@9d5c22e3
12/15/98 19:56:41 |
Joel Sherrill |
Switched to use of ASM compilation conditional.
4.104.114.84.95
@2417b15
12/15/98 15:00:25 |
Joel Sherrill |
Changed reference from no_cpu to mips64orion.
4.104.114.84.95
@0c291bc
12/14/98 23:58:22 |
Joel Sherrill |
Switch from .s to .S on include
4.104.114.84.95
@0162910
12/14/98 23:15:38 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to rename all
.s …
4.104.114.84.95
@2ffe30d
12/07/98 17:45:48 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
This patch avoids a …
4.104.114.84.95
@4721cf1
12/03/98 23:54:14 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…> to add remote debug …
4.104.114.84.95
@8a9caa03
11/19/98 20:23:34 |
Joel Sherrill |
Renamed exception constants per requests from Erik Ivanenko …
4.104.114.84.95
@b4e3b2b
10/28/98 19:25:12 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>.
I just happened …
4.104.114.84.95
@714137ef
10/13/98 15:03:27 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct minor …
4.104.114.84.95
@d171f8a8
10/06/98 20:55:28 |
Joel Sherrill |
Corrected assembly language to use constants instead of addresses. …
4.104.114.84.95
@dff5b40
10/06/98 20:54:36 |
Joel Sherrill |
Added missing field (idle_task_stack_size) to CPU Table.
4.104.114.84.95
@086836e1
10/01/98 18:50:43 |
Joel Sherrill |
Patch from Thomas Doerfler <td@…> to improve 403 support.
4.104.114.84.95
@17408b90
09/30/98 13:02:30 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I found that my …
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@b285860
08/31/98 23:03:45 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Eric> NB : there …
4.104.114.84.95
@eb562f2
08/21/98 16:39:52 |
Joel Sherrill |
Here is a patch …
4.104.114.84.95
@29381405
08/21/98 16:16:00 |
Joel Sherrill |
Spacing changes
4.104.114.84.95
@28e7d7fa
08/20/98 22:04:22 |
Joel Sherrill |
Patches from Eric Norum
4.104.114.84.95
@0280cb6
08/20/98 14:39:09 |
Joel Sherrill |
FreeBSD stack compiles for the first time (except libc/strsep.c)
4.104.114.84.95
@8b2ee37c
08/19/98 20:09:59 |
Joel Sherrill |
- Use the …
4.104.114.84.95
@f2226f44
08/19/98 12:41:22 |
Joel Sherrill |
Added 68060 definition from Chris Johns.
4.104.114.84.95
@26e5cd4
08/13/98 14:23:37 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>. Comments follow:
Here is a …
4.104.114.84.95
@bd8c8b2a
08/05/98 16:51:39 |
Joel Sherrill |
Patch from Eric Valette <valette@…> which brings the i386ex …
4.104.114.84.95
@ab0df696
08/05/98 15:15:46 |
Joel Sherrill |
Automatic CPU type detection code from Eric Valette …
4.104.114.84.95
@4d11a92f
08/05/98 15:11:33 |
Joel Sherrill |
Redid Makefiles to properly do a preinstall. There was remnants of …
4.104.114.84.95
@5ef4fae
08/01/98 14:40:51 |
Joel Sherrill |
Merged patch from David Fiddes <D.J.Fiddes@…> to add ColdFire? …
4.104.114.84.95
@41d07439
07/30/98 18:06:51 |
Joel Sherrill |
Now that Joel …
4.104.114.84.95
@67a2288
07/23/98 22:02:34 |
Joel Sherrill |
Patch from Eric VALETTE <valette@…>:
Here is a …
4.104.114.84.95
@73452854
07/23/98 20:04:55 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Here is a pure …
4.104.114.84.95
@dd6dddc
07/01/98 21:33:11 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@b22b1294
06/25/98 16:26:43 |
Joel Sherrill |
Coldfire support patch from David Fiddes <D.J.Fiddes@…>.
4.104.114.84.95
@924e17a
06/25/98 16:10:45 |
Joel Sherrill |
Patch from Robin Kirkham <Robin.Kirkham@…> to …
4.104.114.84.95
@803de41
06/24/98 17:58:56 |
Joel Sherrill |
Suggestion from Robin Kirkham <Robin.Kirkham@…> to …
4.104.114.84.95
@9a6994b4
06/18/98 15:22:35 |
Joel Sherrill |
Added freebsd support from Dario Alcocer <alcocer@…>.
