@4a3db517
12/05/14 10:07:02 |
Sebastian Huber |
bsps/sparc: Fix trap table initialization
Fixes bug introduced with …
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@e870941
12/04/14 08:38:27 |
Sebastian Huber |
libmisc: More useful default configuration
The dummy.c was a de-facto …
4.115
@13d9029
12/04/14 17:21:11 |
Ben Gras |
beagle bsp: disable watchdog on am335x
On recent u-boots, the …
4.115
@038e1dba
12/03/14 23:56:39 |
dolezj21 |
i386: doxygen and comments related to VESA real mode framebuffer
4.115
@d78eac6
12/03/14 23:56:38 |
dolezj21 |
i386/pc386: cammelCase (struct and function names) to underscores, …
4.115
@adc1dbeb
12/04/14 14:15:52 |
Sebastian Huber |
bsp/leon3: Fix trap table initialization
4.115
@dff1803
12/03/14 10:35:52 |
Daniel Hellstrom |
SPARC: optimize IRQ enable & disable
* Coding style cleanups.
* Use …
4.115
@4081032
12/02/14 22:36:59 |
Ben Gras |
pc386 bsp fix for default mode
If USE_VBE_RM is 0, …
4.115
@fa4fe456
01/30/14 01:58:41 |
Nick Withers |
Move the flash size probe into bankValidate()
Previously, …
4.115
@2501814e
11/23/14 21:53:00 |
Jiri Gaisler |
sparc/leon2: LEON_Is_interrupt_masked for Leon2 in leon.h wrongly …
4.115
@291f30f
11/23/14 21:53:00 |
Jiri Gaisler |
sparc/leon3: LEON_Is_interrupt_masked for Leon3 in leon.h wrongly …
4.115
@0d3b5d47
11/11/14 14:18:01 |
Daniel Hellstrom |
SPARC: optimize window underflow trap
Save five instructions on …
4.115
@348d1812
05/27/14 09:15:46 |
Daniel Hellstrom |
SPARC: window overflow optimization
I see no need for waiting the 3 …
4.115
@dd309b1
12/01/14 03:55:23 |
Chris Johns |
m68k/mcf5235: GCC 4.9.2 generates invalid code for Init5235.
Move the …
4.115
@3a8566b7
11/27/14 13:03:34 |
Sebastian Huber |
bsp/qoriq: Delete empty header file
close #2062
4.115
@cbc433c7
11/25/14 07:40:20 |
Sebastian Huber |
bsps/arm: Add .nocache section
This section can be use to provide a …
4.115
@61f8d668
11/19/14 20:26:11 |
josh.oguin |
libbsp/shared/bspinit.c: Document assumption of NULL returned
4.115
@42fe0d3
11/25/14 07:36:58 |
Sebastian Huber |
bsps/arm: L2C 310 avoid infinite loops
4.115
@55db0e5
11/24/14 08:44:50 |
Sebastian Huber |
bsp/ngmp: Use -muser-mode GCC option
This option is necessary to use …
4.115
@b46a31e
11/23/14 15:48:17 |
Joel Sherrill |
leon2: include <rtems/ringbuf.h> not <ringbuf.h>
close #2113
4.115
@ff1c613
11/21/14 19:11:57 |
Joel Sherrill |
powerpc/haleakala: Fix warnings
4.115
@502609c8
11/21/14 17:15:22 |
Michael Hamel |
powerpc/haleakala: Add network driver
close 1405
4.115
@11925eef
11/21/14 07:49:57 |
Sebastian Huber |
Delete or rename MIN/MAX macros and defines
Include <sys/param.h> if …
4.115
@280f4ecc
11/20/14 16:05:02 |
Gedare Bloom |
autotools: regenerate preinstall.am for pc386
4.115
@067da5c
11/20/14 14:00:33 |
dolezj21 |
i386/pc386: VESA based frame buffer utilizing real mode interrupt 10h
4.115
@c5a74946
11/20/14 14:00:32 |
dolezj21 |
i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA …
4.115
@586c86c7
11/20/14 14:00:31 |
dolezj21 |
i386/shared/realmode_int: real mode interrupt interface
4.115
@74d2d940
11/20/14 14:00:30 |
dolezj21 |
i386: global descriptor table manipulation functions
4.115
@ec494ff
11/20/14 14:00:26 |
dolezj21 |
i386/pc386: configurable size of descriptor tables
4.115
@50440c0
11/19/14 14:30:24 |
Sebastian Huber |
bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs
4.115
@d1eb7b1
11/19/14 14:07:58 |
Sebastian Huber |
bsps/arm: L2C 310 drop exclusive cache support
Optimize locking.
