@d9a0689e
05/29/96 16:07:21 |
Joel Sherrill |
Addressed RTEMS API initialization tasks table in a system without …
4.104.114.84.95
@99f9dffa
05/29/96 16:05:28 |
Joel Sherrill |
Added default POSIX API configuration table.
4.104.114.84.95
@019bce7
05/29/96 16:05:06 |
Joel Sherrill |
It is now not an error to have 0 RTEMS initialization tasks since you …
4.104.114.84.95
@974ff40
05/29/96 16:04:31 |
Joel Sherrill |
renamed signal.c to psignal.c to avoid naming problems.
added mp …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@c6fa38c0
05/28/96 19:29:51 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@7640525
05/28/96 19:29:02 |
Joel Sherrill |
added enumerated constant for the POSIX API as an error source
4.104.114.84.95
@5a18e04
05/28/96 19:28:32 |
Joel Sherrill |
added initial set of api extension callouts
4.104.114.84.95
@962c9b65
05/28/96 16:33:11 |
Joel Sherrill |
new file
4.104.114.84.95
@47d6b140
05/28/96 16:32:55 |
Joel Sherrill |
commented out interrupt support
4.104.114.84.95
@da33d26
05/28/96 16:18:34 |
Joel Sherrill |
added ifndef's for the POSIX maximum field in the POSIX api …
4.104.114.84.95
@d4b44877
05/28/96 16:17:01 |
Joel Sherrill |
added posix api initialization call to init.c
deleted a blank line in …
4.104.114.84.95
@8165b48f
05/28/96 16:16:28 |
Joel Sherrill |
comment cleanup
4.104.114.84.95
@52d9e4d1
05/28/96 16:16:11 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@2eba45d
05/28/96 14:16:45 |
Joel Sherrill |
made posix configuration information conditional so configurations …
4.104.114.84.95
@cb96372
05/28/96 13:24:58 |
Joel Sherrill |
changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@87a2a74
05/24/96 22:56:23 |
Joel Sherrill |
changed version to 3.5.17
4.104.114.84.95
@568ebf3
05/24/96 19:32:37 |
Joel Sherrill |
updates to fix typos
4.104.114.84.95
@8b2ecf85
05/23/96 15:37:38 |
Joel Sherrill |
updates from Tony Bennett
4.104.114.84.95
@a5f56a43
05/23/96 15:35:32 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@859f17ce
05/23/96 15:35:26 |
Joel Sherrill |
invoke thread stack free routine instead of Workspace free.
4.104.114.84.95
@d196e48
05/23/96 15:34:54 |
Joel Sherrill |
updates from Tony Bennett.
Broke the setjmp/longjmp pair in the …
4.104.114.84.95
@ef006c1
05/22/96 22:34:18 |
Joel Sherrill |
Modified to correct variables which defined the range of object …
4.104.114.84.95
@f4719d5a
05/22/96 22:32:39 |
Joel Sherrill |
These files have been modified in the initial pass at getting the …
4.104.114.84.95
@05195890
05/22/96 22:31:51 |
Joel Sherrill |
4.104.114.84.95
@92262ab
05/10/96 20:23:27 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@1c964ffa
05/08/96 21:53:50 |
Joel Sherrill |
4.104.114.84.95
@bf6661e
05/02/96 14:39:07 |
Joel Sherrill |
Updated version to 3.5.15.
4.104.114.84.95
@dce1c1a1
05/01/96 15:24:37 |
Joel Sherrill |
Updates from Eric Norum to use the mcpu32 flags and fix comments.
4.104.114.84.95
@a412622
04/24/96 21:21:14 |
Joel Sherrill |
changed version number to 3.5.14
4.104.114.84.95
@1543932
04/24/96 17:36:35 |
Joel Sherrill |
added comment regarding stack alignment issues to thread stack …
4.104.114.84.95
@8389628
04/22/96 16:53:46 |
Joel Sherrill |
4.104.114.84.95
@1f94ed6b
04/22/96 16:50:17 |
Joel Sherrill |
Updates from Tony Bennett.