4.104.114.84.95
@7738906
06/12/98 21:12:12 |
Joel Sherrill |
Added optimized version of memcpy.c to this directory since RTEMS …
4.104.114.84.95
@937a6f3c
06/03/98 19:00:17 |
Joel Sherrill |
Added CPU_ISR_PASSES_FRAME_POINTER so some ports could pass just the …
4.104.114.84.95
@75d0b0b
06/03/98 18:49:38 |
Joel Sherrill |
Corrected macros for assembly language program sections.
4.104.114.84.95
@448ba47
05/27/98 12:26:07 |
Joel Sherrill |
Fixed spacing
4.104.114.84.95
@139e6efe
05/27/98 12:21:32 |
Joel Sherrill |
Fix from Jiri Gaisler <jgais@…> for a problem in which …
4.104.114.84.95
@d7588ef
05/21/98 16:39:51 |
Joel Sherrill |
Per suggestion from Ralf Corsepius made all macros solaris2 -- not …
4.104.114.84.95
@64876e3
05/18/98 16:37:32 |
Joel Sherrill |
Added bsp_specs.
4.104.114.84.95
@b77b2674
05/04/98 12:36:59 |
Joel Sherrill |
fixed swap of unsigned16
4.104.114.84.95
@d74daf9
04/30/98 16:48:40 |
Joel Sherrill |
Fixed case where wrong variable was used.
4.104.114.84.95
@0c508af
04/27/98 18:18:13 |
Joel Sherrill |
Added I386_HAS_BSWAP cpu model feature flag so swap u32 could take …
4.104.114.84.95
@b0aba4c4
04/27/98 16:10:16 |
Joel Sherrill |
Added swap of unsigned16
4.104.114.84.95
@eac9871
04/27/98 15:30:59 |
Joel Sherrill |
Fixed spelling errors.
4.104.114.84.95
@0153d180
04/27/98 15:28:43 |
Joel Sherrill |
Fixed trace bit manipulation per requests from Eric Norum and Chris …
4.104.114.84.95
@72aa8cf
04/27/98 14:16:29 |
Joel Sherrill |
Fixed CVS Id
4.104.114.84.95
@8a1636d
04/15/98 22:16:22 |
Joel Sherrill |
Added bh, ch, dh, bl, cl, and dl register macros.
4.104.114.84.95
@4381e50
04/14/98 22:44:49 |
Joel Sherrill |
Ralf Corsepius suggested a way to get rid of UNIX compiler files and …
4.104.114.84.95
@993e1b5
04/14/98 19:54:24 |
Joel Sherrill |
Refreshing effort from Avenger.
4.104.114.84.95
@5e34bf4
03/31/98 14:19:27 |
Joel Sherrill |
Added "sigemptyset()" call to insure that the memcmp() would work.
It …
4.104.114.84.95
@a30359bb
03/27/98 19:42:58 |
Joel Sherrill |
Changed int to unsigned32 to match cpu.h.
4.104.114.84.95
@c80add4
03/25/98 18:46:47 |
Joel Sherrill |
m68k software interrupt stack support from Chris Johns and Eric Norum.
4.104.114.84.95
@ddf142d
03/24/98 20:53:48 |
Joel Sherrill |
Added _XOPEN_SOURCE definition to allow use of UNIX IPC.
4.104.114.84.95
@bdac86b5
03/24/98 17:13:03 |
Joel Sherrill |
Real definition for the beginning of the data section per Eric Norum's …
4.104.114.84.95
@72b397a
03/24/98 17:10:44 |
Joel Sherrill |
Corrected register constraints per suggestion from Thomas Doerfler, …
4.104.114.84.95
@d662fef8
03/24/98 16:33:32 |
Joel Sherrill |
More cpu model flags converted to using cpp predefines.
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@2b4aec8
03/21/98 15:31:13 |
Joel Sherrill |
Fixed spacing to be consistent with other CPUs.
4.104.114.84.95
@25804b60
03/20/98 17:38:53 |
Joel Sherrill |
Here is my attempt at …
4.104.114.84.95
@50cf94da
03/20/98 17:16:31 |
Joel Sherrill |
SH port submitted from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@b4589477
02/17/98 13:21:37 |
Joel Sherrill |
Swapped C++ and ASM "endifs"
4.104.114.84.95
@77ea27fc
02/04/98 14:47:23 |
Joel Sherrill |
Ralf Corsepius noticed that generally was spelled incorrectly.