4.115
@5f4f828
11/19/14 13:55:53 |
Sebastian Huber |
bsps/arm: L1 cache support changes
4.115
@e492e7f8
11/19/14 13:37:11 |
Sebastian Huber |
bsps/arm: L2C 310 compile-time errata 588369
4.115
@52d24b00
11/19/14 13:29:27 |
Sebastian Huber |
bsps/arm: L2C 310 compile-time errata 753970
4.115
@55741886
11/19/14 13:19:13 |
Sebastian Huber |
bsps/arm: L2C 310 exclusive config is fatal
4.115
@d53de34
11/19/14 13:08:44 |
Sebastian Huber |
bsps/arm: L2C 310 use l2c_310_* prefix throughout
4.115
@861d315
11/19/14 13:05:36 |
Sebastian Huber |
bsps/arm: L2C 310 use L2C_310_* prefix throughout
4.115
@f2fed0c1
11/19/14 11:24:07 |
Sebastian Huber |
bsps/arm: L2C 310 add compile time checks
Simplify initialization. …
4.115
@13f1462f
11/19/14 11:07:04 |
Sebastian Huber |
bsps/arm: L2C 310 delete invalid link
4.115
@a9d6c20
11/19/14 11:23:02 |
Sebastian Huber |
bsps/arm: L2C 310 simplify and remove white space
4.115
@957c075
11/19/14 10:51:33 |
Sebastian Huber |
bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE
Rename BSP_ARM_L2CC_BASE …
4.115
@45a63ee
11/10/14 12:46:32 |
Sebastian Huber |
bsp/xilinx-zynq: Add Cadence I2C bus driver
4.115
@bdf8fa76
11/13/14 09:12:32 |
Sebastian Huber |
bsp/xilinx-zynq: Add zync_clock_cpu_1x()
4.115
@234d5c40
11/13/14 09:15:41 |
Sebastian Huber |
bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK
Rename …
4.115
@8100e71
11/12/14 13:02:53 |
Sebastian Huber |
bsp/xilinx-zynq: Adjust BSP_ARM_A9MPCORE_PERIPHCLK
4.115
@f0c564c
11/12/14 12:57:24 |
Sebastian Huber |
bsps/arm: Adjust stacks for ARMv4
Reduce non-IRQ stacks to size zero. …
4.115
@96a9f4c
11/12/14 13:00:05 |
alan.cudmore |
ARM removed shared/abort from several ARM BSPs
4.115
@a373dc37
11/05/14 23:52:23 |
Joel Sherrill |
lpc23xx_tli800-testsuite.tcfg: Add dl02
4.115
@091c610
11/05/14 23:52:05 |
Joel Sherrill |
lpc2362-testsuite.tcfg: Add dl02
4.115
@0b91cfbf
11/05/14 23:51:43 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests
4.115
@f9e4139
11/05/14 21:31:36 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add dl02
4.115
@8d74b80e
11/04/14 21:05:08 |
Joel Sherrill |
lpc23xx_tli800-testsuite.tcfg: Add dl01
4.115
@6d84a9f
11/04/14 21:04:46 |
Joel Sherrill |
lpc2362-testsuite.tcfg: Add dl01
4.115
@a7812cdc
11/04/14 21:04:28 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01
4.115
@643e7cb8
11/04/14 21:02:03 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add dl01
4.115
@de5596b
11/04/14 02:02:03 |
Chris Johns |
Regenerated preinstall.am file.
4.115
@53dd6d61
11/03/14 18:53:40 |
Ben Gras |
BSP for several Beagle products
Specifically the beagleboard, …
4.115
@7a66986
08/22/12 12:39:02 |
ziemke |
Added BeagleBoard? BSP
Coding done in course of GSoC2012.