4.104.114.84.95
@8faca06
04/22/96 16:46:36 |
Joel Sherrill |
thread.c: added support for optional user provided stack allocator
4.104.114.84.95
@6365f81
04/22/96 16:46:00 |
Joel Sherrill |
made initialization routine a regular subroutine
4.104.114.84.95
@a155b3c
04/22/96 16:45:47 |
Joel Sherrill |
interr.h: added stack allocater error code
wkspace.h: made …
4.104.114.84.95
@cc4c1fe4
04/22/96 16:44:54 |
Joel Sherrill |
added stack allocation fields to the cpu table
updates from Tony …
4.104.114.84.95
@96981e3a
04/22/96 16:44:04 |
Joel Sherrill |
4.104.114.84.95
@9a1ccb3
04/22/96 16:43:44 |
Joel Sherrill |
added CPU_M68K_EXTB_L …
4.104.114.84.95
@f581163a
04/22/96 16:30:30 |
Joel Sherrill |
4.104.114.84.95
@d0b7c4e6
04/22/96 16:30:02 |
Joel Sherrill |
updartes from Tony Bennett
4.104.114.84.95
@debe919
04/19/96 21:10:58 |
Joel Sherrill |
event.c: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@78b2ff1
04/19/96 21:10:38 |
Joel Sherrill |
4.104.114.84.95
@c26b62f
04/19/96 21:10:32 |
Joel Sherrill |
event.h: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@8f9e9bdc
04/19/96 21:10:27 |
Joel Sherrill |
4.104.114.84.95
@3b76313
04/19/96 21:09:20 |
Joel Sherrill |
modified to generate fatal error when an unconfigured directive is invoked.
4.104.114.84.95
@f4d52cd7
04/19/96 19:36:59 |
Joel Sherrill |
changes to compile in macro configuration without warnings.
4.104.114.84.95
@14966f8
03/21/96 20:19:55 |
Joel Sherrill |
4.104.114.84.95
@f398452
03/21/96 20:19:33 |
Joel Sherrill |
updated for 68302 and so gen68360 bsp would compile
4.104.114.84.95
@d08b1c75
03/21/96 20:19:03 |
Joel Sherrill |
update to reflect internal threads reorganization
4.104.114.84.95
@110f4ff7
03/06/96 22:23:56 |
Joel Sherrill |
Added 68360 support submitted by W. Eric Norum …
4.104.114.84.95
@e6424462
03/06/96 21:37:43 |
Joel Sherrill |
As part of reducing visibility into rtems and hiding the .inl files …
4.104.114.84.95
@1a8fde6c
03/06/96 21:34:57 |
Joel Sherrill |
Removed prototyes for static inline routines and moved the comments …
4.104.114.84.95
@8e76546
03/06/96 21:26:28 |
Joel Sherrill |
Removed prototyes for static inline rgutines and moved the comments …
4.104.114.84.95
@66d9e3ad
02/21/96 22:37:55 |
Joel Sherrill |
Changed io manager initialization routine to not be static and added …
4.104.114.84.95
@10017a72
02/21/96 22:37:47 |
Joel Sherrill |
Changed io manager initialization routine to not be static.
4.104.114.84.95
@4ff1920
02/21/96 22:37:18 |
Joel Sherrill |
changed io manager initialization routine to not be static
4.104.114.84.95
@8cbbe312
02/21/96 14:47:03 |
Joel Sherrill |
Dispersal of internal thread handler resulted in the SYSI task being …
4.104.114.84.95
@adf98bd
02/21/96 14:44:11 |
Joel Sherrill |
Removed the internal thread objects and dispersed its contents to
the …
4.104.114.84.95
@75f09e5
02/21/96 14:43:34 |
Joel Sherrill |
Dispersal of internal thread handler resulted in IDLE thread becoming …
4.104.114.84.95
@c4b8161d
02/21/96 14:37:32 |
Joel Sherrill |
MPCI Receive became a thread and the prototype changed.
4.104.114.84.95
@56d34e6
02/21/96 14:32:02 |
Joel Sherrill |
the …
4.104.114.84.95
@b2b52cbc
02/14/96 19:00:00 |
Joel Sherrill |
Removed arguments from _Thread_Start_multitasking.
4.104.114.84.95
@f972294d
02/14/96 18:59:37 |
Joel Sherrill |
idle thread now created before system initialization thread.
