack
5
@d2a45a58
03/23/17 09:07:52 |
Sebastian Huber |
bsp/qoriq: Fix L1 cache flush
5
@f6e793a2
04/03/17 08:05:51 |
Sebastian Huber |
bsp/qoriq: Adjust MMU config only once
5
@2ba996fa
03/23/17 09:07:22 |
Sebastian Huber |
bsp/qoriq: Add post-link hook
5
@1301468
04/03/17 10:51:51 |
Sebastian Huber |
bsps: Fix baud settings
Update #2897.
5
@cd3d747
03/27/17 06:01:38 |
Sebastian Huber |
arm: Optimize context switch
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to …
5
@af5bbd3
03/27/17 12:20:56 |
Sebastian Huber |
bsp/qoriq: Regenerate preinstall.am
5
@bd7f099
03/27/17 11:53:01 |
Sebastian Huber |
bsp/tms570: Use shared benchmark timer
5
@b8e97e5
03/27/17 11:52:35 |
Sebastian Huber |
bsps: Add simple CPU counter benchmark timer
5
@e2191d6c
03/27/17 11:21:59 |
Sebastian Huber |
bsp/tms570: Simplify CPU counter support
Only touch the cycle counter …
5
@0a6a2a7b
03/27/17 11:20:20 |
Sebastian Huber |
bsps/arm: Add Performance Monitors Extension
5
@de9f326
03/27/17 10:09:21 |
Sebastian Huber |
bsp/tms570: Simplify <bsp.h>
5
@b7262b2
03/27/17 10:08:19 |
Sebastian Huber |
bsp/tms570: Remove OPERATION_COUNT define
This is the wrong place to …
5
@1c6926c1
03/21/17 19:39:48 |
kevin-kirspel |
termios: Synchronize with latest FreeBSD headers
Adding modified …
5
@c4b058ca
03/22/17 09:38:27 |
Sebastian Huber |
bsp/atsam: Fix DMA support of some drivers
5
@68929dca
03/09/17 22:12:52 |
joel |
libbsp/mips/shared/irq/i8259.c: Add include of rtems/bspIo.h
5
@a557f6c8
03/09/17 22:12:08 |
joel |
libbsp/shared/clock/clockdrv.c: Remove unneeded printk()
5
@a05b749
03/09/17 22:08:27 |
joel |
libbsp/malta/pci/pci.c: Correct printk() formats
5
@e026dbc5
03/09/17 22:07:55 |
joel |
libbsp/csb350/clock/clockdrv.c: Remove unneeded printk()
5
@b07eae90
03/09/17 20:55:59 |
joel |
libbsp/mips/shared/irq.c: Fix warnings
5
@dc95663e
03/09/17 13:14:42 |
Sebastian Huber |
bsp/tms570: Fix CPU counter frequency
The CPU counter runs with the …
5
@5ca634e9
03/09/17 12:23:54 |
Sebastian Huber |
bsp/tms570: Support printk() early
Allow use of printk() early in the …
5
@ce5bcc87
03/08/17 06:20:48 |
Sebastian Huber |
bsp/beagle: Fix warnings
5
@f25c798
03/07/17 13:57:09 |
Sebastian Huber |
bsp/smdk2410: Fix format warning
5
@f82e9af7
03/07/17 13:55:58 |
Sebastian Huber |
bsp/lpc176x: Fix integer to pointer warnings
5
@504a5822
03/07/17 13:53:15 |
Sebastian Huber |
bsps/umon: Fix format warnings
5
@65b63b2
03/07/17 13:40:45 |
Sebastian Huber |
bsp/altera-cyclone-v: Remove debug output
5
@2433a8ab
03/07/17 13:32:42 |
Sebastian Huber |
arm: Remove legacy execption support
5
@6584eb2
03/08/17 09:34:24 |
Sebastian Huber |
bsp/qoriq: Fix memory configuration
Take nocache section into account …
5
@9cd20cd
03/07/17 09:57:46 |
Sebastian Huber |
bsps: Provide <bsp/fdt.h> for every BSP
Add bsp_fdt_map_intr() …
5
@a11e1ff5
03/07/17 06:58:11 |
Sebastian Huber |
powerpc: Optimize AltiVec? context switch
Use r8 instead of r5 to …
5
@c6f76392
03/07/17 06:50:12 |
Sebastian Huber |
powerpc: Fix AltiVec? context switch
Update #2751.
