@43fbb50f
02/15/19 11:07:23 |
Sebastian Huber |
bsp/altera-cyclone-v: Make FDT support optional
5
@eec706e2
02/11/19 06:34:14 |
Sebastian Huber |
bsps/powerpc: Fix small data area section
Fix small data area in case …
5
@6c9f017
02/02/19 04:09:53 |
Chris Johns |
libdl: Add powerpc large memory and small data support.
- Add support …
5
@b08278e
02/02/19 04:32:38 |
Chris Johns |
powerpc/psim: Increase the psim memory to 256M
This allows test dl09 …
5
@568490a
02/08/19 11:40:45 |
Jiri Gaisler |
griscv: add additional cpu configurations
* Also switch default …
5
@4e686261
02/07/19 10:13:01 |
Sebastian Huber |
bsps/irq: Fix interrupt server init (SMP)
5
@0fb52ce
02/07/19 06:45:58 |
Sebastian Huber |
bsps/arm: Fix generic timer frequency
Update #3456.
5
@b1381ae
01/25/19 14:50:14 |
Sebastian Huber |
bsps/powerpc: Fix warnings
5
@81aec18
01/24/19 13:29:03 |
Sebastian Huber |
bsps/powerpc: Fix 64-bit issues in assembler files
We have to be …
5
@d3d4e77
01/18/19 11:37:55 |
Jiri Gaisler |
riscv: add griscv bsp
Update #3678.
5
@c1dcd6af
01/21/19 10:27:07 |
Jiri Gaisler |
grlib: make memory coherency cpu-independent
Update #3678.
5
@9b2b389
01/18/19 17:00:47 |
Jiri Gaisler |
grlib: use cpu-independent routines for uncached access
Update #3678.
5
@5981c8ca
01/18/19 10:29:08 |
Jiri Gaisler |
grlib: use rtems_interrupt_handler_install()
Update #3678.
5
@411c297
01/18/19 10:24:18 |
Jiri Gaisler |
grlib: make apbuart driver independent of bsp
Update #3678.
5
@7eb606d3
12/22/18 17:31:04 |
Sebastian Huber |
grlib: Move source files
Update #3678.
5
@31720925
12/22/18 06:13:44 |
Sebastian Huber |
grlib: Move header files
Update #3678.
5
@95c1921
01/21/19 08:17:05 |
Sebastian Huber |
bsps/arm: Remove unused bsp_stack_irq_size
Update #3459.
5
@12dfe5dc
01/16/19 21:42:18 |
joel |
bsps/i386/shared/cache/cache.c: Make compile
5
@e7d623e7
01/10/19 06:57:36 |
Sebastian Huber |
bsps/arm: Conditional ARMv7-AR data cache disable
Update #3667.
Close …
5
@0abe47f
01/10/19 06:29:54 |
thomas.doerfler |
bsps/arm: Fix typo in disable cache for ARMv7-AR
Update #3667.
5
@9aee88a
01/08/19 13:43:02 |
Sebastian Huber |
bsp/riscv: Clear boot command line
5
@c05d7a9d
12/21/18 20:43:27 |
Sebastian Huber |
bsps/sparc: Fix warnings
5
@75e1009f
12/21/18 20:42:09 |
Sebastian Huber |
bsps/sparc: Fix typo
5
@11f3b9a
11/26/18 14:55:38 |
Sebastian Huber |
bsps/sparc: Add grlib_malloc(), grlib_calloc()
This avoids a …
5
@c37807e9
12/21/18 10:57:26 |
Sebastian Huber |
bsps/arm: Add cache size support for CP15
5
@41a557bc
12/21/18 07:39:33 |
Sebastian Huber |
bsps/arm: Add ARMv7-AR disable data cache
Close #3667.
5
@b0c2d48
12/21/18 06:49:47 |
Sebastian Huber |
bsps: Add CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA
Update #3667.
5
@5e0ab02
12/21/18 06:46:58 |
Sebastian Huber |
bsps: Update cache manager documentation
Update #3667.