Commit …
4.115
@e08b0b9
10/30/14 13:29:09 |
Sebastian Huber |
bsp/mpc55xxevb: Fix flash settings for MPC5510
4.115
@513668f6
10/29/14 16:07:20 |
chrisn |
Added missing stm32f4xxxx_adc.h
4.115
@866a6fc
10/23/14 12:31:15 |
Sebastian Huber |
bsps/sparc: Include right header file
4.115
@b442032
10/23/14 08:11:59 |
Sebastian Huber |
bsp/leon3: Fix LEON3_mp_irq definition
Provide it also if …
4.115
@46dde0fc
10/23/14 08:05:17 |
Sebastian Huber |
bsps: Move extern "C" to not cover includes
Some includes may use C++ …
4.115
@77a2226
09/10/14 11:39:53 |
cederman |
bsp/sparc: Ensure that data cache snooping is enabled
Check that data …
4.115
@040ed0b4
10/18/14 08:55:37 |
chrisn |
bsp/stm32f4: Add header files
Added register definition headers for …
4.115
@ea05c438
10/20/14 20:25:37 |
Joel Sherrill |
or1k/or1ksim: Fix warnings
4.115
@ddc8165
10/20/14 20:25:22 |
Joel Sherrill |
arm/raspberrypi: Fix warnings
4.115
@3532ff91
10/20/14 19:36:49 |
Joel Sherrill |
shared/clockdrv_shell.h: Always include <rtems/clockdrv.h> to avoid …
4.115
@71bc995
10/20/14 19:36:19 |
Joel Sherrill |
powerpc/qoriq/include/bsp.h: Add prototypes to fix warnings
4.115
@ed18345
10/20/14 19:21:37 |
Joel Sherrill |
powerpc/qemuppc/startup/cmain.c: Fix warnings
4.115
@7294054b
10/20/14 19:13:47 |
Joel Sherrill |
powerpc/shared/startup/bspstart.c: Fix warning for mvme2100
4.115
@ce5c3b3
10/20/14 18:58:12 |
Joel Sherrill |
nios2/nios2_iss: Fix warnings
4.115
@a4fea82
10/20/14 18:57:54 |
Joel Sherrill |
ss555/startup/bspstart.c: BSP does not use SPRG0
4.115
@ad456877
10/20/14 18:57:41 |
Joel Sherrill |
ep1a/startup/bspstart.c: BSP does not use SPRG0
4.115
@6fc2d389
10/20/14 16:31:25 |
Joel Sherrill |
libbsp/sh/shared/console.c: Eliminate use of obsolete method
4.115
@d6db94a
10/20/14 15:59:08 |
Joel Sherrill |
m68k/mrm332: Fix warnings
4.115
@a8777397
10/20/14 15:58:57 |
Joel Sherrill |
m68k/mcf5329: Fix warnings
4.115
@63fe77e1
10/20/14 15:58:38 |
Joel Sherrill |
m68k/mcf5235: Fix warnings
4.115
@13827524
10/20/14 15:58:21 |
Joel Sherrill |
m68k/mcf5225x: Fix warnings
4.115
@3bba2a9b
10/20/14 15:58:09 |
Joel Sherrill |
m68k/mcf52235: Fix warnings
4.115
@fd36451
10/20/14 15:57:54 |
Joel Sherrill |
m68k/idp: Fix warnings
4.115
@21ee1c8
10/20/14 15:57:44 |
Joel Sherrill |
m68k/gen68360: Fix warnings
4.115
@c2e32ff
10/20/14 14:25:41 |
Joel Sherrill |
lm32 BSP shared and lm32_evr: Fix BSPs
4.115
@770e379
10/20/14 14:15:32 |
Joel Sherrill |
arm/csb337/console/fbcons.c: Fix warning
4.115
@5bdda7f
10/20/14 14:12:46 |
Joel Sherrill |
arm/gba/console/conio.c: Fix warning
4.115
@0f8ee10e
10/20/14 14:11:41 |
Joel Sherrill |
arm/edb7312: Fix warnings
4.115
@4f21badb
10/20/14 02:27:09 |
Joel Sherrill |
m68k/csb360: Fix warnings
4.115
@3d4898f
10/20/14 02:21:06 |
Joel Sherrill |
m68k/av5282: Fix warning
4.115
@8566e1fc
10/20/14 02:14:23 |
Joel Sherrill |
lm32/milkymist/startup/bspclean.c: Include <bsp.h> to fix warning
4.115
@51995b69
10/19/14 22:14:07 |
Joel Sherrill |
m68k/mrm332: Move include of <rtems/m68k/sim.h>
This file defines at …
4.115
@6e8e869
10/17/14 15:21:31 |
Joel Sherrill |
powerpc/shared/irq/irq_init.c: Fix warnings
4.115
@f33e6c0
10/17/14 15:21:18 |
Joel Sherrill |
powerpc/shared/bootloader: Fix warnings
4.115
@04d3761
10/17/14 15:20:50 |
Joel Sherrill |
powerpc/motorola_powerpc/include/bsp.h: Fix warnings
4.115
@ba9c4a7
10/17/14 15:09:55 |
Joel Sherrill |
powerpc/psim: Fix warnings
4.115
@3064411
10/17/14 15:08:01 |
Joel Sherrill |
powerpc/qemuppc: Fix warnings
4.115
@b5548e5
10/17/14 14:50:05 |
Joel Sherrill |
powerpc/gen83xx: Fix warnings
4.115
@d8e2046
10/17/14 13:52:43 |
Joel Sherrill |
sparc/leon3/include/bsp.h: Fix warnings
4.115
@c676ef3
10/17/14 13:52:33 |
Joel Sherrill |
sparc/leon2/include/bsp.h: Fix warnings
4.115
@4c75e72
10/17/14 13:52:07 |
Joel Sherrill |
sparc/erc32: Fix warnings
4.115
