@0643693
06/11/99 14:06:13 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix bug reported by
Ian …
4.104.114.84.95
@0860426
06/09/99 16:46:13 |
Joel Sherrill |
Modified to return an error when a bogus return address for the …
4.104.114.84.95
@8dba373
06/09/99 13:50:47 |
Joel Sherrill |
Switched to using strcasecmp() since it is more portable.
D. V. …
4.104.114.84.95
@f74abcf7
05/28/99 18:21:25 |
Joel Sherrill |
Changes from Eric Norum to add a loop and limit on the length of time …
4.104.114.84.95
@18cb17f
05/28/99 17:35:12 |
Joel Sherrill |
changed version to 19990528
4.104.114.84.95
@403d7b18
05/28/99 16:09:00 |
Joel Sherrill |
Alignment corrected per Eric Norum's suggestion.
4.104.114.84.95
@8f3c1d20
05/28/99 16:08:18 |
Joel Sherrill |
At the request of Gumby, the cpu is now halted rather than spinning
on …
4.104.114.84.95
@35d2d3c
05/28/99 14:00:21 |
Joel Sherrill |
Renamed tod.c to coretod.c to remove conflicts with "Time Of Day" …
4.104.114.84.95
@803ce291
05/28/99 13:07:00 |
Joel Sherrill |
Renamed clock.c to rtclock.c to avoid conflicts with clock drivers
in …
4.104.114.84.95
@11cdbeb
05/27/99 18:03:50 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to eliminate a panic when …
4.104.114.84.95
@1c841bd2
05/27/99 16:13:19 |
Joel Sherrill |
Split out the routine rtems_assoc_name_bad().
4.104.114.84.95
@556ea0e3
05/27/99 16:12:20 |
Joel Sherrill |
Removed usage of printf.
4.104.114.84.95
@5adf355a
05/27/99 16:11:52 |
Joel Sherrill |
Split initialization and reserve resources from termios to reduce
size …
4.104.114.84.95
@2a333f9
05/27/99 15:46:34 |
Joel Sherrill |
Disabled running size_rtems until all file splitting is finished.
4.104.114.84.95
@7398901
05/27/99 15:46:00 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@326378bf
05/27/99 15:44:20 |
Joel Sherrill |
Corrected so rtems.o is built and installed on all targets.
4.104.114.84.95
@82d11f87
05/27/99 15:43:32 |
Joel Sherrill |
Corrected macro names.
4.104.114.84.95
@da47e4a9
05/26/99 14:00:48 |
Joel Sherrill |
Initiated updating this to reflect split up.
4.104.114.84.95
@0aeda88
05/20/99 16:16:44 |
Joel Sherrill |
Renamed to rtemstimer.c to avoid conflict with timer drivers in EVERY …
4.104.114.84.95
@8bbaf3b
05/20/99 13:32:54 |
Joel Sherrill |
Removed all post 4.0 changes.
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@fbec4a1
05/18/99 17:33:52 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@0995b6f
05/17/99 23:48:34 |
Joel Sherrill |
Reworked to avoid pulling in the jump point entry in EVERY executable.
4.104.114.84.95
@9180f63
05/17/99 23:26:50 |
Joel Sherrill |
Fixed some typos.
4.104.114.84.95
@c9973bb
05/17/99 23:22:45 |
Joel Sherrill |
Split Interrupt Manager into one routine per file.
4.104.114.84.95
@0123e3b
05/17/99 23:20:52 |
Joel Sherrill |
Split Signal Manager into one routine per file.
4.104.114.84.95
@1dc030f
05/17/99 23:18:20 |
Joel Sherrill |
Dual-Ported Memory Manager split into one routine per file.
4.104.114.84.95
@842db5f3
05/17/99 23:15:20 |
Joel Sherrill |
Split Partition Manager into one routine per file.
4.104.114.84.95
@be47df9
05/17/99 23:10:36 |
Joel Sherrill |
Split Timer Manager into one routine per file.
4.104.114.84.95
@cc2bc302
05/17/99 23:06:03 |
Joel Sherrill |
Split Event Manager into one routine per file.