5
@a6f70e1
12/21/18 06:14:42 |
Sebastian Huber |
bsps: Remove superfluous comments in cacheimpl.h
Remove superfluous …
5
@ba85655
12/21/18 09:16:02 |
Sebastian Huber |
ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS
Remove this …
5
@750e795
12/21/18 06:27:16 |
Sebastian Huber |
bsps/i386: Enable instruction cache support
5
@9edc558d
12/20/18 13:21:40 |
Sebastian Huber |
bsp/imx: Fix for RAM end at 4GiB
5
@0a1f5df9
05/03/18 11:03:27 |
Sebastian Huber |
Simplify _CPU_Counter_difference()
In order to simplify the use of …
5
@2e8b5de
12/05/18 12:02:59 |
Sebastian Huber |
bsp/leon2: Move printk() support
Avoid assert() in …
5
@99de42c
12/04/18 22:05:10 |
mcomajoancara |
Capitalize Rtems to RTEMS
5
@0446f680
12/03/18 20:37:32 |
mcomajoancara |
Spelling and grammar fixes in source code comments (GCI 2018)
5
@fdcba406
12/04/18 14:26:55 |
Sebastian Huber |
bsp/leon3: Fix CPU counter frequency
5
@f40f86d
11/30/18 19:01:50 |
shashvatjain2002 |
powerpc/haleakala:Add per-section compilation and linking support (GCI …
5
@c056f21
11/30/18 18:07:17 |
shashvatjain2002 |
powerpc/mpc8260ads:Add per-section compilation and linking support …
5
@8b3ca0c
11/30/18 16:39:29 |
shashvatjain2002 |
powerpc/qemuppc:Add per-section compilation and linking support (GCI …
5
@8b6273a8
11/30/18 15:03:25 |
shashvatjain2002 |
powerpc/ss555:Add per-section compilation and linking support(GCI …
5
@10e7d87
11/30/18 14:33:31 |
joel |
mcf52235-testsuite.tcfg: Add dl07
5
@e447d4c0
11/29/18 22:46:06 |
joel |
generic_or1k-testsuite.tcfg: Enable sptls01 now that GCC is from FSF …
5
@8b28fdd
11/29/18 20:39:47 |
shashvatjain2002 |
m68k/mrm332:Add per-section compilation and linking support (GCI 2018) …
5
@f57d4d5
11/29/18 18:32:46 |
shashvatjain2002 |
m68k/mcf5206elite:Add per-section compilation and linking support (GCI …
5
@d6d4002
11/29/18 16:54:12 |
joel |
bfin/shared/dev/clock.c: Include rtems/score/thread.h
5
@b56edf1
11/29/18 16:53:48 |
joel |
lpc23xx_tli800-testsuite.tcfg: Add dl07
5
@9002859
11/29/18 16:53:32 |
joel |
lpc2362-testsuite.tcfg: Add dl07
5
@7ed1e618
11/29/18 15:19:44 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add dl07
5
@1491db5b
11/29/18 15:19:06 |
joel |
lpc1768_mbed_ahb_ram-testsuite.tcfg: Add dl07
5
@1d78d66
11/29/18 15:18:48 |
joel |
lpc1768_mbed-testsuite.tcfg: Add dl07
5
@1fe6d11
11/28/18 17:53:36 |
shashvatjain2002 |
m68k/mcf52235:Add per-section compilation and linking support(GCI …
5
@9c4dc7b0
11/28/18 20:07:41 |
shashvatjain2002 |
m68k/mcf5225x:Add per-section compilation and linking support(GCI …
5
@cc119eb
11/28/18 15:36:31 |
shashvatjain2002 |
m68k/mcf5329:Add per-section compilation and linking support (GCI …
5
@e80d34e
11/28/18 13:15:38 |
shashvatjain2002 |
m68k/mcf5235:Add per-section compilation and linking support (GCI …
5
@a919807
11/28/18 16:43:23 |
joel |
lm3s3749-testsuite.tcfg: Add dl07
5
@5bf0c1a
11/28/18 13:52:22 |
Sebastian Huber |
bsps/sparc: Fix SMP build
Update #3622.
5
@89bff5a
11/27/18 02:29:49 |
shashvatjain2002 |
m68k/av5282: Add per-section compilation and linking support (GCI …
5
@a7267241
11/26/18 14:44:25 |
Sebastian Huber |
bsps/sparc: Add and use <grlib_impl.h>
Reduce copy and paste.
5
@0a75a4aa
11/26/18 13:04:59 |
Sebastian Huber |
Remove rtems_cache_*_processor_set() functions
The following …
5
@1947449
11/25/18 20:17:54 |
shashvatjain2002 |
m68k/uC5282: Add per-section compilation and linking (GCI 2018)
The …
5
@ffe9e7a
11/25/18 07:37:01 |
shashvatjain2002 |
m68k/gen68360:Add per-section compilation and linking support
The …
5
@1b2124d
11/24/18 20:55:07 |
pritishjain2001 |
m68k/gen68340:Add per-section compilation and linking support
The …
5
@2ce44de
11/22/18 01:25:43 |
zenon.hans.taneka |
Changed slightly awkward sentence structure
5
@e0caabe
11/20/18 12:09:53 |
Sebastian Huber |
bsps/arm: Avoid short range branch in start.S
5
@faafc229
11/20/18 12:06:04 |
Sebastian Huber |
bsps/arm: Use local labels in start.S
5
@94529131
11/20/18 12:03:20 |
Sebastian Huber |
bsps/arm: Simplify start.S
The boot_card() function does not return.