4.104.114.84.95
@5c3511e
01/30/98 21:49:51 |
Joel Sherrill |
Big patch form Ralf Corsepius described in this email:
Here is the …
4.104.114.84.95
@3a85d03d
01/28/98 15:39:30 |
Joel Sherrill |
Change to remove warning on glibc2 systems per Ralf Corsepius's
suggestion.
4.104.114.84.95
@2936b425
01/23/98 17:45:05 |
Joel Sherrill |
Solaris port updates from Chris Johns
4.104.114.84.95
@fbaf52eb
01/20/98 20:31:21 |
Joel Sherrill |
Removed warning per Chris John's suggestion.
4.104.114.84.95
@cb5bfe4
01/20/98 19:41:09 |
Joel Sherrill |
Removed CONFIG_DIR and PROJECT_HOME directories.
4.104.114.84.95
@4bf453a
12/22/97 17:27:17 |
Joel Sherrill |
Changed from .align to .p2align to avoid differences in meaning of …
4.104.114.84.95
@674c900
12/10/97 16:58:00 |
Joel Sherrill |
Modified a lot of files to take a first cut at supporting building …
4.104.114.84.95
@80868140
11/29/97 17:51:27 |
Joel Sherrill |
Patch from Chris Johns to filter out the trace bit on CPU models
which …
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@e63e254e
08/22/97 19:19:07 |
Joel Sherrill |
Corrected bug per Katsutoshi Shibuya's report:
The definition of …
4.104.114.84.95
@91333c2
07/31/97 22:04:17 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@487c4f62
07/10/97 19:09:16 |
Joel Sherrill |
Strip the trace bit from the SR register when dispatching a thread …
4.104.114.84.95
@eb14a2ff
07/09/97 23:55:39 |
Joel Sherrill |
Repository damaged -- files readded.
4.104.114.84.95
@8fabc273
07/09/97 23:33:08 |
Joel Sherrill |
Added sp, sfc, and fpcsr register defines.
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@0a6fb22
04/22/97 20:19:25 |
Joel Sherrill |
Patch from Chris John <cjohns@…> to add use of a select …
4.104.114.84.95
@f2545552
04/22/97 19:57:02 |
Joel Sherrill |
multiprocessing fixed on linux by fixing cpu.c so correct form of …
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@5bf6ffb
04/16/97 17:34:40 |
Joel Sherrill |
Added FPSP support for MC68040
4.104.114.84.95
@e2d79559
04/09/97 14:05:50 |
Joel Sherrill |
Added ka9q tcpip stack and network driver for the gen68360. This …
4.104.114.84.95
@d6ba279
04/07/97 21:24:02 |
Joel Sherrill |
added initialization of variable to eliminate warning.
4.104.114.84.95
@12d6f14
04/07/97 21:22:15 |
Joel Sherrill |
added "ifndef" to avoid redefinition warning.
4.104.114.84.95
@424ab48
04/07/97 21:21:55 |
Joel Sherrill |
added volatile to Switch_necessary structure member to avoid warning.
4.104.114.84.95
@d911f4c2
04/07/97 21:21:21 |
Joel Sherrill |
added test to avoid spurious error
4.104.114.84.95
@4e8c5a6b
04/07/97 21:20:57 |
Joel Sherrill |
added prototype for missing routine.
4.104.114.84.95
@d749165
04/07/97 21:20:48 |
Joel Sherrill |
added "return" to eliminate warning.
4.104.114.84.95
@2ff1d549
04/07/97 21:20:35 |
Joel Sherrill |
4.104.114.84.95
@82ab443e
04/07/97 21:20:16 |
Joel Sherrill |
added prototypes for two assembly language routines to eliminate warnings.
4.104.114.84.95
@32ef3dc
04/07/97 21:19:59 |
Joel Sherrill |
commented out sccs_id to eliminate warning.
4.104.114.84.95
@11259ab7
04/07/97 21:19:15 |
Joel Sherrill |
added plea for someone to implement software stack switching for …
4.104.114.84.95
@77d20fb
04/07/97 21:18:50 |
Joel Sherrill |
Replaced warning message for cpus which do not have hardware support …
4.104.114.84.95
@2e4bc8b4
04/07/97 21:17:42 |
Joel Sherrill |
initialized variable to eliminate warning
4.104.114.84.95
@94784cf8
04/07/97 21:16:47 |
Joel Sherrill |
changed signed int to unsigned to eliminate warning
4.104.114.84.95