4.104.114.84.95
@5f9b3db
05/17/99 23:03:07 |
Joel Sherrill |
Split Rate Monotonic Manager into one routine per file.
4.104.114.84.95
@c06d8f64
05/17/99 22:58:30 |
Joel Sherrill |
Split the Semaphore Manager into one routine per file.
4.104.114.84.95
@a2d0f39
05/17/99 22:56:13 |
Joel Sherrill |
Moved some MP routines to semmp.c.
4.104.114.84.95
@3270ca6
05/17/99 22:53:34 |
Joel Sherrill |
Forgot to actually remove the routines. :)
4.104.114.84.95
@1e1b3e00
05/17/99 22:52:59 |
Joel Sherrill |
Split Message Manager into one routine per file.
4.104.114.84.95
@ef22ab2
05/17/99 22:46:01 |
Joel Sherrill |
Moved an MP routine from msg.c to here.
4.104.114.84.95
@86cb89f
05/17/99 22:45:47 |
Joel Sherrill |
Cleaned up some multiprocessing issues.
4.104.114.84.95
@bd83f47
05/17/99 22:42:47 |
Joel Sherrill |
Split Clock Manager into one routine per file.
4.104.114.84.95
@5aa64518
05/17/99 22:39:20 |
Joel Sherrill |
Split Region Manager into one routine per file.
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@2f831ac
05/17/99 22:16:52 |
Joel Sherrill |
Moved _Entry_Table to its own file to avoid having every RTEMS …
4.104.114.84.95
@c4d69e2
05/17/99 21:02:16 |
Joel Sherrill |
Split Task Manager into multiple files. Eventually this effort will …
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@a238cc9
05/17/99 15:45:15 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to remove compiler …
4.104.114.84.95
@577c4080
05/17/99 15:28:52 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…>:
Here's a tiny …
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@4c5080ed
05/11/99 16:30:51 |
Joel Sherrill |
Fix based on bug report from Jay Kulpinski <jskulpin@…> …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@acb644a6
05/07/99 16:30:44 |
Joel Sherrill |
Error reporting fixed by Jennifer.
4.104.114.84.95
@cfcb5a2
04/27/99 17:31:39 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to corrent a miscount in …
4.104.114.84.95
@c7aa9d6
04/26/99 18:22:08 |
Joel Sherrill |
Repairing damage and recovering changes including C++ wrappers..
4.104.114.84.95
@c8cfdcfe
04/26/99 18:04:46 |
Joel Sherrill |
Recovered changes since CVS file was corrupted.
4.104.114.84.95
@8b8204a1
04/26/99 17:35:57 |
Joel Sherrill |
changed version to 19990426
4.104.114.84.95
@0b28bd9c
04/23/99 16:37:54 |
Joel Sherrill |
changed version to 19990423
4.104.114.84.95
@933388ae
04/22/99 21:13:23 |
Joel Sherrill |
Added lstat().
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
@4186b3b
04/19/99 17:17:41 |
Joel Sherrill |
Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease …
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@1059abcd
04/19/99 15:37:36 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@7cdf7fc1
04/19/99 15:27:19 |
Joel Sherrill |
After discussion with Eric Norum <eric@…>,
I added …
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
This one is …
4.104.114.84.95
@d006519b
04/15/99 19:01:32 |
Joel Sherrill |
Added reentrant versions.
4.104.114.84.95
@a68e6b9
04/15/99 18:58:43 |
Joel Sherrill |
Updated version string.
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
@93994fdb
04/15/99 18:57:31 |
Joel Sherrill |
Now compiles and is included in normal build even though it is …
4.104.114.84.95
@0f4e074
04/15/99 18:57:02 |
Joel Sherrill |
Cleaned up.
4.104.114.84.95
@3afecf8
04/15/99 18:56:42 |
Joel Sherrill |
Now compiles and is included in normal build even though it is untested.