5
@0a6a4ddb
11/16/18 06:46:16 |
Sebastian Huber |
bsps/moxie: Use interrupt stack for init stack
Update #3459.
5
@38f81bfc
11/16/18 07:01:24 |
Sebastian Huber |
bsps/nios2: Use interrupt stack for init stack
Update #3459.
5
@0989001
11/15/18 05:40:35 |
Sebastian Huber |
bsps/sparc64: Use interrupt stack for init stack
Update #3459.
5
@5f5bbd1
11/16/18 07:55:30 |
Sebastian Huber |
bsps/x86_64: Use interrupt stack for init stack
Update #3459.
5
@0ce6bf3
11/16/18 05:39:49 |
Sebastian Huber |
bsps/epiphany: Use interrupt stack for init stack
Update #3459.
5
@a74ee417
11/16/18 05:36:28 |
Sebastian Huber |
bsps/bfin: Use interrupt stack for init stack
Update #3459.
5
@508f319e
11/16/18 06:43:51 |
Sebastian Huber |
bsps/mips: Use interrupt stack for init stack
Update #3459.
5
@84e59b7c
11/15/18 19:47:22 |
Sebastian Huber |
bsps/powerpc: Use interrupt stack for init stack
Move start.o to …
5
@cc61d5c
11/16/18 06:36:04 |
Sebastian Huber |
bsps/m68k: Use interrupt stack for init stack
Update #3459.
5
@5247a214
11/14/18 22:48:56 |
pisa |
bsp/tms570: correct baudrate calculation.
5
@aefd4a2
11/14/18 22:46:43 |
pisa |
bsp/tms570: correct inclusion of header files for build with HW init.
5
@a13b89b
11/14/18 07:42:22 |
Sebastian Huber |
bsp/i386: Use interrupt stack for init stack
Update #3459.
5
@5f32da0
11/14/18 06:58:38 |
Sebastian Huber |
bsp/or1k: Use interrupt stack for init stack
Update #3459.
5
@28bf4ca
11/14/18 06:00:59 |
Sebastian Huber |
or1k: Support GCC 9
Close #3602.
5
@9a029ce
11/09/18 12:06:52 |
Sebastian Huber |
bsps/irq: Use rtems_malloc()
5
@510fbfc3
11/08/18 14:31:03 |
Sebastian Huber |
sh: Remove use of proc_ptr
Update #3585.
5
@54c5ffc
11/08/18 14:05:22 |
Sebastian Huber |
or1k: Remove use of proc_ptr
Update #3585.
5
@5c6edee
11/08/18 14:44:56 |
Sebastian Huber |
m68k: Remove use of proc_ptr
Update #3585.
5
@3c6a6e8
11/08/18 14:14:32 |
Sebastian Huber |
i386: Remove use of proc_ptr
Update #3585.
5
@a043ff8
11/08/18 14:33:47 |
Sebastian Huber |
epiphany: Remove use of proc_ptr
Update #3585.
5
@93fae332
11/12/18 08:33:04 |
Sebastian Huber |
Include missing <sys/types.h>
Update #3598.
5
@bfcf1473
11/08/18 15:21:48 |
Sebastian Huber |
m32c: Remove this target
Update #3599.
5
@7ea7178
11/09/18 18:16:27 |
shashvatjain2002 |
arm/csb337: Update Doxygen (GCI 2018)
5
@b3c624d8
11/08/18 00:47:49 |
shashvatjain2002 |
arm/altera cyclone v: Update Doxygen (GCI 2018)
5
@84aedcae
11/08/18 12:49:38 |
Sebastian Huber |
Include missing <rtems/score/thread.h>
Update #3598.
5
@5841e0b
11/09/18 12:47:20 |
Sebastian Huber |
bsp/lpc32xx: Include missing <time.h>
Update #3598.
5
@fdd3b85
11/09/18 09:46:50 |
Sebastian Huber |
bsp/motorola_powerpc: Include <sys/param.h>
Update #3598.
5
@0288536
11/09/18 08:40:45 |
Sebastian Huber |
bsps: Include missing header files
Update #3598.
5
@efdb4a7
11/09/18 08:37:53 |
Sebastian Huber |
bsp/beatnik: Fix warnings
5
@32953f90
11/08/18 07:38:24 |
Sebastian Huber |
bsp/realview-pbx-a9: Update headers.am
5
@4fea054c
11/06/18 18:34:15 |
Sebastian Huber |
score: Remove _ISR_Dispatch()
This function was only used on some …
5
@ff081aee
11/06/18 15:58:02 |
Sebastian Huber |
score: Rename interrupt stack symbols
Rename
5
@2faea99
11/07/18 10:08:50 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix printk() support
Avoid dependencies on the …
5
