@9832652c
06/28/21 06:44:49 |
Sebastian Huber |
bsps/irq: Add rtems_interrupt_raise()
Add rtems_interrupt_raise_on() …
@781213f9
06/28/21 06:20:53 |
Sebastian Huber |
bsps/irq: Add rtems_interrupt_vector_is_enabled()
Add a default …
@5cc1695
04/19/21 08:55:33 |
robin.mueller.m |
Fixes for TMS570 BSP
When compiling the lwIP port for the TMS570, …
@b24e8142
07/16/21 12:32:03 |
robin.mueller.m |
STM32H7 ethernet pin corrections
These patches were submitted a few …
@7b2d569
07/09/21 08:39:01 |
Sebastian Huber |
bsp/imx: Fix SMP start
Flush imx_gic_dist_base so that secondary …
@a398909
07/09/21 08:40:35 |
Sebastian Huber |
bsps/arm: Fix SMP start
Skip the data cache initialization if we are …
@89b652a5
07/07/21 14:37:27 |
christian.mauderer |
bsps/imxrt: Fix undefined symbol
@8b0e3334
07/06/21 15:53:12 |
dangipranav |
bsps/arm: Add start up support for ARMv6 RPi Models
@b28c0c66
07/07/21 12:38:40 |
Sebastian Huber |
bsp/raspberrypi: Fix <bsp/irq.h> header guard
@1b560731
07/07/21 07:52:56 |
Sebastian Huber |
bsp/imx: Fix pointer from integer warning
@0d3453a4
05/28/21 14:54:00 |
bsps/imxrt: Simplify linkcmds and make it flexible
Calling the memory …
@95a38dd
05/28/21 13:50:31 |
bsps/imxrt: Allow different ARM PLL setting
Update #4180
@6b7a3858
06/19/21 12:24:26 |
Sebastian Huber |
bsp/atsam: Fix BSP_INTERRUPT_VECTOR_COUNT
Fix an off by one error.
@94cf67c
06/19/21 10:48:27 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAX
This define is no longer …
@3fee6620
06/19/21 10:51:58 |
Sebastian Huber |
bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT
Use …
@cd5573c
06/19/21 10:40:57 |
Sebastian Huber |
bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNT
Assert …
@af73b7b6
06/18/21 05:37:18 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MIN
Remove …
@55ce66ca
06/07/21 07:37:51 |
Sebastian Huber |
arm/fvp: Fix integer from pointer without a cast
Update #4202.
@ea41722c
04/30/21 17:14:48 |
ryan.long |
Change filesystem utime_h handler to utimens_h
Also updated licenses. …
@15e26f4
05/12/21 09:34:52 |
bsps/imxrt: Enable DMA clock
The EDMA is intialized so make sure the …
@691fec40
05/11/21 11:46:56 |
bsps/imxrt: Fix OCRAM, ITCM and DTCM sizes
The sizes are configurable …
@988cc1a
04/12/21 14:53:43 |
bsps/imxrt: Add addresses and interrupts to dts
Add addresses and …
@c3056666
05/12/21 06:46:30 |
bsps/imxrt: Reduce devicetree size
Remove symbols that would be …
@08e4e6f2
04/07/21 13:05:26 |
bsps/imxrt: Fix documentation error
Update #4180
@98cb84e
05/17/21 06:04:07 |
Sebastian Huber |
arm/altera-cyclone-v: Fix compile error
Update #4406.
@523867d
05/11/21 15:27:20 |
Sebastian Huber |
rtems: Constify rtems_task_wake_when()
Add a parameter to …
@3af2dc7
05/11/21 14:26:55 |
frank.kuehndel |
_TOD_Validate(): Fix incorrect return code
This patch fixes bug …
@e10dec0
04/30/21 13:47:10 |
Sebastian Huber |
bsps: Support RTEMS_NOINIT in linkcmds
Update #3866.