4.104.114.84.95
@3090760
04/15/99 18:55:55 |
Joel Sherrill |
Now compile files that previously existed but were not built because …
4.104.114.84.95
@24a9af6
04/15/99 18:55:14 |
Joel Sherrill |
Now install header files that existed but were not previously installed.
4.104.114.84.95
@8a2943aa
04/15/99 18:54:40 |
Joel Sherrill |
Now install some header files that existed but were not previously …
4.104.114.84.95
@053acd70
04/15/99 18:54:16 |
Joel Sherrill |
Now install utsname.h.
4.104.114.84.95
@d0f53fe
04/15/99 18:54:01 |
Joel Sherrill |
Enabled cancellation information in POSIX API thread extension structure.
4.104.114.84.95
@02d46fa
04/15/99 18:53:35 |
Joel Sherrill |
Added set_errno_and_return_minus_one_cast.
4.104.114.84.95
@39daf58
04/15/99 18:53:22 |
Joel Sherrill |
Added in some header files that existed but were not previously installed.
4.104.114.84.95
@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@8cdb582
04/12/99 15:41:33 |
Joel Sherrill |
This patch …
4.104.114.84.95
@d115315
04/12/99 15:36:07 |
Joel Sherrill |
Added line to initialize timer_max.
4.104.114.84.95
@5907192
04/07/99 20:56:47 |
Joel Sherrill |
changed version to 19990407
4.104.114.84.95
@3084de2
04/07/99 15:57:05 |
Joel Sherrill |
MPC821 support and PPC patches from Andrew Bray …
4.104.114.84.95
@e53c4a3
04/06/99 15:45:21 |
Joel Sherrill |
Cleaning up unused files.
4.104.114.84.95
@517660f1
04/01/99 16:36:22 |
Joel Sherrill |
Moved sparc specific version of in_cksum_hdr to an inline routine like …
4.104.114.84.95
@5eb7da97
04/01/99 16:20:03 |
Joel Sherrill |
Disable IXON by default based on comment from Eric Norum …
4.104.114.84.95
@414e1b3
03/31/99 23:56:34 |
Joel Sherrill |
changed version to 19990331
4.104.114.84.95
@77a0067
03/31/99 23:36:18 |
Joel Sherrill |
changed version to 199900331
4.104.114.84.95
@18040d3
03/31/99 23:35:22 |
Joel Sherrill |
Patch from Thomas Doerfler <td@…> to add flow control:
4.104.114.84.95
@ecab6a39
03/31/99 23:29:19 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@ec2328ee
03/31/99 23:24:57 |
Jennifer.Averett |
Removed asserts that shouldn't be called and commented case where this …
4.104.114.84.95
@8cc57f6
03/31/99 23:24:51 |
Joel Sherrill |
Modified to be valid m68k code on all CPU models.
4.104.114.84.95
@f719ef1
03/31/99 23:23:52 |
Jennifer.Averett |
Corrected return value.
4.104.114.84.95
@73b943bc
03/31/99 23:21:19 |
Joel Sherrill |
Fixed paths to include files so this will build.
4.104.114.84.95
@6a10709
03/31/99 22:33:14 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>:
joel@… wrote:
4.104.114.84.95
@5c95996
03/31/99 22:09:11 |
Joel Sherrill |
When compiled in debug mode, the POSIX threads inline file was not …
4.104.114.84.95
@efa0baa5
03/31/99 20:51:07 |
Joel Sherrill |
Patch from Eric Norum <eric@…> which changed the exit …
4.104.114.84.95
@ceb06d96
03/30/99 17:43:51 |
Joel Sherrill |
Removed warning for `#ifdef' argument starts with punctuation.
4.104.114.84.95
@707d4d0
03/30/99 17:42:25 |
Joel Sherrill |
Removed warning for const removal.
4.104.114.84.95
@5c6c4c2
03/30/99 17:41:26 |
Joel Sherrill |
Fixed typo where _POSIX_signals_Clear_process_signals was not …
4.104.114.84.95
@6a4096b
03/30/99 15:40:29 |
Joel Sherrill |
Patch to add shutdown() routine from Tony R. Ambardar <tonya@…>.
4.104.114.84.95