Also …
4.104.114.84.95
@744d2878
02/14/96 18:48:39 |
Joel Sherrill |
removed arguments from _Thread_Start_multitasking
4.104.114.84.95
@df26b788
02/14/96 17:06:57 |
Joel Sherrill |
white space problem
4.104.114.84.95
@389fa850
02/14/96 17:06:40 |
Joel Sherrill |
Moved some initialization from the system initialization thread to …
4.104.114.84.95
@94b3ec59
02/13/96 22:14:48 |
Joel Sherrill |
changed post task extension from user set to api set and added flag
in …
4.104.114.84.95
@6ca1184
02/13/96 22:14:25 |
Joel Sherrill |
added clear of _ISR_Signals_to_thread_executing
4.104.114.84.95
@391f6628
02/13/96 15:38:37 |
Joel Sherrill |
more comments added and existing ones cleaned up in synchronization paths
4.104.114.84.95
@b38955b
02/13/96 15:38:03 |
Joel Sherrill |
comma removed from end of last enumerated element
4.104.114.84.95
@18269cef
02/13/96 15:37:33 |
Joel Sherrill |
comment added to describe synchronization logic in timeout routine
4.104.114.84.95
@a31ddf7
02/12/96 14:36:09 |
Joel Sherrill |
4.104.114.84.95
@107ce47b
02/09/96 14:30:42 |
Joel Sherrill |
new isr synchronization algorithm using a single enumerated set of states.
4.104.114.84.95
@6dae1c2d
02/09/96 14:25:33 |
Joel Sherrill |
added rtems_interrupt_is_in_progress
4.104.114.84.95
@8a38f3b
02/09/96 14:21:37 |
Joel Sherrill |
4.104.114.84.95
@f3dabb04
02/08/96 22:16:35 |
Joel Sherrill |
changed synchronization algorithm to be a single list of enumerated states
4.104.114.84.95
@d57392d
02/08/96 16:18:38 |
Joel Sherrill |
alignment on workspace changed from CPU_ALIGNMENT to CPU_HEAP_ALIGNMENT
4.104.114.84.95
@4f60309b
02/01/96 22:09:07 |
Joel Sherrill |
Swapped order of nested acquisition check and check for returning …
4.104.114.84.95
@f00a0522
02/01/96 21:54:40 |
Joel Sherrill |
synchronization state bugs address
4.104.114.84.95
@665356af
02/01/96 19:39:21 |
Joel Sherrill |
invalid use of tcb field resource count
4.104.114.84.95
@eaa442fc
01/19/96 22:20:40 |
Joel Sherrill |
added a task begin extension for unix simulator configurations. This …
4.104.114.84.95
@75d482d
01/19/96 22:18:08 |
Joel Sherrill |
4.104.114.84.95
@5d3e539
01/17/96 20:11:33 |
Joel Sherrill |
added class to initial id macro
4.104.114.84.95
@b9be5d03
01/17/96 20:11:23 |
Joel Sherrill |
increased stack size
4.104.114.84.95
@6661eaa1
01/15/96 23:06:16 |
Joel Sherrill |
Split error handler into its own directory.
4.104.114.84.95
@a625ccd
01/15/96 23:04:50 |
Joel Sherrill |
Made real body of _Heap_Walk conditional on RTEMS_DEBUG. This is …
4.104.114.84.95
@c64e4ed4
01/15/96 21:50:28 |
Joel Sherrill |
updates from Tony Bennett for PA and UNIX ports
4.104.114.84.95
@5c491aef
12/20/95 15:39:19 |
Joel Sherrill |
changes remerged after lost in disk crash -- recovered from snapshot, …
4.104.114.84.95
@8bdcfc4
12/19/95 20:26:32 |
Joel Sherrill |
changes remerged after disk crash -- history lost
4.104.114.84.95
@0b0a3267
12/08/95 22:13:18 |
Joel Sherrill |
changed version
4.104.114.84.95
@67d224a
12/08/95 21:06:15 |
Joel Sherrill |
added correct use of _Thread_queue_Enter_critical_section
4.104.114.84.95
@e88d2db
12/05/95 21:41:21 |
Joel Sherrill |
Added comments for addition of is_fp flag to _CPU_Context_Initialize.
4.104.114.84.95
@289ad86
12/05/95 15:29:53 |
Joel Sherrill |
bug fix in statistics from Tony Bennett (tbennett@…)
4.104.114.84.95
@76b6fd0c
12/05/95 15:28:21 |
Joel Sherrill |
minor changes so it would compile in a cross environment
4.104.114.84.95
@ca201c9
12/05/95 15:28:12 |
Joel Sherrill |
4.104.114.84.95
@11ab74e
12/05/95 15:27:51 |
Joel Sherrill |
new states added and _Rate_monotonic_Set_State removed.
4.104.114.84.95
@8d0b7d96
12/01/95 22:03:55 |
Joel Sherrill |
Insert mode argument to _Watchdog_Insert removed. Now are watchdog …
4.104.114.84.95
@caaa47c
12/01/95 21:08:03 |
Joel Sherrill |
Added new synchronization algorithm.
4.104.114.84.95