@263e00b
04/29/21 11:42:00 |
Sebastian Huber |
bsps/arm: ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX
Change the …
@3764935
04/26/21 09:20:32 |
robin.mueller.m |
Implementation for STM32 HAL_GetTick using RTEMS
Uses configured …
@d75b29d
04/10/21 19:15:27 |
niteesh.gs |
bsps/beagle: Refactored i2c driver
Refactored the i2c driver to parse …
@2a24f99d
04/16/21 05:50:21 |
Sebastian Huber |
bsps/arm: Set MSP in ARMv7-M start code
Set the Main Stack Pointer …
@100c050c
04/20/21 16:31:31 |
robin.mueller.m |
Updated tick implementation for HAL_GetTick
This now uses …
@c90fa83
02/25/21 02:09:56 |
vijay |
bsps: Remove networking drivers
Update #3850
@05cd707d
04/06/21 07:56:41 |
Sebastian Huber |
arm/stm32h7: Add STM32H7_USART3_GPIO_*
@6bb6b69b
04/06/21 07:43:23 |
Sebastian Huber |
arm/stm32h7: Add STM32H7_HSE_FREQUENCY
@8fd29cfb
03/02/21 15:14:41 |
stm32h7: Add init for sdmmc pins
Update #4372
@aa9e3c62
03/02/21 13:00:50 |
stm32h7: Add SDMMC modules to clock
Update #4372
@5607464
03/13/21 11:02:03 |
niteesh.gs |
bsp/beagle: Ported Beagle pinmux driver to RTEMS
The following files …
@7589f1e0
03/13/21 11:02:02 |
niteesh.gs |
bsps/beagle: Added SOC detection using FDT
Detects the SOC type using …
@65ab1cda
02/04/21 13:27:50 |
bsps/arm/imxrt: Add FDT and FDT helper for QTMR
Makes it simpler to …
@320cb42
02/23/21 08:18:40 |
james.fitzsimons |
bsps/beagle: Updating licences to latest BSD 2 clause
@db86c3eb
02/23/21 08:18:39 |
james.fitzsimons |
bsps/beagle: Adding QEP driver support to BeagleBoneBlack? BSP
@de7df04
02/26/21 08:48:41 |
Sebastian Huber |
bsps: Fix legacy build
@32b0d6f8
02/24/21 10:13:30 |
Sebastian Huber |
bsps: Change license to BSD-2-Clause of some files
Change license to …
@b361eabd
01/28/21 05:28:33 |
Sebastian Huber |
bsps: Replace bsp_specs with an empty file
This fixes an issue with …
@9eb9813
01/26/21 14:29:00 |
Sebastian Huber |
bsps: Add missing DWARF 5 sections
Sort alphabetically.
@33c12d5
01/25/21 10:19:21 |
Sebastian Huber |
bsps: Support DWARF 5 sections
GCC 11 uses DWARF 5 by default.
@7b99d76
01/18/21 09:02:40 |
bsp/imx: Fix system counter init for imx6
For i.MX7 U-Boot …
@36b4e8c
12/14/20 13:12:21 |
bsps/imxrt: Add ioctl to LPSPI to get registers
This allows an …
@d9794a1
12/14/20 13:54:47 |
bsps/imxrt: Add DMA numbers to dtsi
Also currently no driver uses …
@a434cc8
11/24/20 16:22:38 |
bsps/shared: Adapt fsl-edma driver for imxrt
Note: The changes have …
@22e9dafb
12/14/20 13:09:11 |
bsps/imxrt: Use standard names to avoid warnings
If spi or i2c slaves …
@6600585f
01/04/21 18:21:11 |
Sebastian Huber |
bsp/stm32h7: Split console configuration
This allows applications to …
@affc8de
01/04/21 17:58:24 |
Sebastian Huber |
bsp/stm32h7: Split start configuration
@828ea6e
12/23/20 09:25:33 |
Sebastian Huber |
Update header.am
@81c7f5be
12/03/20 14:31:40 |
Sebastian Huber |
arm/fvp: New BSP
This BSP supports the Arm Fixed Virtual Platform. …
@016bcb3
12/22/20 12:10:53 |
Sebastian Huber |
bsps/arm: Rely on initialized vector table
The …
@9f3a08e
12/22/20 12:00:27 |
Sebastian Huber |
bsps: Use header file for GIC architecture support
This avoids a …
@23d9223a
12/21/20 09:08:30 |
Sebastian Huber |
bsps/arm: Invalidate TLB in start.S
Update #4202.
@e164df5e
12/18/20 21:00:54 |
Sebastian Huber |
bsps/arm: Clear SCTLR[M, I, A, C] in start.S
Initialize the data and …
@b32fd227
12/21/20 07:08:00 |
Sebastian Huber |
bsps/arm: Add arm-data-cache-loop-set-way.h
This makes it possible to …
@46a3c04
12/21/20 08:40:50 |
Sebastian Huber |
bsps/arm: Remove optional start hook arguments
The start hook …
@76a1a53
12/21/20 06:29:41 |
Sebastian Huber |
bsps/arm: Invalidate branch predictors earlier
Make sure the branch …
@272534e
12/18/20 09:11:51 |
Sebastian Huber |
bsps/arm: Set VBAR in start.S
Set the VBAR to the vector table in the …
@b5aceef
12/10/20 09:49:37 |
Sebastian Huber |
bsps: Remove gicvx_interrupt_dispatch()
Avoid one level of …
@0deeb02
12/15/20 10:24:14 |
Sebastian Huber |
bsps/arm: Fix MMU configuration
Update #4184.