5
@696b5b1e
03/06/17 13:37:43 |
Sebastian Huber |
bsp/beatnik: More verbose fatal extension
5
@b925ae7
03/06/17 10:10:06 |
Sebastian Huber |
bsp/beatnik: Update due to API changes
The device_t typedef is …
5
@49caf22
02/03/17 07:55:27 |
Daniel Hellstrom |
leon, grspw_pkt: fix overwrite protection when more than 32 devs
This …
5
@cc8a50ab
02/03/17 07:53:35 |
Daniel Hellstrom |
leon,grtm: ioctl() shouldn't access pointer before validated
This is …
5
@fec8288
01/23/17 15:45:48 |
Daniel Hellstrom |
leon, grspw_pkt: SMP support
The driver already was developed with …
5
@36fc8b18
02/24/17 11:54:01 |
Daniel Hellstrom |
leon, grspw_pkt: unregister ISR on close
5
@090016a
01/22/17 10:34:25 |
Daniel Hellstrom |
leon, grspw_pkt: ISR activate shutdown work only if errintr enabled
5
@029ce4d1
02/24/17 11:49:07 |
Daniel Hellstrom |
leon, grspw_pkt: fix descriptor table mem leak on grspw_close()
5
@1b559e3
01/22/17 10:30:04 |
Daniel Hellstrom |
leon, grspw_pkt: add missing GRSPW1 IP-core support
5
@94fb377b
01/22/17 14:58:18 |
Daniel Hellstrom |
leon, grspw_pkt: ISR RX/TX DMA interrupt source disable configurable
5
@8acfa94
01/22/17 14:43:17 |
Daniel Hellstrom |
leon, grpsw_pkt: set unique work-task name
5
@72ec13ef
01/22/17 14:35:27 |
Daniel Hellstrom |
leon, grspw_pkt: functions to support custom work-task
Added new …
5
@29c2304
01/22/17 14:03:51 |
Daniel Hellstrom |
leon, grspw_pkt: fix interrupt code ctrl bit declarations
5
@ab9b447
01/22/17 14:01:55 |
Daniel Hellstrom |
leon, grspw_pkt: added work-task configuration options
Following …
5
@f46f5f84
02/13/17 09:16:14 |
javier.jalle |
leon, grpci2: latency timer user configurable (default 64)
5
@0c23dd5
02/15/17 10:05:27 |
javier.jalle |
leon, gr740: fix device registration for GRPCI2 core
5
@73b06e64
01/31/17 09:14:29 |
javier.jalle |
leon, gr-cpci-leon4-n2x: small comment fix
5
@bb8e099
01/26/17 15:03:19 |
javier.jalle |
leon, grpci2: updated DMA descriptor layout
5
@d9d8dbd
01/26/17 14:37:34 |
javier.jalle |
leon, grpci2: fixed wrong bit layout
5
@a545ce26
01/26/17 14:31:17 |
javier.jalle |
leon, grpci2: added TIMEOUT interrupt
5
@89173ee9
01/26/17 10:36:52 |
javier.jalle |
bsps/sparc: Updated L2C registers
5
@ef94150f
04/12/16 11:53:42 |
Daniel Hellstrom |
leon, grspw_pkt: Added checks for special list cases
- Fixed …
5
@a7cc0da9
04/08/16 12:03:47 |
Daniel Hellstrom |
leon, grspw_pkt: fix stscfg cfg TimeCode? Int clr
Without this patch …
5
@0d31dcc
04/07/16 08:02:55 |
Daniel Hellstrom |
leon, grspw_pkt: split DMA sem into RX and TX sem
By introducing a …
5
@7701c37
04/07/16 07:36:37 |
Daniel Hellstrom |
leon, grspw_pkt: coding style fix
5
@77856f6
03/30/16 12:29:52 |
Daniel Hellstrom |
leon, grspw_pkt: allow user controlled DMA intr
The user has already …
5
@1ef9caa2
03/29/16 12:59:59 |
Daniel Hellstrom |
leon, grspw_pkt: support for reading tx/rx DMA queue
* Add support …
5
@eb5a42f6
03/23/16 09:45:26 |
Daniel Hellstrom |
leon, grspw_pkt: fixed device/dma closing
The user is now responsible …
5
@36c3fbbd
03/23/16 08:57:10 |
Daniel Hellstrom |
leon, grspw_pkt: coding style fixups
5
@9cb7e5d
03/22/16 15:41:51 |
Daniel Hellstrom |
leon, grspw_pkt: fixed and improved RX/TX wait
5
@57e1f4c3
03/22/16 15:07:51 |
Daniel Hellstrom |
leon, grspw_pkt: fixed error return path in dma_open
5
@ac7da5bc
03/22/16 14:51:13 |
Daniel Hellstrom |
leon, grspw_pkt: Manual handling of link status events
Added …
5
@49cf776e
03/22/16 14:37:36 |
Daniel Hellstrom |
leon, grspw_pkt: added link_ctrl options
Improved the link error …
5
@fad4324d
03/22/16 12:59:56 |
Daniel Hellstrom |
leon, grspw_pkt: added grspw_link_status_clr() to API
5
@c442647f
03/22/16 10:42:10 |
Daniel Hellstrom |
leon, grspw_pkt: code style clean-ups
5
@61cc024a
03/21/16 14:02:58 |
Daniel Hellstrom |
leon, gptimer: start/reset must take RS and IP into account
5
@b109add
03/21/16 12:50:27 |
Daniel Hellstrom |
leon: Fix ambapp_bus OCCAN device registeration order
NOTE that this …
5
@6ecad1d
10/27/15 11:41:50 |
maberg |
leon, grspw_pkt: Preserve DMA address enable at start.