@9b3def2
11/24/20 09:55:14 |
bsps/arm/imx*: Fix location of shared headers
When moving the headers …
@b63a187
12/04/20 08:44:51 |
bsps/imxrt: Split up dts.
This allows simpler creation of own dts …
@66723ee6
11/07/20 13:07:26 |
bsp/rtl22xx: Fix non-ASCII character
@86d3c275
11/07/20 10:11:07 |
bsps: Replace non-ASCII trademark symbol
@2fbc889
11/07/20 10:03:29 |
bsps: Replace non-ASCII copyright character
@1a7afb5
11/24/20 08:40:38 |
jan.sommer |
bsps/arm: Fix MMU small pages support
- For small tables only round …
@105e520
12/10/20 07:08:00 |
Sebastian Huber |
bsps: Remove ARM GIC SGI target filter
Remove the target filter for …
@b6925e1
12/09/20 13:29:47 |
Sebastian Huber |
bsps: Fix GICv3 arm_gic_trigger_sgi()
Use the targets parameter to …
@6b79abfb
12/10/20 08:41:54 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix smpfatal04 test
@e68827e
12/04/20 10:42:42 |
Sebastian Huber |
arm/cache-cp15: Support Armv8
Update #4202.
@5b064a4
12/03/20 09:08:23 |
Sebastian Huber |
bsps: Remove unused bsp_stack_main_size
@a151ee1
10/29/20 18:40:54 |
kinsey.moore |
bsps: Move ARM GICv2 driver to bsps/shared
This moves the ARM GICv2 …
@f085957
10/26/20 15:26:49 |
kinsey.moore |
bsps: Move zynq-uart to bsps/shared
This moves the zynq-uart driver …
@9c20b987
11/26/20 18:53:25 |
Sebastian Huber |
rtems: Add <rtems/rtems/clockimpl.h>
@fe58f6ce
11/26/20 07:13:52 |
Sebastian Huber |
bsp/stm32h7: Add and use BSP Doxygen group
Update #3910.
@7141afbb
10/09/20 13:55:35 |
bsp/imxrt: Add new BSP
Update #4180
@57b5b29c
11/17/20 09:11:23 |
bsp/imxrt: Adapt imported files
Update #4180
@8abf858c
10/16/20 11:15:47 |
bsp/imxrt: Fix warnings for imported files
Update #4180
@48f6a6c3
10/12/20 11:40:30 |
bsp/imxrt: Import files from MCUXpresso SDK V2.8.5
The following …
@b169095c
11/17/20 08:38:50 |
cpu/armv7m: Add table based init for ARMV7M_MPU
Modify the MPU …
@6cece585
11/03/20 10:21:41 |
bsps/imx: Move imx-gpio to arm/shared
Update #4180
@e00f443
10/27/20 09:00:31 |
imx: Move imx_iomux to arm/shared
Update #4180
@cab11b5
11/09/20 08:16:51 |
bsp/atsam: Fix XDMAD status
In "bsp/atsam: Simplify XDMAD_Handler()" …
@99494370
03/04/20 11:34:34 |
Sebastian Huber |
bsp/stm32h7: New BSP
Update #3910.
@c44e404
04/03/20 09:12:53 |
Sebastian Huber |
bsp/stm32h7: Fix warnings
Update #3910.
@e4ba06f
04/02/20 06:28:56 |
Sebastian Huber |
bsp/stm32h7: Disable unused functions
Update #3910.
@abb7858
04/01/20 09:11:59 |
Sebastian Huber |
bsp/stm32h7: Enable LL drivers
Update #3910.
@2f157e2
03/23/20 10:37:46 |
Sebastian Huber |
bsp/stm32h7: Move <math.h> include
This is necessary for libbsd …
@2cfcd00
03/19/20 10:28:45 |
Sebastian Huber |
bsp/stm32h7: Constify some functions
Update #3910.
@2131228
03/04/20 11:33:17 |
Sebastian Huber |
bsp/stm32h7: Import from STM32CubeMX-5.6.0
Update #3910.
@273613f
04/03/20 08:03:28 |
Sebastian Huber |
bsps/arm: Sort fast text/data sections
@3fccdc95
03/20/20 07:10:46 |
Sebastian Huber |
bsps/arm: Add support for MPU region alignment
Update #3910.
@cf16821
10/16/20 04:34:39 |
Sebastian Huber |
bsps/arm: Add workaround for Errata 794072
Add a workaround for …