The EN bit …
5
@a48bfc0f
10/20/15 09:25:06 |
maberg |
leon, grspw_pkt: Fixed txpkt flag for link error
There was a mixup …
5
@3395ca99
06/30/15 13:00:51 |
maberg |
leon, grspw_pkt: Fixed parameter check in grspw_dma_open()
5
@4431f7d
04/13/15 07:01:54 |
Daniel Hellstrom |
leon, gr1553b: RT status words register declarations fix
The fix does …
5
@d745297
01/02/15 12:18:33 |
Daniel Hellstrom |
leon, gr1553b: comment cleanup
5
@be66bbc1
01/02/15 12:16:10 |
Daniel Hellstrom |
leon, grspw: rxPktSize must set DMA RX max length
5
@c0dafd7b
03/02/17 15:53:45 |
Sebastian Huber |
bsp/qoriq: Use at most 2GiB of RAM
5
@d3f60af
03/02/17 14:25:34 |
Sebastian Huber |
bsp/qoriq: Adjust workspace according to FDT
5
@35136d3
03/02/17 14:20:52 |
Sebastian Huber |
bsp/qoriq: Use -O2
5
@62f16ad
03/02/17 14:20:19 |
Sebastian Huber |
bsp/qoriq: Enable linker garbage collection
5
@891b834f
03/02/17 14:17:35 |
Sebastian Huber |
bsp/qoriq: Do not overwrite configured baud
5
@805d7213
03/02/17 10:57:28 |
Sebastian Huber |
powerpc: Fix warnings
5
@09dab28d
03/02/17 10:54:58 |
Sebastian Huber |
powerpc: Fix interrupt thread dispatch
Update #2751.
5
@08d85992
03/01/17 10:31:57 |
Sebastian Huber |
bsps/powerpc: Fix warnings
5
@3398602
02/21/17 14:25:03 |
Sebastian Huber |
Add rtems_interrupt_server_request_submit()
This function may be used …
5
@11f0d52
02/22/17 08:01:40 |
Sebastian Huber |
bsp/xilinx-zynq: Add interrupt support to UART
5
@6b2fcc4
02/21/17 09:30:30 |
Sebastian Huber |
bsp/xilinx-zynq: Use new Termios device driver
5
@7318e7db
02/15/17 12:41:02 |
Sebastian Huber |
bsp/lpc24xx: Remove debug output
5
@6afeeda
02/15/17 12:39:02 |
Sebastian Huber |
5
@f6f764c1
02/15/17 12:28:02 |
Sebastian Huber |
5
@32292d5d
02/15/17 12:14:40 |
Sebastian Huber |
5
@bc744618
02/15/17 11:57:56 |
Sebastian Huber |
bsps/sparc: Fix warnings
5
@444cb5c
02/15/17 10:12:40 |
Sebastian Huber |
bsps/arm: Fix prototype
5
@73f8d93
02/15/17 10:09:50 |
Sebastian Huber |
5
@180107e9
01/30/17 10:33:31 |
Christian.Mauderer |
bsps/arm: Fix Cortex-M DWT CPU counter.
It is necessary to enable the …
5
@b43c2e8
01/24/17 14:40:31 |
kevin-kirspel |
Adding ARM VFP V2 support
5
@2f8f951b
01/23/17 13:51:27 |
kevin-kirspel |
bsp/lpc32xx: Fix interrupt controller suppport
Enable/Disable? vector …
5
@e8606d5b
01/20/17 13:21:29 |
Sebastian Huber |
bsp/beatnik: Remove superfluous check
Close #2874.
5
